root/Development/ray/test/renders/ref/trans2_win.hdr
Thu Jul 27 05:20:03 2023 UTC (2 years, 3 months ago) by greg
Changes since 1.7: +23 -30 lines
Diff to previous 1.7
test: updated rendering references for trans2
Tue Apr 26 20:06:43 2022 UTC (3 years, 6 months ago) by greg
Changes since 1.6: +28 -25 lines
Diff to previous 1.6
test: Updated reference images after ambient super-sampling bug fix
Mon Apr 25 17:15:56 2022 UTC (3 years, 6 months ago) by greg
Changes since 1.5: +28 -23 lines
Diff to previous 1.5
test: Updated trans2 tests after -as bug fix in -r 2.89 of ambcomp.c
Sat Feb 20 07:56:30 2021 UTC (4 years, 8 months ago) by greg
Changes since 1.4: +21 -17 lines
Diff to previous 1.4
test: moved illum surfaces flush with inner wall
Sat Feb 20 00:51:18 2021 UTC (4 years, 8 months ago) by greg
Changes since 1.3: +18 -24 lines
Diff to previous 1.3
test: increased pixel sampling in attempt to beat variance issues
Fri Feb 19 06:01:47 2021 UTC (4 years, 8 months ago) by greg
Changes since 1.2: +27 -67 lines
Diff to previous 1.2
test: fixes and improvements with addition of batches for splitting job
Fri Jan 22 00:01:38 2021 UTC (4 years, 9 months ago) by greg
Changes since 1.1: +65 -76 lines
Diff to previous 1.1
test: updated default -av setting in rad, which affected tests
Sat Jan 2 01:56:17 2021 UTC (4 years, 9 months ago) by greg
test: added missing test for trans2-win
