root/radiance/ray/test/renders/ref/mist_def.hdr
Tue Apr 26 20:06:43 2022 UTC (3 years ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.5: +32 -36 lines
Diff to previous 1.5
test: Updated reference images after ambient super-sampling bug fix
Fri Jan 22 00:01:38 2021 UTC (4 years, 3 months ago) by greg
Changes since 1.4: +36 -36 lines
Diff to previous 1.4
test: updated default -av setting in rad, which affected tests
Wed Dec 5 02:11:55 2018 UTC (6 years, 5 months ago) by greg
Changes since 1.3: +34 -32 lines
Diff to previous 1.3
Moved dielectric cube from mist to tfunc scene
Tue Dec 4 00:32:20 2018 UTC (6 years, 5 months ago) by greg
Changes since 1.2: +34 -31 lines
Diff to previous 1.2
Added test for different glow behavior
Sat Nov 17 23:22:43 2018 UTC (6 years, 5 months ago) by greg
Changes since 1.1: +28 -43 lines
Diff to previous 1.1
Minor changes and tweaks to make comparisons more reliable
Sat Nov 17 22:09:13 2018 UTC (6 years, 5 months ago) by greg
Created rendering tests
