root/radiance/ray/test/testcases/cal/test_rcalc.py
Revision: 1.1
Committed: Mon Mar 28 17:48:43 2016 UTC (9 years, 4 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad6R0, rad5R4, rad5R2, rad5R3, HEAD
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
# User Rev Content
1 schorsch 1.1 # -*- coding: utf-8 -*-
2     from __future__ import division, print_function, unicode_literals
3
4     # We currently only test for output of recno after receiving a
5     # single column list from cnt().
6     # This serves to uncover the nl eating bug in buffered pipes
7     # in Visual Studio 2015 before update 2.
8
9     import struct
10     import unittest
11
12     from pyradlib import lcompare
13     from pyradlib.pyrad_proc import PIPE, Error, ProcMixin
14
15
16     class RcalcTestCase(unittest.TestCase, ProcMixin):
17
18     def _runit(self, cmd1, cmd2, actstr, nl=False):
19     try:
20     procs = self.call_many((cmd1, cmd2), actstr, out=PIPE,
21     universal_newlines=nl)
22     res, eres = procs[-1].communicate()
23     if eres: print('Errors', eres) # XXX
24     except Error as e:
25     self.fail('%s [%s]' % (str(e), self.qjoin(cmd)))
26     finally:
27     for proc in procs:
28     proc.wait()
29     if nl: return [int(s) for s in res.split()]
30     return res
31
32     #return lcompare.split_rad(raw)
33
34     def test_recno_oascii(self):
35     for n in (5, 10, 55, 200,1321, 1328,1329,1330,1331,1332, 2000, 3721, 5000,9876):
36     orig = range(n)
37     exp = [i+1 for i in orig]
38     cntcmd = ['cnt', str(n)]
39     aacmd = ['rcalc', '-e', '$1=recno']
40     aresl = self._runit(cntcmd, aacmd, 'calculate recno', nl=True)
41     try: lcompare.lcompare(aresl, exp)
42     except lcompare.error as e:
43     self.fail(('recno_oascii n=%d -- ' % n) +str(e))
44
45     def test_recno_ofloat(self):
46     for n in (5, 10, 55, 200,1321, 1328,1329,1330,1331,1332, 2000, 3721, 5000):
47     orig = range(n)
48     exp = (i+1 for i in orig)
49     cntcmd = ['cnt', str(n)]
50     afcmd = ['rcalc', '-of', '-e', '$1=recno']
51     res = self._runit(cntcmd, afcmd, 'calculate recno')
52     if len(res) != n * 4:
53     self.fail(('recno_ofloat n=%d -- Length of resulting data '
54     'differs from expected (%d != %d)')
55     % (n, len(res), n*4))
56     iresl = struct.unpack('f'*n, res)
57     try: lcompare.lcompare(iresl, exp)
58     except lcompare.error as e:
59     self.fail(('recno_ofloat n=%d -- ' % n) +str(e))
60
61     def test_recno_odouble(self):
62     for n in (5, 10, 55, 200,1321, 1328,1329,1330,1331,1332, 2000, 3721, 5000):
63     orig = range(n)
64     exp = (i+1 for i in orig)
65     cntcmd = ['cnt', str(n)]
66     adcmd = ['rcalc', '-od', '-e', '$1=recno']
67     res = self._runit(cntcmd, adcmd, 'calculate recno')
68     if len(res) != n * 8:
69     self.fail(('recno_odouble n=%d -- Length of resulting data '
70     'differs from expected (%d != %d)')
71     % (n, len(res), n*8))
72     iresl = struct.unpack('d'*n, res)
73     try: lcompare.lcompare(iresl, exp)
74     except lcompare.error as e:
75     self.fail(('recno_odouble n=%d -- ' % n) +str(e))
76
77
78     # vi: set ts=4 sw=4 :
