root/radiance/ray/test/run_tests.py
Revision: 1.5
Committed: Sat Apr 2 15:57:24 2016 UTC (8 years, 2 months ago) by schorsch
Content type: text/x-python
Changes since 1.4: +2 -4 lines
test cases and data for some more scripts.
1 #!/usr/bin/env python
2 # -*- coding: utf-8 -*-
3 ''' run_tests.py - Run Radiance test suite
4 2013 - 2016 Georg Mischler
5
6 Invocation:
7 As script, call with -H for instructions.
8 As module, see docstrings in class RadianceTests for instructions.
9 '''
10 from __future__ import division, print_function, unicode_literals
11 __all__ = ['TESTCATS', 'RadianceTests', 'main']
12 import os
13 import sys
14 import types
15 import argparse
16 import unittest
17
18 SHORTPROGN = os.path.splitext(os.path.basename(sys.argv[0]))[0]
19 TESTCATS = ('pyrad','cal','cv','gen','hd','meta','ot','px', 'rt','util',)
20
21 class Error(Exception): pass
22
23 class RadianceTests():
24 '''Test Radiance programs below subdirectory "testcases" recursively.
25
26 This class will create a virtual module "testsupport" with constants
27 and functions for use in individual test cases.
28
29 bindir - list of paths added to PATH
30 path - complete list of paths currently in PATH
31 radlib - list of paths added to RAYPATH
32 raypath - complete list of paths currently in RAYPATH
33 pyradlib - absolute path of python support library directory
34 datadir - absolute path of test data directory
35 datafile([sub, [sub,]] fn) - return absolute file path in
36 data directory or in a subdirectory
37 '''
38 def __init__(self, **args):
39 '''Args are:
40 bindir=[directory ...] - will be prepended to PATH for tests
41 radlib=[directory ...] - will be prepended to RAYPATH for tests
42 cat=[category ...] - only test those categories (else TESTCATS)
43 V=False - if True, verbose listing of executed tests
44 '''
45 self.bindir = args.get('bindir')
46 self.radlib = args.get('radlib')
47 self.testcats = args.get('cat')
48 self.V = 2 if args.get('V') else 1
49 try:
50 old_osenv = os.environ
51
52 thisfile = os.path.abspath(__file__)
53 self.thisdir = os.path.split(thisfile)[0]
54 self.testdir = os.path.join(self.thisdir, 'testcases')
55 old_syspath = sys.path
56 if self.testdir not in sys.path:
57 sys.path.insert(0, self.testdir)
58
59 oldpath = old_osenv.get('PATH', '')
60 pathlist = oldpath.split(os.pathsep)
61 if self.bindir:
62 for bdir in self.bindir:
63 if bdir not in pathlist:
64 pathlist.insert(0, bdir)
65 os.environ['PATH'] = os.pathsep.join(pathlist)
66
67 oldraypath = old_osenv.get('RAYPATH', '')
68 raypathlist = oldraypath.split(os.pathsep)
69 if self.radlib:
70 for rlib in self.radlib + ['.']:
71 if rlib not in raypathlist:
72 raypathlist.insert(0, rlib)
73 os.environ['RAYPATH'] = os.pathsep.join(raypathlist)
74
75 pyradlib = None
76 for rp in raypathlist:
77 prd = os.path.join(rp, 'pyradlib')
78 if os.path.isdir(prd) or os.path.islink(prd):
79 if rp not in sys.path:
80 sys.path.insert(0, rp)
81 pyradlib = prd
82 if not pyradlib:
83 raise Error('Python support library directory "pyradlib" not found on RAYPATH')
84
85 # Since this here is the best place to figure out where
86 # everything is, we create an ad-hoc module to hold directory
87 # paths and functions for creating file paths.
88 # The individual test cases can then "import testsupport" to
89 # get access to the complete information.
90 supmod = types.ModuleType(str('testsupport'))
91 datadir = os.path.join(self.thisdir, 'test data')
92 supmod.bindir = self.bindir
93 supmod.datadir = datadir
94 supmod.datafile = lambda fn,*ffn: os.path.join(datadir, fn, *ffn)
95 supmod.path = pathlist
96 supmod.radlib = self.radlib
97 supmod.raypath = raypathlist
98 supmod.pyradlib = pyradlib
99 sys.modules['testsupport'] = supmod
100
101 self._run_all()
102 finally:
103 if hasattr(sys.modules, 'testsupport'):
104 del sys.modules['testsupport']
105 os.environ = old_osenv
106 sys.path = old_syspath
107
108 def _run_all(self):
109 runner = unittest.TextTestRunner(verbosity=self.V)
110 if self.testcats:
111 cats = self.testcats
112 else: cats = TESTCATS
113 for dir in cats:
114 loader = unittest.defaultTestLoader
115 fulldir = os.path.join(self.testdir, dir)
116 if not os.path.isdir(fulldir):
117 raise Error('No such directory: "%s"' % fulldir)
118 suite = loader.discover(fulldir, 'test_*.py',
119 top_level_dir=self.thisdir)
120 count = suite.countTestCases()
121 if count:
122 print('\n--', dir, '----', file=sys.stderr)
123 runner.run(suite)
124
125
126 def main():
127 '''Main function for invocation as script. See usage instructions with -H'''
128 parser = argparse.ArgumentParser(add_help=False,
129 description='Run Radiance test suite',)
130 parser.add_argument('-V', action='store_true',
131 help='Verbose: Print all executed test cases to stderr')
132 parser.add_argument('-H', action='help',
133 help='Help: print this text to stderr and exit')
134 parser.add_argument('-p', action='store', nargs=1,
135 dest='bindir', metavar='bindir', help='Path to Radiance binaries')
136 parser.add_argument('-l', action='store', nargs=1,
137 dest='radlib', metavar='radlib', help='Path to Radiance library')
138 parser.add_argument('-c', action='store', nargs=1,
139 dest='cat', metavar='cat', help='Category of tests to run (else all)')
140 args = parser.parse_args()
141 RadianceTests(**vars(args))
142
143
144 if __name__ == '__main__':
145 try: main()
146 except KeyboardInterrupt:
147 sys.stderr.write('*cancelled*\n')
148 exit(1)
149 except Error as e:
150 sys.stderr.write('%s: %s\n' % (SHORTPROGN, str(e)))
151 exit(-1)
152
153 # vi: set ts=4 sw=4 :
