root/radiance/ray/test/renders/ref/trans2_fish.hdr
Thu Jul 27 05:20:03 2023 UTC (21 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.11: +47 -62 lines
Diff to previous 1.11 , to selected 1.9
test: updated rendering references for trans2
Fri Jul 14 15:03:48 2023 UTC (22 months ago) by greg
Changes since 1.10: +62 -58 lines
Diff to previous 1.10 , to selected 1.9
test: Better fix to accuracy issues
Tue Jul 11 02:40:29 2023 UTC (22 months ago) by greg
Changes since 1.9: +61 -40 lines
Diff to previous 1.9
test: Increased calculation parameters again trying to eliminate delta errors
Revision 1.9 - (view) (download) (annotate) - [selected]
Tue Apr 26 20:06:43 2022 UTC (3 years ago) by greg
Changes since 1.8: +34 -44 lines
Diff to previous 1.8
test: Updated reference images after ambient super-sampling bug fix
Mon Apr 25 17:15:56 2022 UTC (3 years ago) by greg
Changes since 1.7: +47 -46 lines
Diff to previous 1.7 , to selected 1.9
test: Updated trans2 tests after -as bug fix in -r 2.89 of ambcomp.c
Thu May 6 22:54:03 2021 UTC (4 years ago) by greg
Changes since 1.6: +45 -33 lines
Diff to previous 1.6 , to selected 1.9
test: Rerendered image with outlier pixel
Sat Feb 20 07:56:30 2021 UTC (4 years, 2 months ago) by greg
Changes since 1.5: +33 -41 lines
Diff to previous 1.5 , to selected 1.9
test: moved illum surfaces flush with inner wall
Sat Feb 20 00:51:18 2021 UTC (4 years, 2 months ago) by greg
Changes since 1.4: +41 -33 lines
Diff to previous 1.4 , to selected 1.9
test: increased pixel sampling in attempt to beat variance issues
Fri Feb 19 06:01:47 2021 UTC (4 years, 2 months ago) by greg
Changes since 1.3: +35 -41 lines
Diff to previous 1.3 , to selected 1.9
test: fixes and improvements with addition of batches for splitting job
Fri Jan 22 00:01:38 2021 UTC (4 years, 3 months ago) by greg
Changes since 1.2: +40 -71 lines
Diff to previous 1.2 , to selected 1.9
test: updated default -av setting in rad, which affected tests
Sat Jan 2 01:56:17 2021 UTC (4 years, 4 months ago) by greg
Changes since 1.1: +71 -48 lines
Diff to previous 1.1 , to selected 1.9
test: added missing test for trans2-win
Sat Nov 17 22:09:13 2018 UTC (6 years, 5 months ago) by greg
Diff to selected 1.9
Created rendering tests
