| 1 |
# -*- coding: utf-8 -*-
| 2 |
from __future__ import division, print_function, unicode_literals
| 3 |
| 4 |
import struct
| 5 |
import operator
| 6 |
import unittest
| 7 |
from functools import reduce
| 8 |
| 9 |
import testsupport as ts
| 10 |
from pyradlib import lcompare
| 11 |
from pyradlib.pyrad_proc import PIPE, Error, ProcMixin
| 12 |
| 13 |
| 14 |
class LcompareTestCase(unittest.TestCase, ProcMixin):
| 15 |
| 16 |
def test_lc_llcompare(self):
| 17 |
# with values higher than 44721, total will return a float in e-format.
| 18 |
for xc, data, exp in (
| 19 |
( None,
| 20 |
( ('abcde', 'fgh', '1234', '56.789'),
| 21 |
('xyz', '432', '987.65432')
| 22 |
| 23 |
( ('abcde', 'fgh', 1234, 56.789),
| 24 |
('xyz', 432, 987.65432)
| 25 |
| 26 |
| 27 |
( None,
| 28 |
( (('a', 'b', 'c'),('d', 'e', 'f')),
| 29 |
(('0', '1', '2', '3'),('1.1', '2.2', '3.000e-03')),
| 30 |
| 31 |
| 32 |
(range(4),(1.1, 2.2, 0.003)),
| 33 |
| 34 |
| 35 |
( lcompare.error, # top level length
| 36 |
(('a', 'b', 'c'),('c','d'),('e','f'),),
| 37 |
(('a', 'b', 'c'),('c','d'),),
| 38 |
| 39 |
| 40 |
| 41 |
| 42 |
| 43 |
( lcompare.error, # 2nd level length
| 44 |
(('a', 'b', 'c'),('c','d'),('e','f','g'),),
| 45 |
| 46 |
| 47 |
| 48 |
| 49 |
| 50 |
| 51 |
( lcompare.error, # string diff
| 52 |
| 53 |
(('a', 'b', 'c'),('c','d'),('e','f','h'),),
| 54 |
| 55 |
( lcompare.error, # int diff
| 56 |
(('a', 'b', 'c'),('c','d'),('1','2','3'),),
| 57 |
(('a', 'b', 'c'),('c','d'),( 1, 2, 4),),
| 58 |
| 59 |
( lcompare.error, # float diff
| 60 |
(('a', 'b', 'c'),('c','d'),('1.1','2.2','3.3'),),
| 61 |
(('a', 'b', 'c'),('c','d'),( 1.1, 2.2, 3.4),),
| 62 |
| 63 |
( lcompare.error, # exponent diff
| 64 |
(('a', 'b', 'c'),('c','d'),('1.1','2.2','3.0000e-02'),),
| 65 |
(('a', 'b', 'c'),('c','d'),( 1.1, 2.2, 0.003),),
| 66 |
| 67 |
( lcompare.error, # fuzzy compare
| 68 |
(('a', 'b', 'c'),('c','d'),('1.1','2.2','3.00000003'),),
| 69 |
(('a', 'b', 'c'),('c','d'),( 1.1, 2.2, 3.0000003),),
| 70 |
| 71 |
( None, # fuzzy compare
| 72 |
(('a', 'b', 'c'),('c','d'),('1.1','2.2','3.000000003'),),
| 73 |
(('a', 'b', 'c'),('c','d'),( 1.1, 2.2, 3.00000003),),
| 74 |
| 75 |
| 76 |
if xc:
| 77 |
self.assertRaises(xc, lcompare.llcompare, data, exp)
| 78 |
else:
| 79 |
try: lcompare.llcompare(data, exp)
| 80 |
except lcompare.error as e:
| 81 |
self.fail(('call_one_text ') +str(e))
| 82 |
| 83 |
def test_lc_split_headers(self):
| 84 |
htxt = '''example.hdr:
| 85 |
Xim format conversion by:
| 86 |
FORMAT=32-bit_rle_rgbe
| 87 |
pfilt -e 2 -x 512 -y 512 -p 1 -r .67
| 88 |
EXPOSURE=4.926198e+00
| 89 |
normpat
| 90 |
pfilt -1 -e .2
| 91 |
EXPOSURE=2.000000e-01
| 92 |
pfilt -x 128 -y 128
| 93 |
PIXASPECT=0.500000
| 94 |
EXPOSURE=2.571646e+00'''
| 95 |
res = lcompare.split_headers(htxt)
| 96 |
exp = (
| 97 |
('', ('example.hdr:',)),
| 98 |
('\t\t', ('Xim','format','conversion','by:')),
| 99 |
('\t\t', 'FORMAT', '=', ('32-bit_rle_rgbe',)),
| 100 |
('\t\t',
| 101 |
('pfilt','-e','2','-x','512','-y','512','-p','1','-r','.67')),
| 102 |
('\t\t', 'EXPOSURE', '=', ('4.926198e+00',)),
| 103 |
('\t\t', ('normpat',)),
| 104 |
('\t\t', ('pfilt','-1','-e','.2',)),
| 105 |
('\t\t', 'EXPOSURE', '=', ('2.000000e-01',)),
| 106 |
('\t\t', ('pfilt','-x','128','-y','128',)),
| 107 |
('\t\t', 'PIXASPECT', '=', ('0.500000',)),
| 108 |
('\t\t', 'EXPOSURE', '=', ('2.571646e+00',)),
| 109 |
| 110 |
try: lcompare.llcompare(res, exp)
| 111 |
| 112 |
| 113 |
| 114 |
def test_lc_split_radfile(self):
| 115 |
df = ts.datafile('window_src.rad')
| 116 |
exp = ([['#'],
| 117 |
['#', 'A', 'plain', 'old', 'glass', 'window'],
| 118 |
| 119 |
[], ['void', 'light', 'window_light'],
| 120 |
[0], [0], [3, 1, 1, 1],
| 121 |
[], ['window_light', 'polygon', 'window'],
| 122 |
[0], [0], [12], [23.5, 43, 30], [23.5, 26, 30],
| 123 |
[-23.5, 26, 30], [-23.5, 43, 30], []])
| 124 |
resl = lcompare.split_radfile(df)
| 125 |
try: lcompare.lcompare(resl, exp)
| 126 |
| 127 |
print(resl, exp)
| 128 |
self.fail(('call_one_text n=%d -- ' % n) +str(e))
| 129 |
| 130 |
def test_lc_split_rad(self):
| 131 |
| 132 |
exp = ([['#'],
| 133 |
| 134 |
| 135 |
| 136 |
| 137 |
| 138 |
| 139 |
| 140 |
with open(df) as f:
| 141 |
res = f.read()
| 142 |
resl = lcompare.split_rad(res)
| 143 |
| 144 |
| 145 |
print(resl, exp)
| 146 |
| 147 |
| 148 |
| 149 |
# vi: set ts=4 sw=4 :
