root/radiance/ray/test/renders/trans2.rif
Thu Jul 27 05:20:03 2023 UTC (23 months ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 1.6
test: updated rendering references for trans2
Revision 1.6 - (view) (download) (annotate) - [selected]
Fri Jul 14 15:03:47 2023 UTC (23 months, 2 weeks ago) by greg
Diff to previous 1.5
test: Better fix to accuracy issues
Tue Jul 11 02:40:29 2023 UTC (23 months, 2 weeks ago) by greg
Diff to previous 1.4 , to selected 1.6
test: Increased calculation parameters again trying to eliminate delta errors
Mon Apr 25 17:15:56 2022 UTC (3 years, 2 months ago) by greg
Diff to previous 1.3 , to selected 1.6
test: Updated trans2 tests after -as bug fix in -r 2.89 of ambcomp.c
Sat Feb 20 00:51:18 2021 UTC (4 years, 4 months ago) by greg
Changes since 1.2: +3 -1 lines
Diff to previous 1.2 , to selected 1.6
test: increased pixel sampling in attempt to beat variance issues
Fri Feb 19 06:01:47 2021 UTC (4 years, 4 months ago) by greg
Changes since 1.1: +5 -3 lines
Diff to previous 1.1 , to selected 1.6
test: fixes and improvements with addition of batches for splitting job
Sat Nov 17 22:09:12 2018 UTC (6 years, 7 months ago) by greg
Diff to selected 1.6
Created rendering tests
