root/radiance/ray/test/testcases/pyrad/test_lcompare.py
Revision: 1.2
Committed: Wed Mar 30 18:23:38 2016 UTC (9 years, 3 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Activate all tests.
1 # -*- coding: utf-8 -*-
2 from __future__ import division, print_function, unicode_literals
3
4 import struct
5 import operator
6 import unittest
7 from functools import reduce
8
9 import testsupport as ts
10 from pyradlib import lcompare
11 from pyradlib.pyrad_proc import PIPE, Error, ProcMixin
12
13
14 class LcompareTestCase(unittest.TestCase, ProcMixin):
15
16 def test_lc_llcompare(self):
17 # with values higher than 44721, total will return a float in e-format.
18 for xc, data, exp in (
19 ( None,
20 ( ('abcde', 'fgh', '1234', '56.789'),
21 ('xyz', '432', '987.65432')
22 ),
23 ( ('abcde', 'fgh', 1234, 56.789),
24 ('xyz', 432, 987.65432)
25 ),
26 ),
27 ( None,
28 ( (('a', 'b', 'c'),('d', 'e', 'f')),
29 (('0', '1', '2', '3'),('1.1', '2.2', '3.000e-03')),
30 ),
31 ( (('a', 'b', 'c'),('d', 'e', 'f')),
32 (range(4),(1.1, 2.2, 0.003)),
33 ),
34 ),
35 ( lcompare.error, # top level length
36 (('a', 'b', 'c'),('c','d'),('e','f'),),
37 (('a', 'b', 'c'),('c','d'),),
38 ),
39 ( lcompare.error, # top level length
40 (('a', 'b', 'c'),('c','d'),),
41 (('a', 'b', 'c'),('c','d'),('e','f'),),
42 ),
43 ( lcompare.error, # 2nd level length
44 (('a', 'b', 'c'),('c','d'),('e','f','g'),),
45 (('a', 'b', 'c'),('c','d'),('e','f'),),
46 ),
47 ( lcompare.error, # 2nd level length
48 (('a', 'b', 'c'),('c','d'),('e','f'),),
49 (('a', 'b', 'c'),('c','d'),('e','f','g'),),
50 ),
51 ( lcompare.error, # string diff
52 (('a', 'b', 'c'),('c','d'),('e','f','g'),),
53 (('a', 'b', 'c'),('c','d'),('e','f','h'),),
54 ),
55 ( lcompare.error, # int diff
56 (('a', 'b', 'c'),('c','d'),('1','2','3'),),
57 (('a', 'b', 'c'),('c','d'),( 1, 2, 4),),
58 ),
59 ( lcompare.error, # float diff
60 (('a', 'b', 'c'),('c','d'),('1.1','2.2','3.3'),),
61 (('a', 'b', 'c'),('c','d'),( 1.1, 2.2, 3.4),),
62 ),
63 ( lcompare.error, # exponent diff
64 (('a', 'b', 'c'),('c','d'),('1.1','2.2','3.0000e-02'),),
65 (('a', 'b', 'c'),('c','d'),( 1.1, 2.2, 0.003),),
66 ),
67 ( lcompare.error, # fuzzy compare
68 (('a', 'b', 'c'),('c','d'),('1.1','2.2','3.00000003'),),
69 (('a', 'b', 'c'),('c','d'),( 1.1, 2.2, 3.0000003),),
70 ),
71 ( None, # fuzzy compare
72 (('a', 'b', 'c'),('c','d'),('1.1','2.2','3.000000003'),),
73 (('a', 'b', 'c'),('c','d'),( 1.1, 2.2, 3.00000003),),
74 ),
75 ):
76 if xc:
77 self.assertRaises(xc, lcompare.llcompare, data, exp)
78 else:
79 try: lcompare.llcompare(data, exp)
80 except lcompare.error as e:
81 self.fail(('call_one_text ') +str(e))
82
83 def test_lc_split_headers(self):
84 htxt = '''example.hdr:
85 Xim format conversion by:
86 FORMAT=32-bit_rle_rgbe
87 pfilt -e 2 -x 512 -y 512 -p 1 -r .67
88 EXPOSURE=4.926198e+00
89 normpat
90 pfilt -1 -e .2
91 EXPOSURE=2.000000e-01
92 pfilt -x 128 -y 128
93 PIXASPECT=0.500000
94 EXPOSURE=2.571646e+00'''
95 res = lcompare.split_headers(htxt)
96 exp = (
97 ('', ('example.hdr:',)),
98 ('\t\t', ('Xim','format','conversion','by:')),
99 ('\t\t', 'FORMAT', '=', ('32-bit_rle_rgbe',)),
100 ('\t\t',
101 ('pfilt','-e','2','-x','512','-y','512','-p','1','-r','.67')),
102 ('\t\t', 'EXPOSURE', '=', ('4.926198e+00',)),
103 ('\t\t', ('normpat',)),
104 ('\t\t', ('pfilt','-1','-e','.2',)),
105 ('\t\t', 'EXPOSURE', '=', ('2.000000e-01',)),
106 ('\t\t', ('pfilt','-x','128','-y','128',)),
107 ('\t\t', 'PIXASPECT', '=', ('0.500000',)),
108 ('\t\t', 'EXPOSURE', '=', ('2.571646e+00',)),
109 )
110 try: lcompare.llcompare(res, exp)
111 except lcompare.error as e:
112 self.fail(('call_one_text ') +str(e))
113
114 def test_lc_split_radfile(self):
115 df = ts.datafile('window_src.rad')
116 exp = ([['#'],
117 ['#', 'A', 'plain', 'old', 'glass', 'window'],
118 ['#'],
119 [], ['void', 'light', 'window_light'],
120 [0], [0], [3, 1, 1, 1],
121 [], ['window_light', 'polygon', 'window'],
122 [0], [0], [12], [23.5, 43, 30], [23.5, 26, 30],
123 [-23.5, 26, 30], [-23.5, 43, 30], []])
124 resl = lcompare.split_radfile(df)
125 try: lcompare.lcompare(resl, exp)
126 except lcompare.error as e:
127 print(resl, exp)
128 self.fail(('call_one_text n=%d -- ' % n) +str(e))
129
130 def test_lc_split_rad(self):
131 df = ts.datafile('window_src.rad')
132 exp = ([['#'],
133 ['#', 'A', 'plain', 'old', 'glass', 'window'],
134 ['#'],
135 [], ['void', 'light', 'window_light'],
136 [0], [0], [3, 1, 1, 1],
137 [], ['window_light', 'polygon', 'window'],
138 [0], [0], [12], [23.5, 43, 30], [23.5, 26, 30],
139 [-23.5, 26, 30], [-23.5, 43, 30], []])
140 with open(df) as f:
141 res = f.read()
142 resl = lcompare.split_rad(res)
143 try: lcompare.lcompare(resl, exp)
144 except lcompare.error as e:
145 print(resl, exp)
146 self.fail(('call_one_text n=%d -- ' % n) +str(e))
147
148
149 # vi: set ts=4 sw=4 :
