root/radiance/ray/test/renders/ref/mixtex_def.hdr
Tue Apr 26 20:06:43 2022 UTC (3 years ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.7: +16 -20 lines
Diff to previous 1.7
test: Updated reference images after ambient super-sampling bug fix
Fri Jan 22 00:01:38 2021 UTC (4 years, 3 months ago) by greg
Changes since 1.6: +19 -14 lines
Diff to previous 1.6
test: updated default -av setting in rad, which affected tests
Fri Jan 1 20:15:35 2021 UTC (4 years, 4 months ago) by greg
Changes since 1.5: +14 -19 lines
Diff to previous 1.5
Added bias compensation to photon-mapping tests
Mon Aug 10 20:48:12 2020 UTC (4 years, 9 months ago) by greg
Changes since 1.4: +20 -22 lines
Diff to previous 1.4
test(mkpmap): Better choice of photon portal thanks to Roland Schregle
Fri Dec 7 17:44:58 2018 UTC (6 years, 5 months ago) by greg
Changes since 1.3: +22 -17 lines
Diff to previous 1.3
Switched to photon-mapping in mixtex scene to reduce artifacts
Sat Dec 1 22:58:43 2018 UTC (6 years, 5 months ago) by greg
Changes since 1.2: +16 -24 lines
Diff to previous 1.2
Minor calculation improvements for mixtex and added combined scene for amusement
Sat Dec 1 02:06:09 2018 UTC (6 years, 5 months ago) by greg
Changes since 1.1: +26 -17 lines
Diff to previous 1.1
Finished additions for BSDF's, etc. to complete primitive testing
Wed Nov 21 22:59:04 2018 UTC (6 years, 5 months ago) by greg
Work in progress on test of mixtures, textures and BSDF data types
