root/radiance/ray/test/renders/ref/trans2_def.hdr
Thu Jul 27 05:20:03 2023 UTC (2 years ago) by greg
Changes since 1.7: +71 -34 lines
Diff to previous 1.7 , to selected 1.2
test: updated rendering references for trans2
Tue Apr 26 20:06:43 2022 UTC (3 years, 3 months ago) by greg
Changes since 1.6: +33 -66 lines
test: Updated reference images after ambient super-sampling bug fix
Mon Apr 25 17:15:56 2022 UTC (3 years, 3 months ago) by greg
Changes since 1.5: +68 -65 lines
test: Updated trans2 tests after -as bug fix in -r 2.89 of ambcomp.c
Sat Feb 20 07:56:30 2021 UTC (4 years, 5 months ago) by greg
Changes since 1.4: +65 -52 lines
test: moved illum surfaces flush with inner wall
Sat Feb 20 00:51:18 2021 UTC (4 years, 5 months ago) by greg
Changes since 1.3: +54 -72 lines
test: increased pixel sampling in attempt to beat variance issues
Fri Jan 22 00:01:38 2021 UTC (4 years, 6 months ago) by greg
Changes since 1.2: +69 -54 lines
Diff to previous 1.2
test: updated default -av setting in rad, which affected tests
Sat Jan 2 01:56:17 2021 UTC (4 years, 7 months ago) by greg
Changes since 1.1: +54 -61 lines
Diff to previous 1.1
test: added missing test for trans2-win
Sat Nov 17 22:09:13 2018 UTC (6 years, 8 months ago) by greg
Diff to selected 1.2
Created rendering tests
