root/Development/ray/test/renders/ref/tfunc_def.hdr
Tue Apr 26 20:06:43 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.4: +37 -35 lines
Diff to previous 1.4
test: Updated reference images after ambient super-sampling bug fix
Sat Feb 20 07:56:30 2021 UTC (4 years, 10 months ago) by greg
Changes since 1.3: +34 -29 lines
Diff to previous 1.3
test: moved illum surfaces flush with inner wall
Fri Jan 22 00:01:38 2021 UTC (4 years, 11 months ago) by greg
Changes since 1.2: +30 -40 lines
Diff to previous 1.2
test: updated default -av setting in rad, which affected tests
Wed Dec 5 02:11:55 2018 UTC (7 years, 1 month ago) by greg
Changes since 1.1: +41 -59 lines
Diff to previous 1.1
Moved dielectric cube from mist to tfunc scene
Sat Nov 17 22:09:13 2018 UTC (7 years, 1 month ago) by greg
Created rendering tests
