root/radiance/ray/test/renders/ref/inst_def.hdr
Tue Apr 26 20:06:43 2022 UTC (3 years ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 1.5: +24 -33 lines
Diff to previous 1.5
test: Updated reference images after ambient super-sampling bug fix
Fri Jan 22 00:01:38 2021 UTC (4 years, 3 months ago) by greg
Changes since 1.4: +33 -33 lines
Diff to previous 1.4
test: updated default -av setting in rad, which affected tests
Fri Jul 24 16:35:02 2020 UTC (4 years, 9 months ago) by greg
Changes since 1.3: +32 -45 lines
Diff to previous 1.3
Another attempt to fix failing test
Mon Jul 20 16:22:26 2020 UTC (4 years, 9 months ago) by greg
Changes since 1.2: +46 -44 lines
Diff to previous 1.2
test: improved test that was failing due to sampling misses
Tue Dec 4 00:32:20 2018 UTC (6 years, 5 months ago) by greg
Changes since 1.1: +45 -53 lines
Diff to previous 1.1
Added test for different glow behavior
Sat Nov 17 22:09:13 2018 UTC (6 years, 5 months ago) by greg
Created rendering tests
