root/radiance/ray/test/run_tests.py
Revision 1.6 - (view) (download) (as text) (annotate) - [selected]
Mon Jan 8 13:38:37 2018 UTC (6 years, 4 months ago) by schorsch
Diff to previous 1.5
Sat Apr 2 15:57:24 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 1.4: +2 -4 lines
Diff to previous 1.4 , to selected 1.6
test cases and data for some more scripts.
Wed Mar 30 18:09:00 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 1.3: +8 -8 lines
Diff to previous 1.3 , to selected 1.6
The test utilities need testing (and some fixing) as well.
Mon Mar 28 17:48:43 2016 UTC (8 years, 1 month ago) by schorsch
Changes since 1.2: +150 -188 lines
Diff to previous 1.2 , to selected 1.6
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Mar 10 01:49:56 2016 UTC (8 years, 2 months ago) by schorsch
Changes since 1.1: +15 -14 lines
Diff to previous 1.1 , to selected 1.6
SCons build system learns about platform architecture
Sun Dec 7 20:40:51 2003 UTC (20 years, 5 months ago) by schorsch
Diff to selected 1.6
First attempt at testing framework.
Links to HEAD: (view) (download) (as text) (annotate) Links to rad5R2: (view) (download) (as text) (annotate)
