root/radiance/ray/test/run_tests.bat
Sat Apr 2 15:57:24 2016 UTC (9 years, 4 months ago) by schorsch
CVS Tags: HEAD, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Changes since 1.4: +1 -3 lines
Diff to previous 1.4
test cases and data for some more scripts.
Fri Apr 1 22:07:55 2016 UTC (9 years, 4 months ago) by schorsch
Diff to previous 1.3
data files for test_falsecolor
Mon Mar 28 17:48:43 2016 UTC (9 years, 4 months ago) by schorsch
Diff to previous 1.2
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
Thu Mar 10 01:49:56 2016 UTC (9 years, 5 months ago) by schorsch
Diff to previous 1.1
SCons build system learns about platform architecture
Sun Dec 7 20:40:51 2003 UTC (21 years, 8 months ago) by schorsch
First attempt at testing framework.
