--- ray/test/renders/ref/combined.rad 2018/11/20 17:12:41 1.4 +++ ray/test/renders/ref/combined.rad 2023/11/17 21:22:27 1.14 @@ -1,3 +1,10 @@ +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A collection of all our scene bits without the front caps +# +# xform -n i0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Basic materials used for walls, etc. void plastic wall_mat 0 @@ -18,16 +25,21 @@ void plastic black_outside 0 0 5 0.05 0.05 0.05 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ void metal chrome 0 0 5 0.6 0.6 0.75 1 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ void metal gold 0 0 5 0.99717 0.781957 0.334172 1 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A photographed sunset taken on Nov. 6 2018, Berkeley CA +# Artificial sun source scaled to cover circumsolar void colorpict sunset_pat 9 red green blue sunset.hdr fisheye.cal fish_u fish_v -rz 90 @@ -53,6 +65,11 @@ sol_light source i0.bigsun 0 0 4 -0.9338 -0.35 0.001 1 +# xform -n dielectric.1 -t 0 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon dielectric.1.wall.b 0 @@ -119,6 +136,14 @@ black_outside polygon dielectric.1.wall.4 -8 -0.1 3.1 -8 -0.1 -0.1 -6.12323399574e-18 -0.1 -0.1 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon dielectric.1.wall.6 0 @@ -155,6 +180,10 @@ floor_mat polygon dielectric.1.wall.9 -8 5 4.89858719659e-16 -8 0 4.89858719659e-16 0 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Rectangular opening cut in end wall +# xform -ry -90 -t -8 0 0 +# genprism wall_mat end_wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 1 1 2 1 2 4 1 4 1 1 -l 0 0 .2 -c wall_mat polygon dielectric.1.end_wall.b 0 @@ -266,6 +295,17 @@ wall_mat polygon dielectric.1.end_wall.9 -8.2 4 1 -8.2 1 1 -8 1 1 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Vase model courtesy Tom Mertens from web page: +# http://people.csail.mit.edu/tmertens/textransfer/data +# Include acknowledgment in any published work: +# "textured 3D model from the MIT CSAIL database" +# +# Origin is at center of base; Z-axis is up. +# Vase is approx. 23cm tall +# Moved into middle of room for testing +# void colorpict vase_pat 13 lim_r lim_g lim_b vase.hdr climit.cal Lu Lv -i 1 -t 0 0 0 @@ -281,16 +321,25 @@ vase_clay mesh dielectric.1.vase 17 vase.rtm -t 25 5 130 -s .005 -t -4 2.5 1 -i 1 -t 0 0 0 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# xform -s 0.0253999863 -rz 90 -t -4 2.5 2.999 +# +# Wellmade 2 lamp fixture, model 395-12A-248RS +# +# Dimensions in inches, fixture parallel to y axis, center at origin +# void brightdata lum_dist 19 flatcorr rect_fixture.dat source.cal src_phi4 src_theta -s 0.0253999863 -rz 90 -t -4 2.5 2.999 -i 1 -t 0 0 0 0 0 +# this is scaled by 1/area (SI) lum_dist light lum_bright 0 0 3 20 20 20 +# 3 1.55 1.55 1.55 lum_bright polygon dielectric.1.luminaire 0 @@ -300,6 +349,8 @@ lum_bright polygon dielectric.1.luminaire -4.57784968833 2.22695014728 2.999 -4.57784968833 2.77304985273 2.999 -3.42215031167 2.77304985272 2.999 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Pink glass pane made of two dieletric faces to fit any opening in end wall void dielectric dielectric_pink 0 @@ -323,219 +374,238 @@ dielectric_pink polygon dielectric.1.blue_glazing -8.15 5 3 -8.15 5 0 -8.15 0 0 +# xform -n glass.2 -t 0 5.2 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon glass.2.wall.b 0 0 30 - -6.12323399574e-18 5 -0.1 - -6.12323399574e-18 10.2 -0.1 - 1.89820253868e-16 10.2 3.1 - 1.89820253868e-16 5 3.1 - -6.12323399574e-18 5 -0.1 - 0 5.1 0 - 1.83697019872e-16 5.1 3 - 1.83697019872e-16 10.1 3 - 0 10.1 0 - 0 5.1 0 + -6.12323399574e-18 5.1 -0.1 + -6.12323399574e-18 10.3 -0.1 + 1.89820253868e-16 10.3 3.1 + 1.89820253868e-16 5.1 3.1 + -6.12323399574e-18 5.1 -0.1 + 0 5.2 0 + 1.83697019872e-16 5.2 3 + 1.83697019872e-16 10.2 3 + 0 10.2 0 + 0 5.2 0 black_outside polygon glass.2.wall.t 0 0 30 - -8 5.1 4.89858719659e-16 - -8 10.1 4.89858719659e-16 - -8 10.1 3 - -8 5.1 3 - -8 5.1 4.89858719659e-16 - -8 5 -0.1 - -8 5 3.1 - -8 10.2 3.1 - -8 10.2 -0.1 - -8 5 -0.1 + -8 5.2 4.89858719659e-16 + -8 10.2 4.89858719659e-16 + -8 10.2 3 + -8 5.2 3 + -8 5.2 4.89858719659e-16 + -8 5.1 -0.1 + -8 5.1 3.1 + -8 10.3 3.1 + -8 10.3 -0.1 + -8 5.1 -0.1 black_outside polygon glass.2.wall.1 0 0 12 - -6.12323399574e-18 5 -0.1 - -8 5 -0.1 - -8 10.2 -0.1 - -6.12323399574e-18 10.2 -0.1 + -6.12323399574e-18 5.1 -0.1 + -8 5.1 -0.1 + -8 10.3 -0.1 + -6.12323399574e-18 10.3 -0.1 black_outside polygon glass.2.wall.2 0 0 12 - -6.12323399574e-18 10.2 -0.1 - -8 10.2 -0.1 - -8 10.2 3.1 - 1.89820253868e-16 10.2 3.1 + -6.12323399574e-18 10.3 -0.1 + -8 10.3 -0.1 + -8 10.3 3.1 + 1.89820253868e-16 10.3 3.1 black_outside polygon glass.2.wall.3 0 0 12 - 1.89820253868e-16 10.2 3.1 - -8 10.2 3.1 - -8 5 3.1 - 1.89820253868e-16 5 3.1 + 1.89820253868e-16 10.3 3.1 + -8 10.3 3.1 + -8 5.1 3.1 + 1.89820253868e-16 5.1 3.1 black_outside polygon glass.2.wall.4 0 0 12 - 1.89820253868e-16 5 3.1 - -8 5 3.1 - -8 5 -0.1 - -6.12323399574e-18 5 -0.1 + 1.89820253868e-16 5.1 3.1 + -8 5.1 3.1 + -8 5.1 -0.1 + -6.12323399574e-18 5.1 -0.1 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon glass.2.wall.6 0 0 12 - 0 5.1 0 - -8 5.1 4.89858719659e-16 - -8 5.1 3 - 1.83697019872e-16 5.1 3 + 0 5.2 0 + -8 5.2 4.89858719659e-16 + -8 5.2 3 + 1.83697019872e-16 5.2 3 ceil_mat polygon glass.2.wall.7 0 0 12 - 1.83697019872e-16 5.1 3 - -8 5.1 3 - -8 10.1 3 - 1.83697019872e-16 10.1 3 + 1.83697019872e-16 5.2 3 + -8 5.2 3 + -8 10.2 3 + 1.83697019872e-16 10.2 3 wall_mat polygon glass.2.wall.8 0 0 12 - 1.83697019872e-16 10.1 3 - -8 10.1 3 - -8 10.1 4.89858719659e-16 - 0 10.1 0 + 1.83697019872e-16 10.2 3 + -8 10.2 3 + -8 10.2 4.89858719659e-16 + 0 10.2 0 floor_mat polygon glass.2.wall.9 0 0 12 - 0 10.1 0 - -8 10.1 4.89858719659e-16 - -8 5.1 4.89858719659e-16 - 0 5.1 0 + 0 10.2 0 + -8 10.2 4.89858719659e-16 + -8 5.2 4.89858719659e-16 + 0 5.2 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Rectangular opening cut in end wall +# xform -ry -90 -t -8 0 0 +# genprism wall_mat end_wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 1 1 2 1 2 4 1 4 1 1 -l 0 0 .2 -c wall_mat polygon glass.2.end_wall.b 0 0 30 - -8 5 -0.1 - -8 10.2 -0.1 - -8 10.2 3.1 - -8 5 3.1 - -8 5 -0.1 - -8 6.1 1 - -8 6.1 2 - -8 9.1 2 - -8 9.1 1 - -8 6.1 1 + -8 5.1 -0.1 + -8 10.3 -0.1 + -8 10.3 3.1 + -8 5.1 3.1 + -8 5.1 -0.1 + -8 6.2 1 + -8 6.2 2 + -8 9.2 2 + -8 9.2 1 + -8 6.2 1 wall_mat polygon glass.2.end_wall.t 0 0 30 - -8.2 6.1 1 - -8.2 9.1 1 - -8.2 9.1 2 - -8.2 6.1 2 - -8.2 6.1 1 - -8.2 5 -0.1 - -8.2 5 3.1 - -8.2 10.2 3.1 - -8.2 10.2 -0.1 - -8.2 5 -0.1 + -8.2 6.2 1 + -8.2 9.2 1 + -8.2 9.2 2 + -8.2 6.2 2 + -8.2 6.2 1 + -8.2 5.1 -0.1 + -8.2 5.1 3.1 + -8.2 10.3 3.1 + -8.2 10.3 -0.1 + -8.2 5.1 -0.1 wall_mat polygon glass.2.end_wall.1 0 0 12 - -8 5 -0.1 - -8.2 5 -0.1 - -8.2 10.2 -0.1 - -8 10.2 -0.1 + -8 5.1 -0.1 + -8.2 5.1 -0.1 + -8.2 10.3 -0.1 + -8 10.3 -0.1 wall_mat polygon glass.2.end_wall.2 0 0 12 - -8 10.2 -0.1 - -8.2 10.2 -0.1 - -8.2 10.2 3.1 - -8 10.2 3.1 + -8 10.3 -0.1 + -8.2 10.3 -0.1 + -8.2 10.3 3.1 + -8 10.3 3.1 wall_mat polygon glass.2.end_wall.3 0 0 12 - -8 10.2 3.1 - -8.2 10.2 3.1 - -8.2 5 3.1 - -8 5 3.1 + -8 10.3 3.1 + -8.2 10.3 3.1 + -8.2 5.1 3.1 + -8 5.1 3.1 wall_mat polygon glass.2.end_wall.4 0 0 12 - -8 5 3.1 - -8.2 5 3.1 - -8.2 5 -0.1 - -8 5 -0.1 + -8 5.1 3.1 + -8.2 5.1 3.1 + -8.2 5.1 -0.1 + -8 5.1 -0.1 wall_mat polygon glass.2.end_wall.5 0 0 12 - -8 5 -0.1 - -8.2 5 -0.1 - -8.2 6.1 1 - -8 6.1 1 + -8 5.1 -0.1 + -8.2 5.1 -0.1 + -8.2 6.2 1 + -8 6.2 1 wall_mat polygon glass.2.end_wall.6 0 0 12 - -8 6.1 1 - -8.2 6.1 1 - -8.2 6.1 2 - -8 6.1 2 + -8 6.2 1 + -8.2 6.2 1 + -8.2 6.2 2 + -8 6.2 2 wall_mat polygon glass.2.end_wall.7 0 0 12 - -8 6.1 2 - -8.2 6.1 2 - -8.2 9.1 2 - -8 9.1 2 + -8 6.2 2 + -8.2 6.2 2 + -8.2 9.2 2 + -8 9.2 2 wall_mat polygon glass.2.end_wall.8 0 0 12 - -8 9.1 2 - -8.2 9.1 2 - -8.2 9.1 1 - -8 9.1 1 + -8 9.2 2 + -8.2 9.2 2 + -8.2 9.2 1 + -8 9.2 1 wall_mat polygon glass.2.end_wall.9 0 0 12 - -8 9.1 1 - -8.2 9.1 1 - -8.2 6.1 1 - -8 6.1 1 + -8 9.2 1 + -8.2 9.2 1 + -8.2 6.2 1 + -8 6.2 1 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A green metal torus with glowing red stripes void metal green_metal 0 @@ -548,12 +618,14 @@ void glow red_glow 4 0.8 0.02 0.01 0 void mixfunc striped -10 green_metal red_glow "if(mod(atan2(Py-A2,Px-A1),PI/10) - PI/20, 1, 0)" . -i 1 -t 0 5.1 0 +10 green_metal red_glow "if(mod(atan2(Py-A2,Px-A1),PI/10) - PI/20, 1, 0)" . -i 1 -t 0 5.2 0 0 3 -4 2.5 1.5 +# xform -ry 52 -s .2 -t -4 2.5 1.5 +# genrev striped torus sin(2*PI*t) 2+cos(2*PI*t) 32 -s striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.48795016716 0 -49.8024616447 149.407384934 @@ -561,12 +633,12 @@ Phong cone glass.2.torus.1 0 0 8 - -4 7.6 1.5 - -3.96925334567 7.6 1.52402191909 + -4 7.7 1.5 + -3.96925334567 7.7 1.52402191909 0.6 0.59615705608 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.290284677254 1.99036945334 -4.93767924242 @@ -574,12 +646,12 @@ Phong cone glass.2.torus.2 0 0 8 - -3.96925334567 7.6 1.52402191909 - -3.93968826801 7.6 1.54712068931 + -3.96925334567 7.7 1.52402191909 + -3.93968826801 7.7 1.54712068931 0.59615705608 0.584775906502 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.471396736826 1.99036945334 -4.86266017104 @@ -587,12 +659,12 @@ Phong cone glass.2.torus.3 0 0 8 - -3.93968826801 7.6 1.54712068931 - -3.9124409364 7.6 1.56840863786 + -3.93968826801 7.7 1.54712068931 + -3.9124409364 7.7 1.56840863786 0.584775906502 0.56629392246 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.634393284164 1.99036945334 -4.75374936005 @@ -600,12 +672,12 @@ Phong cone glass.2.torus.4 0 0 8 - -3.9124409364 7.6 1.56840863786 - -3.8885584505 7.6 1.58706768082 + -3.9124409364 7.7 1.56840863786 + -3.8885584505 7.7 1.58706768082 0.56629392246 0.541421356238 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.773010453363 1.99036945334 -4.61513219085 @@ -613,12 +685,12 @@ Phong cone glass.2.torus.5 0 0 8 - -3.8885584505 7.6 1.58706768082 - -3.86895860084 7.6 1.60238076164 + -3.8885584505 7.7 1.58706768082 + -3.86895860084 7.7 1.60238076164 0.541421356238 0.511114046604 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.881921264348 1.99036945334 -4.45213564351 @@ -626,12 +698,12 @@ Phong cone glass.2.torus.6 0 0 8 - -3.86895860084 7.6 1.60238076164 - -3.85439459867 7.6 1.6137594072 + -3.86895860084 7.7 1.60238076164 + -3.85439459867 7.7 1.6137594072 0.511114046604 0.476536686474 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.956940335732 1.99036945334 -4.27102358394 @@ -639,12 +711,12 @@ Phong cone glass.2.torus.7 0 0 8 - -3.85439459867 7.6 1.6137594072 - -3.84542613041 7.6 1.62076634254 + -3.85439459867 7.7 1.6137594072 + -3.84542613041 7.7 1.62076634254 0.476536686474 0.439018064404 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.995184726672 1.99036945334 -4.07875604702 @@ -652,12 +724,12 @@ Phong cone glass.2.torus.8 0 0 8 - -3.84542613041 7.6 1.62076634254 - -3.84239784928 7.6 1.62313229507 + -3.84542613041 7.7 1.62076634254 + -3.84239784928 7.7 1.62313229507 0.439018064404 0.4 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.995184726672 1.99036945334 -3.88272176636 @@ -665,12 +737,12 @@ Phong cup glass.2.torus.9 0 0 8 - -3.84239784928 7.6 1.62313229507 - -3.84542613041 7.6 1.62076634254 + -3.84239784928 7.7 1.62313229507 + -3.84542613041 7.7 1.62076634254 0.4 0.360981935596 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.956940335732 1.99036945334 -3.69045422943 @@ -678,12 +750,12 @@ Phong cup glass.2.torus.10 0 0 8 - -3.84542613041 7.6 1.62076634254 - -3.85439459867 7.6 1.6137594072 + -3.84542613041 7.7 1.62076634254 + -3.85439459867 7.7 1.6137594072 0.360981935596 0.323463313526 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.881921264348 1.99036945334 -3.50934216986 @@ -691,12 +763,12 @@ Phong cup glass.2.torus.11 0 0 8 - -3.85439459867 7.6 1.6137594072 - -3.86895860084 7.6 1.60238076164 + -3.85439459867 7.7 1.6137594072 + -3.86895860084 7.7 1.60238076164 0.323463313526 0.288885953396 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.773010453363 1.99036945334 -3.34634562253 @@ -704,12 +776,12 @@ Phong cup glass.2.torus.12 0 0 8 - -3.86895860084 7.6 1.60238076164 - -3.8885584505 7.6 1.58706768082 + -3.86895860084 7.7 1.60238076164 + -3.8885584505 7.7 1.58706768082 0.288885953396 0.258578643762 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.634393284164 1.99036945334 -3.20772845333 @@ -717,12 +789,12 @@ Phong cup glass.2.torus.13 0 0 8 - -3.8885584505 7.6 1.58706768082 - -3.9124409364 7.6 1.56840863786 + -3.8885584505 7.7 1.58706768082 + -3.9124409364 7.7 1.56840863786 0.258578643762 0.23370607754 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.471396736826 1.99036945334 -3.09881764234 @@ -730,12 +802,12 @@ Phong cup glass.2.torus.14 0 0 8 - -3.9124409364 7.6 1.56840863786 - -3.93968826801 7.6 1.54712068931 + -3.9124409364 7.7 1.56840863786 + -3.93968826801 7.7 1.54712068931 0.23370607754 0.215224093498 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.290284677254 1.99036945334 -3.02379857096 @@ -743,12 +815,12 @@ Phong cup glass.2.torus.15 0 0 8 - -3.93968826801 7.6 1.54712068931 - -3.96925334567 7.6 1.52402191909 + -3.93968826801 7.7 1.54712068931 + -3.96925334567 7.7 1.52402191909 0.215224093498 0.20384294392 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 -0.0980171403296 1.99036945334 -2.98555418002 @@ -756,12 +828,12 @@ Phong cup glass.2.torus.16 0 0 8 - -3.96925334567 7.6 1.52402191909 - -4 7.6 1.5 + -3.96925334567 7.7 1.52402191909 + -4 7.7 1.5 0.20384294392 0.2 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.0980171403296 1.99036945334 -2.98555418002 @@ -769,12 +841,12 @@ Phong cup glass.2.torus.17 0 0 8 - -4 7.6 1.5 - -4.03074665433 7.6 1.47597808091 + -4 7.7 1.5 + -4.03074665433 7.7 1.47597808091 0.2 0.20384294392 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.290284677254 1.99036945334 -3.02379857096 @@ -782,12 +854,12 @@ Phong cup glass.2.torus.18 0 0 8 - -4.03074665433 7.6 1.47597808091 - -4.06031173199 7.6 1.45287931069 + -4.03074665433 7.7 1.47597808091 + -4.06031173199 7.7 1.45287931069 0.20384294392 0.215224093498 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.471396736826 1.99036945334 -3.09881764234 @@ -795,12 +867,12 @@ Phong cup glass.2.torus.19 0 0 8 - -4.06031173199 7.6 1.45287931069 - -4.0875590636 7.6 1.43159136214 + -4.06031173199 7.7 1.45287931069 + -4.0875590636 7.7 1.43159136214 0.215224093498 0.23370607754 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.634393284164 1.99036945334 -3.20772845333 @@ -808,12 +880,12 @@ Phong cup glass.2.torus.20 0 0 8 - -4.0875590636 7.6 1.43159136214 - -4.1114415495 7.6 1.41293231918 + -4.0875590636 7.7 1.43159136214 + -4.1114415495 7.7 1.41293231918 0.23370607754 0.258578643762 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.773010453363 1.99036945334 -3.34634562253 @@ -821,12 +893,12 @@ Phong cup glass.2.torus.21 0 0 8 - -4.1114415495 7.6 1.41293231918 - -4.13104139916 7.6 1.39761923836 + -4.1114415495 7.7 1.41293231918 + -4.13104139916 7.7 1.39761923836 0.258578643762 0.288885953396 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.881921264348 1.99036945334 -3.50934216986 @@ -834,12 +906,12 @@ Phong cup glass.2.torus.22 0 0 8 - -4.13104139916 7.6 1.39761923836 - -4.14560540133 7.6 1.3862405928 + -4.13104139916 7.7 1.39761923836 + -4.14560540133 7.7 1.3862405928 0.288885953396 0.323463313526 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.956940335732 1.99036945334 -3.69045422943 @@ -847,12 +919,12 @@ Phong cup glass.2.torus.23 0 0 8 - -4.14560540133 7.6 1.3862405928 - -4.15457386959 7.6 1.37923365746 + -4.14560540133 7.7 1.3862405928 + -4.15457386959 7.7 1.37923365746 0.323463313526 0.360981935596 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.995184726672 1.99036945334 -3.88272176636 @@ -860,12 +932,12 @@ Phong cup glass.2.torus.24 0 0 8 - -4.15457386959 7.6 1.37923365746 - -4.15760215072 7.6 1.37686770493 + -4.15457386959 7.7 1.37923365746 + -4.15760215072 7.7 1.37686770493 0.360981935596 0.4 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.995184726672 1.99036945334 -4.07875604702 @@ -873,12 +945,12 @@ Phong cone glass.2.torus.25 0 0 8 - -4.15760215072 7.6 1.37686770493 - -4.15457386959 7.6 1.37923365746 + -4.15760215072 7.7 1.37686770493 + -4.15457386959 7.7 1.37923365746 0.4 0.439018064404 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.956940335732 1.99036945334 -4.27102358394 @@ -886,12 +958,12 @@ Phong cone glass.2.torus.26 0 0 8 - -4.15457386959 7.6 1.37923365746 - -4.14560540133 7.6 1.3862405928 + -4.15457386959 7.7 1.37923365746 + -4.14560540133 7.7 1.3862405928 0.439018064404 0.476536686474 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.881921264348 1.99036945334 -4.45213564351 @@ -899,12 +971,12 @@ Phong cone glass.2.torus.27 0 0 8 - -4.14560540133 7.6 1.3862405928 - -4.13104139916 7.6 1.39761923836 + -4.14560540133 7.7 1.3862405928 + -4.13104139916 7.7 1.39761923836 0.476536686474 0.511114046604 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.773010453363 1.99036945334 -4.61513219085 @@ -912,12 +984,12 @@ Phong cone glass.2.torus.28 0 0 8 - -4.13104139916 7.6 1.39761923836 - -4.1114415495 7.6 1.41293231918 + -4.13104139916 7.7 1.39761923836 + -4.1114415495 7.7 1.41293231918 0.511114046604 0.541421356238 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.634393284164 1.99036945334 -4.75374936005 @@ -925,12 +997,12 @@ Phong cone glass.2.torus.29 0 0 8 - -4.1114415495 7.6 1.41293231918 - -4.0875590636 7.6 1.43159136214 + -4.1114415495 7.7 1.41293231918 + -4.0875590636 7.7 1.43159136214 0.541421356238 0.56629392246 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.471396736826 1.99036945334 -4.86266017104 @@ -938,12 +1010,12 @@ Phong cone glass.2.torus.30 0 0 8 - -4.0875590636 7.6 1.43159136214 - -4.06031173199 7.6 1.45287931069 + -4.0875590636 7.7 1.43159136214 + -4.06031173199 7.7 1.45287931069 0.56629392246 0.584775906502 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.99036945334 0.290284677254 1.99036945334 -4.93767924242 @@ -951,12 +1023,12 @@ Phong cone glass.2.torus.31 0 0 8 - -4.06031173199 7.6 1.45287931069 - -4.03074665433 7.6 1.47597808091 + -4.06031173199 7.7 1.45287931069 + -4.03074665433 7.7 1.47597808091 0.584775906502 0.59615705608 striped texfunc Phong -20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.1 0 +20 rev_dx rev_dy rev_dz rev.cal -i 1 -ry 52 -s .2 -t -4 2.5 1.5 -i 1 -t 0 5.2 0 0 4 1.48795016716 3.33066907388e-16 -49.8024616447 149.407384934 @@ -964,9 +1036,14 @@ Phong cone glass.2.torus.32 0 0 8 - -4.03074665433 7.6 1.47597808091 - -4 7.6 1.5 + -4.03074665433 7.7 1.47597808091 + -4 7.7 1.5 0.59615705608 0.6 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A clear glazing used to create rectangular illum at window +# mkillum -ab 0 !oconv -i glass.oct illum_glass.rad +#@mkillum ! +# mkillum f=glass_ill c=d d=50 s=64 void glass glass_clear 0 @@ -974,7 +1051,7 @@ void glass glass_clear 3 0.92 0.92 0.92 void colordata illum_mat.dist -15 red green blue glass_illR.dat glass_illG.dat glass_illB.dat illum.cal il_alth il_azih -i 1 -t 0 5.1 0 +15 red green blue glass_illR.dat glass_illG.dat glass_illB.dat illum.cal il_alth il_azih -i 1 -t 0 5.2 0 0 9 0 1 0 0 0 1 1 0 0 @@ -987,181 +1064,204 @@ illum_mat polygon glass.2.clear_glazing 0 0 12 - -8.1 6.1 1 - -8.1 9.1 1 - -8.1 9.1 2 - -8.1 6.1 2 + -8 6.2 1 + -8 9.2 1 + -8 9.2 2 + -8 6.2 2 +# xform -n inst.3 -t 0 10.4 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon inst.3.wall.b 0 0 30 - -6.12323399574e-18 10.1 -0.1 - -6.12323399574e-18 15.3 -0.1 - 1.89820253868e-16 15.3 3.1 - 1.89820253868e-16 10.1 3.1 - -6.12323399574e-18 10.1 -0.1 - 0 10.2 0 - 1.83697019872e-16 10.2 3 - 1.83697019872e-16 15.2 3 - 0 15.2 0 - 0 10.2 0 + -6.12323399574e-18 10.3 -0.1 + -6.12323399574e-18 15.5 -0.1 + 1.89820253868e-16 15.5 3.1 + 1.89820253868e-16 10.3 3.1 + -6.12323399574e-18 10.3 -0.1 + 0 10.4 0 + 1.83697019872e-16 10.4 3 + 1.83697019872e-16 15.4 3 + 0 15.4 0 + 0 10.4 0 black_outside polygon inst.3.wall.t 0 0 30 - -8 10.2 4.89858719659e-16 - -8 15.2 4.89858719659e-16 - -8 15.2 3 - -8 10.2 3 - -8 10.2 4.89858719659e-16 - -8 10.1 -0.1 - -8 10.1 3.1 - -8 15.3 3.1 - -8 15.3 -0.1 - -8 10.1 -0.1 + -8 10.4 4.89858719659e-16 + -8 15.4 4.89858719659e-16 + -8 15.4 3 + -8 10.4 3 + -8 10.4 4.89858719659e-16 + -8 10.3 -0.1 + -8 10.3 3.1 + -8 15.5 3.1 + -8 15.5 -0.1 + -8 10.3 -0.1 black_outside polygon inst.3.wall.1 0 0 12 - -6.12323399574e-18 10.1 -0.1 - -8 10.1 -0.1 - -8 15.3 -0.1 - -6.12323399574e-18 15.3 -0.1 + -6.12323399574e-18 10.3 -0.1 + -8 10.3 -0.1 + -8 15.5 -0.1 + -6.12323399574e-18 15.5 -0.1 black_outside polygon inst.3.wall.2 0 0 12 - -6.12323399574e-18 15.3 -0.1 - -8 15.3 -0.1 - -8 15.3 3.1 - 1.89820253868e-16 15.3 3.1 + -6.12323399574e-18 15.5 -0.1 + -8 15.5 -0.1 + -8 15.5 3.1 + 1.89820253868e-16 15.5 3.1 black_outside polygon inst.3.wall.3 0 0 12 - 1.89820253868e-16 15.3 3.1 - -8 15.3 3.1 - -8 10.1 3.1 - 1.89820253868e-16 10.1 3.1 + 1.89820253868e-16 15.5 3.1 + -8 15.5 3.1 + -8 10.3 3.1 + 1.89820253868e-16 10.3 3.1 black_outside polygon inst.3.wall.4 0 0 12 - 1.89820253868e-16 10.1 3.1 - -8 10.1 3.1 - -8 10.1 -0.1 - -6.12323399574e-18 10.1 -0.1 + 1.89820253868e-16 10.3 3.1 + -8 10.3 3.1 + -8 10.3 -0.1 + -6.12323399574e-18 10.3 -0.1 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon inst.3.wall.6 0 0 12 - 0 10.2 0 - -8 10.2 4.89858719659e-16 - -8 10.2 3 - 1.83697019872e-16 10.2 3 + 0 10.4 0 + -8 10.4 4.89858719659e-16 + -8 10.4 3 + 1.83697019872e-16 10.4 3 ceil_mat polygon inst.3.wall.7 0 0 12 - 1.83697019872e-16 10.2 3 - -8 10.2 3 - -8 15.2 3 - 1.83697019872e-16 15.2 3 + 1.83697019872e-16 10.4 3 + -8 10.4 3 + -8 15.4 3 + 1.83697019872e-16 15.4 3 wall_mat polygon inst.3.wall.8 0 0 12 - 1.83697019872e-16 15.2 3 - -8 15.2 3 - -8 15.2 4.89858719659e-16 - 0 15.2 0 + 1.83697019872e-16 15.4 3 + -8 15.4 3 + -8 15.4 4.89858719659e-16 + 0 15.4 0 floor_mat polygon inst.3.wall.9 0 0 12 - 0 15.2 0 - -8 15.2 4.89858719659e-16 - -8 10.2 4.89858719659e-16 - 0 10.2 0 + 0 15.4 0 + -8 15.4 4.89858719659e-16 + -8 10.4 4.89858719659e-16 + 0 10.4 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A closed wall for the end cap of our diorama +# xform -t -8.2 -.1 -.1 +# genbox wall_mat end_wall .2 5.2 3.2 wall_mat polygon inst.3.end_wall.1540 0 0 12 - -8 10.1 -0.1 - -8 10.1 3.1 - -8.2 10.1 3.1 - -8.2 10.1 -0.1 + -8 10.3 -0.1 + -8 10.3 3.1 + -8.2 10.3 3.1 + -8.2 10.3 -0.1 wall_mat polygon inst.3.end_wall.4620 0 0 12 - -8.2 10.1 3.1 - -8.2 15.3 3.1 - -8.2 15.3 -0.1 - -8.2 10.1 -0.1 + -8.2 10.3 3.1 + -8.2 15.5 3.1 + -8.2 15.5 -0.1 + -8.2 10.3 -0.1 wall_mat polygon inst.3.end_wall.2310 0 0 12 - -8.2 15.3 -0.1 - -8 15.3 -0.1 - -8 10.1 -0.1 - -8.2 10.1 -0.1 + -8.2 15.5 -0.1 + -8 15.5 -0.1 + -8 10.3 -0.1 + -8.2 10.3 -0.1 wall_mat polygon inst.3.end_wall.3267 0 0 12 - -8 15.3 -0.1 - -8.2 15.3 -0.1 - -8.2 15.3 3.1 - -8 15.3 3.1 + -8 15.5 -0.1 + -8.2 15.5 -0.1 + -8.2 15.5 3.1 + -8 15.5 3.1 wall_mat polygon inst.3.end_wall.5137 0 0 12 - -8 10.1 3.1 - -8 10.1 -0.1 - -8 15.3 -0.1 - -8 15.3 3.1 + -8 10.3 3.1 + -8 10.3 -0.1 + -8 15.5 -0.1 + -8 15.5 3.1 wall_mat polygon inst.3.end_wall.6457 0 0 12 - -8.2 15.3 3.1 - -8.2 10.1 3.1 - -8 10.1 3.1 - -8 15.3 3.1 + -8.2 15.5 3.1 + -8.2 10.3 3.1 + -8 10.3 3.1 + -8 15.5 3.1 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Test of instance primitive and spaces in names and modifiers +# void instance "inst.3.porsche #1" -15 porsche.octf -rx 90 -s .15 -t -4 2 1 -i 1 -t 0 10.2 0 +15 porsche.octf -rx 90 -s .15 -t -4 2 1 -i 1 -t 0 10.4 0 0 0 void ashik2 "ashik mat" -10 1 0 0 . -i 1 -t 0 10.2 0 +10 1 0 0 . -i 1 -t 0 10.4 0 0 8 0.3 0.1 0.05 0.05 0.05 0.08 5 30 "ashik mat" instance inst.3.porsche2 -15 porsche.octf -rx 90 -s .15 -t -4 3 1 -i 1 -t 0 10.2 0 +15 porsche.octf -rx 90 -s .15 -t -4 3 1 -i 1 -t 0 10.4 0 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A pair of spotlights, one pink and one bluish void spotlight pink_spotlight 0 @@ -1173,7 +1273,7 @@ pink_spotlight ring inst.3.pspot 0 0 8 - -2 11.2 2.5 + -2 11.4 2.5 -2.5 1.5 -2 0 0.2 @@ -1187,430 +1287,618 @@ blue_spotlight ring inst.3.bspot 0 0 8 - -2 14.2 2.5 + -2 14.4 2.5 -2.5 -1.5 -2 0 0.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# xform -s 0.0253999863 -rz 90 -t -4 2.5 2.999 +# +# Wellmade 2 lamp fixture, model 395-12A-248RS +# +# Dimensions in inches, fixture parallel to y axis, center at origin +# void brightdata lum_dist -19 flatcorr rect_fixture.dat source.cal src_phi4 src_theta -s 0.0253999863 -rz 90 -t -4 2.5 2.999 -i 1 -t 0 10.2 0 +19 flatcorr rect_fixture.dat source.cal src_phi4 src_theta -s 0.0253999863 -rz 90 -t -4 2.5 2.999 -i 1 -t 0 10.4 0 0 0 +# this is scaled by 1/area (SI) lum_dist light lum_bright 0 0 3 20 20 20 +# 3 1.55 1.55 1.55 lum_bright polygon inst.3.luminaire 0 0 12 - -3.42215031167 12.4269501473 2.999 - -4.57784968833 12.4269501473 2.999 - -4.57784968833 12.9730498527 2.999 - -3.42215031167 12.9730498527 2.999 + -3.42215031167 12.6269501473 2.999 + -4.57784968833 12.6269501473 2.999 + -4.57784968833 13.1730498527 2.999 + -3.42215031167 13.1730498527 2.999 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Test of glow source with limited effect +# +void glow red_glow +0 +0 +4 5 0.05 0.05 1.5 + +red_glow sphere inst.3.red_bulb +0 +0 +4 -7 11.4 2 0.25 +# Negative influence radius means no illumination cast + +void glow green_glow +0 +0 +4 0.05 5 0.05 -1 + +green_glow sphere inst.3.green_bulb +0 +0 +4 -7 12.4 2 0.25 +# xform -n mesh.4 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c + black_outside polygon mesh.4.wall.b 0 0 30 - -6.12323399574e-18 15.2 -0.1 - -6.12323399574e-18 20.4 -0.1 - 1.89820253868e-16 20.4 3.1 - 1.89820253868e-16 15.2 3.1 - -6.12323399574e-18 15.2 -0.1 - 0 15.3 0 - 1.83697019872e-16 15.3 3 - 1.83697019872e-16 20.3 3 - 0 20.3 0 - 0 15.3 0 + -6.12323399574e-18 15.5 -0.1 + -6.12323399574e-18 20.7 -0.1 + 1.89820253868e-16 20.7 3.1 + 1.89820253868e-16 15.5 3.1 + -6.12323399574e-18 15.5 -0.1 + 0 15.6 0 + 1.83697019872e-16 15.6 3 + 1.83697019872e-16 20.6 3 + 0 20.6 0 + 0 15.6 0 black_outside polygon mesh.4.wall.t 0 0 30 - -8 15.3 4.89858719659e-16 - -8 20.3 4.89858719659e-16 - -8 20.3 3 - -8 15.3 3 - -8 15.3 4.89858719659e-16 - -8 15.2 -0.1 - -8 15.2 3.1 - -8 20.4 3.1 - -8 20.4 -0.1 - -8 15.2 -0.1 + -8 15.6 4.89858719659e-16 + -8 20.6 4.89858719659e-16 + -8 20.6 3 + -8 15.6 3 + -8 15.6 4.89858719659e-16 + -8 15.5 -0.1 + -8 15.5 3.1 + -8 20.7 3.1 + -8 20.7 -0.1 + -8 15.5 -0.1 black_outside polygon mesh.4.wall.1 0 0 12 - -6.12323399574e-18 15.2 -0.1 - -8 15.2 -0.1 - -8 20.4 -0.1 - -6.12323399574e-18 20.4 -0.1 + -6.12323399574e-18 15.5 -0.1 + -8 15.5 -0.1 + -8 20.7 -0.1 + -6.12323399574e-18 20.7 -0.1 black_outside polygon mesh.4.wall.2 0 0 12 - -6.12323399574e-18 20.4 -0.1 - -8 20.4 -0.1 - -8 20.4 3.1 - 1.89820253868e-16 20.4 3.1 + -6.12323399574e-18 20.7 -0.1 + -8 20.7 -0.1 + -8 20.7 3.1 + 1.89820253868e-16 20.7 3.1 black_outside polygon mesh.4.wall.3 0 0 12 - 1.89820253868e-16 20.4 3.1 - -8 20.4 3.1 - -8 15.2 3.1 - 1.89820253868e-16 15.2 3.1 + 1.89820253868e-16 20.7 3.1 + -8 20.7 3.1 + -8 15.5 3.1 + 1.89820253868e-16 15.5 3.1 black_outside polygon mesh.4.wall.4 0 0 12 - 1.89820253868e-16 15.2 3.1 - -8 15.2 3.1 - -8 15.2 -0.1 - -6.12323399574e-18 15.2 -0.1 + 1.89820253868e-16 15.5 3.1 + -8 15.5 3.1 + -8 15.5 -0.1 + -6.12323399574e-18 15.5 -0.1 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon mesh.4.wall.6 0 0 12 - 0 15.3 0 - -8 15.3 4.89858719659e-16 - -8 15.3 3 - 1.83697019872e-16 15.3 3 + 0 15.6 0 + -8 15.6 4.89858719659e-16 + -8 15.6 3 + 1.83697019872e-16 15.6 3 ceil_mat polygon mesh.4.wall.7 0 0 12 - 1.83697019872e-16 15.3 3 - -8 15.3 3 - -8 20.3 3 - 1.83697019872e-16 20.3 3 + 1.83697019872e-16 15.6 3 + -8 15.6 3 + -8 20.6 3 + 1.83697019872e-16 20.6 3 wall_mat polygon mesh.4.wall.8 0 0 12 - 1.83697019872e-16 20.3 3 - -8 20.3 3 - -8 20.3 4.89858719659e-16 - 0 20.3 0 + 1.83697019872e-16 20.6 3 + -8 20.6 3 + -8 20.6 4.89858719659e-16 + 0 20.6 0 floor_mat polygon mesh.4.wall.9 0 0 12 - 0 20.3 0 - -8 20.3 4.89858719659e-16 - -8 15.3 4.89858719659e-16 - 0 15.3 0 + 0 20.6 0 + -8 20.6 4.89858719659e-16 + -8 15.6 4.89858719659e-16 + 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A closed wall for the end cap of our diorama +# xform -t -8.2 -.1 -.1 +# genbox wall_mat end_wall .2 5.2 3.2 wall_mat polygon mesh.4.end_wall.1540 0 0 12 - -8 15.2 -0.1 - -8 15.2 3.1 - -8.2 15.2 3.1 - -8.2 15.2 -0.1 + -8 15.5 -0.1 + -8 15.5 3.1 + -8.2 15.5 3.1 + -8.2 15.5 -0.1 wall_mat polygon mesh.4.end_wall.4620 0 0 12 - -8.2 15.2 3.1 - -8.2 20.4 3.1 - -8.2 20.4 -0.1 - -8.2 15.2 -0.1 + -8.2 15.5 3.1 + -8.2 20.7 3.1 + -8.2 20.7 -0.1 + -8.2 15.5 -0.1 wall_mat polygon mesh.4.end_wall.2310 0 0 12 - -8.2 20.4 -0.1 - -8 20.4 -0.1 - -8 15.2 -0.1 - -8.2 15.2 -0.1 + -8.2 20.7 -0.1 + -8 20.7 -0.1 + -8 15.5 -0.1 + -8.2 15.5 -0.1 wall_mat polygon mesh.4.end_wall.3267 0 0 12 - -8 20.4 -0.1 - -8.2 20.4 -0.1 - -8.2 20.4 3.1 - -8 20.4 3.1 + -8 20.7 -0.1 + -8.2 20.7 -0.1 + -8.2 20.7 3.1 + -8 20.7 3.1 wall_mat polygon mesh.4.end_wall.5137 0 0 12 - -8 15.2 3.1 - -8 15.2 -0.1 - -8 20.4 -0.1 - -8 20.4 3.1 + -8 15.5 3.1 + -8 15.5 -0.1 + -8 20.7 -0.1 + -8 20.7 3.1 wall_mat polygon mesh.4.end_wall.6457 0 0 12 - -8.2 20.4 3.1 - -8.2 15.2 3.1 - -8 15.2 3.1 - -8 20.4 3.1 + -8.2 20.7 3.1 + -8.2 15.5 3.1 + -8 15.5 3.1 + -8 20.7 3.1 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# xform -s 0.0253999863 -rz 90 -t -4 2.5 2.999 +# +# Wellmade 2 lamp fixture, model 395-12A-248RS +# +# Dimensions in inches, fixture parallel to y axis, center at origin +# +void brightdata lum_dist +19 flatcorr rect_fixture.dat source.cal src_phi4 src_theta -s 0.0253999863 -rz 90 -t -4 2.5 2.999 -i 1 -t 0 15.6 0 +0 +0 +# this is scaled by 1/area (SI) + +lum_dist light lum_bright +0 +0 +3 20 20 20 +# 3 1.55 1.55 1.55 + +lum_bright polygon mesh.4.luminaire +0 +0 +12 + -3.42215031167 17.8269501473 2.999 + -4.57784968833 17.8269501473 2.999 + -4.57784968833 18.3730498527 2.999 + -3.42215031167 18.3730498527 2.999 +# xform -n mesh.plainclothes.5.0 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 0 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# + void mesh mesh.plainclothes.5.0.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 0 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 0 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mesh.plainclothes.5.1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 1 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# void mesh mesh.plainclothes.5.1.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 1 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 1 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mesh.plainclothes.5.2 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 2 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# void mesh mesh.plainclothes.5.2.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 2 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 2 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mesh.plainclothes.5.3 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 3 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# void mesh mesh.plainclothes.5.3.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 3 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 3 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mesh.plainclothes.5.4 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 4 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# void mesh mesh.plainclothes.5.4.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 4 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 4 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mesh.plainclothes.5.5 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 5 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# void mesh mesh.plainclothes.5.5.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 5 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 5 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mesh.plainclothes.5.6 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 6 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# void mesh mesh.plainclothes.5.6.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 6 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 6 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mesh.plainclothes.5.7 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 7 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# void mesh mesh.plainclothes.5.7.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 7 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 7 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mesh.plainclothes.5.8 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 8 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# void mesh mesh.plainclothes.5.8.woman -27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 8 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +27 woman.rtm -i 1 -s 1.5 -rx 90 -rz -80 -t 1 0 0 -i 8 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.0 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 0 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.0.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 0 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 0 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 1 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.1.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 1 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 1 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.2 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 2 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.2.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 2 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 2 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.3 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 3 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.3.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 3 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 3 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.4 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 4 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.4.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 4 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 4 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.5 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 5 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.5.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 5 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 5 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.6 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 6 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.6.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 6 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 6 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.7 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 7 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.7.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 7 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 7 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -m chrome -n mesh.shiny.6.8 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 8 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Mesh test with a woman model +# chrome mesh mesh.shiny.6.8.woman -29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 8 -rz 40 -i 1 -t -5 2.5 0 -t 0 15 0 +29 woman.rtm -i 1 -s 1.5 -rx 90 -rz -105 -t 1 0 0 -rz 20 -i 8 -rz 40 -i 1 -t -5 2.5 0 -t 0 15.6 0 0 0 +# xform -n mirror.7 -t 0 0 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon mirror.7.wall.b 0 0 30 - -6.12323399574e-18 -0.1 3 - -6.12323399574e-18 5.1 3 - 1.89820253868e-16 5.1 6.2 - 1.89820253868e-16 -0.1 6.2 - -6.12323399574e-18 -0.1 3 - 0 0 3.1 - 1.83697019872e-16 0 6.1 - 1.83697019872e-16 5 6.1 - 0 5 3.1 - 0 0 3.1 + -6.12323399574e-18 -0.1 3.1 + -6.12323399574e-18 5.1 3.1 + 1.89820253868e-16 5.1 6.3 + 1.89820253868e-16 -0.1 6.3 + -6.12323399574e-18 -0.1 3.1 + 0 0 3.2 + 1.83697019872e-16 0 6.2 + 1.83697019872e-16 5 6.2 + 0 5 3.2 + 0 0 3.2 black_outside polygon mirror.7.wall.t 0 0 30 - -8 0 3.1 - -8 5 3.1 - -8 5 6.1 - -8 0 6.1 - -8 0 3.1 - -8 -0.1 3 - -8 -0.1 6.2 - -8 5.1 6.2 - -8 5.1 3 - -8 -0.1 3 + -8 0 3.2 + -8 5 3.2 + -8 5 6.2 + -8 0 6.2 + -8 0 3.2 + -8 -0.1 3.1 + -8 -0.1 6.3 + -8 5.1 6.3 + -8 5.1 3.1 + -8 -0.1 3.1 black_outside polygon mirror.7.wall.1 0 0 12 - -6.12323399574e-18 -0.1 3 - -8 -0.1 3 - -8 5.1 3 - -6.12323399574e-18 5.1 3 + -6.12323399574e-18 -0.1 3.1 + -8 -0.1 3.1 + -8 5.1 3.1 + -6.12323399574e-18 5.1 3.1 black_outside polygon mirror.7.wall.2 0 0 12 - -6.12323399574e-18 5.1 3 - -8 5.1 3 - -8 5.1 6.2 - 1.89820253868e-16 5.1 6.2 + -6.12323399574e-18 5.1 3.1 + -8 5.1 3.1 + -8 5.1 6.3 + 1.89820253868e-16 5.1 6.3 black_outside polygon mirror.7.wall.3 0 0 12 - 1.89820253868e-16 5.1 6.2 - -8 5.1 6.2 - -8 -0.1 6.2 - 1.89820253868e-16 -0.1 6.2 + 1.89820253868e-16 5.1 6.3 + -8 5.1 6.3 + -8 -0.1 6.3 + 1.89820253868e-16 -0.1 6.3 black_outside polygon mirror.7.wall.4 0 0 12 - 1.89820253868e-16 -0.1 6.2 - -8 -0.1 6.2 - -8 -0.1 3 - -6.12323399574e-18 -0.1 3 + 1.89820253868e-16 -0.1 6.3 + -8 -0.1 6.3 + -8 -0.1 3.1 + -6.12323399574e-18 -0.1 3.1 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon mirror.7.wall.6 0 0 12 - 0 0 3.1 - -8 0 3.1 - -8 0 6.1 - 1.83697019872e-16 0 6.1 + 0 0 3.2 + -8 0 3.2 + -8 0 6.2 + 1.83697019872e-16 0 6.2 ceil_mat polygon mirror.7.wall.7 0 0 12 - 1.83697019872e-16 0 6.1 - -8 0 6.1 - -8 5 6.1 - 1.83697019872e-16 5 6.1 + 1.83697019872e-16 0 6.2 + -8 0 6.2 + -8 5 6.2 + 1.83697019872e-16 5 6.2 wall_mat polygon mirror.7.wall.8 0 0 12 - 1.83697019872e-16 5 6.1 - -8 5 6.1 - -8 5 3.1 - 0 5 3.1 + 1.83697019872e-16 5 6.2 + -8 5 6.2 + -8 5 3.2 + 0 5 3.2 floor_mat polygon mirror.7.wall.9 0 0 12 - 0 5 3.1 - -8 5 3.1 - -8 0 3.1 - 0 0 3.1 + 0 5 3.2 + -8 5 3.2 + -8 0 3.2 + 0 0 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A closed wall for the end cap of our diorama +# xform -t -8.2 -.1 -.1 +# genbox wall_mat end_wall .2 5.2 3.2 wall_mat polygon mirror.7.end_wall.1540 0 0 12 - -8 -0.1 3 - -8 -0.1 6.2 - -8.2 -0.1 6.2 - -8.2 -0.1 3 + -8 -0.1 3.1 + -8 -0.1 6.3 + -8.2 -0.1 6.3 + -8.2 -0.1 3.1 wall_mat polygon mirror.7.end_wall.4620 0 0 12 - -8.2 -0.1 6.2 - -8.2 5.1 6.2 - -8.2 5.1 3 - -8.2 -0.1 3 + -8.2 -0.1 6.3 + -8.2 5.1 6.3 + -8.2 5.1 3.1 + -8.2 -0.1 3.1 wall_mat polygon mirror.7.end_wall.2310 0 0 12 - -8.2 5.1 3 - -8 5.1 3 - -8 -0.1 3 - -8.2 -0.1 3 + -8.2 5.1 3.1 + -8 5.1 3.1 + -8 -0.1 3.1 + -8.2 -0.1 3.1 wall_mat polygon mirror.7.end_wall.3267 0 0 12 - -8 5.1 3 - -8.2 5.1 3 - -8.2 5.1 6.2 - -8 5.1 6.2 + -8 5.1 3.1 + -8.2 5.1 3.1 + -8.2 5.1 6.3 + -8 5.1 6.3 wall_mat polygon mirror.7.end_wall.5137 0 0 12 - -8 -0.1 6.2 - -8 -0.1 3 - -8 5.1 3 - -8 5.1 6.2 + -8 -0.1 6.3 + -8 -0.1 3.1 + -8 5.1 3.1 + -8 5.1 6.3 wall_mat polygon mirror.7.end_wall.6457 0 0 12 - -8.2 5.1 6.2 - -8.2 -0.1 6.2 - -8 -0.1 6.2 - -8 5.1 6.2 + -8.2 5.1 6.3 + -8.2 -0.1 6.3 + -8 -0.1 6.3 + -8 5.1 6.3 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A bluish glass pane to fit any opening in end wall void glass glass_blue 0 @@ -1621,10 +1909,13 @@ glass_blue polygon mirror.7.blue_glazing 0 0 12 - -8.1 0 3.1 - -8.1 5 3.1 - -8.1 5 6.1 - -8.1 0 6.1 + -8.1 0 3.2 + -8.1 5 3.2 + -8.1 5 6.2 + -8.1 0 6.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Antimatter to cut through window wall with round, bevelled portal +# Couple with closed_end.rad void antimatter wall_eraser 1 wall_mat @@ -1635,7 +1926,7 @@ wall_eraser ring mirror.7.outer_portal 0 0 8 - -8.201 2.5 4.6 + -8.201 2.5 4.7 -1 0 0 0 1 @@ -1643,17 +1934,20 @@ wall_eraser cone mirror.7.side_portal 0 0 8 - -8.201 2.5 4.6 - -7.999 2.5 4.6 + -8.201 2.5 4.7 + -7.999 2.5 4.7 1 1.1 wall_eraser ring mirror.7.inner_portal 0 0 8 - -7.999 2.5 4.6 + -7.999 2.5 4.7 1 0 0 0 1.1 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Red ball inside water cube, test for interface +# Should match ball_in_cube.rad, but using bubble to invert normal void dielectric clear_water 0 @@ -1666,65 +1960,74 @@ void interface red_interface 8 0.98 0.98 0.98 1.33 0.98 0.05 0.02 1.6 +# xform -t -.5 -.5 -.5 -rz 17 -t -4 2.5 1.5 +# genbox clear_water watery 1 1 1 clear_water polygon mirror.7.watery.1540 0 0 12 - -3.37566176966 2.16803347438 4.1 - -3.37566176966 2.16803347438 5.1 - -4.33196652562 1.87566176966 5.1 - -4.33196652562 1.87566176966 4.1 + -3.37566176966 2.16803347438 4.2 + -3.37566176966 2.16803347438 5.2 + -4.33196652562 1.87566176966 5.2 + -4.33196652562 1.87566176966 4.2 clear_water polygon mirror.7.watery.4620 0 0 12 - -4.33196652562 1.87566176966 5.1 - -4.62433823034 2.83196652562 5.1 - -4.62433823034 2.83196652562 4.1 - -4.33196652562 1.87566176966 4.1 + -4.33196652562 1.87566176966 5.2 + -4.62433823034 2.83196652562 5.2 + -4.62433823034 2.83196652562 4.2 + -4.33196652562 1.87566176966 4.2 clear_water polygon mirror.7.watery.2310 0 0 12 - -4.62433823034 2.83196652562 4.1 - -3.66803347438 3.12433823034 4.1 - -3.37566176966 2.16803347438 4.1 - -4.33196652562 1.87566176966 4.1 + -4.62433823034 2.83196652562 4.2 + -3.66803347438 3.12433823034 4.2 + -3.37566176966 2.16803347438 4.2 + -4.33196652562 1.87566176966 4.2 clear_water polygon mirror.7.watery.3267 0 0 12 - -3.66803347438 3.12433823034 4.1 - -4.62433823034 2.83196652562 4.1 - -4.62433823034 2.83196652562 5.1 - -3.66803347438 3.12433823034 5.1 + -3.66803347438 3.12433823034 4.2 + -4.62433823034 2.83196652562 4.2 + -4.62433823034 2.83196652562 5.2 + -3.66803347438 3.12433823034 5.2 clear_water polygon mirror.7.watery.5137 0 0 12 - -3.37566176966 2.16803347438 5.1 - -3.37566176966 2.16803347438 4.1 - -3.66803347438 3.12433823034 4.1 - -3.66803347438 3.12433823034 5.1 + -3.37566176966 2.16803347438 5.2 + -3.37566176966 2.16803347438 4.2 + -3.66803347438 3.12433823034 4.2 + -3.66803347438 3.12433823034 5.2 clear_water polygon mirror.7.watery.6457 0 0 12 - -4.62433823034 2.83196652562 5.1 - -4.33196652562 1.87566176966 5.1 - -3.37566176966 2.16803347438 5.1 - -3.66803347438 3.12433823034 5.1 + -4.62433823034 2.83196652562 5.2 + -4.33196652562 1.87566176966 5.2 + -3.37566176966 2.16803347438 5.2 + -3.66803347438 3.12433823034 5.2 red_interface bubble mirror.7.red_ruby 0 0 -4 -4 2.5 4.6 0.25 +4 -4 2.5 4.7 0.25 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A mirror on the Y=5 wall with an alternate material having some pink diffuse +# +# Also used for testing rfluxmtx +# +#@rfluxmtx h=kf u=+Z void plastic pink_mirror_mat 0 @@ -1740,296 +2043,279 @@ wall_mirror polygon mirror.7.mirror 0 0 12 - -5 4.99 4.1 - -2 4.99 4.1 - -2 4.99 5.1 - -5 4.99 5.1 + -5 4.99 4.2 + -2 4.99 4.2 + -2 4.99 5.2 + -5 4.99 5.2 +# xform -n mist.8 -t 0 5.2 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon mist.8.wall.b 0 0 30 - -6.12323399574e-18 5 3 - -6.12323399574e-18 10.2 3 - 1.89820253868e-16 10.2 6.2 - 1.89820253868e-16 5 6.2 - -6.12323399574e-18 5 3 - 0 5.1 3.1 - 1.83697019872e-16 5.1 6.1 - 1.83697019872e-16 10.1 6.1 - 0 10.1 3.1 - 0 5.1 3.1 + -6.12323399574e-18 5.1 3.1 + -6.12323399574e-18 10.3 3.1 + 1.89820253868e-16 10.3 6.3 + 1.89820253868e-16 5.1 6.3 + -6.12323399574e-18 5.1 3.1 + 0 5.2 3.2 + 1.83697019872e-16 5.2 6.2 + 1.83697019872e-16 10.2 6.2 + 0 10.2 3.2 + 0 5.2 3.2 black_outside polygon mist.8.wall.t 0 0 30 + -8 5.2 3.2 + -8 10.2 3.2 + -8 10.2 6.2 + -8 5.2 6.2 + -8 5.2 3.2 -8 5.1 3.1 - -8 10.1 3.1 - -8 10.1 6.1 - -8 5.1 6.1 + -8 5.1 6.3 + -8 10.3 6.3 + -8 10.3 3.1 -8 5.1 3.1 - -8 5 3 - -8 5 6.2 - -8 10.2 6.2 - -8 10.2 3 - -8 5 3 black_outside polygon mist.8.wall.1 0 0 12 - -6.12323399574e-18 5 3 - -8 5 3 - -8 10.2 3 - -6.12323399574e-18 10.2 3 + -6.12323399574e-18 5.1 3.1 + -8 5.1 3.1 + -8 10.3 3.1 + -6.12323399574e-18 10.3 3.1 black_outside polygon mist.8.wall.2 0 0 12 - -6.12323399574e-18 10.2 3 - -8 10.2 3 - -8 10.2 6.2 - 1.89820253868e-16 10.2 6.2 + -6.12323399574e-18 10.3 3.1 + -8 10.3 3.1 + -8 10.3 6.3 + 1.89820253868e-16 10.3 6.3 black_outside polygon mist.8.wall.3 0 0 12 - 1.89820253868e-16 10.2 6.2 - -8 10.2 6.2 - -8 5 6.2 - 1.89820253868e-16 5 6.2 + 1.89820253868e-16 10.3 6.3 + -8 10.3 6.3 + -8 5.1 6.3 + 1.89820253868e-16 5.1 6.3 black_outside polygon mist.8.wall.4 0 0 12 - 1.89820253868e-16 5 6.2 - -8 5 6.2 - -8 5 3 - -6.12323399574e-18 5 3 + 1.89820253868e-16 5.1 6.3 + -8 5.1 6.3 + -8 5.1 3.1 + -6.12323399574e-18 5.1 3.1 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon mist.8.wall.6 0 0 12 - 0 5.1 3.1 - -8 5.1 3.1 - -8 5.1 6.1 - 1.83697019872e-16 5.1 6.1 + 0 5.2 3.2 + -8 5.2 3.2 + -8 5.2 6.2 + 1.83697019872e-16 5.2 6.2 ceil_mat polygon mist.8.wall.7 0 0 12 - 1.83697019872e-16 5.1 6.1 - -8 5.1 6.1 - -8 10.1 6.1 - 1.83697019872e-16 10.1 6.1 + 1.83697019872e-16 5.2 6.2 + -8 5.2 6.2 + -8 10.2 6.2 + 1.83697019872e-16 10.2 6.2 wall_mat polygon mist.8.wall.8 0 0 12 - 1.83697019872e-16 10.1 6.1 - -8 10.1 6.1 - -8 10.1 3.1 - 0 10.1 3.1 + 1.83697019872e-16 10.2 6.2 + -8 10.2 6.2 + -8 10.2 3.2 + 0 10.2 3.2 floor_mat polygon mist.8.wall.9 0 0 12 - 0 10.1 3.1 - -8 10.1 3.1 - -8 5.1 3.1 - 0 5.1 3.1 + 0 10.2 3.2 + -8 10.2 3.2 + -8 5.2 3.2 + 0 5.2 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A closed wall for the end cap of our diorama +# xform -t -8.2 -.1 -.1 +# genbox wall_mat end_wall .2 5.2 3.2 wall_mat polygon mist.8.end_wall.1540 0 0 12 - -8 5 3 - -8 5 6.2 - -8.2 5 6.2 - -8.2 5 3 + -8 5.1 3.1 + -8 5.1 6.3 + -8.2 5.1 6.3 + -8.2 5.1 3.1 wall_mat polygon mist.8.end_wall.4620 0 0 12 - -8.2 5 6.2 - -8.2 10.2 6.2 - -8.2 10.2 3 - -8.2 5 3 + -8.2 5.1 6.3 + -8.2 10.3 6.3 + -8.2 10.3 3.1 + -8.2 5.1 3.1 wall_mat polygon mist.8.end_wall.2310 0 0 12 - -8.2 10.2 3 - -8 10.2 3 - -8 5 3 - -8.2 5 3 + -8.2 10.3 3.1 + -8 10.3 3.1 + -8 5.1 3.1 + -8.2 5.1 3.1 wall_mat polygon mist.8.end_wall.3267 0 0 12 - -8 10.2 3 - -8.2 10.2 3 - -8.2 10.2 6.2 - -8 10.2 6.2 + -8 10.3 3.1 + -8.2 10.3 3.1 + -8.2 10.3 6.3 + -8 10.3 6.3 wall_mat polygon mist.8.end_wall.5137 0 0 12 - -8 5 6.2 - -8 5 3 - -8 10.2 3 - -8 10.2 6.2 + -8 5.1 6.3 + -8 5.1 3.1 + -8 10.3 3.1 + -8 10.3 6.3 wall_mat polygon mist.8.end_wall.6457 0 0 12 - -8.2 10.2 6.2 - -8.2 5 6.2 - -8 5 6.2 - -8 10.2 6.2 + -8.2 10.3 6.3 + -8.2 5.1 6.3 + -8 5.1 6.3 + -8 10.3 6.3 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Test of cylinders, tubes, and BRTDfunc material -void dielectric clear_water +void BRTDfunc brtd_mat +16 .1 .1 .1+if(Rdot-.8,0,.7) .1+if(RdotP-.8,.7,0) .1 .1 0 0 0 . -i 1 -t 0 5.2 3.2 0 -0 -5 0.98 0.98 0.98 1.33 0 +9 0.01 0.01 0.01 0.01 0.1 0.01 0.05 0.05 0.05 -void interface red_interface +brtd_mat cylinder mist.8.cyl1 0 0 -8 - 0.98 0.05 0.02 1.6 - 0.98 0.98 0.98 1.33 +7 + -4.2 7.7 4.7 + -3.8 7.7 4.7 + 0.5 -clear_water polygon mist.8.watery.1540 +brtd_mat tube mist.8.tube2 0 0 -12 - -3.37566176966 7.26803347438 4.1 - -3.37566176966 7.26803347438 5.1 - -4.33196652562 6.97566176966 5.1 - -4.33196652562 6.97566176966 4.1 +7 + -4 7.5 4.7 + -4 7.9 4.7 + 0.45 -clear_water polygon mist.8.watery.4620 +brtd_mat cylinder mist.8.cyl3 0 0 -12 - -4.33196652562 6.97566176966 5.1 - -4.62433823034 7.93196652562 5.1 - -4.62433823034 7.93196652562 4.1 - -4.33196652562 6.97566176966 4.1 +7 + -4 7.7 4.5 + -4 7.7 4.9 + 0.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Bluish mist suffusing space -clear_water polygon mist.8.watery.2310 -0 -0 -12 - -4.62433823034 7.93196652562 4.1 - -3.66803347438 8.22433823034 4.1 - -3.37566176966 7.26803347438 4.1 - -4.33196652562 6.97566176966 4.1 - -clear_water polygon mist.8.watery.3267 -0 -0 -12 - -3.66803347438 8.22433823034 4.1 - -4.62433823034 7.93196652562 4.1 - -4.62433823034 7.93196652562 5.1 - -3.66803347438 8.22433823034 5.1 - -clear_water polygon mist.8.watery.5137 -0 -0 -12 - -3.37566176966 7.26803347438 5.1 - -3.37566176966 7.26803347438 4.1 - -3.66803347438 8.22433823034 4.1 - -3.66803347438 8.22433823034 5.1 - -clear_water polygon mist.8.watery.6457 -0 -0 -12 - -4.62433823034 7.93196652562 5.1 - -4.33196652562 6.97566176966 5.1 - -3.37566176966 7.26803347438 5.1 - -3.66803347438 8.22433823034 5.1 - -red_interface sphere mist.8.red_ruby -0 -0 -4 -4 7.6 4.6 0.25 - void mist blue_mist 0 0 7 0.1 0.1 0.4 0.9 0.9 0.9 0.3 +# xform -t -7.99 .01 .01 +# genbox blue_mist smoke 7.98 4.98 2.98 blue_mist polygon mist.8.smoke.1540 0 0 12 - -0.01 5.11 3.11 - -0.01 5.11 6.09 - -7.99 5.11 6.09 - -7.99 5.11 3.11 + -0.01 5.21 3.21 + -0.01 5.21 6.19 + -7.99 5.21 6.19 + -7.99 5.21 3.21 blue_mist polygon mist.8.smoke.4620 0 0 12 - -7.99 5.11 6.09 - -7.99 10.09 6.09 - -7.99 10.09 3.11 - -7.99 5.11 3.11 + -7.99 5.21 6.19 + -7.99 10.19 6.19 + -7.99 10.19 3.21 + -7.99 5.21 3.21 blue_mist polygon mist.8.smoke.2310 0 0 12 - -7.99 10.09 3.11 - -0.01 10.09 3.11 - -0.01 5.11 3.11 - -7.99 5.11 3.11 + -7.99 10.19 3.21 + -0.01 10.19 3.21 + -0.01 5.21 3.21 + -7.99 5.21 3.21 blue_mist polygon mist.8.smoke.3267 0 0 12 - -0.01 10.09 3.11 - -7.99 10.09 3.11 - -7.99 10.09 6.09 - -0.01 10.09 6.09 + -0.01 10.19 3.21 + -7.99 10.19 3.21 + -7.99 10.19 6.19 + -0.01 10.19 6.19 blue_mist polygon mist.8.smoke.5137 0 0 12 - -0.01 5.11 6.09 - -0.01 5.11 3.11 - -0.01 10.09 3.11 - -0.01 10.09 6.09 + -0.01 5.21 6.19 + -0.01 5.21 3.21 + -0.01 10.19 3.21 + -0.01 10.19 6.19 blue_mist polygon mist.8.smoke.6457 0 0 12 - -7.99 10.09 6.09 - -7.99 5.11 6.09 - -0.01 5.11 6.09 - -0.01 10.09 6.09 + -7.99 10.19 6.19 + -7.99 5.21 6.19 + -0.01 5.21 6.19 + -0.01 10.19 6.19 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A pair of spotlights, one pink and one bluish void spotlight pink_spotlight 0 @@ -2041,7 +2327,7 @@ pink_spotlight ring mist.8.pspot 0 0 8 - -2 6.1 5.6 + -2 6.2 5.7 -2.5 1.5 -2 0 0.2 @@ -2055,9 +2341,11 @@ blue_spotlight ring mist.8.bspot 0 0 8 - -2 9.1 5.6 + -2 9.2 5.7 -2.5 -1.5 -2 0 0.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Mist cones to accompany spotlights void mist blue_spot_mist 1 mist.8.bspot @@ -2068,7 +2356,7 @@ blue_spot_mist ring mist.8.blue_spot_start 0 0 8 - -1.95 9.13 5.64 + -1.95 9.23 5.74 2.5 1.5 2 0 0.3 @@ -2076,15 +2364,15 @@ blue_spot_mist cone mist.8.blue_spot_beam 0 0 8 - -1.95 9.13 5.64 - -6.95 6.13 1.64 + -1.95 9.23 5.74 + -6.95 6.23 1.74 0.3 2.13 blue_spot_mist ring mist.8.blue_spot_end 0 0 8 - -6.95 6.13 1.64 + -6.95 6.23 1.74 -2.5 -1.5 -2 0 2.13 @@ -2097,7 +2385,7 @@ pink_spot_mist ring mist.8.pink_spot_start 0 0 8 - -1.95 6.07 5.64 + -1.95 6.17 5.74 2.5 -1.5 2 0 0.3 @@ -2105,233 +2393,252 @@ pink_spot_mist cone mist.8.pink_spot_beam 0 0 8 - -1.95 6.07 5.64 - -6.95 9.07 1.64 + -1.95 6.17 5.74 + -6.95 9.17 1.74 0.3 2.13 pink_spot_mist ring mist.8.pink_spot_end 0 0 8 - -6.95 9.07 1.64 + -6.95 9.17 1.74 -2.5 1.5 -2 0 2.13 +# xform -n prism1.9 -t 0 10.4 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon prism1.9.wall.b 0 0 30 - -6.12323399574e-18 10.1 3 - -6.12323399574e-18 15.3 3 - 1.89820253868e-16 15.3 6.2 - 1.89820253868e-16 10.1 6.2 - -6.12323399574e-18 10.1 3 - 0 10.2 3.1 - 1.83697019872e-16 10.2 6.1 - 1.83697019872e-16 15.2 6.1 - 0 15.2 3.1 - 0 10.2 3.1 + -6.12323399574e-18 10.3 3.1 + -6.12323399574e-18 15.5 3.1 + 1.89820253868e-16 15.5 6.3 + 1.89820253868e-16 10.3 6.3 + -6.12323399574e-18 10.3 3.1 + 0 10.4 3.2 + 1.83697019872e-16 10.4 6.2 + 1.83697019872e-16 15.4 6.2 + 0 15.4 3.2 + 0 10.4 3.2 black_outside polygon prism1.9.wall.t 0 0 30 - -8 10.2 3.1 - -8 15.2 3.1 - -8 15.2 6.1 - -8 10.2 6.1 - -8 10.2 3.1 - -8 10.1 3 - -8 10.1 6.2 - -8 15.3 6.2 - -8 15.3 3 - -8 10.1 3 + -8 10.4 3.2 + -8 15.4 3.2 + -8 15.4 6.2 + -8 10.4 6.2 + -8 10.4 3.2 + -8 10.3 3.1 + -8 10.3 6.3 + -8 15.5 6.3 + -8 15.5 3.1 + -8 10.3 3.1 black_outside polygon prism1.9.wall.1 0 0 12 - -6.12323399574e-18 10.1 3 - -8 10.1 3 - -8 15.3 3 - -6.12323399574e-18 15.3 3 + -6.12323399574e-18 10.3 3.1 + -8 10.3 3.1 + -8 15.5 3.1 + -6.12323399574e-18 15.5 3.1 black_outside polygon prism1.9.wall.2 0 0 12 - -6.12323399574e-18 15.3 3 - -8 15.3 3 - -8 15.3 6.2 - 1.89820253868e-16 15.3 6.2 + -6.12323399574e-18 15.5 3.1 + -8 15.5 3.1 + -8 15.5 6.3 + 1.89820253868e-16 15.5 6.3 black_outside polygon prism1.9.wall.3 0 0 12 - 1.89820253868e-16 15.3 6.2 - -8 15.3 6.2 - -8 10.1 6.2 - 1.89820253868e-16 10.1 6.2 + 1.89820253868e-16 15.5 6.3 + -8 15.5 6.3 + -8 10.3 6.3 + 1.89820253868e-16 10.3 6.3 black_outside polygon prism1.9.wall.4 0 0 12 - 1.89820253868e-16 10.1 6.2 - -8 10.1 6.2 - -8 10.1 3 - -6.12323399574e-18 10.1 3 + 1.89820253868e-16 10.3 6.3 + -8 10.3 6.3 + -8 10.3 3.1 + -6.12323399574e-18 10.3 3.1 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon prism1.9.wall.6 0 0 12 - 0 10.2 3.1 - -8 10.2 3.1 - -8 10.2 6.1 - 1.83697019872e-16 10.2 6.1 + 0 10.4 3.2 + -8 10.4 3.2 + -8 10.4 6.2 + 1.83697019872e-16 10.4 6.2 ceil_mat polygon prism1.9.wall.7 0 0 12 - 1.83697019872e-16 10.2 6.1 - -8 10.2 6.1 - -8 15.2 6.1 - 1.83697019872e-16 15.2 6.1 + 1.83697019872e-16 10.4 6.2 + -8 10.4 6.2 + -8 15.4 6.2 + 1.83697019872e-16 15.4 6.2 wall_mat polygon prism1.9.wall.8 0 0 12 - 1.83697019872e-16 15.2 6.1 - -8 15.2 6.1 - -8 15.2 3.1 - 0 15.2 3.1 + 1.83697019872e-16 15.4 6.2 + -8 15.4 6.2 + -8 15.4 3.2 + 0 15.4 3.2 floor_mat polygon prism1.9.wall.9 0 0 12 - 0 15.2 3.1 - -8 15.2 3.1 - -8 10.2 3.1 - 0 10.2 3.1 + 0 15.4 3.2 + -8 15.4 3.2 + -8 10.4 3.2 + 0 10.4 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Rectangular opening cut in end wall +# xform -ry -90 -t -8 0 0 +# genprism wall_mat end_wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 1 1 2 1 2 4 1 4 1 1 -l 0 0 .2 -c wall_mat polygon prism1.9.end_wall.b 0 0 30 - -8 10.1 3 - -8 15.3 3 - -8 15.3 6.2 - -8 10.1 6.2 - -8 10.1 3 - -8 11.2 4.1 - -8 11.2 5.1 - -8 14.2 5.1 - -8 14.2 4.1 - -8 11.2 4.1 + -8 10.3 3.1 + -8 15.5 3.1 + -8 15.5 6.3 + -8 10.3 6.3 + -8 10.3 3.1 + -8 11.4 4.2 + -8 11.4 5.2 + -8 14.4 5.2 + -8 14.4 4.2 + -8 11.4 4.2 wall_mat polygon prism1.9.end_wall.t 0 0 30 - -8.2 11.2 4.1 - -8.2 14.2 4.1 - -8.2 14.2 5.1 - -8.2 11.2 5.1 - -8.2 11.2 4.1 - -8.2 10.1 3 - -8.2 10.1 6.2 - -8.2 15.3 6.2 - -8.2 15.3 3 - -8.2 10.1 3 + -8.2 11.4 4.2 + -8.2 14.4 4.2 + -8.2 14.4 5.2 + -8.2 11.4 5.2 + -8.2 11.4 4.2 + -8.2 10.3 3.1 + -8.2 10.3 6.3 + -8.2 15.5 6.3 + -8.2 15.5 3.1 + -8.2 10.3 3.1 wall_mat polygon prism1.9.end_wall.1 0 0 12 - -8 10.1 3 - -8.2 10.1 3 - -8.2 15.3 3 - -8 15.3 3 + -8 10.3 3.1 + -8.2 10.3 3.1 + -8.2 15.5 3.1 + -8 15.5 3.1 wall_mat polygon prism1.9.end_wall.2 0 0 12 - -8 15.3 3 - -8.2 15.3 3 - -8.2 15.3 6.2 - -8 15.3 6.2 + -8 15.5 3.1 + -8.2 15.5 3.1 + -8.2 15.5 6.3 + -8 15.5 6.3 wall_mat polygon prism1.9.end_wall.3 0 0 12 - -8 15.3 6.2 - -8.2 15.3 6.2 - -8.2 10.1 6.2 - -8 10.1 6.2 + -8 15.5 6.3 + -8.2 15.5 6.3 + -8.2 10.3 6.3 + -8 10.3 6.3 wall_mat polygon prism1.9.end_wall.4 0 0 12 - -8 10.1 6.2 - -8.2 10.1 6.2 - -8.2 10.1 3 - -8 10.1 3 + -8 10.3 6.3 + -8.2 10.3 6.3 + -8.2 10.3 3.1 + -8 10.3 3.1 wall_mat polygon prism1.9.end_wall.5 0 0 12 - -8 10.1 3 - -8.2 10.1 3 - -8.2 11.2 4.1 - -8 11.2 4.1 + -8 10.3 3.1 + -8.2 10.3 3.1 + -8.2 11.4 4.2 + -8 11.4 4.2 wall_mat polygon prism1.9.end_wall.6 0 0 12 - -8 11.2 4.1 - -8.2 11.2 4.1 - -8.2 11.2 5.1 - -8 11.2 5.1 + -8 11.4 4.2 + -8.2 11.4 4.2 + -8.2 11.4 5.2 + -8 11.4 5.2 wall_mat polygon prism1.9.end_wall.7 0 0 12 - -8 11.2 5.1 - -8.2 11.2 5.1 - -8.2 14.2 5.1 - -8 14.2 5.1 + -8 11.4 5.2 + -8.2 11.4 5.2 + -8.2 14.4 5.2 + -8 14.4 5.2 wall_mat polygon prism1.9.end_wall.8 0 0 12 - -8 14.2 5.1 - -8.2 14.2 5.1 - -8.2 14.2 4.1 - -8 14.2 4.1 + -8 14.4 5.2 + -8.2 14.4 5.2 + -8.2 14.4 4.2 + -8 14.4 4.2 wall_mat polygon prism1.9.end_wall.9 0 0 12 - -8 14.2 4.1 - -8.2 14.2 4.1 - -8.2 11.2 4.1 - -8 11.2 4.1 + -8 14.4 4.2 + -8.2 14.4 4.2 + -8.2 11.4 4.2 + -8 11.4 4.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A singe-direction prism void prism1 prism1mat -13 coef1 dx1 dy1 dz1 prism.cal -rz 90 -i 1 -t 0 10.2 3.1 +13 coef1 dx1 dy1 dz1 prism.cal -rz 90 -i 1 -t 0 10.4 3.2 0 4 1.52 0.2 0.1 0.2 @@ -2339,13 +2646,25 @@ prism1mat polygon prism1.9.prism1_window 0 0 12 - -8.1 11.2 4.1 - -8.1 14.2 4.1 - -8.1 14.2 5.1 - -8.1 11.2 5.1 + -8.1 11.4 4.2 + -8.1 14.4 4.2 + -8.1 14.4 5.2 + -8.1 11.4 5.2 +# xform -m gold -n prism1.10 -t 0 10.2 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Vase model courtesy Tom Mertens from web page: +# http://people.csail.mit.edu/tmertens/textransfer/data +# Include acknowledgment in any published work: +# "textured 3D model from the MIT CSAIL database" +# +# Origin is at center of base; Z-axis is up. +# Vase is approx. 23cm tall +# Moved into middle of room for testing +# void colorpict vase_pat -13 lim_r lim_g lim_b vase.hdr climit.cal Lu Lv -i 1 -t 0 10.2 3.1 +13 lim_r lim_g lim_b vase.hdr climit.cal Lu Lv -i 1 -t 0 10.2 3.2 0 3 0.318558228 0.196044229 0.0860372415 @@ -2355,225 +2674,244 @@ vase_pat plastic vase_clay 5 1 1 1 0 0 gold mesh prism1.10.vase -17 vase.rtm -t 25 5 130 -s .005 -t -4 2.5 1 -i 1 -t 0 10.2 3.1 +17 vase.rtm -t 25 5 130 -s .005 -t -4 2.5 1 -i 1 -t 0 10.2 3.2 0 0 +# xform -n prism2.11 -t 0 15.6 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon prism2.11.wall.b 0 0 30 - -6.12323399574e-18 15.2 3 - -6.12323399574e-18 20.4 3 - 1.89820253868e-16 20.4 6.2 - 1.89820253868e-16 15.2 6.2 - -6.12323399574e-18 15.2 3 - 0 15.3 3.1 - 1.83697019872e-16 15.3 6.1 - 1.83697019872e-16 20.3 6.1 - 0 20.3 3.1 - 0 15.3 3.1 + -6.12323399574e-18 15.5 3.1 + -6.12323399574e-18 20.7 3.1 + 1.89820253868e-16 20.7 6.3 + 1.89820253868e-16 15.5 6.3 + -6.12323399574e-18 15.5 3.1 + 0 15.6 3.2 + 1.83697019872e-16 15.6 6.2 + 1.83697019872e-16 20.6 6.2 + 0 20.6 3.2 + 0 15.6 3.2 black_outside polygon prism2.11.wall.t 0 0 30 - -8 15.3 3.1 - -8 20.3 3.1 - -8 20.3 6.1 - -8 15.3 6.1 - -8 15.3 3.1 - -8 15.2 3 - -8 15.2 6.2 - -8 20.4 6.2 - -8 20.4 3 - -8 15.2 3 + -8 15.6 3.2 + -8 20.6 3.2 + -8 20.6 6.2 + -8 15.6 6.2 + -8 15.6 3.2 + -8 15.5 3.1 + -8 15.5 6.3 + -8 20.7 6.3 + -8 20.7 3.1 + -8 15.5 3.1 black_outside polygon prism2.11.wall.1 0 0 12 - -6.12323399574e-18 15.2 3 - -8 15.2 3 - -8 20.4 3 - -6.12323399574e-18 20.4 3 + -6.12323399574e-18 15.5 3.1 + -8 15.5 3.1 + -8 20.7 3.1 + -6.12323399574e-18 20.7 3.1 black_outside polygon prism2.11.wall.2 0 0 12 - -6.12323399574e-18 20.4 3 - -8 20.4 3 - -8 20.4 6.2 - 1.89820253868e-16 20.4 6.2 + -6.12323399574e-18 20.7 3.1 + -8 20.7 3.1 + -8 20.7 6.3 + 1.89820253868e-16 20.7 6.3 black_outside polygon prism2.11.wall.3 0 0 12 - 1.89820253868e-16 20.4 6.2 - -8 20.4 6.2 - -8 15.2 6.2 - 1.89820253868e-16 15.2 6.2 + 1.89820253868e-16 20.7 6.3 + -8 20.7 6.3 + -8 15.5 6.3 + 1.89820253868e-16 15.5 6.3 black_outside polygon prism2.11.wall.4 0 0 12 - 1.89820253868e-16 15.2 6.2 - -8 15.2 6.2 - -8 15.2 3 - -6.12323399574e-18 15.2 3 + 1.89820253868e-16 15.5 6.3 + -8 15.5 6.3 + -8 15.5 3.1 + -6.12323399574e-18 15.5 3.1 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon prism2.11.wall.6 0 0 12 - 0 15.3 3.1 - -8 15.3 3.1 - -8 15.3 6.1 - 1.83697019872e-16 15.3 6.1 + 0 15.6 3.2 + -8 15.6 3.2 + -8 15.6 6.2 + 1.83697019872e-16 15.6 6.2 ceil_mat polygon prism2.11.wall.7 0 0 12 - 1.83697019872e-16 15.3 6.1 - -8 15.3 6.1 - -8 20.3 6.1 - 1.83697019872e-16 20.3 6.1 + 1.83697019872e-16 15.6 6.2 + -8 15.6 6.2 + -8 20.6 6.2 + 1.83697019872e-16 20.6 6.2 wall_mat polygon prism2.11.wall.8 0 0 12 - 1.83697019872e-16 20.3 6.1 - -8 20.3 6.1 - -8 20.3 3.1 - 0 20.3 3.1 + 1.83697019872e-16 20.6 6.2 + -8 20.6 6.2 + -8 20.6 3.2 + 0 20.6 3.2 floor_mat polygon prism2.11.wall.9 0 0 12 - 0 20.3 3.1 - -8 20.3 3.1 - -8 15.3 3.1 - 0 15.3 3.1 + 0 20.6 3.2 + -8 20.6 3.2 + -8 15.6 3.2 + 0 15.6 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Rectangular opening cut in end wall +# xform -ry -90 -t -8 0 0 +# genprism wall_mat end_wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 1 1 2 1 2 4 1 4 1 1 -l 0 0 .2 -c wall_mat polygon prism2.11.end_wall.b 0 0 30 - -8 15.2 3 - -8 20.4 3 - -8 20.4 6.2 - -8 15.2 6.2 - -8 15.2 3 - -8 16.3 4.1 - -8 16.3 5.1 - -8 19.3 5.1 - -8 19.3 4.1 - -8 16.3 4.1 + -8 15.5 3.1 + -8 20.7 3.1 + -8 20.7 6.3 + -8 15.5 6.3 + -8 15.5 3.1 + -8 16.6 4.2 + -8 16.6 5.2 + -8 19.6 5.2 + -8 19.6 4.2 + -8 16.6 4.2 wall_mat polygon prism2.11.end_wall.t 0 0 30 - -8.2 16.3 4.1 - -8.2 19.3 4.1 - -8.2 19.3 5.1 - -8.2 16.3 5.1 - -8.2 16.3 4.1 - -8.2 15.2 3 - -8.2 15.2 6.2 - -8.2 20.4 6.2 - -8.2 20.4 3 - -8.2 15.2 3 + -8.2 16.6 4.2 + -8.2 19.6 4.2 + -8.2 19.6 5.2 + -8.2 16.6 5.2 + -8.2 16.6 4.2 + -8.2 15.5 3.1 + -8.2 15.5 6.3 + -8.2 20.7 6.3 + -8.2 20.7 3.1 + -8.2 15.5 3.1 wall_mat polygon prism2.11.end_wall.1 0 0 12 - -8 15.2 3 - -8.2 15.2 3 - -8.2 20.4 3 - -8 20.4 3 + -8 15.5 3.1 + -8.2 15.5 3.1 + -8.2 20.7 3.1 + -8 20.7 3.1 wall_mat polygon prism2.11.end_wall.2 0 0 12 - -8 20.4 3 - -8.2 20.4 3 - -8.2 20.4 6.2 - -8 20.4 6.2 + -8 20.7 3.1 + -8.2 20.7 3.1 + -8.2 20.7 6.3 + -8 20.7 6.3 wall_mat polygon prism2.11.end_wall.3 0 0 12 - -8 20.4 6.2 - -8.2 20.4 6.2 - -8.2 15.2 6.2 - -8 15.2 6.2 + -8 20.7 6.3 + -8.2 20.7 6.3 + -8.2 15.5 6.3 + -8 15.5 6.3 wall_mat polygon prism2.11.end_wall.4 0 0 12 - -8 15.2 6.2 - -8.2 15.2 6.2 - -8.2 15.2 3 - -8 15.2 3 + -8 15.5 6.3 + -8.2 15.5 6.3 + -8.2 15.5 3.1 + -8 15.5 3.1 wall_mat polygon prism2.11.end_wall.5 0 0 12 - -8 15.2 3 - -8.2 15.2 3 - -8.2 16.3 4.1 - -8 16.3 4.1 + -8 15.5 3.1 + -8.2 15.5 3.1 + -8.2 16.6 4.2 + -8 16.6 4.2 wall_mat polygon prism2.11.end_wall.6 0 0 12 - -8 16.3 4.1 - -8.2 16.3 4.1 - -8.2 16.3 5.1 - -8 16.3 5.1 + -8 16.6 4.2 + -8.2 16.6 4.2 + -8.2 16.6 5.2 + -8 16.6 5.2 wall_mat polygon prism2.11.end_wall.7 0 0 12 - -8 16.3 5.1 - -8.2 16.3 5.1 - -8.2 19.3 5.1 - -8 19.3 5.1 + -8 16.6 5.2 + -8.2 16.6 5.2 + -8.2 19.6 5.2 + -8 19.6 5.2 wall_mat polygon prism2.11.end_wall.8 0 0 12 - -8 19.3 5.1 - -8.2 19.3 5.1 - -8.2 19.3 4.1 - -8 19.3 4.1 + -8 19.6 5.2 + -8.2 19.6 5.2 + -8.2 19.6 4.2 + -8 19.6 4.2 wall_mat polygon prism2.11.end_wall.9 0 0 12 - -8 19.3 4.1 - -8.2 19.3 4.1 - -8.2 16.3 4.1 - -8 16.3 4.1 + -8 19.6 4.2 + -8.2 19.6 4.2 + -8.2 16.6 4.2 + -8 16.6 4.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A dual-direction prism void prism2 prism2mat -17 coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 prism.cal -rz 90 -i 1 -t 0 15.3 3.1 +17 coef1 dx1 dy1 dz1 coef2 dx2 dy2 dz2 prism.cal -rz 90 -i 1 -t 0 15.6 3.2 0 4 1.52 0.2 0.1 0.2 @@ -2581,13 +2919,25 @@ prism2mat polygon prism2.11.prism2_window 0 0 12 - -8.1 16.3 4.1 - -8.1 19.3 4.1 - -8.1 19.3 5.1 - -8.1 16.3 5.1 + -8.1 16.6 4.2 + -8.1 19.6 4.2 + -8.1 19.6 5.2 + -8.1 16.6 5.2 +# xform -m gold -n prism2.12 -t 0 15.3 3.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Vase model courtesy Tom Mertens from web page: +# http://people.csail.mit.edu/tmertens/textransfer/data +# Include acknowledgment in any published work: +# "textured 3D model from the MIT CSAIL database" +# +# Origin is at center of base; Z-axis is up. +# Vase is approx. 23cm tall +# Moved into middle of room for testing +# void colorpict vase_pat -13 lim_r lim_g lim_b vase.hdr climit.cal Lu Lv -i 1 -t 0 15.3 3.1 +13 lim_r lim_g lim_b vase.hdr climit.cal Lu Lv -i 1 -t 0 15.3 3.2 0 3 0.318558228 0.196044229 0.0860372415 @@ -2597,9 +2947,12 @@ vase_pat plastic vase_clay 5 1 1 1 0 0 gold mesh prism2.12.vase -17 vase.rtm -t 25 5 130 -s .005 -t -4 2.5 1 -i 1 -t 0 15.3 3.1 +17 vase.rtm -t 25 5 130 -s .005 -t -4 2.5 1 -i 1 -t 0 15.3 3.2 0 0 +# xform -n tfunc.13 -t 0 0 6.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Basic materials used for walls, etc. void plastic wall_mat 0 @@ -2620,251 +2973,316 @@ void plastic black_outside 0 0 5 0.05 0.05 0.05 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon tfunc.13.wall.b 0 0 30 - -6.12323399574e-18 -0.1 6.1 - -6.12323399574e-18 5.1 6.1 - 1.89820253868e-16 5.1 9.3 - 1.89820253868e-16 -0.1 9.3 - -6.12323399574e-18 -0.1 6.1 - 0 0 6.2 - 1.83697019872e-16 0 9.2 - 1.83697019872e-16 5 9.2 - 0 5 6.2 - 0 0 6.2 + -6.12323399574e-18 -0.1 6.3 + -6.12323399574e-18 5.1 6.3 + 1.89820253868e-16 5.1 9.5 + 1.89820253868e-16 -0.1 9.5 + -6.12323399574e-18 -0.1 6.3 + 0 0 6.4 + 1.83697019872e-16 0 9.4 + 1.83697019872e-16 5 9.4 + 0 5 6.4 + 0 0 6.4 black_outside polygon tfunc.13.wall.t 0 0 30 - -8 0 6.2 - -8 5 6.2 - -8 5 9.2 - -8 0 9.2 - -8 0 6.2 - -8 -0.1 6.1 - -8 -0.1 9.3 - -8 5.1 9.3 - -8 5.1 6.1 - -8 -0.1 6.1 + -8 0 6.4 + -8 5 6.4 + -8 5 9.4 + -8 0 9.4 + -8 0 6.4 + -8 -0.1 6.3 + -8 -0.1 9.5 + -8 5.1 9.5 + -8 5.1 6.3 + -8 -0.1 6.3 black_outside polygon tfunc.13.wall.1 0 0 12 - -6.12323399574e-18 -0.1 6.1 - -8 -0.1 6.1 - -8 5.1 6.1 - -6.12323399574e-18 5.1 6.1 + -6.12323399574e-18 -0.1 6.3 + -8 -0.1 6.3 + -8 5.1 6.3 + -6.12323399574e-18 5.1 6.3 black_outside polygon tfunc.13.wall.2 0 0 12 - -6.12323399574e-18 5.1 6.1 - -8 5.1 6.1 - -8 5.1 9.3 - 1.89820253868e-16 5.1 9.3 + -6.12323399574e-18 5.1 6.3 + -8 5.1 6.3 + -8 5.1 9.5 + 1.89820253868e-16 5.1 9.5 black_outside polygon tfunc.13.wall.3 0 0 12 - 1.89820253868e-16 5.1 9.3 - -8 5.1 9.3 - -8 -0.1 9.3 - 1.89820253868e-16 -0.1 9.3 + 1.89820253868e-16 5.1 9.5 + -8 5.1 9.5 + -8 -0.1 9.5 + 1.89820253868e-16 -0.1 9.5 black_outside polygon tfunc.13.wall.4 0 0 12 - 1.89820253868e-16 -0.1 9.3 - -8 -0.1 9.3 - -8 -0.1 6.1 - -6.12323399574e-18 -0.1 6.1 + 1.89820253868e-16 -0.1 9.5 + -8 -0.1 9.5 + -8 -0.1 6.3 + -6.12323399574e-18 -0.1 6.3 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon tfunc.13.wall.6 0 0 12 - 0 0 6.2 - -8 0 6.2 - -8 0 9.2 - 1.83697019872e-16 0 9.2 + 0 0 6.4 + -8 0 6.4 + -8 0 9.4 + 1.83697019872e-16 0 9.4 ceil_mat polygon tfunc.13.wall.7 0 0 12 - 1.83697019872e-16 0 9.2 - -8 0 9.2 - -8 5 9.2 - 1.83697019872e-16 5 9.2 + 1.83697019872e-16 0 9.4 + -8 0 9.4 + -8 5 9.4 + 1.83697019872e-16 5 9.4 wall_mat polygon tfunc.13.wall.8 0 0 12 - 1.83697019872e-16 5 9.2 - -8 5 9.2 - -8 5 6.2 - 0 5 6.2 + 1.83697019872e-16 5 9.4 + -8 5 9.4 + -8 5 6.4 + 0 5 6.4 floor_mat polygon tfunc.13.wall.9 0 0 12 - 0 5 6.2 - -8 5 6.2 - -8 0 6.2 - 0 0 6.2 + 0 5 6.4 + -8 5 6.4 + -8 0 6.4 + 0 0 6.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Rectangular opening cut in end wall +# xform -ry -90 -t -8 0 0 +# genprism wall_mat end_wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 1 1 2 1 2 4 1 4 1 1 -l 0 0 .2 -c wall_mat polygon tfunc.13.end_wall.b 0 0 30 - -8 -0.1 6.1 - -8 5.1 6.1 - -8 5.1 9.3 - -8 -0.1 9.3 - -8 -0.1 6.1 - -8 1 7.2 - -8 1 8.2 - -8 4 8.2 - -8 4 7.2 - -8 1 7.2 + -8 -0.1 6.3 + -8 5.1 6.3 + -8 5.1 9.5 + -8 -0.1 9.5 + -8 -0.1 6.3 + -8 1 7.4 + -8 1 8.4 + -8 4 8.4 + -8 4 7.4 + -8 1 7.4 wall_mat polygon tfunc.13.end_wall.t 0 0 30 - -8.2 1 7.2 - -8.2 4 7.2 - -8.2 4 8.2 - -8.2 1 8.2 - -8.2 1 7.2 - -8.2 -0.1 6.1 - -8.2 -0.1 9.3 - -8.2 5.1 9.3 - -8.2 5.1 6.1 - -8.2 -0.1 6.1 + -8.2 1 7.4 + -8.2 4 7.4 + -8.2 4 8.4 + -8.2 1 8.4 + -8.2 1 7.4 + -8.2 -0.1 6.3 + -8.2 -0.1 9.5 + -8.2 5.1 9.5 + -8.2 5.1 6.3 + -8.2 -0.1 6.3 wall_mat polygon tfunc.13.end_wall.1 0 0 12 - -8 -0.1 6.1 - -8.2 -0.1 6.1 - -8.2 5.1 6.1 - -8 5.1 6.1 + -8 -0.1 6.3 + -8.2 -0.1 6.3 + -8.2 5.1 6.3 + -8 5.1 6.3 wall_mat polygon tfunc.13.end_wall.2 0 0 12 - -8 5.1 6.1 - -8.2 5.1 6.1 - -8.2 5.1 9.3 - -8 5.1 9.3 + -8 5.1 6.3 + -8.2 5.1 6.3 + -8.2 5.1 9.5 + -8 5.1 9.5 wall_mat polygon tfunc.13.end_wall.3 0 0 12 - -8 5.1 9.3 - -8.2 5.1 9.3 - -8.2 -0.1 9.3 - -8 -0.1 9.3 + -8 5.1 9.5 + -8.2 5.1 9.5 + -8.2 -0.1 9.5 + -8 -0.1 9.5 wall_mat polygon tfunc.13.end_wall.4 0 0 12 - -8 -0.1 9.3 - -8.2 -0.1 9.3 - -8.2 -0.1 6.1 - -8 -0.1 6.1 + -8 -0.1 9.5 + -8.2 -0.1 9.5 + -8.2 -0.1 6.3 + -8 -0.1 6.3 wall_mat polygon tfunc.13.end_wall.5 0 0 12 - -8 -0.1 6.1 - -8.2 -0.1 6.1 - -8.2 1 7.2 - -8 1 7.2 + -8 -0.1 6.3 + -8.2 -0.1 6.3 + -8.2 1 7.4 + -8 1 7.4 wall_mat polygon tfunc.13.end_wall.6 0 0 12 - -8 1 7.2 - -8.2 1 7.2 - -8.2 1 8.2 - -8 1 8.2 + -8 1 7.4 + -8.2 1 7.4 + -8.2 1 8.4 + -8 1 8.4 wall_mat polygon tfunc.13.end_wall.7 0 0 12 - -8 1 8.2 - -8.2 1 8.2 - -8.2 4 8.2 - -8 4 8.2 + -8 1 8.4 + -8.2 1 8.4 + -8.2 4 8.4 + -8 4 8.4 wall_mat polygon tfunc.13.end_wall.8 0 0 12 - -8 4 8.2 - -8.2 4 8.2 - -8.2 4 7.2 - -8 4 7.2 + -8 4 8.4 + -8.2 4 8.4 + -8.2 4 7.4 + -8 4 7.4 wall_mat polygon tfunc.13.end_wall.9 0 0 12 - -8 4 7.2 - -8.2 4 7.2 - -8.2 1 7.2 - -8 1 7.2 + -8 4 7.4 + -8.2 4 7.4 + -8.2 1 7.4 + -8 1 7.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Red ball inside water cube, test for interface -void BRTDfunc brtd_mat -16 .1 .1 .1+if(Rdot-.8,0,.7) .1+if(RdotP-.8,.7,0) .1 .1 0 0 0 . -i 1 -t 0 0 6.2 +void dielectric clear_water 0 -9 0.01 0.01 0.01 0.01 0.1 0.01 0.05 0.05 0.05 +0 +5 0.98 0.98 0.98 1.33 0 -brtd_mat cylinder tfunc.13.cyl1 +void interface red_interface 0 0 -7 - -4.2 2.5 7.7 - -3.8 2.5 7.7 - 0.5 +8 + 0.98 0.05 0.02 1.6 + 0.98 0.98 0.98 1.33 +# xform -t -.5 -.5 -.5 -rz 17 -t -4 2.5 1.5 +# genbox clear_water watery 1 1 1 -brtd_mat tube tfunc.13.tube2 +clear_water polygon tfunc.13.watery.1540 0 0 -7 - -4 2.3 7.7 - -4 2.7 7.7 - 0.45 +12 + -3.37566176966 2.16803347438 7.4 + -3.37566176966 2.16803347438 8.4 + -4.33196652562 1.87566176966 8.4 + -4.33196652562 1.87566176966 7.4 -brtd_mat cylinder tfunc.13.cyl3 +clear_water polygon tfunc.13.watery.4620 0 0 -7 - -4 2.5 7.5 - -4 2.5 7.9 - 0.4 +12 + -4.33196652562 1.87566176966 8.4 + -4.62433823034 2.83196652562 8.4 + -4.62433823034 2.83196652562 7.4 + -4.33196652562 1.87566176966 7.4 +clear_water polygon tfunc.13.watery.2310 +0 +0 +12 + -4.62433823034 2.83196652562 7.4 + -3.66803347438 3.12433823034 7.4 + -3.37566176966 2.16803347438 7.4 + -4.33196652562 1.87566176966 7.4 + +clear_water polygon tfunc.13.watery.3267 +0 +0 +12 + -3.66803347438 3.12433823034 7.4 + -4.62433823034 2.83196652562 7.4 + -4.62433823034 2.83196652562 8.4 + -3.66803347438 3.12433823034 8.4 + +clear_water polygon tfunc.13.watery.5137 +0 +0 +12 + -3.37566176966 2.16803347438 8.4 + -3.37566176966 2.16803347438 7.4 + -3.66803347438 3.12433823034 7.4 + -3.66803347438 3.12433823034 8.4 + +clear_water polygon tfunc.13.watery.6457 +0 +0 +12 + -4.62433823034 2.83196652562 8.4 + -4.33196652562 1.87566176966 8.4 + -3.37566176966 2.16803347438 8.4 + -3.66803347438 3.12433823034 8.4 + +red_interface sphere tfunc.13.red_ruby +0 +0 +4 -4 2.5 7.9 0.25 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A transfunc window to turn into a light source with mkillum +#@mkillum l+ f=tfunc_ill c=a d=100 s=128 i=void + void transfunc tfunc_mat -8 absdf aniso.cal -i 1 -t 0 0 6.2 +8 absdf aniso.cal -i 1 -t 0 0 6.4 0 11 0.9 0.9 0.9 0.05 0.8 0.9 0.1 0.02 0 0 1 @@ -2872,223 +3290,254 @@ tfunc_mat polygon tfunc.13.tfunc_window 0 0 12 - -8.1 1 7.2 - -8.1 4 7.2 - -8.1 4 8.2 - -8.1 1 8.2 + -8.1 1 7.4 + -8.1 4 7.4 + -8.1 4 8.4 + -8.1 1 8.4 +void polygon tfunc.13.tfunc_window +0 +0 +12 + -8 1 7.4 + -8 4 7.4 + -8 4 8.4 + -8 1 8.4 +# xform -n trans.14 -t 0 5.2 6.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c + black_outside polygon trans.14.wall.b 0 0 30 - -6.12323399574e-18 5 6.1 - -6.12323399574e-18 10.2 6.1 - 1.89820253868e-16 10.2 9.3 - 1.89820253868e-16 5 9.3 - -6.12323399574e-18 5 6.1 - 0 5.1 6.2 - 1.83697019872e-16 5.1 9.2 - 1.83697019872e-16 10.1 9.2 - 0 10.1 6.2 - 0 5.1 6.2 + -6.12323399574e-18 5.1 6.3 + -6.12323399574e-18 10.3 6.3 + 1.89820253868e-16 10.3 9.5 + 1.89820253868e-16 5.1 9.5 + -6.12323399574e-18 5.1 6.3 + 0 5.2 6.4 + 1.83697019872e-16 5.2 9.4 + 1.83697019872e-16 10.2 9.4 + 0 10.2 6.4 + 0 5.2 6.4 black_outside polygon trans.14.wall.t 0 0 30 - -8 5.1 6.2 - -8 10.1 6.2 - -8 10.1 9.2 - -8 5.1 9.2 - -8 5.1 6.2 - -8 5 6.1 - -8 5 9.3 - -8 10.2 9.3 - -8 10.2 6.1 - -8 5 6.1 + -8 5.2 6.4 + -8 10.2 6.4 + -8 10.2 9.4 + -8 5.2 9.4 + -8 5.2 6.4 + -8 5.1 6.3 + -8 5.1 9.5 + -8 10.3 9.5 + -8 10.3 6.3 + -8 5.1 6.3 black_outside polygon trans.14.wall.1 0 0 12 - -6.12323399574e-18 5 6.1 - -8 5 6.1 - -8 10.2 6.1 - -6.12323399574e-18 10.2 6.1 + -6.12323399574e-18 5.1 6.3 + -8 5.1 6.3 + -8 10.3 6.3 + -6.12323399574e-18 10.3 6.3 black_outside polygon trans.14.wall.2 0 0 12 - -6.12323399574e-18 10.2 6.1 - -8 10.2 6.1 - -8 10.2 9.3 - 1.89820253868e-16 10.2 9.3 + -6.12323399574e-18 10.3 6.3 + -8 10.3 6.3 + -8 10.3 9.5 + 1.89820253868e-16 10.3 9.5 black_outside polygon trans.14.wall.3 0 0 12 - 1.89820253868e-16 10.2 9.3 - -8 10.2 9.3 - -8 5 9.3 - 1.89820253868e-16 5 9.3 + 1.89820253868e-16 10.3 9.5 + -8 10.3 9.5 + -8 5.1 9.5 + 1.89820253868e-16 5.1 9.5 black_outside polygon trans.14.wall.4 0 0 12 - 1.89820253868e-16 5 9.3 - -8 5 9.3 - -8 5 6.1 - -6.12323399574e-18 5 6.1 + 1.89820253868e-16 5.1 9.5 + -8 5.1 9.5 + -8 5.1 6.3 + -6.12323399574e-18 5.1 6.3 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon trans.14.wall.6 0 0 12 - 0 5.1 6.2 - -8 5.1 6.2 - -8 5.1 9.2 - 1.83697019872e-16 5.1 9.2 + 0 5.2 6.4 + -8 5.2 6.4 + -8 5.2 9.4 + 1.83697019872e-16 5.2 9.4 ceil_mat polygon trans.14.wall.7 0 0 12 - 1.83697019872e-16 5.1 9.2 - -8 5.1 9.2 - -8 10.1 9.2 - 1.83697019872e-16 10.1 9.2 + 1.83697019872e-16 5.2 9.4 + -8 5.2 9.4 + -8 10.2 9.4 + 1.83697019872e-16 10.2 9.4 wall_mat polygon trans.14.wall.8 0 0 12 - 1.83697019872e-16 10.1 9.2 - -8 10.1 9.2 - -8 10.1 6.2 - 0 10.1 6.2 + 1.83697019872e-16 10.2 9.4 + -8 10.2 9.4 + -8 10.2 6.4 + 0 10.2 6.4 floor_mat polygon trans.14.wall.9 0 0 12 - 0 10.1 6.2 - -8 10.1 6.2 - -8 5.1 6.2 - 0 5.1 6.2 + 0 10.2 6.4 + -8 10.2 6.4 + -8 5.2 6.4 + 0 5.2 6.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Rectangular opening cut in end wall +# xform -ry -90 -t -8 0 0 +# genprism wall_mat end_wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 1 1 2 1 2 4 1 4 1 1 -l 0 0 .2 -c wall_mat polygon trans.14.end_wall.b 0 0 30 - -8 5 6.1 - -8 10.2 6.1 - -8 10.2 9.3 - -8 5 9.3 - -8 5 6.1 - -8 6.1 7.2 - -8 6.1 8.2 - -8 9.1 8.2 - -8 9.1 7.2 - -8 6.1 7.2 + -8 5.1 6.3 + -8 10.3 6.3 + -8 10.3 9.5 + -8 5.1 9.5 + -8 5.1 6.3 + -8 6.2 7.4 + -8 6.2 8.4 + -8 9.2 8.4 + -8 9.2 7.4 + -8 6.2 7.4 wall_mat polygon trans.14.end_wall.t 0 0 30 - -8.2 6.1 7.2 - -8.2 9.1 7.2 - -8.2 9.1 8.2 - -8.2 6.1 8.2 - -8.2 6.1 7.2 - -8.2 5 6.1 - -8.2 5 9.3 - -8.2 10.2 9.3 - -8.2 10.2 6.1 - -8.2 5 6.1 + -8.2 6.2 7.4 + -8.2 9.2 7.4 + -8.2 9.2 8.4 + -8.2 6.2 8.4 + -8.2 6.2 7.4 + -8.2 5.1 6.3 + -8.2 5.1 9.5 + -8.2 10.3 9.5 + -8.2 10.3 6.3 + -8.2 5.1 6.3 wall_mat polygon trans.14.end_wall.1 0 0 12 - -8 5 6.1 - -8.2 5 6.1 - -8.2 10.2 6.1 - -8 10.2 6.1 + -8 5.1 6.3 + -8.2 5.1 6.3 + -8.2 10.3 6.3 + -8 10.3 6.3 wall_mat polygon trans.14.end_wall.2 0 0 12 - -8 10.2 6.1 - -8.2 10.2 6.1 - -8.2 10.2 9.3 - -8 10.2 9.3 + -8 10.3 6.3 + -8.2 10.3 6.3 + -8.2 10.3 9.5 + -8 10.3 9.5 wall_mat polygon trans.14.end_wall.3 0 0 12 - -8 10.2 9.3 - -8.2 10.2 9.3 - -8.2 5 9.3 - -8 5 9.3 + -8 10.3 9.5 + -8.2 10.3 9.5 + -8.2 5.1 9.5 + -8 5.1 9.5 wall_mat polygon trans.14.end_wall.4 0 0 12 - -8 5 9.3 - -8.2 5 9.3 - -8.2 5 6.1 - -8 5 6.1 + -8 5.1 9.5 + -8.2 5.1 9.5 + -8.2 5.1 6.3 + -8 5.1 6.3 wall_mat polygon trans.14.end_wall.5 0 0 12 - -8 5 6.1 - -8.2 5 6.1 - -8.2 6.1 7.2 - -8 6.1 7.2 + -8 5.1 6.3 + -8.2 5.1 6.3 + -8.2 6.2 7.4 + -8 6.2 7.4 wall_mat polygon trans.14.end_wall.6 0 0 12 - -8 6.1 7.2 - -8.2 6.1 7.2 - -8.2 6.1 8.2 - -8 6.1 8.2 + -8 6.2 7.4 + -8.2 6.2 7.4 + -8.2 6.2 8.4 + -8 6.2 8.4 wall_mat polygon trans.14.end_wall.7 0 0 12 - -8 6.1 8.2 - -8.2 6.1 8.2 - -8.2 9.1 8.2 - -8 9.1 8.2 + -8 6.2 8.4 + -8.2 6.2 8.4 + -8.2 9.2 8.4 + -8 9.2 8.4 wall_mat polygon trans.14.end_wall.8 0 0 12 - -8 9.1 8.2 - -8.2 9.1 8.2 - -8.2 9.1 7.2 - -8 9.1 7.2 + -8 9.2 8.4 + -8.2 9.2 8.4 + -8.2 9.2 7.4 + -8 9.2 7.4 wall_mat polygon trans.14.end_wall.9 0 0 12 - -8 9.1 7.2 - -8.2 9.1 7.2 - -8.2 6.1 7.2 - -8 6.1 7.2 + -8 9.2 7.4 + -8.2 9.2 7.4 + -8.2 6.2 7.4 + -8 6.2 7.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Four balls made of plastic2, metal2, plasfunc, and metfunc +# Mixtext used to label each +# void plastic white_mat 0 @@ -3101,35 +3550,35 @@ void plastic black_shiny 5 0.01 0.01 0.01 0.04 0.05 void plastic2 plas2_mat -10 0 0 1 . -i 1 -t 0 5.1 6.2 +10 0 0 1 . -i 1 -t 0 5.2 6.4 0 6 0.7 0.2 0.8 0.08 0.2 0.08 void plasfunc plasfunc_mat -8 absdf aniso.cal -i 1 -t 0 5.1 6.2 +8 absdf aniso.cal -i 1 -t 0 5.2 6.4 0 9 0.7 0.2 0.8 0.08 0.2 0.08 0 0 1 void metal2 met2_mat -10 0 1 0 . -i 1 -t 0 5.1 6.2 +10 0 1 0 . -i 1 -t 0 5.2 6.4 0 6 0.1 0.7 0.3 0.9 0.1 0.03 void metfunc metfunc_mat -8 absdf aniso.cal -i 1 -t 0 5.1 6.2 +8 absdf aniso.cal -i 1 -t 0 5.2 6.4 0 9 0.1 0.7 0.3 0.9 0.1 0.03 0 1 0 plas2_mat sphere trans.14.plas2_ball 0 0 -4 -4 7.1 8.2 0.4 +4 -4 7.2 8.4 0.4 void mixtext plas2_text 5 black_shiny void helvet.fnt . plastic2 0 10 - -4 6.15 8.25 + -4 6.25 8.45 0 0.05 0 0 0 -0.1 -0.2 @@ -3138,21 +3587,21 @@ plas2_text polygon trans.14.plas2_label 0 0 12 - -4 6.6 8.3 - -4 6.6 8.1 - -4 6.1 8.1 - -4 6.1 8.3 + -4 6.7 8.5 + -4 6.7 8.3 + -4 6.2 8.3 + -4 6.2 8.5 plasfunc_mat sphere trans.14.plasfunc_ball 0 0 -4 -4 8.1 8.2 0.4 +4 -4 8.2 8.4 0.4 void mixtext plasf_text 5 void white_mat helvet.fnt . plasfunc 0 10 - -4 8.65 8.25 + -4 8.75 8.45 0 0.05 0 0 0 -0.1 -0.2 @@ -3161,21 +3610,21 @@ plasf_text polygon trans.14.plasf_label 0 0 12 - -4 9.1 8.3 - -4 9.1 8.1 - -4 8.6 8.1 - -4 8.6 8.3 + -4 9.2 8.5 + -4 9.2 8.3 + -4 8.7 8.3 + -4 8.7 8.5 met2_mat sphere trans.14.met2_ball 0 0 -4 -4 7.1 7.2 0.4 +4 -4 7.2 7.4 0.4 void mixtext met2_text 5 white_mat black_shiny helvet.fnt . metal2 0 10 - -4 6.15 7.25 + -4 6.25 7.45 0 0.05 0 0 0 -0.1 -0.2 @@ -3184,21 +3633,21 @@ met2_text polygon trans.14.met2_label 0 0 12 - -4 6.6 7.3 - -4 6.6 7.1 - -4 6.1 7.1 - -4 6.1 7.3 + -4 6.7 7.5 + -4 6.7 7.3 + -4 6.2 7.3 + -4 6.2 7.5 metfunc_mat sphere trans.14.metfunc_ball 0 0 -4 -4 8.1 7.2 0.4 +4 -4 8.2 7.4 0.4 void mixtext metf_text 5 black_shiny white_mat helvet.fnt . metfunc 0 10 - -4 8.65 7.25 + -4 8.75 7.45 0 0.05 0 0 0 -0.1 -0.2 @@ -3207,10 +3656,12 @@ metf_text polygon trans.14.metf_label 0 0 12 - -4 9.1 7.3 - -4 9.1 7.1 - -4 8.6 7.1 - -4 8.6 7.3 + -4 9.2 7.5 + -4 9.2 7.3 + -4 8.7 7.3 + -4 8.7 7.5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A pair of spotlights, one pink and one bluish void spotlight pink_spotlight 0 @@ -3222,7 +3673,7 @@ pink_spotlight ring trans.14.pspot 0 0 8 - -2 6.1 8.7 + -2 6.2 8.9 -2.5 1.5 -2 0 0.2 @@ -3236,28 +3687,39 @@ blue_spotlight ring trans.14.bspot 0 0 8 - -2 9.1 8.7 + -2 9.2 8.9 -2.5 -1.5 -2 0 0.2 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# xform -s 0.0253999863 -rz 90 -t -4 2.5 2.999 +# +# Wellmade 2 lamp fixture, model 395-12A-248RS +# +# Dimensions in inches, fixture parallel to y axis, center at origin +# void brightdata lum_dist -19 flatcorr rect_fixture.dat source.cal src_phi4 src_theta -s 0.0253999863 -rz 90 -t -4 2.5 2.999 -i 1 -t 0 5.1 6.2 +19 flatcorr rect_fixture.dat source.cal src_phi4 src_theta -s 0.0253999863 -rz 90 -t -4 2.5 2.999 -i 1 -t 0 5.2 6.4 0 0 +# this is scaled by 1/area (SI) lum_dist light lum_bright 0 0 3 20 20 20 +# 3 1.55 1.55 1.55 lum_bright polygon trans.14.luminaire 0 0 12 - -3.42215031167 7.32695014727 9.199 - -4.57784968833 7.32695014728 9.199 - -4.57784968833 7.87304985273 9.199 - -3.42215031167 7.87304985272 9.199 + -3.42215031167 7.42695014727 9.399 + -4.57784968833 7.42695014728 9.399 + -4.57784968833 7.97304985273 9.399 + -3.42215031167 7.97304985272 9.399 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A yellowish trans material in our window void trans yellow_trans 0 @@ -3268,226 +3730,245 @@ yellow_trans polygon trans.14.yellow_diffuser 0 0 12 - -8.1 5.1 6.2 - -8.1 10.1 6.2 - -8.1 10.1 9.2 - -8.1 5.1 9.2 + -8.1 5.2 6.4 + -8.1 10.2 6.4 + -8.1 10.2 9.4 + -8.1 5.2 9.4 +# xform -n trans2.15 -t 0 10.4 6.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c black_outside polygon trans2.15.wall.b 0 0 30 - -6.12323399574e-18 10.1 6.1 - -6.12323399574e-18 15.3 6.1 - 1.89820253868e-16 15.3 9.3 - 1.89820253868e-16 10.1 9.3 - -6.12323399574e-18 10.1 6.1 - 0 10.2 6.2 - 1.83697019872e-16 10.2 9.2 - 1.83697019872e-16 15.2 9.2 - 0 15.2 6.2 - 0 10.2 6.2 + -6.12323399574e-18 10.3 6.3 + -6.12323399574e-18 15.5 6.3 + 1.89820253868e-16 15.5 9.5 + 1.89820253868e-16 10.3 9.5 + -6.12323399574e-18 10.3 6.3 + 0 10.4 6.4 + 1.83697019872e-16 10.4 9.4 + 1.83697019872e-16 15.4 9.4 + 0 15.4 6.4 + 0 10.4 6.4 black_outside polygon trans2.15.wall.t 0 0 30 - -8 10.2 6.2 - -8 15.2 6.2 - -8 15.2 9.2 - -8 10.2 9.2 - -8 10.2 6.2 - -8 10.1 6.1 - -8 10.1 9.3 - -8 15.3 9.3 - -8 15.3 6.1 - -8 10.1 6.1 + -8 10.4 6.4 + -8 15.4 6.4 + -8 15.4 9.4 + -8 10.4 9.4 + -8 10.4 6.4 + -8 10.3 6.3 + -8 10.3 9.5 + -8 15.5 9.5 + -8 15.5 6.3 + -8 10.3 6.3 black_outside polygon trans2.15.wall.1 0 0 12 - -6.12323399574e-18 10.1 6.1 - -8 10.1 6.1 - -8 15.3 6.1 - -6.12323399574e-18 15.3 6.1 + -6.12323399574e-18 10.3 6.3 + -8 10.3 6.3 + -8 15.5 6.3 + -6.12323399574e-18 15.5 6.3 black_outside polygon trans2.15.wall.2 0 0 12 - -6.12323399574e-18 15.3 6.1 - -8 15.3 6.1 - -8 15.3 9.3 - 1.89820253868e-16 15.3 9.3 + -6.12323399574e-18 15.5 6.3 + -8 15.5 6.3 + -8 15.5 9.5 + 1.89820253868e-16 15.5 9.5 black_outside polygon trans2.15.wall.3 0 0 12 - 1.89820253868e-16 15.3 9.3 - -8 15.3 9.3 - -8 10.1 9.3 - 1.89820253868e-16 10.1 9.3 + 1.89820253868e-16 15.5 9.5 + -8 15.5 9.5 + -8 10.3 9.5 + 1.89820253868e-16 10.3 9.5 black_outside polygon trans2.15.wall.4 0 0 12 - 1.89820253868e-16 10.1 9.3 - -8 10.1 9.3 - -8 10.1 6.1 - -6.12323399574e-18 10.1 6.1 + 1.89820253868e-16 10.3 9.5 + -8 10.3 9.5 + -8 10.3 6.3 + -6.12323399574e-18 10.3 6.3 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 wall_mat polygon trans2.15.wall.6 0 0 12 - 0 10.2 6.2 - -8 10.2 6.2 - -8 10.2 9.2 - 1.83697019872e-16 10.2 9.2 + 0 10.4 6.4 + -8 10.4 6.4 + -8 10.4 9.4 + 1.83697019872e-16 10.4 9.4 ceil_mat polygon trans2.15.wall.7 0 0 12 - 1.83697019872e-16 10.2 9.2 - -8 10.2 9.2 - -8 15.2 9.2 - 1.83697019872e-16 15.2 9.2 + 1.83697019872e-16 10.4 9.4 + -8 10.4 9.4 + -8 15.4 9.4 + 1.83697019872e-16 15.4 9.4 wall_mat polygon trans2.15.wall.8 0 0 12 - 1.83697019872e-16 15.2 9.2 - -8 15.2 9.2 - -8 15.2 6.2 - 0 15.2 6.2 + 1.83697019872e-16 15.4 9.4 + -8 15.4 9.4 + -8 15.4 6.4 + 0 15.4 6.4 floor_mat polygon trans2.15.wall.9 0 0 12 - 0 15.2 6.2 - -8 15.2 6.2 - -8 10.2 6.2 - 0 10.2 6.2 + 0 15.4 6.4 + -8 15.4 6.4 + -8 10.4 6.4 + 0 10.4 6.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Rectangular opening cut in end wall +# xform -ry -90 -t -8 0 0 +# genprism wall_mat end_wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 1 1 2 1 2 4 1 4 1 1 -l 0 0 .2 -c wall_mat polygon trans2.15.end_wall.b 0 0 30 - -8 10.1 6.1 - -8 15.3 6.1 - -8 15.3 9.3 - -8 10.1 9.3 - -8 10.1 6.1 - -8 11.2 7.2 - -8 11.2 8.2 - -8 14.2 8.2 - -8 14.2 7.2 - -8 11.2 7.2 + -8 10.3 6.3 + -8 15.5 6.3 + -8 15.5 9.5 + -8 10.3 9.5 + -8 10.3 6.3 + -8 11.4 7.4 + -8 11.4 8.4 + -8 14.4 8.4 + -8 14.4 7.4 + -8 11.4 7.4 wall_mat polygon trans2.15.end_wall.t 0 0 30 - -8.2 11.2 7.2 - -8.2 14.2 7.2 - -8.2 14.2 8.2 - -8.2 11.2 8.2 - -8.2 11.2 7.2 - -8.2 10.1 6.1 - -8.2 10.1 9.3 - -8.2 15.3 9.3 - -8.2 15.3 6.1 - -8.2 10.1 6.1 + -8.2 11.4 7.4 + -8.2 14.4 7.4 + -8.2 14.4 8.4 + -8.2 11.4 8.4 + -8.2 11.4 7.4 + -8.2 10.3 6.3 + -8.2 10.3 9.5 + -8.2 15.5 9.5 + -8.2 15.5 6.3 + -8.2 10.3 6.3 wall_mat polygon trans2.15.end_wall.1 0 0 12 - -8 10.1 6.1 - -8.2 10.1 6.1 - -8.2 15.3 6.1 - -8 15.3 6.1 + -8 10.3 6.3 + -8.2 10.3 6.3 + -8.2 15.5 6.3 + -8 15.5 6.3 wall_mat polygon trans2.15.end_wall.2 0 0 12 - -8 15.3 6.1 - -8.2 15.3 6.1 - -8.2 15.3 9.3 - -8 15.3 9.3 + -8 15.5 6.3 + -8.2 15.5 6.3 + -8.2 15.5 9.5 + -8 15.5 9.5 wall_mat polygon trans2.15.end_wall.3 0 0 12 - -8 15.3 9.3 - -8.2 15.3 9.3 - -8.2 10.1 9.3 - -8 10.1 9.3 + -8 15.5 9.5 + -8.2 15.5 9.5 + -8.2 10.3 9.5 + -8 10.3 9.5 wall_mat polygon trans2.15.end_wall.4 0 0 12 - -8 10.1 9.3 - -8.2 10.1 9.3 - -8.2 10.1 6.1 - -8 10.1 6.1 + -8 10.3 9.5 + -8.2 10.3 9.5 + -8.2 10.3 6.3 + -8 10.3 6.3 wall_mat polygon trans2.15.end_wall.5 0 0 12 - -8 10.1 6.1 - -8.2 10.1 6.1 - -8.2 11.2 7.2 - -8 11.2 7.2 + -8 10.3 6.3 + -8.2 10.3 6.3 + -8.2 11.4 7.4 + -8 11.4 7.4 wall_mat polygon trans2.15.end_wall.6 0 0 12 - -8 11.2 7.2 - -8.2 11.2 7.2 - -8.2 11.2 8.2 - -8 11.2 8.2 + -8 11.4 7.4 + -8.2 11.4 7.4 + -8.2 11.4 8.4 + -8 11.4 8.4 wall_mat polygon trans2.15.end_wall.7 0 0 12 - -8 11.2 8.2 - -8.2 11.2 8.2 - -8.2 14.2 8.2 - -8 14.2 8.2 + -8 11.4 8.4 + -8.2 11.4 8.4 + -8.2 14.4 8.4 + -8 14.4 8.4 wall_mat polygon trans2.15.end_wall.8 0 0 12 - -8 14.2 8.2 - -8.2 14.2 8.2 - -8.2 14.2 7.2 - -8 14.2 7.2 + -8 14.4 8.4 + -8.2 14.4 8.4 + -8.2 14.4 7.4 + -8 14.4 7.4 wall_mat polygon trans2.15.end_wall.9 0 0 12 - -8 14.2 7.2 - -8.2 14.2 7.2 - -8.2 11.2 7.2 - -8 11.2 7.2 + -8 14.4 7.4 + -8.2 14.4 7.4 + -8.2 11.4 7.4 + -8 11.4 7.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Test of cylinders, tubes, and BRTDfunc material void BRTDfunc brtd_mat -16 .1 .1 .1+if(Rdot-.8,0,.7) .1+if(RdotP-.8,.7,0) .1 .1 0 0 0 . -i 1 -t 0 10.2 6.2 +16 .1 .1 .1+if(Rdot-.8,0,.7) .1+if(RdotP-.8,.7,0) .1 .1 0 0 0 . -i 1 -t 0 10.4 6.4 0 9 0.01 0.01 0.01 0.01 0.1 0.01 0.05 0.05 0.05 @@ -3495,28 +3976,31 @@ brtd_mat cylinder trans2.15.cyl1 0 0 7 - -4.2 12.7 7.7 - -3.8 12.7 7.7 + -4.2 12.9 7.9 + -3.8 12.9 7.9 0.5 brtd_mat tube trans2.15.tube2 0 0 7 - -4 12.5 7.7 - -4 12.9 7.7 + -4 12.7 7.9 + -4 13.1 7.9 0.45 brtd_mat cylinder trans2.15.cyl3 0 0 7 - -4 12.7 7.5 - -4 12.7 7.9 + -4 12.9 7.7 + -4 12.9 8.1 0.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A trans2 window to turn into an llum with mkillum +#@mkillum l- f=trans2_ill c=a d=200 s=256 i=void void trans2 trans2_mat -10 0 0 1 . -i 1 -t 0 10.2 6.2 +10 0 0 1 . -i 1 -t 0 10.4 6.4 0 8 0.9 0.9 0.9 0.05 0.1 0.02 0.8 0.9 @@ -3524,7 +4008,9728 @@ trans2_mat polygon trans2.15.tfunc_window 0 0 12 - -8.1 11.2 7.2 - -8.1 14.2 7.2 - -8.1 14.2 8.2 - -8.1 11.2 8.2 + -8.1 11.4 7.4 + -8.1 14.4 7.4 + -8.1 14.4 8.4 + -8.1 11.4 8.4 + +void polygon trans2.15.tfunc_window +0 +0 +12 + -8 11.4 7.4 + -8 14.4 7.4 + -8 14.4 8.4 + -8 11.4 8.4 +# xform -n patterns.16 -t 0 15.6 6.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A set of 9 patterned materials +# + +void brightfunc noisepat +8 "1 - .35*(1+fnoise3(3*Px,3*Py,3*Pz))" . -i 1 -t 0 15.6 6.4 +0 +0 + +noisepat plastic base_mat +0 +0 +5 0.8 0.8 0.8 0.03 0.08 + +inherit alias base_mat1 + base_mat + +void colortext textpat +3 helvet.fnt . Color +0 +16 + -5.6 16.35 6.9 + 0 0.08 0 + 0.2 0 0 + 1 0.1 0.1 + 0.1 0.1 1 + -0.2 + +textpat alias mat1 + base_mat + +void alias mat3 + base_mat +# Intentionally redefining base_mat + +void plastic base_mat +0 +0 +5 0.8 0.7 0.3 0 0 + +void brighttext textpat +3 helvet.fnt . Black +0 +11 + -4.1 16.35 6.9 + 0 0.08 0 + 0.2 0 0 + 0.01 1 + +textpat alias mat4 + base_mat + +void brighttext textpat +2 helvet.fnt test.txt +0 +12 + -4.2 17.9 6.9 + 0 0.025 0 + 0.07 0 0 + 1 0.01 0.15 + +textpat alias tempmat + base_mat + +inherit alias mat5 + tempmat + +void colortext textpat2 +2 helvet.fnt test.txt +0 +15 + -4.2 19.4 6.9 + 0 0.025 0 + 0.07 0 0 + 0.1 0.7 0.5 + 1 1 1 + +textpat2 alias mat6 + base_mat1 + +void colorfunc cfpat +10 .5+.2*noise3x(5*Px,5*Py,5*Pz) .5+.2*noise3y(5*Px,5*Py,5*Pz) .5+.2*noise3z(5*Px,5*Py,5*Pz) . -i 1 -t 0 15.6 6.4 +0 +0 + +cfpat alias mat7 + base_mat1 + +noisepat alias mat8 + base_mat + +cfpat alias mat9 + base_mat + +inherit alias mat2 + base_mat1 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c + +black_outside polygon patterns.16.wall.b +0 +0 +30 + -6.12323399574e-18 15.5 6.3 + -6.12323399574e-18 20.7 6.3 + 1.89820253868e-16 20.7 9.5 + 1.89820253868e-16 15.5 9.5 + -6.12323399574e-18 15.5 6.3 + 0 15.6 6.4 + 1.83697019872e-16 15.6 9.4 + 1.83697019872e-16 20.6 9.4 + 0 20.6 6.4 + 0 15.6 6.4 + +black_outside polygon patterns.16.wall.t +0 +0 +30 + -8 15.6 6.4 + -8 20.6 6.4 + -8 20.6 9.4 + -8 15.6 9.4 + -8 15.6 6.4 + -8 15.5 6.3 + -8 15.5 9.5 + -8 20.7 9.5 + -8 20.7 6.3 + -8 15.5 6.3 + +black_outside polygon patterns.16.wall.1 +0 +0 +12 + -6.12323399574e-18 15.5 6.3 + -8 15.5 6.3 + -8 20.7 6.3 + -6.12323399574e-18 20.7 6.3 + +black_outside polygon patterns.16.wall.2 +0 +0 +12 + -6.12323399574e-18 20.7 6.3 + -8 20.7 6.3 + -8 20.7 9.5 + 1.89820253868e-16 20.7 9.5 + +black_outside polygon patterns.16.wall.3 +0 +0 +12 + 1.89820253868e-16 20.7 9.5 + -8 20.7 9.5 + -8 15.5 9.5 + 1.89820253868e-16 15.5 9.5 + +black_outside polygon patterns.16.wall.4 +0 +0 +12 + 1.89820253868e-16 15.5 9.5 + -8 15.5 9.5 + -8 15.5 6.3 + -6.12323399574e-18 15.5 6.3 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 + +wall_mat polygon patterns.16.wall.6 +0 +0 +12 + 0 15.6 6.4 + -8 15.6 6.4 + -8 15.6 9.4 + 1.83697019872e-16 15.6 9.4 + +ceil_mat polygon patterns.16.wall.7 +0 +0 +12 + 1.83697019872e-16 15.6 9.4 + -8 15.6 9.4 + -8 20.6 9.4 + 1.83697019872e-16 20.6 9.4 + +wall_mat polygon patterns.16.wall.8 +0 +0 +12 + 1.83697019872e-16 20.6 9.4 + -8 20.6 9.4 + -8 20.6 6.4 + 0 20.6 6.4 + +floor_mat polygon patterns.16.wall.9 +0 +0 +12 + 0 20.6 6.4 + -8 20.6 6.4 + -8 15.6 6.4 + 0 15.6 6.4 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A closed wall for the end cap of our diorama +# xform -t -8.2 -.1 -.1 +# genbox wall_mat end_wall .2 5.2 3.2 + +wall_mat polygon patterns.16.end_wall.1540 +0 +0 +12 + -8 15.5 6.3 + -8 15.5 9.5 + -8.2 15.5 9.5 + -8.2 15.5 6.3 + +wall_mat polygon patterns.16.end_wall.4620 +0 +0 +12 + -8.2 15.5 9.5 + -8.2 20.7 9.5 + -8.2 20.7 6.3 + -8.2 15.5 6.3 + +wall_mat polygon patterns.16.end_wall.2310 +0 +0 +12 + -8.2 20.7 6.3 + -8 20.7 6.3 + -8 15.5 6.3 + -8.2 15.5 6.3 + +wall_mat polygon patterns.16.end_wall.3267 +0 +0 +12 + -8 20.7 6.3 + -8.2 20.7 6.3 + -8.2 20.7 9.5 + -8 20.7 9.5 + +wall_mat polygon patterns.16.end_wall.5137 +0 +0 +12 + -8 15.5 9.5 + -8 15.5 6.3 + -8 20.7 6.3 + -8 20.7 9.5 + +wall_mat polygon patterns.16.end_wall.6457 +0 +0 +12 + -8.2 20.7 9.5 + -8.2 15.5 9.5 + -8 15.5 9.5 + -8 20.7 9.5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A set of 9 disks to be painted in various modes +# +# xform -m mat1 -n disk1 -t -5.5 1 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat1 cone patterns.16.disk1.seg.1 +0 +0 +8 + -5.5 16.6 7.42942286341 + -5.5 16.6 7.43367146941 + 0.45 0.442559632181 + +mat1 cone patterns.16.disk1.seg.2 +0 +0 +8 + -5.5 16.6 7.43367146941 + -5.5 16.6 7.43784905182 + 0.442559632181 0.435079155496 + +mat1 cone patterns.16.disk1.seg.3 +0 +0 +8 + -5.5 16.6 7.43784905182 + -5.5 16.6 7.44195523203 + 0.435079155496 0.427559247895 + +mat1 cone patterns.16.disk1.seg.4 +0 +0 +8 + -5.5 16.6 7.44195523203 + -5.5 16.6 7.4459896379 + 0.427559247895 0.420000590903 + +mat1 cone patterns.16.disk1.seg.5 +0 +0 +8 + -5.5 16.6 7.4459896379 + -5.5 16.6 7.44995190379 + 0.420000590903 0.412403869555 + +mat1 cone patterns.16.disk1.seg.6 +0 +0 +8 + -5.5 16.6 7.44995190379 + -5.5 16.6 7.45384167061 + 0.412403869555 0.404769772336 + +mat1 cone patterns.16.disk1.seg.7 +0 +0 +8 + -5.5 16.6 7.45384167061 + -5.5 16.6 7.45765858582 + 0.404769772336 0.397098991119 + +mat1 cone patterns.16.disk1.seg.8 +0 +0 +8 + -5.5 16.6 7.45765858582 + -5.5 16.6 7.46140230351 + 0.397098991119 0.389392221102 + +mat1 cone patterns.16.disk1.seg.9 +0 +0 +8 + -5.5 16.6 7.46140230351 + -5.5 16.6 7.46507248439 + 0.389392221102 0.381650160744 + +mat1 cone patterns.16.disk1.seg.10 +0 +0 +8 + -5.5 16.6 7.46507248439 + -5.5 16.6 7.46866879582 + 0.381650160744 0.373873511702 + +mat1 cone patterns.16.disk1.seg.11 +0 +0 +8 + -5.5 16.6 7.46866879582 + -5.5 16.6 7.47219091188 + 0.373873511702 0.366062978768 + +mat1 cone patterns.16.disk1.seg.12 +0 +0 +8 + -5.5 16.6 7.47219091188 + -5.5 16.6 7.47563851336 + 0.366062978768 0.358219269806 + +mat1 cone patterns.16.disk1.seg.13 +0 +0 +8 + -5.5 16.6 7.47563851336 + -5.5 16.6 7.4790112878 + 0.358219269806 0.350343095686 + +mat1 cone patterns.16.disk1.seg.14 +0 +0 +8 + -5.5 16.6 7.4790112878 + -5.5 16.6 7.48230892954 + 0.350343095686 0.342435170218 + +mat1 cone patterns.16.disk1.seg.15 +0 +0 +8 + -5.5 16.6 7.48230892954 + -5.5 16.6 7.48553113971 + 0.342435170218 0.334496210094 + +mat1 cone patterns.16.disk1.seg.16 +0 +0 +8 + -5.5 16.6 7.48553113971 + -5.5 16.6 7.48867762629 + 0.334496210094 0.326526934816 + +mat1 cone patterns.16.disk1.seg.17 +0 +0 +8 + -5.5 16.6 7.48867762629 + -5.5 16.6 7.49174810411 + 0.326526934816 0.318528066632 + +mat1 cone patterns.16.disk1.seg.18 +0 +0 +8 + -5.5 16.6 7.49174810411 + -5.5 16.6 7.49474229489 + 0.318528066632 0.310500330475 + +mat1 cone patterns.16.disk1.seg.19 +0 +0 +8 + -5.5 16.6 7.49474229489 + -5.5 16.6 7.49765992728 + 0.310500330475 0.302444453894 + +mat1 cone patterns.16.disk1.seg.20 +0 +0 +8 + -5.5 16.6 7.49765992728 + -5.5 16.6 7.50050073684 + 0.302444453894 0.294361166986 + +mat1 cone patterns.16.disk1.seg.21 +0 +0 +8 + -5.5 16.6 7.50050073684 + -5.5 16.6 7.50326446613 + 0.294361166986 0.286251202333 + +mat1 cone patterns.16.disk1.seg.22 +0 +0 +8 + -5.5 16.6 7.50326446613 + -5.5 16.6 7.50595086467 + 0.286251202333 0.278115294937 + +mat1 cone patterns.16.disk1.seg.23 +0 +0 +8 + -5.5 16.6 7.50595086467 + -5.5 16.6 7.50855968898 + 0.278115294937 0.269954182149 + +mat1 cone patterns.16.disk1.seg.24 +0 +0 +8 + -5.5 16.6 7.50855968898 + -5.5 16.6 7.51109070264 + 0.269954182149 0.261768603605 + +mat1 cone patterns.16.disk1.seg.25 +0 +0 +8 + -5.5 16.6 7.51109070264 + -5.5 16.6 7.51354367625 + 0.261768603605 0.253559301157 + +mat1 cone patterns.16.disk1.seg.26 +0 +0 +8 + -5.5 16.6 7.51354367625 + -5.5 16.6 7.51591838752 + 0.253559301157 0.24532701881 + +mat1 cone patterns.16.disk1.seg.27 +0 +0 +8 + -5.5 16.6 7.51591838752 + -5.5 16.6 7.51821462121 + 0.24532701881 0.237072502648 + +mat1 cone patterns.16.disk1.seg.28 +0 +0 +8 + -5.5 16.6 7.51821462121 + -5.5 16.6 7.52043216923 + 0.237072502648 0.228796500774 + +mat1 cone patterns.16.disk1.seg.29 +0 +0 +8 + -5.5 16.6 7.52043216923 + -5.5 16.6 7.5225708306 + 0.228796500774 0.220499763235 + +mat1 cone patterns.16.disk1.seg.30 +0 +0 +8 + -5.5 16.6 7.5225708306 + -5.5 16.6 7.52463041149 + 0.220499763235 0.212183041958 + +mat1 cone patterns.16.disk1.seg.31 +0 +0 +8 + -5.5 16.6 7.52463041149 + -5.5 16.6 7.52661072525 + 0.212183041958 0.203847090683 + +mat1 cone patterns.16.disk1.seg.32 +0 +0 +8 + -5.5 16.6 7.52661072525 + -5.5 16.6 7.5285115924 + 0.203847090683 0.19549266489 + +mat1 cone patterns.16.disk1.seg.33 +0 +0 +8 + -5.5 16.6 7.5285115924 + -5.5 16.6 7.53033284066 + 0.19549266489 0.187120521736 + +mat1 cone patterns.16.disk1.seg.34 +0 +0 +8 + -5.5 16.6 7.53033284066 + -5.5 16.6 7.53207430498 + 0.187120521736 0.178731419981 + +mat1 cone patterns.16.disk1.seg.35 +0 +0 +8 + -5.5 16.6 7.53207430498 + -5.5 16.6 7.53373582754 + 0.178731419981 0.170326119924 + +mat1 cone patterns.16.disk1.seg.36 +0 +0 +8 + -5.5 16.6 7.53373582754 + -5.5 16.6 7.53531725774 + 0.170326119924 0.161905383332 + +mat1 cone patterns.16.disk1.seg.37 +0 +0 +8 + -5.5 16.6 7.53531725774 + -5.5 16.6 7.53681845226 + 0.161905383332 0.153469973369 + +mat1 cone patterns.16.disk1.seg.38 +0 +0 +8 + -5.5 16.6 7.53681845226 + -5.5 16.6 7.53823927506 + 0.153469973369 0.145020654532 + +mat1 cone patterns.16.disk1.seg.39 +0 +0 +8 + -5.5 16.6 7.53823927506 + -5.5 16.6 7.53957959736 + 0.145020654532 0.136558192575 + +mat1 cone patterns.16.disk1.seg.40 +0 +0 +8 + -5.5 16.6 7.53957959736 + -5.5 16.6 7.54083929769 + 0.136558192575 0.128083354446 + +mat1 cone patterns.16.disk1.seg.41 +0 +0 +8 + -5.5 16.6 7.54083929769 + -5.5 16.6 7.54201826189 + 0.128083354446 0.119596908213 + +mat1 cone patterns.16.disk1.seg.42 +0 +0 +8 + -5.5 16.6 7.54201826189 + -5.5 16.6 7.5431163831 + 0.119596908213 0.111099622997 + +mat1 cone patterns.16.disk1.seg.43 +0 +0 +8 + -5.5 16.6 7.5431163831 + -5.5 16.6 7.54413356181 + 0.111099622997 0.102592268901 + +mat1 cone patterns.16.disk1.seg.44 +0 +0 +8 + -5.5 16.6 7.54413356181 + -5.5 16.6 7.54506970583 + 0.102592268901 0.0940756169409 + +mat1 cone patterns.16.disk1.seg.45 +0 +0 +8 + -5.5 16.6 7.54506970583 + -5.5 16.6 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat1 cone patterns.16.disk1.seg.46 +0 +0 +8 + -5.5 16.6 7.54592473032 + -5.5 16.6 7.54669855778 + 0.0855504389738 0.077017507631 + +mat1 cone patterns.16.disk1.seg.47 +0 +0 +8 + -5.5 16.6 7.54669855778 + -5.5 16.6 7.54739111808 + 0.077017507631 0.068477596246 + +mat1 cone patterns.16.disk1.seg.48 +0 +0 +8 + -5.5 16.6 7.54739111808 + -5.5 16.6 7.54800234847 + 0.068477596246 0.059931478785 + +mat1 cone patterns.16.disk1.seg.49 +0 +0 +8 + -5.5 16.6 7.54800234847 + -5.5 16.6 7.54853219353 + 0.059931478785 0.0513799297765 + +mat1 cone patterns.16.disk1.seg.50 +0 +0 +8 + -5.5 16.6 7.54853219353 + -5.5 16.6 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat1 cone patterns.16.disk1.seg.51 +0 +0 +8 + -5.5 16.6 7.54898060527 + -5.5 16.6 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat1 cone patterns.16.disk1.seg.52 +0 +0 +8 + -5.5 16.6 7.54934754302 + -5.5 16.6 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat1 cone patterns.16.disk1.seg.53 +0 +0 +8 + -5.5 16.6 7.54963297355 + -5.5 16.6 7.54983687097 + 0.0257004457143 0.017134924593 + +mat1 cone patterns.16.disk1.seg.54 +0 +0 +8 + -5.5 16.6 7.54983687097 + -5.5 16.6 7.54995921682 + 0.017134924593 0.00856785054562 + +mat1 cone patterns.16.disk1.seg.55 +0 +0 +8 + -5.5 16.6 7.54995921682 + -5.5 16.6 7.55 + 0.00856785054562 0 +# xform -m mat2 -n disk2 -t -5.5 2.5 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat2 cone patterns.16.disk2.seg.1 +0 +0 +8 + -5.5 18.1 7.42942286341 + -5.5 18.1 7.43367146941 + 0.45 0.442559632181 + +mat2 cone patterns.16.disk2.seg.2 +0 +0 +8 + -5.5 18.1 7.43367146941 + -5.5 18.1 7.43784905182 + 0.442559632181 0.435079155496 + +mat2 cone patterns.16.disk2.seg.3 +0 +0 +8 + -5.5 18.1 7.43784905182 + -5.5 18.1 7.44195523203 + 0.435079155496 0.427559247895 + +mat2 cone patterns.16.disk2.seg.4 +0 +0 +8 + -5.5 18.1 7.44195523203 + -5.5 18.1 7.4459896379 + 0.427559247895 0.420000590903 + +mat2 cone patterns.16.disk2.seg.5 +0 +0 +8 + -5.5 18.1 7.4459896379 + -5.5 18.1 7.44995190379 + 0.420000590903 0.412403869555 + +mat2 cone patterns.16.disk2.seg.6 +0 +0 +8 + -5.5 18.1 7.44995190379 + -5.5 18.1 7.45384167061 + 0.412403869555 0.404769772336 + +mat2 cone patterns.16.disk2.seg.7 +0 +0 +8 + -5.5 18.1 7.45384167061 + -5.5 18.1 7.45765858582 + 0.404769772336 0.397098991119 + +mat2 cone patterns.16.disk2.seg.8 +0 +0 +8 + -5.5 18.1 7.45765858582 + -5.5 18.1 7.46140230351 + 0.397098991119 0.389392221102 + +mat2 cone patterns.16.disk2.seg.9 +0 +0 +8 + -5.5 18.1 7.46140230351 + -5.5 18.1 7.46507248439 + 0.389392221102 0.381650160744 + +mat2 cone patterns.16.disk2.seg.10 +0 +0 +8 + -5.5 18.1 7.46507248439 + -5.5 18.1 7.46866879582 + 0.381650160744 0.373873511702 + +mat2 cone patterns.16.disk2.seg.11 +0 +0 +8 + -5.5 18.1 7.46866879582 + -5.5 18.1 7.47219091188 + 0.373873511702 0.366062978768 + +mat2 cone patterns.16.disk2.seg.12 +0 +0 +8 + -5.5 18.1 7.47219091188 + -5.5 18.1 7.47563851336 + 0.366062978768 0.358219269806 + +mat2 cone patterns.16.disk2.seg.13 +0 +0 +8 + -5.5 18.1 7.47563851336 + -5.5 18.1 7.4790112878 + 0.358219269806 0.350343095686 + +mat2 cone patterns.16.disk2.seg.14 +0 +0 +8 + -5.5 18.1 7.4790112878 + -5.5 18.1 7.48230892954 + 0.350343095686 0.342435170218 + +mat2 cone patterns.16.disk2.seg.15 +0 +0 +8 + -5.5 18.1 7.48230892954 + -5.5 18.1 7.48553113971 + 0.342435170218 0.334496210094 + +mat2 cone patterns.16.disk2.seg.16 +0 +0 +8 + -5.5 18.1 7.48553113971 + -5.5 18.1 7.48867762629 + 0.334496210094 0.326526934816 + +mat2 cone patterns.16.disk2.seg.17 +0 +0 +8 + -5.5 18.1 7.48867762629 + -5.5 18.1 7.49174810411 + 0.326526934816 0.318528066632 + +mat2 cone patterns.16.disk2.seg.18 +0 +0 +8 + -5.5 18.1 7.49174810411 + -5.5 18.1 7.49474229489 + 0.318528066632 0.310500330475 + +mat2 cone patterns.16.disk2.seg.19 +0 +0 +8 + -5.5 18.1 7.49474229489 + -5.5 18.1 7.49765992728 + 0.310500330475 0.302444453894 + +mat2 cone patterns.16.disk2.seg.20 +0 +0 +8 + -5.5 18.1 7.49765992728 + -5.5 18.1 7.50050073684 + 0.302444453894 0.294361166986 + +mat2 cone patterns.16.disk2.seg.21 +0 +0 +8 + -5.5 18.1 7.50050073684 + -5.5 18.1 7.50326446613 + 0.294361166986 0.286251202333 + +mat2 cone patterns.16.disk2.seg.22 +0 +0 +8 + -5.5 18.1 7.50326446613 + -5.5 18.1 7.50595086467 + 0.286251202333 0.278115294937 + +mat2 cone patterns.16.disk2.seg.23 +0 +0 +8 + -5.5 18.1 7.50595086467 + -5.5 18.1 7.50855968898 + 0.278115294937 0.269954182149 + +mat2 cone patterns.16.disk2.seg.24 +0 +0 +8 + -5.5 18.1 7.50855968898 + -5.5 18.1 7.51109070264 + 0.269954182149 0.261768603605 + +mat2 cone patterns.16.disk2.seg.25 +0 +0 +8 + -5.5 18.1 7.51109070264 + -5.5 18.1 7.51354367625 + 0.261768603605 0.253559301157 + +mat2 cone patterns.16.disk2.seg.26 +0 +0 +8 + -5.5 18.1 7.51354367625 + -5.5 18.1 7.51591838752 + 0.253559301157 0.24532701881 + +mat2 cone patterns.16.disk2.seg.27 +0 +0 +8 + -5.5 18.1 7.51591838752 + -5.5 18.1 7.51821462121 + 0.24532701881 0.237072502648 + +mat2 cone patterns.16.disk2.seg.28 +0 +0 +8 + -5.5 18.1 7.51821462121 + -5.5 18.1 7.52043216923 + 0.237072502648 0.228796500774 + +mat2 cone patterns.16.disk2.seg.29 +0 +0 +8 + -5.5 18.1 7.52043216923 + -5.5 18.1 7.5225708306 + 0.228796500774 0.220499763235 + +mat2 cone patterns.16.disk2.seg.30 +0 +0 +8 + -5.5 18.1 7.5225708306 + -5.5 18.1 7.52463041149 + 0.220499763235 0.212183041958 + +mat2 cone patterns.16.disk2.seg.31 +0 +0 +8 + -5.5 18.1 7.52463041149 + -5.5 18.1 7.52661072525 + 0.212183041958 0.203847090683 + +mat2 cone patterns.16.disk2.seg.32 +0 +0 +8 + -5.5 18.1 7.52661072525 + -5.5 18.1 7.5285115924 + 0.203847090683 0.19549266489 + +mat2 cone patterns.16.disk2.seg.33 +0 +0 +8 + -5.5 18.1 7.5285115924 + -5.5 18.1 7.53033284066 + 0.19549266489 0.187120521736 + +mat2 cone patterns.16.disk2.seg.34 +0 +0 +8 + -5.5 18.1 7.53033284066 + -5.5 18.1 7.53207430498 + 0.187120521736 0.178731419981 + +mat2 cone patterns.16.disk2.seg.35 +0 +0 +8 + -5.5 18.1 7.53207430498 + -5.5 18.1 7.53373582754 + 0.178731419981 0.170326119924 + +mat2 cone patterns.16.disk2.seg.36 +0 +0 +8 + -5.5 18.1 7.53373582754 + -5.5 18.1 7.53531725774 + 0.170326119924 0.161905383332 + +mat2 cone patterns.16.disk2.seg.37 +0 +0 +8 + -5.5 18.1 7.53531725774 + -5.5 18.1 7.53681845226 + 0.161905383332 0.153469973369 + +mat2 cone patterns.16.disk2.seg.38 +0 +0 +8 + -5.5 18.1 7.53681845226 + -5.5 18.1 7.53823927506 + 0.153469973369 0.145020654532 + +mat2 cone patterns.16.disk2.seg.39 +0 +0 +8 + -5.5 18.1 7.53823927506 + -5.5 18.1 7.53957959736 + 0.145020654532 0.136558192575 + +mat2 cone patterns.16.disk2.seg.40 +0 +0 +8 + -5.5 18.1 7.53957959736 + -5.5 18.1 7.54083929769 + 0.136558192575 0.128083354446 + +mat2 cone patterns.16.disk2.seg.41 +0 +0 +8 + -5.5 18.1 7.54083929769 + -5.5 18.1 7.54201826189 + 0.128083354446 0.119596908213 + +mat2 cone patterns.16.disk2.seg.42 +0 +0 +8 + -5.5 18.1 7.54201826189 + -5.5 18.1 7.5431163831 + 0.119596908213 0.111099622997 + +mat2 cone patterns.16.disk2.seg.43 +0 +0 +8 + -5.5 18.1 7.5431163831 + -5.5 18.1 7.54413356181 + 0.111099622997 0.102592268901 + +mat2 cone patterns.16.disk2.seg.44 +0 +0 +8 + -5.5 18.1 7.54413356181 + -5.5 18.1 7.54506970583 + 0.102592268901 0.0940756169409 + +mat2 cone patterns.16.disk2.seg.45 +0 +0 +8 + -5.5 18.1 7.54506970583 + -5.5 18.1 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat2 cone patterns.16.disk2.seg.46 +0 +0 +8 + -5.5 18.1 7.54592473032 + -5.5 18.1 7.54669855778 + 0.0855504389738 0.077017507631 + +mat2 cone patterns.16.disk2.seg.47 +0 +0 +8 + -5.5 18.1 7.54669855778 + -5.5 18.1 7.54739111808 + 0.077017507631 0.068477596246 + +mat2 cone patterns.16.disk2.seg.48 +0 +0 +8 + -5.5 18.1 7.54739111808 + -5.5 18.1 7.54800234847 + 0.068477596246 0.059931478785 + +mat2 cone patterns.16.disk2.seg.49 +0 +0 +8 + -5.5 18.1 7.54800234847 + -5.5 18.1 7.54853219353 + 0.059931478785 0.0513799297765 + +mat2 cone patterns.16.disk2.seg.50 +0 +0 +8 + -5.5 18.1 7.54853219353 + -5.5 18.1 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat2 cone patterns.16.disk2.seg.51 +0 +0 +8 + -5.5 18.1 7.54898060527 + -5.5 18.1 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat2 cone patterns.16.disk2.seg.52 +0 +0 +8 + -5.5 18.1 7.54934754302 + -5.5 18.1 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat2 cone patterns.16.disk2.seg.53 +0 +0 +8 + -5.5 18.1 7.54963297355 + -5.5 18.1 7.54983687097 + 0.0257004457143 0.017134924593 + +mat2 cone patterns.16.disk2.seg.54 +0 +0 +8 + -5.5 18.1 7.54983687097 + -5.5 18.1 7.54995921682 + 0.017134924593 0.00856785054562 + +mat2 cone patterns.16.disk2.seg.55 +0 +0 +8 + -5.5 18.1 7.54995921682 + -5.5 18.1 7.55 + 0.00856785054562 0 +# xform -m mat3 -n disk3 -t -5.5 4 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat3 cone patterns.16.disk3.seg.1 +0 +0 +8 + -5.5 19.6 7.42942286341 + -5.5 19.6 7.43367146941 + 0.45 0.442559632181 + +mat3 cone patterns.16.disk3.seg.2 +0 +0 +8 + -5.5 19.6 7.43367146941 + -5.5 19.6 7.43784905182 + 0.442559632181 0.435079155496 + +mat3 cone patterns.16.disk3.seg.3 +0 +0 +8 + -5.5 19.6 7.43784905182 + -5.5 19.6 7.44195523203 + 0.435079155496 0.427559247895 + +mat3 cone patterns.16.disk3.seg.4 +0 +0 +8 + -5.5 19.6 7.44195523203 + -5.5 19.6 7.4459896379 + 0.427559247895 0.420000590903 + +mat3 cone patterns.16.disk3.seg.5 +0 +0 +8 + -5.5 19.6 7.4459896379 + -5.5 19.6 7.44995190379 + 0.420000590903 0.412403869555 + +mat3 cone patterns.16.disk3.seg.6 +0 +0 +8 + -5.5 19.6 7.44995190379 + -5.5 19.6 7.45384167061 + 0.412403869555 0.404769772336 + +mat3 cone patterns.16.disk3.seg.7 +0 +0 +8 + -5.5 19.6 7.45384167061 + -5.5 19.6 7.45765858582 + 0.404769772336 0.397098991119 + +mat3 cone patterns.16.disk3.seg.8 +0 +0 +8 + -5.5 19.6 7.45765858582 + -5.5 19.6 7.46140230351 + 0.397098991119 0.389392221102 + +mat3 cone patterns.16.disk3.seg.9 +0 +0 +8 + -5.5 19.6 7.46140230351 + -5.5 19.6 7.46507248439 + 0.389392221102 0.381650160744 + +mat3 cone patterns.16.disk3.seg.10 +0 +0 +8 + -5.5 19.6 7.46507248439 + -5.5 19.6 7.46866879582 + 0.381650160744 0.373873511702 + +mat3 cone patterns.16.disk3.seg.11 +0 +0 +8 + -5.5 19.6 7.46866879582 + -5.5 19.6 7.47219091188 + 0.373873511702 0.366062978768 + +mat3 cone patterns.16.disk3.seg.12 +0 +0 +8 + -5.5 19.6 7.47219091188 + -5.5 19.6 7.47563851336 + 0.366062978768 0.358219269806 + +mat3 cone patterns.16.disk3.seg.13 +0 +0 +8 + -5.5 19.6 7.47563851336 + -5.5 19.6 7.4790112878 + 0.358219269806 0.350343095686 + +mat3 cone patterns.16.disk3.seg.14 +0 +0 +8 + -5.5 19.6 7.4790112878 + -5.5 19.6 7.48230892954 + 0.350343095686 0.342435170218 + +mat3 cone patterns.16.disk3.seg.15 +0 +0 +8 + -5.5 19.6 7.48230892954 + -5.5 19.6 7.48553113971 + 0.342435170218 0.334496210094 + +mat3 cone patterns.16.disk3.seg.16 +0 +0 +8 + -5.5 19.6 7.48553113971 + -5.5 19.6 7.48867762629 + 0.334496210094 0.326526934816 + +mat3 cone patterns.16.disk3.seg.17 +0 +0 +8 + -5.5 19.6 7.48867762629 + -5.5 19.6 7.49174810411 + 0.326526934816 0.318528066632 + +mat3 cone patterns.16.disk3.seg.18 +0 +0 +8 + -5.5 19.6 7.49174810411 + -5.5 19.6 7.49474229489 + 0.318528066632 0.310500330475 + +mat3 cone patterns.16.disk3.seg.19 +0 +0 +8 + -5.5 19.6 7.49474229489 + -5.5 19.6 7.49765992728 + 0.310500330475 0.302444453894 + +mat3 cone patterns.16.disk3.seg.20 +0 +0 +8 + -5.5 19.6 7.49765992728 + -5.5 19.6 7.50050073684 + 0.302444453894 0.294361166986 + +mat3 cone patterns.16.disk3.seg.21 +0 +0 +8 + -5.5 19.6 7.50050073684 + -5.5 19.6 7.50326446613 + 0.294361166986 0.286251202333 + +mat3 cone patterns.16.disk3.seg.22 +0 +0 +8 + -5.5 19.6 7.50326446613 + -5.5 19.6 7.50595086467 + 0.286251202333 0.278115294937 + +mat3 cone patterns.16.disk3.seg.23 +0 +0 +8 + -5.5 19.6 7.50595086467 + -5.5 19.6 7.50855968898 + 0.278115294937 0.269954182149 + +mat3 cone patterns.16.disk3.seg.24 +0 +0 +8 + -5.5 19.6 7.50855968898 + -5.5 19.6 7.51109070264 + 0.269954182149 0.261768603605 + +mat3 cone patterns.16.disk3.seg.25 +0 +0 +8 + -5.5 19.6 7.51109070264 + -5.5 19.6 7.51354367625 + 0.261768603605 0.253559301157 + +mat3 cone patterns.16.disk3.seg.26 +0 +0 +8 + -5.5 19.6 7.51354367625 + -5.5 19.6 7.51591838752 + 0.253559301157 0.24532701881 + +mat3 cone patterns.16.disk3.seg.27 +0 +0 +8 + -5.5 19.6 7.51591838752 + -5.5 19.6 7.51821462121 + 0.24532701881 0.237072502648 + +mat3 cone patterns.16.disk3.seg.28 +0 +0 +8 + -5.5 19.6 7.51821462121 + -5.5 19.6 7.52043216923 + 0.237072502648 0.228796500774 + +mat3 cone patterns.16.disk3.seg.29 +0 +0 +8 + -5.5 19.6 7.52043216923 + -5.5 19.6 7.5225708306 + 0.228796500774 0.220499763235 + +mat3 cone patterns.16.disk3.seg.30 +0 +0 +8 + -5.5 19.6 7.5225708306 + -5.5 19.6 7.52463041149 + 0.220499763235 0.212183041958 + +mat3 cone patterns.16.disk3.seg.31 +0 +0 +8 + -5.5 19.6 7.52463041149 + -5.5 19.6 7.52661072525 + 0.212183041958 0.203847090683 + +mat3 cone patterns.16.disk3.seg.32 +0 +0 +8 + -5.5 19.6 7.52661072525 + -5.5 19.6 7.5285115924 + 0.203847090683 0.19549266489 + +mat3 cone patterns.16.disk3.seg.33 +0 +0 +8 + -5.5 19.6 7.5285115924 + -5.5 19.6 7.53033284066 + 0.19549266489 0.187120521736 + +mat3 cone patterns.16.disk3.seg.34 +0 +0 +8 + -5.5 19.6 7.53033284066 + -5.5 19.6 7.53207430498 + 0.187120521736 0.178731419981 + +mat3 cone patterns.16.disk3.seg.35 +0 +0 +8 + -5.5 19.6 7.53207430498 + -5.5 19.6 7.53373582754 + 0.178731419981 0.170326119924 + +mat3 cone patterns.16.disk3.seg.36 +0 +0 +8 + -5.5 19.6 7.53373582754 + -5.5 19.6 7.53531725774 + 0.170326119924 0.161905383332 + +mat3 cone patterns.16.disk3.seg.37 +0 +0 +8 + -5.5 19.6 7.53531725774 + -5.5 19.6 7.53681845226 + 0.161905383332 0.153469973369 + +mat3 cone patterns.16.disk3.seg.38 +0 +0 +8 + -5.5 19.6 7.53681845226 + -5.5 19.6 7.53823927506 + 0.153469973369 0.145020654532 + +mat3 cone patterns.16.disk3.seg.39 +0 +0 +8 + -5.5 19.6 7.53823927506 + -5.5 19.6 7.53957959736 + 0.145020654532 0.136558192575 + +mat3 cone patterns.16.disk3.seg.40 +0 +0 +8 + -5.5 19.6 7.53957959736 + -5.5 19.6 7.54083929769 + 0.136558192575 0.128083354446 + +mat3 cone patterns.16.disk3.seg.41 +0 +0 +8 + -5.5 19.6 7.54083929769 + -5.5 19.6 7.54201826189 + 0.128083354446 0.119596908213 + +mat3 cone patterns.16.disk3.seg.42 +0 +0 +8 + -5.5 19.6 7.54201826189 + -5.5 19.6 7.5431163831 + 0.119596908213 0.111099622997 + +mat3 cone patterns.16.disk3.seg.43 +0 +0 +8 + -5.5 19.6 7.5431163831 + -5.5 19.6 7.54413356181 + 0.111099622997 0.102592268901 + +mat3 cone patterns.16.disk3.seg.44 +0 +0 +8 + -5.5 19.6 7.54413356181 + -5.5 19.6 7.54506970583 + 0.102592268901 0.0940756169409 + +mat3 cone patterns.16.disk3.seg.45 +0 +0 +8 + -5.5 19.6 7.54506970583 + -5.5 19.6 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat3 cone patterns.16.disk3.seg.46 +0 +0 +8 + -5.5 19.6 7.54592473032 + -5.5 19.6 7.54669855778 + 0.0855504389738 0.077017507631 + +mat3 cone patterns.16.disk3.seg.47 +0 +0 +8 + -5.5 19.6 7.54669855778 + -5.5 19.6 7.54739111808 + 0.077017507631 0.068477596246 + +mat3 cone patterns.16.disk3.seg.48 +0 +0 +8 + -5.5 19.6 7.54739111808 + -5.5 19.6 7.54800234847 + 0.068477596246 0.059931478785 + +mat3 cone patterns.16.disk3.seg.49 +0 +0 +8 + -5.5 19.6 7.54800234847 + -5.5 19.6 7.54853219353 + 0.059931478785 0.0513799297765 + +mat3 cone patterns.16.disk3.seg.50 +0 +0 +8 + -5.5 19.6 7.54853219353 + -5.5 19.6 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat3 cone patterns.16.disk3.seg.51 +0 +0 +8 + -5.5 19.6 7.54898060527 + -5.5 19.6 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat3 cone patterns.16.disk3.seg.52 +0 +0 +8 + -5.5 19.6 7.54934754302 + -5.5 19.6 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat3 cone patterns.16.disk3.seg.53 +0 +0 +8 + -5.5 19.6 7.54963297355 + -5.5 19.6 7.54983687097 + 0.0257004457143 0.017134924593 + +mat3 cone patterns.16.disk3.seg.54 +0 +0 +8 + -5.5 19.6 7.54983687097 + -5.5 19.6 7.54995921682 + 0.017134924593 0.00856785054562 + +mat3 cone patterns.16.disk3.seg.55 +0 +0 +8 + -5.5 19.6 7.54995921682 + -5.5 19.6 7.55 + 0.00856785054562 0 +# xform -m mat4 -n disk4 -t -4 1 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat4 cone patterns.16.disk4.seg.1 +0 +0 +8 + -4 16.6 7.42942286341 + -4 16.6 7.43367146941 + 0.45 0.442559632181 + +mat4 cone patterns.16.disk4.seg.2 +0 +0 +8 + -4 16.6 7.43367146941 + -4 16.6 7.43784905182 + 0.442559632181 0.435079155496 + +mat4 cone patterns.16.disk4.seg.3 +0 +0 +8 + -4 16.6 7.43784905182 + -4 16.6 7.44195523203 + 0.435079155496 0.427559247895 + +mat4 cone patterns.16.disk4.seg.4 +0 +0 +8 + -4 16.6 7.44195523203 + -4 16.6 7.4459896379 + 0.427559247895 0.420000590903 + +mat4 cone patterns.16.disk4.seg.5 +0 +0 +8 + -4 16.6 7.4459896379 + -4 16.6 7.44995190379 + 0.420000590903 0.412403869555 + +mat4 cone patterns.16.disk4.seg.6 +0 +0 +8 + -4 16.6 7.44995190379 + -4 16.6 7.45384167061 + 0.412403869555 0.404769772336 + +mat4 cone patterns.16.disk4.seg.7 +0 +0 +8 + -4 16.6 7.45384167061 + -4 16.6 7.45765858582 + 0.404769772336 0.397098991119 + +mat4 cone patterns.16.disk4.seg.8 +0 +0 +8 + -4 16.6 7.45765858582 + -4 16.6 7.46140230351 + 0.397098991119 0.389392221102 + +mat4 cone patterns.16.disk4.seg.9 +0 +0 +8 + -4 16.6 7.46140230351 + -4 16.6 7.46507248439 + 0.389392221102 0.381650160744 + +mat4 cone patterns.16.disk4.seg.10 +0 +0 +8 + -4 16.6 7.46507248439 + -4 16.6 7.46866879582 + 0.381650160744 0.373873511702 + +mat4 cone patterns.16.disk4.seg.11 +0 +0 +8 + -4 16.6 7.46866879582 + -4 16.6 7.47219091188 + 0.373873511702 0.366062978768 + +mat4 cone patterns.16.disk4.seg.12 +0 +0 +8 + -4 16.6 7.47219091188 + -4 16.6 7.47563851336 + 0.366062978768 0.358219269806 + +mat4 cone patterns.16.disk4.seg.13 +0 +0 +8 + -4 16.6 7.47563851336 + -4 16.6 7.4790112878 + 0.358219269806 0.350343095686 + +mat4 cone patterns.16.disk4.seg.14 +0 +0 +8 + -4 16.6 7.4790112878 + -4 16.6 7.48230892954 + 0.350343095686 0.342435170218 + +mat4 cone patterns.16.disk4.seg.15 +0 +0 +8 + -4 16.6 7.48230892954 + -4 16.6 7.48553113971 + 0.342435170218 0.334496210094 + +mat4 cone patterns.16.disk4.seg.16 +0 +0 +8 + -4 16.6 7.48553113971 + -4 16.6 7.48867762629 + 0.334496210094 0.326526934816 + +mat4 cone patterns.16.disk4.seg.17 +0 +0 +8 + -4 16.6 7.48867762629 + -4 16.6 7.49174810411 + 0.326526934816 0.318528066632 + +mat4 cone patterns.16.disk4.seg.18 +0 +0 +8 + -4 16.6 7.49174810411 + -4 16.6 7.49474229489 + 0.318528066632 0.310500330475 + +mat4 cone patterns.16.disk4.seg.19 +0 +0 +8 + -4 16.6 7.49474229489 + -4 16.6 7.49765992728 + 0.310500330475 0.302444453894 + +mat4 cone patterns.16.disk4.seg.20 +0 +0 +8 + -4 16.6 7.49765992728 + -4 16.6 7.50050073684 + 0.302444453894 0.294361166986 + +mat4 cone patterns.16.disk4.seg.21 +0 +0 +8 + -4 16.6 7.50050073684 + -4 16.6 7.50326446613 + 0.294361166986 0.286251202333 + +mat4 cone patterns.16.disk4.seg.22 +0 +0 +8 + -4 16.6 7.50326446613 + -4 16.6 7.50595086467 + 0.286251202333 0.278115294937 + +mat4 cone patterns.16.disk4.seg.23 +0 +0 +8 + -4 16.6 7.50595086467 + -4 16.6 7.50855968898 + 0.278115294937 0.269954182149 + +mat4 cone patterns.16.disk4.seg.24 +0 +0 +8 + -4 16.6 7.50855968898 + -4 16.6 7.51109070264 + 0.269954182149 0.261768603605 + +mat4 cone patterns.16.disk4.seg.25 +0 +0 +8 + -4 16.6 7.51109070264 + -4 16.6 7.51354367625 + 0.261768603605 0.253559301157 + +mat4 cone patterns.16.disk4.seg.26 +0 +0 +8 + -4 16.6 7.51354367625 + -4 16.6 7.51591838752 + 0.253559301157 0.24532701881 + +mat4 cone patterns.16.disk4.seg.27 +0 +0 +8 + -4 16.6 7.51591838752 + -4 16.6 7.51821462121 + 0.24532701881 0.237072502648 + +mat4 cone patterns.16.disk4.seg.28 +0 +0 +8 + -4 16.6 7.51821462121 + -4 16.6 7.52043216923 + 0.237072502648 0.228796500774 + +mat4 cone patterns.16.disk4.seg.29 +0 +0 +8 + -4 16.6 7.52043216923 + -4 16.6 7.5225708306 + 0.228796500774 0.220499763235 + +mat4 cone patterns.16.disk4.seg.30 +0 +0 +8 + -4 16.6 7.5225708306 + -4 16.6 7.52463041149 + 0.220499763235 0.212183041958 + +mat4 cone patterns.16.disk4.seg.31 +0 +0 +8 + -4 16.6 7.52463041149 + -4 16.6 7.52661072525 + 0.212183041958 0.203847090683 + +mat4 cone patterns.16.disk4.seg.32 +0 +0 +8 + -4 16.6 7.52661072525 + -4 16.6 7.5285115924 + 0.203847090683 0.19549266489 + +mat4 cone patterns.16.disk4.seg.33 +0 +0 +8 + -4 16.6 7.5285115924 + -4 16.6 7.53033284066 + 0.19549266489 0.187120521736 + +mat4 cone patterns.16.disk4.seg.34 +0 +0 +8 + -4 16.6 7.53033284066 + -4 16.6 7.53207430498 + 0.187120521736 0.178731419981 + +mat4 cone patterns.16.disk4.seg.35 +0 +0 +8 + -4 16.6 7.53207430498 + -4 16.6 7.53373582754 + 0.178731419981 0.170326119924 + +mat4 cone patterns.16.disk4.seg.36 +0 +0 +8 + -4 16.6 7.53373582754 + -4 16.6 7.53531725774 + 0.170326119924 0.161905383332 + +mat4 cone patterns.16.disk4.seg.37 +0 +0 +8 + -4 16.6 7.53531725774 + -4 16.6 7.53681845226 + 0.161905383332 0.153469973369 + +mat4 cone patterns.16.disk4.seg.38 +0 +0 +8 + -4 16.6 7.53681845226 + -4 16.6 7.53823927506 + 0.153469973369 0.145020654532 + +mat4 cone patterns.16.disk4.seg.39 +0 +0 +8 + -4 16.6 7.53823927506 + -4 16.6 7.53957959736 + 0.145020654532 0.136558192575 + +mat4 cone patterns.16.disk4.seg.40 +0 +0 +8 + -4 16.6 7.53957959736 + -4 16.6 7.54083929769 + 0.136558192575 0.128083354446 + +mat4 cone patterns.16.disk4.seg.41 +0 +0 +8 + -4 16.6 7.54083929769 + -4 16.6 7.54201826189 + 0.128083354446 0.119596908213 + +mat4 cone patterns.16.disk4.seg.42 +0 +0 +8 + -4 16.6 7.54201826189 + -4 16.6 7.5431163831 + 0.119596908213 0.111099622997 + +mat4 cone patterns.16.disk4.seg.43 +0 +0 +8 + -4 16.6 7.5431163831 + -4 16.6 7.54413356181 + 0.111099622997 0.102592268901 + +mat4 cone patterns.16.disk4.seg.44 +0 +0 +8 + -4 16.6 7.54413356181 + -4 16.6 7.54506970583 + 0.102592268901 0.0940756169409 + +mat4 cone patterns.16.disk4.seg.45 +0 +0 +8 + -4 16.6 7.54506970583 + -4 16.6 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat4 cone patterns.16.disk4.seg.46 +0 +0 +8 + -4 16.6 7.54592473032 + -4 16.6 7.54669855778 + 0.0855504389738 0.077017507631 + +mat4 cone patterns.16.disk4.seg.47 +0 +0 +8 + -4 16.6 7.54669855778 + -4 16.6 7.54739111808 + 0.077017507631 0.068477596246 + +mat4 cone patterns.16.disk4.seg.48 +0 +0 +8 + -4 16.6 7.54739111808 + -4 16.6 7.54800234847 + 0.068477596246 0.059931478785 + +mat4 cone patterns.16.disk4.seg.49 +0 +0 +8 + -4 16.6 7.54800234847 + -4 16.6 7.54853219353 + 0.059931478785 0.0513799297765 + +mat4 cone patterns.16.disk4.seg.50 +0 +0 +8 + -4 16.6 7.54853219353 + -4 16.6 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat4 cone patterns.16.disk4.seg.51 +0 +0 +8 + -4 16.6 7.54898060527 + -4 16.6 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat4 cone patterns.16.disk4.seg.52 +0 +0 +8 + -4 16.6 7.54934754302 + -4 16.6 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat4 cone patterns.16.disk4.seg.53 +0 +0 +8 + -4 16.6 7.54963297355 + -4 16.6 7.54983687097 + 0.0257004457143 0.017134924593 + +mat4 cone patterns.16.disk4.seg.54 +0 +0 +8 + -4 16.6 7.54983687097 + -4 16.6 7.54995921682 + 0.017134924593 0.00856785054562 + +mat4 cone patterns.16.disk4.seg.55 +0 +0 +8 + -4 16.6 7.54995921682 + -4 16.6 7.55 + 0.00856785054562 0 +# xform -m mat5 -n disk5 -t -4 2.5 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat5 cone patterns.16.disk5.seg.1 +0 +0 +8 + -4 18.1 7.42942286341 + -4 18.1 7.43367146941 + 0.45 0.442559632181 + +mat5 cone patterns.16.disk5.seg.2 +0 +0 +8 + -4 18.1 7.43367146941 + -4 18.1 7.43784905182 + 0.442559632181 0.435079155496 + +mat5 cone patterns.16.disk5.seg.3 +0 +0 +8 + -4 18.1 7.43784905182 + -4 18.1 7.44195523203 + 0.435079155496 0.427559247895 + +mat5 cone patterns.16.disk5.seg.4 +0 +0 +8 + -4 18.1 7.44195523203 + -4 18.1 7.4459896379 + 0.427559247895 0.420000590903 + +mat5 cone patterns.16.disk5.seg.5 +0 +0 +8 + -4 18.1 7.4459896379 + -4 18.1 7.44995190379 + 0.420000590903 0.412403869555 + +mat5 cone patterns.16.disk5.seg.6 +0 +0 +8 + -4 18.1 7.44995190379 + -4 18.1 7.45384167061 + 0.412403869555 0.404769772336 + +mat5 cone patterns.16.disk5.seg.7 +0 +0 +8 + -4 18.1 7.45384167061 + -4 18.1 7.45765858582 + 0.404769772336 0.397098991119 + +mat5 cone patterns.16.disk5.seg.8 +0 +0 +8 + -4 18.1 7.45765858582 + -4 18.1 7.46140230351 + 0.397098991119 0.389392221102 + +mat5 cone patterns.16.disk5.seg.9 +0 +0 +8 + -4 18.1 7.46140230351 + -4 18.1 7.46507248439 + 0.389392221102 0.381650160744 + +mat5 cone patterns.16.disk5.seg.10 +0 +0 +8 + -4 18.1 7.46507248439 + -4 18.1 7.46866879582 + 0.381650160744 0.373873511702 + +mat5 cone patterns.16.disk5.seg.11 +0 +0 +8 + -4 18.1 7.46866879582 + -4 18.1 7.47219091188 + 0.373873511702 0.366062978768 + +mat5 cone patterns.16.disk5.seg.12 +0 +0 +8 + -4 18.1 7.47219091188 + -4 18.1 7.47563851336 + 0.366062978768 0.358219269806 + +mat5 cone patterns.16.disk5.seg.13 +0 +0 +8 + -4 18.1 7.47563851336 + -4 18.1 7.4790112878 + 0.358219269806 0.350343095686 + +mat5 cone patterns.16.disk5.seg.14 +0 +0 +8 + -4 18.1 7.4790112878 + -4 18.1 7.48230892954 + 0.350343095686 0.342435170218 + +mat5 cone patterns.16.disk5.seg.15 +0 +0 +8 + -4 18.1 7.48230892954 + -4 18.1 7.48553113971 + 0.342435170218 0.334496210094 + +mat5 cone patterns.16.disk5.seg.16 +0 +0 +8 + -4 18.1 7.48553113971 + -4 18.1 7.48867762629 + 0.334496210094 0.326526934816 + +mat5 cone patterns.16.disk5.seg.17 +0 +0 +8 + -4 18.1 7.48867762629 + -4 18.1 7.49174810411 + 0.326526934816 0.318528066632 + +mat5 cone patterns.16.disk5.seg.18 +0 +0 +8 + -4 18.1 7.49174810411 + -4 18.1 7.49474229489 + 0.318528066632 0.310500330475 + +mat5 cone patterns.16.disk5.seg.19 +0 +0 +8 + -4 18.1 7.49474229489 + -4 18.1 7.49765992728 + 0.310500330475 0.302444453894 + +mat5 cone patterns.16.disk5.seg.20 +0 +0 +8 + -4 18.1 7.49765992728 + -4 18.1 7.50050073684 + 0.302444453894 0.294361166986 + +mat5 cone patterns.16.disk5.seg.21 +0 +0 +8 + -4 18.1 7.50050073684 + -4 18.1 7.50326446613 + 0.294361166986 0.286251202333 + +mat5 cone patterns.16.disk5.seg.22 +0 +0 +8 + -4 18.1 7.50326446613 + -4 18.1 7.50595086467 + 0.286251202333 0.278115294937 + +mat5 cone patterns.16.disk5.seg.23 +0 +0 +8 + -4 18.1 7.50595086467 + -4 18.1 7.50855968898 + 0.278115294937 0.269954182149 + +mat5 cone patterns.16.disk5.seg.24 +0 +0 +8 + -4 18.1 7.50855968898 + -4 18.1 7.51109070264 + 0.269954182149 0.261768603605 + +mat5 cone patterns.16.disk5.seg.25 +0 +0 +8 + -4 18.1 7.51109070264 + -4 18.1 7.51354367625 + 0.261768603605 0.253559301157 + +mat5 cone patterns.16.disk5.seg.26 +0 +0 +8 + -4 18.1 7.51354367625 + -4 18.1 7.51591838752 + 0.253559301157 0.24532701881 + +mat5 cone patterns.16.disk5.seg.27 +0 +0 +8 + -4 18.1 7.51591838752 + -4 18.1 7.51821462121 + 0.24532701881 0.237072502648 + +mat5 cone patterns.16.disk5.seg.28 +0 +0 +8 + -4 18.1 7.51821462121 + -4 18.1 7.52043216923 + 0.237072502648 0.228796500774 + +mat5 cone patterns.16.disk5.seg.29 +0 +0 +8 + -4 18.1 7.52043216923 + -4 18.1 7.5225708306 + 0.228796500774 0.220499763235 + +mat5 cone patterns.16.disk5.seg.30 +0 +0 +8 + -4 18.1 7.5225708306 + -4 18.1 7.52463041149 + 0.220499763235 0.212183041958 + +mat5 cone patterns.16.disk5.seg.31 +0 +0 +8 + -4 18.1 7.52463041149 + -4 18.1 7.52661072525 + 0.212183041958 0.203847090683 + +mat5 cone patterns.16.disk5.seg.32 +0 +0 +8 + -4 18.1 7.52661072525 + -4 18.1 7.5285115924 + 0.203847090683 0.19549266489 + +mat5 cone patterns.16.disk5.seg.33 +0 +0 +8 + -4 18.1 7.5285115924 + -4 18.1 7.53033284066 + 0.19549266489 0.187120521736 + +mat5 cone patterns.16.disk5.seg.34 +0 +0 +8 + -4 18.1 7.53033284066 + -4 18.1 7.53207430498 + 0.187120521736 0.178731419981 + +mat5 cone patterns.16.disk5.seg.35 +0 +0 +8 + -4 18.1 7.53207430498 + -4 18.1 7.53373582754 + 0.178731419981 0.170326119924 + +mat5 cone patterns.16.disk5.seg.36 +0 +0 +8 + -4 18.1 7.53373582754 + -4 18.1 7.53531725774 + 0.170326119924 0.161905383332 + +mat5 cone patterns.16.disk5.seg.37 +0 +0 +8 + -4 18.1 7.53531725774 + -4 18.1 7.53681845226 + 0.161905383332 0.153469973369 + +mat5 cone patterns.16.disk5.seg.38 +0 +0 +8 + -4 18.1 7.53681845226 + -4 18.1 7.53823927506 + 0.153469973369 0.145020654532 + +mat5 cone patterns.16.disk5.seg.39 +0 +0 +8 + -4 18.1 7.53823927506 + -4 18.1 7.53957959736 + 0.145020654532 0.136558192575 + +mat5 cone patterns.16.disk5.seg.40 +0 +0 +8 + -4 18.1 7.53957959736 + -4 18.1 7.54083929769 + 0.136558192575 0.128083354446 + +mat5 cone patterns.16.disk5.seg.41 +0 +0 +8 + -4 18.1 7.54083929769 + -4 18.1 7.54201826189 + 0.128083354446 0.119596908213 + +mat5 cone patterns.16.disk5.seg.42 +0 +0 +8 + -4 18.1 7.54201826189 + -4 18.1 7.5431163831 + 0.119596908213 0.111099622997 + +mat5 cone patterns.16.disk5.seg.43 +0 +0 +8 + -4 18.1 7.5431163831 + -4 18.1 7.54413356181 + 0.111099622997 0.102592268901 + +mat5 cone patterns.16.disk5.seg.44 +0 +0 +8 + -4 18.1 7.54413356181 + -4 18.1 7.54506970583 + 0.102592268901 0.0940756169409 + +mat5 cone patterns.16.disk5.seg.45 +0 +0 +8 + -4 18.1 7.54506970583 + -4 18.1 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat5 cone patterns.16.disk5.seg.46 +0 +0 +8 + -4 18.1 7.54592473032 + -4 18.1 7.54669855778 + 0.0855504389738 0.077017507631 + +mat5 cone patterns.16.disk5.seg.47 +0 +0 +8 + -4 18.1 7.54669855778 + -4 18.1 7.54739111808 + 0.077017507631 0.068477596246 + +mat5 cone patterns.16.disk5.seg.48 +0 +0 +8 + -4 18.1 7.54739111808 + -4 18.1 7.54800234847 + 0.068477596246 0.059931478785 + +mat5 cone patterns.16.disk5.seg.49 +0 +0 +8 + -4 18.1 7.54800234847 + -4 18.1 7.54853219353 + 0.059931478785 0.0513799297765 + +mat5 cone patterns.16.disk5.seg.50 +0 +0 +8 + -4 18.1 7.54853219353 + -4 18.1 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat5 cone patterns.16.disk5.seg.51 +0 +0 +8 + -4 18.1 7.54898060527 + -4 18.1 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat5 cone patterns.16.disk5.seg.52 +0 +0 +8 + -4 18.1 7.54934754302 + -4 18.1 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat5 cone patterns.16.disk5.seg.53 +0 +0 +8 + -4 18.1 7.54963297355 + -4 18.1 7.54983687097 + 0.0257004457143 0.017134924593 + +mat5 cone patterns.16.disk5.seg.54 +0 +0 +8 + -4 18.1 7.54983687097 + -4 18.1 7.54995921682 + 0.017134924593 0.00856785054562 + +mat5 cone patterns.16.disk5.seg.55 +0 +0 +8 + -4 18.1 7.54995921682 + -4 18.1 7.55 + 0.00856785054562 0 +# xform -m mat6 -n disk6 -t -4 4 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat6 cone patterns.16.disk6.seg.1 +0 +0 +8 + -4 19.6 7.42942286341 + -4 19.6 7.43367146941 + 0.45 0.442559632181 + +mat6 cone patterns.16.disk6.seg.2 +0 +0 +8 + -4 19.6 7.43367146941 + -4 19.6 7.43784905182 + 0.442559632181 0.435079155496 + +mat6 cone patterns.16.disk6.seg.3 +0 +0 +8 + -4 19.6 7.43784905182 + -4 19.6 7.44195523203 + 0.435079155496 0.427559247895 + +mat6 cone patterns.16.disk6.seg.4 +0 +0 +8 + -4 19.6 7.44195523203 + -4 19.6 7.4459896379 + 0.427559247895 0.420000590903 + +mat6 cone patterns.16.disk6.seg.5 +0 +0 +8 + -4 19.6 7.4459896379 + -4 19.6 7.44995190379 + 0.420000590903 0.412403869555 + +mat6 cone patterns.16.disk6.seg.6 +0 +0 +8 + -4 19.6 7.44995190379 + -4 19.6 7.45384167061 + 0.412403869555 0.404769772336 + +mat6 cone patterns.16.disk6.seg.7 +0 +0 +8 + -4 19.6 7.45384167061 + -4 19.6 7.45765858582 + 0.404769772336 0.397098991119 + +mat6 cone patterns.16.disk6.seg.8 +0 +0 +8 + -4 19.6 7.45765858582 + -4 19.6 7.46140230351 + 0.397098991119 0.389392221102 + +mat6 cone patterns.16.disk6.seg.9 +0 +0 +8 + -4 19.6 7.46140230351 + -4 19.6 7.46507248439 + 0.389392221102 0.381650160744 + +mat6 cone patterns.16.disk6.seg.10 +0 +0 +8 + -4 19.6 7.46507248439 + -4 19.6 7.46866879582 + 0.381650160744 0.373873511702 + +mat6 cone patterns.16.disk6.seg.11 +0 +0 +8 + -4 19.6 7.46866879582 + -4 19.6 7.47219091188 + 0.373873511702 0.366062978768 + +mat6 cone patterns.16.disk6.seg.12 +0 +0 +8 + -4 19.6 7.47219091188 + -4 19.6 7.47563851336 + 0.366062978768 0.358219269806 + +mat6 cone patterns.16.disk6.seg.13 +0 +0 +8 + -4 19.6 7.47563851336 + -4 19.6 7.4790112878 + 0.358219269806 0.350343095686 + +mat6 cone patterns.16.disk6.seg.14 +0 +0 +8 + -4 19.6 7.4790112878 + -4 19.6 7.48230892954 + 0.350343095686 0.342435170218 + +mat6 cone patterns.16.disk6.seg.15 +0 +0 +8 + -4 19.6 7.48230892954 + -4 19.6 7.48553113971 + 0.342435170218 0.334496210094 + +mat6 cone patterns.16.disk6.seg.16 +0 +0 +8 + -4 19.6 7.48553113971 + -4 19.6 7.48867762629 + 0.334496210094 0.326526934816 + +mat6 cone patterns.16.disk6.seg.17 +0 +0 +8 + -4 19.6 7.48867762629 + -4 19.6 7.49174810411 + 0.326526934816 0.318528066632 + +mat6 cone patterns.16.disk6.seg.18 +0 +0 +8 + -4 19.6 7.49174810411 + -4 19.6 7.49474229489 + 0.318528066632 0.310500330475 + +mat6 cone patterns.16.disk6.seg.19 +0 +0 +8 + -4 19.6 7.49474229489 + -4 19.6 7.49765992728 + 0.310500330475 0.302444453894 + +mat6 cone patterns.16.disk6.seg.20 +0 +0 +8 + -4 19.6 7.49765992728 + -4 19.6 7.50050073684 + 0.302444453894 0.294361166986 + +mat6 cone patterns.16.disk6.seg.21 +0 +0 +8 + -4 19.6 7.50050073684 + -4 19.6 7.50326446613 + 0.294361166986 0.286251202333 + +mat6 cone patterns.16.disk6.seg.22 +0 +0 +8 + -4 19.6 7.50326446613 + -4 19.6 7.50595086467 + 0.286251202333 0.278115294937 + +mat6 cone patterns.16.disk6.seg.23 +0 +0 +8 + -4 19.6 7.50595086467 + -4 19.6 7.50855968898 + 0.278115294937 0.269954182149 + +mat6 cone patterns.16.disk6.seg.24 +0 +0 +8 + -4 19.6 7.50855968898 + -4 19.6 7.51109070264 + 0.269954182149 0.261768603605 + +mat6 cone patterns.16.disk6.seg.25 +0 +0 +8 + -4 19.6 7.51109070264 + -4 19.6 7.51354367625 + 0.261768603605 0.253559301157 + +mat6 cone patterns.16.disk6.seg.26 +0 +0 +8 + -4 19.6 7.51354367625 + -4 19.6 7.51591838752 + 0.253559301157 0.24532701881 + +mat6 cone patterns.16.disk6.seg.27 +0 +0 +8 + -4 19.6 7.51591838752 + -4 19.6 7.51821462121 + 0.24532701881 0.237072502648 + +mat6 cone patterns.16.disk6.seg.28 +0 +0 +8 + -4 19.6 7.51821462121 + -4 19.6 7.52043216923 + 0.237072502648 0.228796500774 + +mat6 cone patterns.16.disk6.seg.29 +0 +0 +8 + -4 19.6 7.52043216923 + -4 19.6 7.5225708306 + 0.228796500774 0.220499763235 + +mat6 cone patterns.16.disk6.seg.30 +0 +0 +8 + -4 19.6 7.5225708306 + -4 19.6 7.52463041149 + 0.220499763235 0.212183041958 + +mat6 cone patterns.16.disk6.seg.31 +0 +0 +8 + -4 19.6 7.52463041149 + -4 19.6 7.52661072525 + 0.212183041958 0.203847090683 + +mat6 cone patterns.16.disk6.seg.32 +0 +0 +8 + -4 19.6 7.52661072525 + -4 19.6 7.5285115924 + 0.203847090683 0.19549266489 + +mat6 cone patterns.16.disk6.seg.33 +0 +0 +8 + -4 19.6 7.5285115924 + -4 19.6 7.53033284066 + 0.19549266489 0.187120521736 + +mat6 cone patterns.16.disk6.seg.34 +0 +0 +8 + -4 19.6 7.53033284066 + -4 19.6 7.53207430498 + 0.187120521736 0.178731419981 + +mat6 cone patterns.16.disk6.seg.35 +0 +0 +8 + -4 19.6 7.53207430498 + -4 19.6 7.53373582754 + 0.178731419981 0.170326119924 + +mat6 cone patterns.16.disk6.seg.36 +0 +0 +8 + -4 19.6 7.53373582754 + -4 19.6 7.53531725774 + 0.170326119924 0.161905383332 + +mat6 cone patterns.16.disk6.seg.37 +0 +0 +8 + -4 19.6 7.53531725774 + -4 19.6 7.53681845226 + 0.161905383332 0.153469973369 + +mat6 cone patterns.16.disk6.seg.38 +0 +0 +8 + -4 19.6 7.53681845226 + -4 19.6 7.53823927506 + 0.153469973369 0.145020654532 + +mat6 cone patterns.16.disk6.seg.39 +0 +0 +8 + -4 19.6 7.53823927506 + -4 19.6 7.53957959736 + 0.145020654532 0.136558192575 + +mat6 cone patterns.16.disk6.seg.40 +0 +0 +8 + -4 19.6 7.53957959736 + -4 19.6 7.54083929769 + 0.136558192575 0.128083354446 + +mat6 cone patterns.16.disk6.seg.41 +0 +0 +8 + -4 19.6 7.54083929769 + -4 19.6 7.54201826189 + 0.128083354446 0.119596908213 + +mat6 cone patterns.16.disk6.seg.42 +0 +0 +8 + -4 19.6 7.54201826189 + -4 19.6 7.5431163831 + 0.119596908213 0.111099622997 + +mat6 cone patterns.16.disk6.seg.43 +0 +0 +8 + -4 19.6 7.5431163831 + -4 19.6 7.54413356181 + 0.111099622997 0.102592268901 + +mat6 cone patterns.16.disk6.seg.44 +0 +0 +8 + -4 19.6 7.54413356181 + -4 19.6 7.54506970583 + 0.102592268901 0.0940756169409 + +mat6 cone patterns.16.disk6.seg.45 +0 +0 +8 + -4 19.6 7.54506970583 + -4 19.6 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat6 cone patterns.16.disk6.seg.46 +0 +0 +8 + -4 19.6 7.54592473032 + -4 19.6 7.54669855778 + 0.0855504389738 0.077017507631 + +mat6 cone patterns.16.disk6.seg.47 +0 +0 +8 + -4 19.6 7.54669855778 + -4 19.6 7.54739111808 + 0.077017507631 0.068477596246 + +mat6 cone patterns.16.disk6.seg.48 +0 +0 +8 + -4 19.6 7.54739111808 + -4 19.6 7.54800234847 + 0.068477596246 0.059931478785 + +mat6 cone patterns.16.disk6.seg.49 +0 +0 +8 + -4 19.6 7.54800234847 + -4 19.6 7.54853219353 + 0.059931478785 0.0513799297765 + +mat6 cone patterns.16.disk6.seg.50 +0 +0 +8 + -4 19.6 7.54853219353 + -4 19.6 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat6 cone patterns.16.disk6.seg.51 +0 +0 +8 + -4 19.6 7.54898060527 + -4 19.6 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat6 cone patterns.16.disk6.seg.52 +0 +0 +8 + -4 19.6 7.54934754302 + -4 19.6 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat6 cone patterns.16.disk6.seg.53 +0 +0 +8 + -4 19.6 7.54963297355 + -4 19.6 7.54983687097 + 0.0257004457143 0.017134924593 + +mat6 cone patterns.16.disk6.seg.54 +0 +0 +8 + -4 19.6 7.54983687097 + -4 19.6 7.54995921682 + 0.017134924593 0.00856785054562 + +mat6 cone patterns.16.disk6.seg.55 +0 +0 +8 + -4 19.6 7.54995921682 + -4 19.6 7.55 + 0.00856785054562 0 +# xform -m mat7 -n disk7 -t -2.5 1 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat7 cone patterns.16.disk7.seg.1 +0 +0 +8 + -2.5 16.6 7.42942286341 + -2.5 16.6 7.43367146941 + 0.45 0.442559632181 + +mat7 cone patterns.16.disk7.seg.2 +0 +0 +8 + -2.5 16.6 7.43367146941 + -2.5 16.6 7.43784905182 + 0.442559632181 0.435079155496 + +mat7 cone patterns.16.disk7.seg.3 +0 +0 +8 + -2.5 16.6 7.43784905182 + -2.5 16.6 7.44195523203 + 0.435079155496 0.427559247895 + +mat7 cone patterns.16.disk7.seg.4 +0 +0 +8 + -2.5 16.6 7.44195523203 + -2.5 16.6 7.4459896379 + 0.427559247895 0.420000590903 + +mat7 cone patterns.16.disk7.seg.5 +0 +0 +8 + -2.5 16.6 7.4459896379 + -2.5 16.6 7.44995190379 + 0.420000590903 0.412403869555 + +mat7 cone patterns.16.disk7.seg.6 +0 +0 +8 + -2.5 16.6 7.44995190379 + -2.5 16.6 7.45384167061 + 0.412403869555 0.404769772336 + +mat7 cone patterns.16.disk7.seg.7 +0 +0 +8 + -2.5 16.6 7.45384167061 + -2.5 16.6 7.45765858582 + 0.404769772336 0.397098991119 + +mat7 cone patterns.16.disk7.seg.8 +0 +0 +8 + -2.5 16.6 7.45765858582 + -2.5 16.6 7.46140230351 + 0.397098991119 0.389392221102 + +mat7 cone patterns.16.disk7.seg.9 +0 +0 +8 + -2.5 16.6 7.46140230351 + -2.5 16.6 7.46507248439 + 0.389392221102 0.381650160744 + +mat7 cone patterns.16.disk7.seg.10 +0 +0 +8 + -2.5 16.6 7.46507248439 + -2.5 16.6 7.46866879582 + 0.381650160744 0.373873511702 + +mat7 cone patterns.16.disk7.seg.11 +0 +0 +8 + -2.5 16.6 7.46866879582 + -2.5 16.6 7.47219091188 + 0.373873511702 0.366062978768 + +mat7 cone patterns.16.disk7.seg.12 +0 +0 +8 + -2.5 16.6 7.47219091188 + -2.5 16.6 7.47563851336 + 0.366062978768 0.358219269806 + +mat7 cone patterns.16.disk7.seg.13 +0 +0 +8 + -2.5 16.6 7.47563851336 + -2.5 16.6 7.4790112878 + 0.358219269806 0.350343095686 + +mat7 cone patterns.16.disk7.seg.14 +0 +0 +8 + -2.5 16.6 7.4790112878 + -2.5 16.6 7.48230892954 + 0.350343095686 0.342435170218 + +mat7 cone patterns.16.disk7.seg.15 +0 +0 +8 + -2.5 16.6 7.48230892954 + -2.5 16.6 7.48553113971 + 0.342435170218 0.334496210094 + +mat7 cone patterns.16.disk7.seg.16 +0 +0 +8 + -2.5 16.6 7.48553113971 + -2.5 16.6 7.48867762629 + 0.334496210094 0.326526934816 + +mat7 cone patterns.16.disk7.seg.17 +0 +0 +8 + -2.5 16.6 7.48867762629 + -2.5 16.6 7.49174810411 + 0.326526934816 0.318528066632 + +mat7 cone patterns.16.disk7.seg.18 +0 +0 +8 + -2.5 16.6 7.49174810411 + -2.5 16.6 7.49474229489 + 0.318528066632 0.310500330475 + +mat7 cone patterns.16.disk7.seg.19 +0 +0 +8 + -2.5 16.6 7.49474229489 + -2.5 16.6 7.49765992728 + 0.310500330475 0.302444453894 + +mat7 cone patterns.16.disk7.seg.20 +0 +0 +8 + -2.5 16.6 7.49765992728 + -2.5 16.6 7.50050073684 + 0.302444453894 0.294361166986 + +mat7 cone patterns.16.disk7.seg.21 +0 +0 +8 + -2.5 16.6 7.50050073684 + -2.5 16.6 7.50326446613 + 0.294361166986 0.286251202333 + +mat7 cone patterns.16.disk7.seg.22 +0 +0 +8 + -2.5 16.6 7.50326446613 + -2.5 16.6 7.50595086467 + 0.286251202333 0.278115294937 + +mat7 cone patterns.16.disk7.seg.23 +0 +0 +8 + -2.5 16.6 7.50595086467 + -2.5 16.6 7.50855968898 + 0.278115294937 0.269954182149 + +mat7 cone patterns.16.disk7.seg.24 +0 +0 +8 + -2.5 16.6 7.50855968898 + -2.5 16.6 7.51109070264 + 0.269954182149 0.261768603605 + +mat7 cone patterns.16.disk7.seg.25 +0 +0 +8 + -2.5 16.6 7.51109070264 + -2.5 16.6 7.51354367625 + 0.261768603605 0.253559301157 + +mat7 cone patterns.16.disk7.seg.26 +0 +0 +8 + -2.5 16.6 7.51354367625 + -2.5 16.6 7.51591838752 + 0.253559301157 0.24532701881 + +mat7 cone patterns.16.disk7.seg.27 +0 +0 +8 + -2.5 16.6 7.51591838752 + -2.5 16.6 7.51821462121 + 0.24532701881 0.237072502648 + +mat7 cone patterns.16.disk7.seg.28 +0 +0 +8 + -2.5 16.6 7.51821462121 + -2.5 16.6 7.52043216923 + 0.237072502648 0.228796500774 + +mat7 cone patterns.16.disk7.seg.29 +0 +0 +8 + -2.5 16.6 7.52043216923 + -2.5 16.6 7.5225708306 + 0.228796500774 0.220499763235 + +mat7 cone patterns.16.disk7.seg.30 +0 +0 +8 + -2.5 16.6 7.5225708306 + -2.5 16.6 7.52463041149 + 0.220499763235 0.212183041958 + +mat7 cone patterns.16.disk7.seg.31 +0 +0 +8 + -2.5 16.6 7.52463041149 + -2.5 16.6 7.52661072525 + 0.212183041958 0.203847090683 + +mat7 cone patterns.16.disk7.seg.32 +0 +0 +8 + -2.5 16.6 7.52661072525 + -2.5 16.6 7.5285115924 + 0.203847090683 0.19549266489 + +mat7 cone patterns.16.disk7.seg.33 +0 +0 +8 + -2.5 16.6 7.5285115924 + -2.5 16.6 7.53033284066 + 0.19549266489 0.187120521736 + +mat7 cone patterns.16.disk7.seg.34 +0 +0 +8 + -2.5 16.6 7.53033284066 + -2.5 16.6 7.53207430498 + 0.187120521736 0.178731419981 + +mat7 cone patterns.16.disk7.seg.35 +0 +0 +8 + -2.5 16.6 7.53207430498 + -2.5 16.6 7.53373582754 + 0.178731419981 0.170326119924 + +mat7 cone patterns.16.disk7.seg.36 +0 +0 +8 + -2.5 16.6 7.53373582754 + -2.5 16.6 7.53531725774 + 0.170326119924 0.161905383332 + +mat7 cone patterns.16.disk7.seg.37 +0 +0 +8 + -2.5 16.6 7.53531725774 + -2.5 16.6 7.53681845226 + 0.161905383332 0.153469973369 + +mat7 cone patterns.16.disk7.seg.38 +0 +0 +8 + -2.5 16.6 7.53681845226 + -2.5 16.6 7.53823927506 + 0.153469973369 0.145020654532 + +mat7 cone patterns.16.disk7.seg.39 +0 +0 +8 + -2.5 16.6 7.53823927506 + -2.5 16.6 7.53957959736 + 0.145020654532 0.136558192575 + +mat7 cone patterns.16.disk7.seg.40 +0 +0 +8 + -2.5 16.6 7.53957959736 + -2.5 16.6 7.54083929769 + 0.136558192575 0.128083354446 + +mat7 cone patterns.16.disk7.seg.41 +0 +0 +8 + -2.5 16.6 7.54083929769 + -2.5 16.6 7.54201826189 + 0.128083354446 0.119596908213 + +mat7 cone patterns.16.disk7.seg.42 +0 +0 +8 + -2.5 16.6 7.54201826189 + -2.5 16.6 7.5431163831 + 0.119596908213 0.111099622997 + +mat7 cone patterns.16.disk7.seg.43 +0 +0 +8 + -2.5 16.6 7.5431163831 + -2.5 16.6 7.54413356181 + 0.111099622997 0.102592268901 + +mat7 cone patterns.16.disk7.seg.44 +0 +0 +8 + -2.5 16.6 7.54413356181 + -2.5 16.6 7.54506970583 + 0.102592268901 0.0940756169409 + +mat7 cone patterns.16.disk7.seg.45 +0 +0 +8 + -2.5 16.6 7.54506970583 + -2.5 16.6 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat7 cone patterns.16.disk7.seg.46 +0 +0 +8 + -2.5 16.6 7.54592473032 + -2.5 16.6 7.54669855778 + 0.0855504389738 0.077017507631 + +mat7 cone patterns.16.disk7.seg.47 +0 +0 +8 + -2.5 16.6 7.54669855778 + -2.5 16.6 7.54739111808 + 0.077017507631 0.068477596246 + +mat7 cone patterns.16.disk7.seg.48 +0 +0 +8 + -2.5 16.6 7.54739111808 + -2.5 16.6 7.54800234847 + 0.068477596246 0.059931478785 + +mat7 cone patterns.16.disk7.seg.49 +0 +0 +8 + -2.5 16.6 7.54800234847 + -2.5 16.6 7.54853219353 + 0.059931478785 0.0513799297765 + +mat7 cone patterns.16.disk7.seg.50 +0 +0 +8 + -2.5 16.6 7.54853219353 + -2.5 16.6 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat7 cone patterns.16.disk7.seg.51 +0 +0 +8 + -2.5 16.6 7.54898060527 + -2.5 16.6 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat7 cone patterns.16.disk7.seg.52 +0 +0 +8 + -2.5 16.6 7.54934754302 + -2.5 16.6 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat7 cone patterns.16.disk7.seg.53 +0 +0 +8 + -2.5 16.6 7.54963297355 + -2.5 16.6 7.54983687097 + 0.0257004457143 0.017134924593 + +mat7 cone patterns.16.disk7.seg.54 +0 +0 +8 + -2.5 16.6 7.54983687097 + -2.5 16.6 7.54995921682 + 0.017134924593 0.00856785054562 + +mat7 cone patterns.16.disk7.seg.55 +0 +0 +8 + -2.5 16.6 7.54995921682 + -2.5 16.6 7.55 + 0.00856785054562 0 +# xform -m mat8 -n disk8 -t -2.5 2.5 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat8 cone patterns.16.disk8.seg.1 +0 +0 +8 + -2.5 18.1 7.42942286341 + -2.5 18.1 7.43367146941 + 0.45 0.442559632181 + +mat8 cone patterns.16.disk8.seg.2 +0 +0 +8 + -2.5 18.1 7.43367146941 + -2.5 18.1 7.43784905182 + 0.442559632181 0.435079155496 + +mat8 cone patterns.16.disk8.seg.3 +0 +0 +8 + -2.5 18.1 7.43784905182 + -2.5 18.1 7.44195523203 + 0.435079155496 0.427559247895 + +mat8 cone patterns.16.disk8.seg.4 +0 +0 +8 + -2.5 18.1 7.44195523203 + -2.5 18.1 7.4459896379 + 0.427559247895 0.420000590903 + +mat8 cone patterns.16.disk8.seg.5 +0 +0 +8 + -2.5 18.1 7.4459896379 + -2.5 18.1 7.44995190379 + 0.420000590903 0.412403869555 + +mat8 cone patterns.16.disk8.seg.6 +0 +0 +8 + -2.5 18.1 7.44995190379 + -2.5 18.1 7.45384167061 + 0.412403869555 0.404769772336 + +mat8 cone patterns.16.disk8.seg.7 +0 +0 +8 + -2.5 18.1 7.45384167061 + -2.5 18.1 7.45765858582 + 0.404769772336 0.397098991119 + +mat8 cone patterns.16.disk8.seg.8 +0 +0 +8 + -2.5 18.1 7.45765858582 + -2.5 18.1 7.46140230351 + 0.397098991119 0.389392221102 + +mat8 cone patterns.16.disk8.seg.9 +0 +0 +8 + -2.5 18.1 7.46140230351 + -2.5 18.1 7.46507248439 + 0.389392221102 0.381650160744 + +mat8 cone patterns.16.disk8.seg.10 +0 +0 +8 + -2.5 18.1 7.46507248439 + -2.5 18.1 7.46866879582 + 0.381650160744 0.373873511702 + +mat8 cone patterns.16.disk8.seg.11 +0 +0 +8 + -2.5 18.1 7.46866879582 + -2.5 18.1 7.47219091188 + 0.373873511702 0.366062978768 + +mat8 cone patterns.16.disk8.seg.12 +0 +0 +8 + -2.5 18.1 7.47219091188 + -2.5 18.1 7.47563851336 + 0.366062978768 0.358219269806 + +mat8 cone patterns.16.disk8.seg.13 +0 +0 +8 + -2.5 18.1 7.47563851336 + -2.5 18.1 7.4790112878 + 0.358219269806 0.350343095686 + +mat8 cone patterns.16.disk8.seg.14 +0 +0 +8 + -2.5 18.1 7.4790112878 + -2.5 18.1 7.48230892954 + 0.350343095686 0.342435170218 + +mat8 cone patterns.16.disk8.seg.15 +0 +0 +8 + -2.5 18.1 7.48230892954 + -2.5 18.1 7.48553113971 + 0.342435170218 0.334496210094 + +mat8 cone patterns.16.disk8.seg.16 +0 +0 +8 + -2.5 18.1 7.48553113971 + -2.5 18.1 7.48867762629 + 0.334496210094 0.326526934816 + +mat8 cone patterns.16.disk8.seg.17 +0 +0 +8 + -2.5 18.1 7.48867762629 + -2.5 18.1 7.49174810411 + 0.326526934816 0.318528066632 + +mat8 cone patterns.16.disk8.seg.18 +0 +0 +8 + -2.5 18.1 7.49174810411 + -2.5 18.1 7.49474229489 + 0.318528066632 0.310500330475 + +mat8 cone patterns.16.disk8.seg.19 +0 +0 +8 + -2.5 18.1 7.49474229489 + -2.5 18.1 7.49765992728 + 0.310500330475 0.302444453894 + +mat8 cone patterns.16.disk8.seg.20 +0 +0 +8 + -2.5 18.1 7.49765992728 + -2.5 18.1 7.50050073684 + 0.302444453894 0.294361166986 + +mat8 cone patterns.16.disk8.seg.21 +0 +0 +8 + -2.5 18.1 7.50050073684 + -2.5 18.1 7.50326446613 + 0.294361166986 0.286251202333 + +mat8 cone patterns.16.disk8.seg.22 +0 +0 +8 + -2.5 18.1 7.50326446613 + -2.5 18.1 7.50595086467 + 0.286251202333 0.278115294937 + +mat8 cone patterns.16.disk8.seg.23 +0 +0 +8 + -2.5 18.1 7.50595086467 + -2.5 18.1 7.50855968898 + 0.278115294937 0.269954182149 + +mat8 cone patterns.16.disk8.seg.24 +0 +0 +8 + -2.5 18.1 7.50855968898 + -2.5 18.1 7.51109070264 + 0.269954182149 0.261768603605 + +mat8 cone patterns.16.disk8.seg.25 +0 +0 +8 + -2.5 18.1 7.51109070264 + -2.5 18.1 7.51354367625 + 0.261768603605 0.253559301157 + +mat8 cone patterns.16.disk8.seg.26 +0 +0 +8 + -2.5 18.1 7.51354367625 + -2.5 18.1 7.51591838752 + 0.253559301157 0.24532701881 + +mat8 cone patterns.16.disk8.seg.27 +0 +0 +8 + -2.5 18.1 7.51591838752 + -2.5 18.1 7.51821462121 + 0.24532701881 0.237072502648 + +mat8 cone patterns.16.disk8.seg.28 +0 +0 +8 + -2.5 18.1 7.51821462121 + -2.5 18.1 7.52043216923 + 0.237072502648 0.228796500774 + +mat8 cone patterns.16.disk8.seg.29 +0 +0 +8 + -2.5 18.1 7.52043216923 + -2.5 18.1 7.5225708306 + 0.228796500774 0.220499763235 + +mat8 cone patterns.16.disk8.seg.30 +0 +0 +8 + -2.5 18.1 7.5225708306 + -2.5 18.1 7.52463041149 + 0.220499763235 0.212183041958 + +mat8 cone patterns.16.disk8.seg.31 +0 +0 +8 + -2.5 18.1 7.52463041149 + -2.5 18.1 7.52661072525 + 0.212183041958 0.203847090683 + +mat8 cone patterns.16.disk8.seg.32 +0 +0 +8 + -2.5 18.1 7.52661072525 + -2.5 18.1 7.5285115924 + 0.203847090683 0.19549266489 + +mat8 cone patterns.16.disk8.seg.33 +0 +0 +8 + -2.5 18.1 7.5285115924 + -2.5 18.1 7.53033284066 + 0.19549266489 0.187120521736 + +mat8 cone patterns.16.disk8.seg.34 +0 +0 +8 + -2.5 18.1 7.53033284066 + -2.5 18.1 7.53207430498 + 0.187120521736 0.178731419981 + +mat8 cone patterns.16.disk8.seg.35 +0 +0 +8 + -2.5 18.1 7.53207430498 + -2.5 18.1 7.53373582754 + 0.178731419981 0.170326119924 + +mat8 cone patterns.16.disk8.seg.36 +0 +0 +8 + -2.5 18.1 7.53373582754 + -2.5 18.1 7.53531725774 + 0.170326119924 0.161905383332 + +mat8 cone patterns.16.disk8.seg.37 +0 +0 +8 + -2.5 18.1 7.53531725774 + -2.5 18.1 7.53681845226 + 0.161905383332 0.153469973369 + +mat8 cone patterns.16.disk8.seg.38 +0 +0 +8 + -2.5 18.1 7.53681845226 + -2.5 18.1 7.53823927506 + 0.153469973369 0.145020654532 + +mat8 cone patterns.16.disk8.seg.39 +0 +0 +8 + -2.5 18.1 7.53823927506 + -2.5 18.1 7.53957959736 + 0.145020654532 0.136558192575 + +mat8 cone patterns.16.disk8.seg.40 +0 +0 +8 + -2.5 18.1 7.53957959736 + -2.5 18.1 7.54083929769 + 0.136558192575 0.128083354446 + +mat8 cone patterns.16.disk8.seg.41 +0 +0 +8 + -2.5 18.1 7.54083929769 + -2.5 18.1 7.54201826189 + 0.128083354446 0.119596908213 + +mat8 cone patterns.16.disk8.seg.42 +0 +0 +8 + -2.5 18.1 7.54201826189 + -2.5 18.1 7.5431163831 + 0.119596908213 0.111099622997 + +mat8 cone patterns.16.disk8.seg.43 +0 +0 +8 + -2.5 18.1 7.5431163831 + -2.5 18.1 7.54413356181 + 0.111099622997 0.102592268901 + +mat8 cone patterns.16.disk8.seg.44 +0 +0 +8 + -2.5 18.1 7.54413356181 + -2.5 18.1 7.54506970583 + 0.102592268901 0.0940756169409 + +mat8 cone patterns.16.disk8.seg.45 +0 +0 +8 + -2.5 18.1 7.54506970583 + -2.5 18.1 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat8 cone patterns.16.disk8.seg.46 +0 +0 +8 + -2.5 18.1 7.54592473032 + -2.5 18.1 7.54669855778 + 0.0855504389738 0.077017507631 + +mat8 cone patterns.16.disk8.seg.47 +0 +0 +8 + -2.5 18.1 7.54669855778 + -2.5 18.1 7.54739111808 + 0.077017507631 0.068477596246 + +mat8 cone patterns.16.disk8.seg.48 +0 +0 +8 + -2.5 18.1 7.54739111808 + -2.5 18.1 7.54800234847 + 0.068477596246 0.059931478785 + +mat8 cone patterns.16.disk8.seg.49 +0 +0 +8 + -2.5 18.1 7.54800234847 + -2.5 18.1 7.54853219353 + 0.059931478785 0.0513799297765 + +mat8 cone patterns.16.disk8.seg.50 +0 +0 +8 + -2.5 18.1 7.54853219353 + -2.5 18.1 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat8 cone patterns.16.disk8.seg.51 +0 +0 +8 + -2.5 18.1 7.54898060527 + -2.5 18.1 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat8 cone patterns.16.disk8.seg.52 +0 +0 +8 + -2.5 18.1 7.54934754302 + -2.5 18.1 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat8 cone patterns.16.disk8.seg.53 +0 +0 +8 + -2.5 18.1 7.54963297355 + -2.5 18.1 7.54983687097 + 0.0257004457143 0.017134924593 + +mat8 cone patterns.16.disk8.seg.54 +0 +0 +8 + -2.5 18.1 7.54983687097 + -2.5 18.1 7.54995921682 + 0.017134924593 0.00856785054562 + +mat8 cone patterns.16.disk8.seg.55 +0 +0 +8 + -2.5 18.1 7.54995921682 + -2.5 18.1 7.55 + 0.00856785054562 0 +# xform -m mat9 -n disk9 -t -2.5 4 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat9 cone patterns.16.disk9.seg.1 +0 +0 +8 + -2.5 19.6 7.42942286341 + -2.5 19.6 7.43367146941 + 0.45 0.442559632181 + +mat9 cone patterns.16.disk9.seg.2 +0 +0 +8 + -2.5 19.6 7.43367146941 + -2.5 19.6 7.43784905182 + 0.442559632181 0.435079155496 + +mat9 cone patterns.16.disk9.seg.3 +0 +0 +8 + -2.5 19.6 7.43784905182 + -2.5 19.6 7.44195523203 + 0.435079155496 0.427559247895 + +mat9 cone patterns.16.disk9.seg.4 +0 +0 +8 + -2.5 19.6 7.44195523203 + -2.5 19.6 7.4459896379 + 0.427559247895 0.420000590903 + +mat9 cone patterns.16.disk9.seg.5 +0 +0 +8 + -2.5 19.6 7.4459896379 + -2.5 19.6 7.44995190379 + 0.420000590903 0.412403869555 + +mat9 cone patterns.16.disk9.seg.6 +0 +0 +8 + -2.5 19.6 7.44995190379 + -2.5 19.6 7.45384167061 + 0.412403869555 0.404769772336 + +mat9 cone patterns.16.disk9.seg.7 +0 +0 +8 + -2.5 19.6 7.45384167061 + -2.5 19.6 7.45765858582 + 0.404769772336 0.397098991119 + +mat9 cone patterns.16.disk9.seg.8 +0 +0 +8 + -2.5 19.6 7.45765858582 + -2.5 19.6 7.46140230351 + 0.397098991119 0.389392221102 + +mat9 cone patterns.16.disk9.seg.9 +0 +0 +8 + -2.5 19.6 7.46140230351 + -2.5 19.6 7.46507248439 + 0.389392221102 0.381650160744 + +mat9 cone patterns.16.disk9.seg.10 +0 +0 +8 + -2.5 19.6 7.46507248439 + -2.5 19.6 7.46866879582 + 0.381650160744 0.373873511702 + +mat9 cone patterns.16.disk9.seg.11 +0 +0 +8 + -2.5 19.6 7.46866879582 + -2.5 19.6 7.47219091188 + 0.373873511702 0.366062978768 + +mat9 cone patterns.16.disk9.seg.12 +0 +0 +8 + -2.5 19.6 7.47219091188 + -2.5 19.6 7.47563851336 + 0.366062978768 0.358219269806 + +mat9 cone patterns.16.disk9.seg.13 +0 +0 +8 + -2.5 19.6 7.47563851336 + -2.5 19.6 7.4790112878 + 0.358219269806 0.350343095686 + +mat9 cone patterns.16.disk9.seg.14 +0 +0 +8 + -2.5 19.6 7.4790112878 + -2.5 19.6 7.48230892954 + 0.350343095686 0.342435170218 + +mat9 cone patterns.16.disk9.seg.15 +0 +0 +8 + -2.5 19.6 7.48230892954 + -2.5 19.6 7.48553113971 + 0.342435170218 0.334496210094 + +mat9 cone patterns.16.disk9.seg.16 +0 +0 +8 + -2.5 19.6 7.48553113971 + -2.5 19.6 7.48867762629 + 0.334496210094 0.326526934816 + +mat9 cone patterns.16.disk9.seg.17 +0 +0 +8 + -2.5 19.6 7.48867762629 + -2.5 19.6 7.49174810411 + 0.326526934816 0.318528066632 + +mat9 cone patterns.16.disk9.seg.18 +0 +0 +8 + -2.5 19.6 7.49174810411 + -2.5 19.6 7.49474229489 + 0.318528066632 0.310500330475 + +mat9 cone patterns.16.disk9.seg.19 +0 +0 +8 + -2.5 19.6 7.49474229489 + -2.5 19.6 7.49765992728 + 0.310500330475 0.302444453894 + +mat9 cone patterns.16.disk9.seg.20 +0 +0 +8 + -2.5 19.6 7.49765992728 + -2.5 19.6 7.50050073684 + 0.302444453894 0.294361166986 + +mat9 cone patterns.16.disk9.seg.21 +0 +0 +8 + -2.5 19.6 7.50050073684 + -2.5 19.6 7.50326446613 + 0.294361166986 0.286251202333 + +mat9 cone patterns.16.disk9.seg.22 +0 +0 +8 + -2.5 19.6 7.50326446613 + -2.5 19.6 7.50595086467 + 0.286251202333 0.278115294937 + +mat9 cone patterns.16.disk9.seg.23 +0 +0 +8 + -2.5 19.6 7.50595086467 + -2.5 19.6 7.50855968898 + 0.278115294937 0.269954182149 + +mat9 cone patterns.16.disk9.seg.24 +0 +0 +8 + -2.5 19.6 7.50855968898 + -2.5 19.6 7.51109070264 + 0.269954182149 0.261768603605 + +mat9 cone patterns.16.disk9.seg.25 +0 +0 +8 + -2.5 19.6 7.51109070264 + -2.5 19.6 7.51354367625 + 0.261768603605 0.253559301157 + +mat9 cone patterns.16.disk9.seg.26 +0 +0 +8 + -2.5 19.6 7.51354367625 + -2.5 19.6 7.51591838752 + 0.253559301157 0.24532701881 + +mat9 cone patterns.16.disk9.seg.27 +0 +0 +8 + -2.5 19.6 7.51591838752 + -2.5 19.6 7.51821462121 + 0.24532701881 0.237072502648 + +mat9 cone patterns.16.disk9.seg.28 +0 +0 +8 + -2.5 19.6 7.51821462121 + -2.5 19.6 7.52043216923 + 0.237072502648 0.228796500774 + +mat9 cone patterns.16.disk9.seg.29 +0 +0 +8 + -2.5 19.6 7.52043216923 + -2.5 19.6 7.5225708306 + 0.228796500774 0.220499763235 + +mat9 cone patterns.16.disk9.seg.30 +0 +0 +8 + -2.5 19.6 7.5225708306 + -2.5 19.6 7.52463041149 + 0.220499763235 0.212183041958 + +mat9 cone patterns.16.disk9.seg.31 +0 +0 +8 + -2.5 19.6 7.52463041149 + -2.5 19.6 7.52661072525 + 0.212183041958 0.203847090683 + +mat9 cone patterns.16.disk9.seg.32 +0 +0 +8 + -2.5 19.6 7.52661072525 + -2.5 19.6 7.5285115924 + 0.203847090683 0.19549266489 + +mat9 cone patterns.16.disk9.seg.33 +0 +0 +8 + -2.5 19.6 7.5285115924 + -2.5 19.6 7.53033284066 + 0.19549266489 0.187120521736 + +mat9 cone patterns.16.disk9.seg.34 +0 +0 +8 + -2.5 19.6 7.53033284066 + -2.5 19.6 7.53207430498 + 0.187120521736 0.178731419981 + +mat9 cone patterns.16.disk9.seg.35 +0 +0 +8 + -2.5 19.6 7.53207430498 + -2.5 19.6 7.53373582754 + 0.178731419981 0.170326119924 + +mat9 cone patterns.16.disk9.seg.36 +0 +0 +8 + -2.5 19.6 7.53373582754 + -2.5 19.6 7.53531725774 + 0.170326119924 0.161905383332 + +mat9 cone patterns.16.disk9.seg.37 +0 +0 +8 + -2.5 19.6 7.53531725774 + -2.5 19.6 7.53681845226 + 0.161905383332 0.153469973369 + +mat9 cone patterns.16.disk9.seg.38 +0 +0 +8 + -2.5 19.6 7.53681845226 + -2.5 19.6 7.53823927506 + 0.153469973369 0.145020654532 + +mat9 cone patterns.16.disk9.seg.39 +0 +0 +8 + -2.5 19.6 7.53823927506 + -2.5 19.6 7.53957959736 + 0.145020654532 0.136558192575 + +mat9 cone patterns.16.disk9.seg.40 +0 +0 +8 + -2.5 19.6 7.53957959736 + -2.5 19.6 7.54083929769 + 0.136558192575 0.128083354446 + +mat9 cone patterns.16.disk9.seg.41 +0 +0 +8 + -2.5 19.6 7.54083929769 + -2.5 19.6 7.54201826189 + 0.128083354446 0.119596908213 + +mat9 cone patterns.16.disk9.seg.42 +0 +0 +8 + -2.5 19.6 7.54201826189 + -2.5 19.6 7.5431163831 + 0.119596908213 0.111099622997 + +mat9 cone patterns.16.disk9.seg.43 +0 +0 +8 + -2.5 19.6 7.5431163831 + -2.5 19.6 7.54413356181 + 0.111099622997 0.102592268901 + +mat9 cone patterns.16.disk9.seg.44 +0 +0 +8 + -2.5 19.6 7.54413356181 + -2.5 19.6 7.54506970583 + 0.102592268901 0.0940756169409 + +mat9 cone patterns.16.disk9.seg.45 +0 +0 +8 + -2.5 19.6 7.54506970583 + -2.5 19.6 7.54592473032 + 0.0940756169409 0.0855504389738 + +mat9 cone patterns.16.disk9.seg.46 +0 +0 +8 + -2.5 19.6 7.54592473032 + -2.5 19.6 7.54669855778 + 0.0855504389738 0.077017507631 + +mat9 cone patterns.16.disk9.seg.47 +0 +0 +8 + -2.5 19.6 7.54669855778 + -2.5 19.6 7.54739111808 + 0.077017507631 0.068477596246 + +mat9 cone patterns.16.disk9.seg.48 +0 +0 +8 + -2.5 19.6 7.54739111808 + -2.5 19.6 7.54800234847 + 0.068477596246 0.059931478785 + +mat9 cone patterns.16.disk9.seg.49 +0 +0 +8 + -2.5 19.6 7.54800234847 + -2.5 19.6 7.54853219353 + 0.059931478785 0.0513799297765 + +mat9 cone patterns.16.disk9.seg.50 +0 +0 +8 + -2.5 19.6 7.54853219353 + -2.5 19.6 7.54898060527 + 0.0513799297765 0.0428237242414 + +mat9 cone patterns.16.disk9.seg.51 +0 +0 +8 + -2.5 19.6 7.54898060527 + -2.5 19.6 7.54934754302 + 0.0428237242414 0.0342636376225 + +mat9 cone patterns.16.disk9.seg.52 +0 +0 +8 + -2.5 19.6 7.54934754302 + -2.5 19.6 7.54963297355 + 0.0342636376225 0.0257004457143 + +mat9 cone patterns.16.disk9.seg.53 +0 +0 +8 + -2.5 19.6 7.54963297355 + -2.5 19.6 7.54983687097 + 0.0257004457143 0.017134924593 + +mat9 cone patterns.16.disk9.seg.54 +0 +0 +8 + -2.5 19.6 7.54983687097 + -2.5 19.6 7.54995921682 + 0.017134924593 0.00856785054562 + +mat9 cone patterns.16.disk9.seg.55 +0 +0 +8 + -2.5 19.6 7.54995921682 + -2.5 19.6 7.55 + 0.00856785054562 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# xform -s 0.0253999863 -rz 90 -t -4 2.5 2.999 +# +# Wellmade 2 lamp fixture, model 395-12A-248RS +# +# Dimensions in inches, fixture parallel to y axis, center at origin +# + +void brightdata lum_dist +19 flatcorr rect_fixture.dat source.cal src_phi4 src_theta -s 0.0253999863 -rz 90 -t -4 2.5 2.999 -i 1 -t 0 15.6 6.4 +0 +0 +# this is scaled by 1/area (SI) + +lum_dist light lum_bright +0 +0 +3 20 20 20 +# 3 1.55 1.55 1.55 + +lum_bright polygon patterns.16.luminaire +0 +0 +12 + -3.42215031167 17.8269501473 9.399 + -4.57784968833 17.8269501473 9.399 + -4.57784968833 18.3730498527 9.399 + -3.42215031167 18.3730498527 9.399 +# xform -n mixtex.17 -t 0 0 9.6 +# +# A set of mixtures and textures applied to 9 materials +# + +void metal2 brushed_gold +10 0 1 0 . -i 1 -t 0 0 9.6 +0 +6 0.99717 0.781957 0.334172 1 0.01 0.04 + +void plastic white +0 +0 +5 0.8 0.8 0.8 0 0 + +void mixdata mat7 +13 white brushed_gold noneg flower.dat . (Py-.7)/.6 (-Px-2.2)/.6 -i 1 -t 0 0 9.6 +0 +0 + +void mixpict mat8 +13 white brushed_gold grey flower.hdr . (Py-2.2)/.6 (-Px-2.2)/.6 -i 1 -t 0 0 9.6 +0 +0 + +void texfunc bumpy_func +12 A1*noise3x(Px,Py,Pz) A1*noise3y(Px,Py,Pz) 0 . -s .02 -i 1 -t 0 0 9.6 +0 +1 0.15 + +bumpy_func alias mat5 + brushed_gold + +void texdata bumpy_pat +15 tdxf tdyf tdzf flower.dat flower.dat flower.dat bumpypat.cal (Py-3.7)/.6 (-Px-3.7)/.6 -i 1 -t 0 0 9.6 +0 +1 0.15 + +bumpy_pat alias mat6 + brushed_gold + +void plasdata mat9 +13 noop sawtooth.dat diskcoords.cal sqx_in sqy_in sqx_out sqy_out -i 1 -t 0 0 9.6 +0 +7 0.5 0.5 0.5 0.05 -1 0 0 + +void metdata mat3 +13 noop sawtooth.dat diskcoords.cal sqx_in sqy_in sqx_out sqy_out -i 1 -t 0 0 9.6 +0 +7 0.9 0.5 0.8 0.95 -1 0 0 + +void BSDF mat2 +12 0 sawtooth.xml -1 0 0 . -i 1 -t 0 0 9.6 +0 +0 + +void aBSDF mat1 +11 blinds20c.xml -1 0 0 . -i 1 -t 0 0 9.6 +0 +0 + +void transdata mat4 +10 noop tcutoff.dat maxang.cal maxang -i 1 -t 0 0 9.6 +0 +6 0.9 0.9 0.9 0.07 0.9 1 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c + +black_outside polygon mixtex.17.wall.b +0 +0 +30 + -6.12323399574e-18 -0.1 9.5 + -6.12323399574e-18 5.1 9.5 + 1.89820253868e-16 5.1 12.7 + 1.89820253868e-16 -0.1 12.7 + -6.12323399574e-18 -0.1 9.5 + 0 0 9.6 + 1.83697019872e-16 0 12.6 + 1.83697019872e-16 5 12.6 + 0 5 9.6 + 0 0 9.6 + +black_outside polygon mixtex.17.wall.t +0 +0 +30 + -8 0 9.6 + -8 5 9.6 + -8 5 12.6 + -8 0 12.6 + -8 0 9.6 + -8 -0.1 9.5 + -8 -0.1 12.7 + -8 5.1 12.7 + -8 5.1 9.5 + -8 -0.1 9.5 + +black_outside polygon mixtex.17.wall.1 +0 +0 +12 + -6.12323399574e-18 -0.1 9.5 + -8 -0.1 9.5 + -8 5.1 9.5 + -6.12323399574e-18 5.1 9.5 + +black_outside polygon mixtex.17.wall.2 +0 +0 +12 + -6.12323399574e-18 5.1 9.5 + -8 5.1 9.5 + -8 5.1 12.7 + 1.89820253868e-16 5.1 12.7 + +black_outside polygon mixtex.17.wall.3 +0 +0 +12 + 1.89820253868e-16 5.1 12.7 + -8 5.1 12.7 + -8 -0.1 12.7 + 1.89820253868e-16 -0.1 12.7 + +black_outside polygon mixtex.17.wall.4 +0 +0 +12 + 1.89820253868e-16 -0.1 12.7 + -8 -0.1 12.7 + -8 -0.1 9.5 + -6.12323399574e-18 -0.1 9.5 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 + +wall_mat polygon mixtex.17.wall.6 +0 +0 +12 + 0 0 9.6 + -8 0 9.6 + -8 0 12.6 + 1.83697019872e-16 0 12.6 + +ceil_mat polygon mixtex.17.wall.7 +0 +0 +12 + 1.83697019872e-16 0 12.6 + -8 0 12.6 + -8 5 12.6 + 1.83697019872e-16 5 12.6 + +wall_mat polygon mixtex.17.wall.8 +0 +0 +12 + 1.83697019872e-16 5 12.6 + -8 5 12.6 + -8 5 9.6 + 0 5 9.6 + +floor_mat polygon mixtex.17.wall.9 +0 +0 +12 + 0 5 9.6 + -8 5 9.6 + -8 0 9.6 + 0 0 9.6 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A bluish glass pane to fit any opening in end wall + +void glass glass_blue +0 +0 +4 0.7 0.9 0.98 1.5 + +glass_blue polygon mixtex.17.blue_glazing +0 +0 +12 + -8.1 0 9.6 + -8.1 5 9.6 + -8.1 5 12.6 + -8.1 0 12.6 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Venetian blinds with BSDF in rectangular window +#@mkillum f=blinds_ill c=d d=200 s=100 i=m_blinds20c_f +# xform -rz 90 -ry 90 -t -8.04 2.5 1.5 +# Produced by: pkgBSDF blinds20c.xml +# Material 'Green specular venetian blinds at 20 degree angle' by 'Greg Ward' + +void BSDF m_blinds20c_f +22 0.0375926 blinds20c.xml 0 1 0 . -i 1 -rz 90 -ry 90 -t -8.04 2.5 1.5 -i 1 -t 0 0 9.6 +0 +0 + +m_blinds20c_f polygon mixtex.17.blinds20c_f +0 +0 +12 + -8.03999924818 1 10.6131551 + -8.03999924818 4 10.6131551 + -8.03999924818 4 11.5868449 + -8.03999924818 1 11.5868449 + +void BSDF m_blinds20c_b +22 -0.0375926 blinds20c.xml 0 1 0 . -i 1 -rz 90 -ry 90 -t -8.04 2.5 1.5 -i 1 -t 0 0 9.6 +0 +0 + +m_blinds20c_b polygon mixtex.17.blinds20c_b +0 +0 +12 + -8.07759185 1 10.6131551 + -8.07759185 4 10.6131551 + -8.07759185 4 11.5868449 + -8.07759185 1 11.5868449 +## Translated from MGF Version 2.0 +## mgf2rad +## mgf2rad /tmp/rtAhkTMq ############################## +# Y-axis points "up", Z-axis into room, right-handed coordinates + +void plastic MagentaPlastic +0 +0 +5 1.677905 0.34403 0.600828 0.02 0.05 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a0.mSlat.f1 +0 +0 +12 + -8.07758770483 1 10.6131551943 + -8.07758770483 4 10.6131551943 + -8.04 4 10.626836 + -8.04 1 10.626836 + +void metal SpecularGreen +0 +0 +5 0.138419 0.898658 0.171458 0.923077 0.03 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a0.gSlat.f2 +0 +0 +12 + -8.07759112503 1 10.6131645912 + -8.07759112503 4 10.6131645912 + -8.0400034202 4 10.6268453969 + -8.0400034202 1 10.6268453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a1.mSlat.f3 +0 +0 +12 + -8.07758770483 1 10.6431551943 + -8.07758770483 4 10.6431551943 + -8.04 4 10.656836 + -8.04 1 10.656836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a1.gSlat.f4 +0 +0 +12 + -8.07759112503 1 10.6431645912 + -8.07759112503 4 10.6431645912 + -8.0400034202 4 10.6568453969 + -8.0400034202 1 10.6568453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a2.mSlat.f5 +0 +0 +12 + -8.07758770483 1 10.6731551943 + -8.07758770483 4 10.6731551943 + -8.04 4 10.686836 + -8.04 1 10.686836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a2.gSlat.f6 +0 +0 +12 + -8.07759112503 1 10.6731645912 + -8.07759112503 4 10.6731645912 + -8.0400034202 4 10.6868453969 + -8.0400034202 1 10.6868453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a3.mSlat.f7 +0 +0 +12 + -8.07758770483 1 10.7031551943 + -8.07758770483 4 10.7031551943 + -8.04 4 10.716836 + -8.04 1 10.716836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a3.gSlat.f8 +0 +0 +12 + -8.07759112503 1 10.7031645912 + -8.07759112503 4 10.7031645912 + -8.0400034202 4 10.7168453969 + -8.0400034202 1 10.7168453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a4.mSlat.f9 +0 +0 +12 + -8.07758770483 1 10.7331551943 + -8.07758770483 4 10.7331551943 + -8.04 4 10.746836 + -8.04 1 10.746836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a4.gSlat.f10 +0 +0 +12 + -8.07759112503 1 10.7331645912 + -8.07759112503 4 10.7331645912 + -8.0400034202 4 10.7468453969 + -8.0400034202 1 10.7468453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a5.mSlat.f11 +0 +0 +12 + -8.07758770483 1 10.7631551943 + -8.07758770483 4 10.7631551943 + -8.04 4 10.776836 + -8.04 1 10.776836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a5.gSlat.f12 +0 +0 +12 + -8.07759112503 1 10.7631645912 + -8.07759112503 4 10.7631645912 + -8.0400034202 4 10.7768453969 + -8.0400034202 1 10.7768453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a6.mSlat.f13 +0 +0 +12 + -8.07758770483 1 10.7931551943 + -8.07758770483 4 10.7931551943 + -8.04 4 10.806836 + -8.04 1 10.806836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a6.gSlat.f14 +0 +0 +12 + -8.07759112503 1 10.7931645912 + -8.07759112503 4 10.7931645912 + -8.0400034202 4 10.8068453969 + -8.0400034202 1 10.8068453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a7.mSlat.f15 +0 +0 +12 + -8.07758770483 1 10.8231551943 + -8.07758770483 4 10.8231551943 + -8.04 4 10.836836 + -8.04 1 10.836836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a7.gSlat.f16 +0 +0 +12 + -8.07759112503 1 10.8231645912 + -8.07759112503 4 10.8231645912 + -8.0400034202 4 10.8368453969 + -8.0400034202 1 10.8368453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a8.mSlat.f17 +0 +0 +12 + -8.07758770483 1 10.8531551943 + -8.07758770483 4 10.8531551943 + -8.04 4 10.866836 + -8.04 1 10.866836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a8.gSlat.f18 +0 +0 +12 + -8.07759112503 1 10.8531645912 + -8.07759112503 4 10.8531645912 + -8.0400034202 4 10.8668453969 + -8.0400034202 1 10.8668453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a9.mSlat.f19 +0 +0 +12 + -8.07758770483 1 10.8831551943 + -8.07758770483 4 10.8831551943 + -8.04 4 10.896836 + -8.04 1 10.896836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a9.gSlat.f20 +0 +0 +12 + -8.07759112503 1 10.8831645912 + -8.07759112503 4 10.8831645912 + -8.0400034202 4 10.8968453969 + -8.0400034202 1 10.8968453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a10.mSlat.f21 +0 +0 +12 + -8.07758770483 1 10.9131551943 + -8.07758770483 4 10.9131551943 + -8.04 4 10.926836 + -8.04 1 10.926836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a10.gSlat.f22 +0 +0 +12 + -8.07759112503 1 10.9131645912 + -8.07759112503 4 10.9131645912 + -8.0400034202 4 10.9268453969 + -8.0400034202 1 10.9268453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a11.mSlat.f23 +0 +0 +12 + -8.07758770483 1 10.9431551943 + -8.07758770483 4 10.9431551943 + -8.04 4 10.956836 + -8.04 1 10.956836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a11.gSlat.f24 +0 +0 +12 + -8.07759112503 1 10.9431645912 + -8.07759112503 4 10.9431645912 + -8.0400034202 4 10.9568453969 + -8.0400034202 1 10.9568453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a12.mSlat.f25 +0 +0 +12 + -8.07758770483 1 10.9731551943 + -8.07758770483 4 10.9731551943 + -8.04 4 10.986836 + -8.04 1 10.986836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a12.gSlat.f26 +0 +0 +12 + -8.07759112503 1 10.9731645912 + -8.07759112503 4 10.9731645912 + -8.0400034202 4 10.9868453969 + -8.0400034202 1 10.9868453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a13.mSlat.f27 +0 +0 +12 + -8.07758770483 1 11.0031551943 + -8.07758770483 4 11.0031551943 + -8.04 4 11.016836 + -8.04 1 11.016836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a13.gSlat.f28 +0 +0 +12 + -8.07759112503 1 11.0031645912 + -8.07759112503 4 11.0031645912 + -8.0400034202 4 11.0168453969 + -8.0400034202 1 11.0168453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a14.mSlat.f29 +0 +0 +12 + -8.07758770483 1 11.0331551943 + -8.07758770483 4 11.0331551943 + -8.04 4 11.046836 + -8.04 1 11.046836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a14.gSlat.f30 +0 +0 +12 + -8.07759112503 1 11.0331645912 + -8.07759112503 4 11.0331645912 + -8.0400034202 4 11.0468453969 + -8.0400034202 1 11.0468453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a15.mSlat.f31 +0 +0 +12 + -8.07758770483 1 11.0631551943 + -8.07758770483 4 11.0631551943 + -8.04 4 11.076836 + -8.04 1 11.076836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a15.gSlat.f32 +0 +0 +12 + -8.07759112503 1 11.0631645912 + -8.07759112503 4 11.0631645912 + -8.0400034202 4 11.0768453969 + -8.0400034202 1 11.0768453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a16.mSlat.f33 +0 +0 +12 + -8.07758770483 1 11.0931551943 + -8.07758770483 4 11.0931551943 + -8.04 4 11.106836 + -8.04 1 11.106836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a16.gSlat.f34 +0 +0 +12 + -8.07759112503 1 11.0931645912 + -8.07759112503 4 11.0931645912 + -8.0400034202 4 11.1068453969 + -8.0400034202 1 11.1068453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a17.mSlat.f35 +0 +0 +12 + -8.07758770483 1 11.1231551943 + -8.07758770483 4 11.1231551943 + -8.04 4 11.136836 + -8.04 1 11.136836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a17.gSlat.f36 +0 +0 +12 + -8.07759112503 1 11.1231645912 + -8.07759112503 4 11.1231645912 + -8.0400034202 4 11.1368453969 + -8.0400034202 1 11.1368453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a18.mSlat.f37 +0 +0 +12 + -8.07758770483 1 11.1531551943 + -8.07758770483 4 11.1531551943 + -8.04 4 11.166836 + -8.04 1 11.166836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a18.gSlat.f38 +0 +0 +12 + -8.07759112503 1 11.1531645912 + -8.07759112503 4 11.1531645912 + -8.0400034202 4 11.1668453969 + -8.0400034202 1 11.1668453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a19.mSlat.f39 +0 +0 +12 + -8.07758770483 1 11.1831551943 + -8.07758770483 4 11.1831551943 + -8.04 4 11.196836 + -8.04 1 11.196836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a19.gSlat.f40 +0 +0 +12 + -8.07759112503 1 11.1831645912 + -8.07759112503 4 11.1831645912 + -8.0400034202 4 11.1968453969 + -8.0400034202 1 11.1968453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a20.mSlat.f41 +0 +0 +12 + -8.07758770483 1 11.2131551943 + -8.07758770483 4 11.2131551943 + -8.04 4 11.226836 + -8.04 1 11.226836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a20.gSlat.f42 +0 +0 +12 + -8.07759112503 1 11.2131645912 + -8.07759112503 4 11.2131645912 + -8.0400034202 4 11.2268453969 + -8.0400034202 1 11.2268453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a21.mSlat.f43 +0 +0 +12 + -8.07758770483 1 11.2431551943 + -8.07758770483 4 11.2431551943 + -8.04 4 11.256836 + -8.04 1 11.256836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a21.gSlat.f44 +0 +0 +12 + -8.07759112503 1 11.2431645912 + -8.07759112503 4 11.2431645912 + -8.0400034202 4 11.2568453969 + -8.0400034202 1 11.2568453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a22.mSlat.f45 +0 +0 +12 + -8.07758770483 1 11.2731551943 + -8.07758770483 4 11.2731551943 + -8.04 4 11.286836 + -8.04 1 11.286836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a22.gSlat.f46 +0 +0 +12 + -8.07759112503 1 11.2731645912 + -8.07759112503 4 11.2731645912 + -8.0400034202 4 11.2868453969 + -8.0400034202 1 11.2868453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a23.mSlat.f47 +0 +0 +12 + -8.07758770483 1 11.3031551943 + -8.07758770483 4 11.3031551943 + -8.04 4 11.316836 + -8.04 1 11.316836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a23.gSlat.f48 +0 +0 +12 + -8.07759112503 1 11.3031645912 + -8.07759112503 4 11.3031645912 + -8.0400034202 4 11.3168453969 + -8.0400034202 1 11.3168453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a24.mSlat.f49 +0 +0 +12 + -8.07758770483 1 11.3331551943 + -8.07758770483 4 11.3331551943 + -8.04 4 11.346836 + -8.04 1 11.346836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a24.gSlat.f50 +0 +0 +12 + -8.07759112503 1 11.3331645912 + -8.07759112503 4 11.3331645912 + -8.0400034202 4 11.3468453969 + -8.0400034202 1 11.3468453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a25.mSlat.f51 +0 +0 +12 + -8.07758770483 1 11.3631551943 + -8.07758770483 4 11.3631551943 + -8.04 4 11.376836 + -8.04 1 11.376836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a25.gSlat.f52 +0 +0 +12 + -8.07759112503 1 11.3631645912 + -8.07759112503 4 11.3631645912 + -8.0400034202 4 11.3768453969 + -8.0400034202 1 11.3768453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a26.mSlat.f53 +0 +0 +12 + -8.07758770483 1 11.3931551943 + -8.07758770483 4 11.3931551943 + -8.04 4 11.406836 + -8.04 1 11.406836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a26.gSlat.f54 +0 +0 +12 + -8.07759112503 1 11.3931645912 + -8.07759112503 4 11.3931645912 + -8.0400034202 4 11.4068453969 + -8.0400034202 1 11.4068453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a27.mSlat.f55 +0 +0 +12 + -8.07758770483 1 11.4231551943 + -8.07758770483 4 11.4231551943 + -8.04 4 11.436836 + -8.04 1 11.436836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a27.gSlat.f56 +0 +0 +12 + -8.07759112503 1 11.4231645912 + -8.07759112503 4 11.4231645912 + -8.0400034202 4 11.4368453969 + -8.0400034202 1 11.4368453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a28.mSlat.f57 +0 +0 +12 + -8.07758770483 1 11.4531551943 + -8.07758770483 4 11.4531551943 + -8.04 4 11.466836 + -8.04 1 11.466836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a28.gSlat.f58 +0 +0 +12 + -8.07759112503 1 11.4531645912 + -8.07759112503 4 11.4531645912 + -8.0400034202 4 11.4668453969 + -8.0400034202 1 11.4668453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a29.mSlat.f59 +0 +0 +12 + -8.07758770483 1 11.4831551943 + -8.07758770483 4 11.4831551943 + -8.04 4 11.496836 + -8.04 1 11.496836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a29.gSlat.f60 +0 +0 +12 + -8.07759112503 1 11.4831645912 + -8.07759112503 4 11.4831645912 + -8.0400034202 4 11.4968453969 + -8.0400034202 1 11.4968453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a30.mSlat.f61 +0 +0 +12 + -8.07758770483 1 11.5131551943 + -8.07758770483 4 11.5131551943 + -8.04 4 11.526836 + -8.04 1 11.526836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a30.gSlat.f62 +0 +0 +12 + -8.07759112503 1 11.5131645912 + -8.07759112503 4 11.5131645912 + -8.0400034202 4 11.5268453969 + -8.0400034202 1 11.5268453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a31.mSlat.f63 +0 +0 +12 + -8.07758770483 1 11.5431551943 + -8.07758770483 4 11.5431551943 + -8.04 4 11.556836 + -8.04 1 11.556836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a31.gSlat.f64 +0 +0 +12 + -8.07759112503 1 11.5431645912 + -8.07759112503 4 11.5431645912 + -8.0400034202 4 11.5568453969 + -8.0400034202 1 11.5568453969 + +MagentaPlastic polygon mixtex.17.VenetianBlinds.a32.mSlat.f65 +0 +0 +12 + -8.07758770483 1 11.5731551943 + -8.07758770483 4 11.5731551943 + -8.04 4 11.586836 + -8.04 1 11.586836 + +SpecularGreen polygon mixtex.17.VenetianBlinds.a32.gSlat.f66 +0 +0 +12 + -8.07759112503 1 11.5731645912 + -8.07759112503 4 11.5731645912 + -8.0400034202 4 11.5868453969 + -8.0400034202 1 11.5868453969 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Rectangular opening cut in end wall +# xform -ry -90 -t -8 0 0 +# genprism wall_mat end_wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 1 1 2 1 2 4 1 4 1 1 -l 0 0 .2 -c + +wall_mat polygon mixtex.17.end_wall.b +0 +0 +30 + -8 -0.1 9.5 + -8 5.1 9.5 + -8 5.1 12.7 + -8 -0.1 12.7 + -8 -0.1 9.5 + -8 1 10.6 + -8 1 11.6 + -8 4 11.6 + -8 4 10.6 + -8 1 10.6 + +wall_mat polygon mixtex.17.end_wall.t +0 +0 +30 + -8.2 1 10.6 + -8.2 4 10.6 + -8.2 4 11.6 + -8.2 1 11.6 + -8.2 1 10.6 + -8.2 -0.1 9.5 + -8.2 -0.1 12.7 + -8.2 5.1 12.7 + -8.2 5.1 9.5 + -8.2 -0.1 9.5 + +wall_mat polygon mixtex.17.end_wall.1 +0 +0 +12 + -8 -0.1 9.5 + -8.2 -0.1 9.5 + -8.2 5.1 9.5 + -8 5.1 9.5 + +wall_mat polygon mixtex.17.end_wall.2 +0 +0 +12 + -8 5.1 9.5 + -8.2 5.1 9.5 + -8.2 5.1 12.7 + -8 5.1 12.7 + +wall_mat polygon mixtex.17.end_wall.3 +0 +0 +12 + -8 5.1 12.7 + -8.2 5.1 12.7 + -8.2 -0.1 12.7 + -8 -0.1 12.7 + +wall_mat polygon mixtex.17.end_wall.4 +0 +0 +12 + -8 -0.1 12.7 + -8.2 -0.1 12.7 + -8.2 -0.1 9.5 + -8 -0.1 9.5 + +wall_mat polygon mixtex.17.end_wall.5 +0 +0 +12 + -8 -0.1 9.5 + -8.2 -0.1 9.5 + -8.2 1 10.6 + -8 1 10.6 + +wall_mat polygon mixtex.17.end_wall.6 +0 +0 +12 + -8 1 10.6 + -8.2 1 10.6 + -8.2 1 11.6 + -8 1 11.6 + +wall_mat polygon mixtex.17.end_wall.7 +0 +0 +12 + -8 1 11.6 + -8.2 1 11.6 + -8.2 4 11.6 + -8 4 11.6 + +wall_mat polygon mixtex.17.end_wall.8 +0 +0 +12 + -8 4 11.6 + -8.2 4 11.6 + -8.2 4 10.6 + -8 4 10.6 + +wall_mat polygon mixtex.17.end_wall.9 +0 +0 +12 + -8 4 10.6 + -8.2 4 10.6 + -8.2 1 10.6 + -8 1 10.6 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A set of 9 disks to be painted in various modes +# +# xform -m mat1 -n disk1 -t -5.5 1 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat1 cone mixtex.17.disk1.seg.1 +0 +0 +8 + -5.5 1 10.6294228634 + -5.5 1 10.6336714694 + 0.45 0.442559632181 + +mat1 cone mixtex.17.disk1.seg.2 +0 +0 +8 + -5.5 1 10.6336714694 + -5.5 1 10.6378490518 + 0.442559632181 0.435079155496 + +mat1 cone mixtex.17.disk1.seg.3 +0 +0 +8 + -5.5 1 10.6378490518 + -5.5 1 10.641955232 + 0.435079155496 0.427559247895 + +mat1 cone mixtex.17.disk1.seg.4 +0 +0 +8 + -5.5 1 10.641955232 + -5.5 1 10.6459896379 + 0.427559247895 0.420000590903 + +mat1 cone mixtex.17.disk1.seg.5 +0 +0 +8 + -5.5 1 10.6459896379 + -5.5 1 10.6499519038 + 0.420000590903 0.412403869555 + +mat1 cone mixtex.17.disk1.seg.6 +0 +0 +8 + -5.5 1 10.6499519038 + -5.5 1 10.6538416706 + 0.412403869555 0.404769772336 + +mat1 cone mixtex.17.disk1.seg.7 +0 +0 +8 + -5.5 1 10.6538416706 + -5.5 1 10.6576585858 + 0.404769772336 0.397098991119 + +mat1 cone mixtex.17.disk1.seg.8 +0 +0 +8 + -5.5 1 10.6576585858 + -5.5 1 10.6614023035 + 0.397098991119 0.389392221102 + +mat1 cone mixtex.17.disk1.seg.9 +0 +0 +8 + -5.5 1 10.6614023035 + -5.5 1 10.6650724844 + 0.389392221102 0.381650160744 + +mat1 cone mixtex.17.disk1.seg.10 +0 +0 +8 + -5.5 1 10.6650724844 + -5.5 1 10.6686687958 + 0.381650160744 0.373873511702 + +mat1 cone mixtex.17.disk1.seg.11 +0 +0 +8 + -5.5 1 10.6686687958 + -5.5 1 10.6721909119 + 0.373873511702 0.366062978768 + +mat1 cone mixtex.17.disk1.seg.12 +0 +0 +8 + -5.5 1 10.6721909119 + -5.5 1 10.6756385134 + 0.366062978768 0.358219269806 + +mat1 cone mixtex.17.disk1.seg.13 +0 +0 +8 + -5.5 1 10.6756385134 + -5.5 1 10.6790112878 + 0.358219269806 0.350343095686 + +mat1 cone mixtex.17.disk1.seg.14 +0 +0 +8 + -5.5 1 10.6790112878 + -5.5 1 10.6823089295 + 0.350343095686 0.342435170218 + +mat1 cone mixtex.17.disk1.seg.15 +0 +0 +8 + -5.5 1 10.6823089295 + -5.5 1 10.6855311397 + 0.342435170218 0.334496210094 + +mat1 cone mixtex.17.disk1.seg.16 +0 +0 +8 + -5.5 1 10.6855311397 + -5.5 1 10.6886776263 + 0.334496210094 0.326526934816 + +mat1 cone mixtex.17.disk1.seg.17 +0 +0 +8 + -5.5 1 10.6886776263 + -5.5 1 10.6917481041 + 0.326526934816 0.318528066632 + +mat1 cone mixtex.17.disk1.seg.18 +0 +0 +8 + -5.5 1 10.6917481041 + -5.5 1 10.6947422949 + 0.318528066632 0.310500330475 + +mat1 cone mixtex.17.disk1.seg.19 +0 +0 +8 + -5.5 1 10.6947422949 + -5.5 1 10.6976599273 + 0.310500330475 0.302444453894 + +mat1 cone mixtex.17.disk1.seg.20 +0 +0 +8 + -5.5 1 10.6976599273 + -5.5 1 10.7005007368 + 0.302444453894 0.294361166986 + +mat1 cone mixtex.17.disk1.seg.21 +0 +0 +8 + -5.5 1 10.7005007368 + -5.5 1 10.7032644661 + 0.294361166986 0.286251202333 + +mat1 cone mixtex.17.disk1.seg.22 +0 +0 +8 + -5.5 1 10.7032644661 + -5.5 1 10.7059508647 + 0.286251202333 0.278115294937 + +mat1 cone mixtex.17.disk1.seg.23 +0 +0 +8 + -5.5 1 10.7059508647 + -5.5 1 10.708559689 + 0.278115294937 0.269954182149 + +mat1 cone mixtex.17.disk1.seg.24 +0 +0 +8 + -5.5 1 10.708559689 + -5.5 1 10.7110907026 + 0.269954182149 0.261768603605 + +mat1 cone mixtex.17.disk1.seg.25 +0 +0 +8 + -5.5 1 10.7110907026 + -5.5 1 10.7135436762 + 0.261768603605 0.253559301157 + +mat1 cone mixtex.17.disk1.seg.26 +0 +0 +8 + -5.5 1 10.7135436762 + -5.5 1 10.7159183875 + 0.253559301157 0.24532701881 + +mat1 cone mixtex.17.disk1.seg.27 +0 +0 +8 + -5.5 1 10.7159183875 + -5.5 1 10.7182146212 + 0.24532701881 0.237072502648 + +mat1 cone mixtex.17.disk1.seg.28 +0 +0 +8 + -5.5 1 10.7182146212 + -5.5 1 10.7204321692 + 0.237072502648 0.228796500774 + +mat1 cone mixtex.17.disk1.seg.29 +0 +0 +8 + -5.5 1 10.7204321692 + -5.5 1 10.7225708306 + 0.228796500774 0.220499763235 + +mat1 cone mixtex.17.disk1.seg.30 +0 +0 +8 + -5.5 1 10.7225708306 + -5.5 1 10.7246304115 + 0.220499763235 0.212183041958 + +mat1 cone mixtex.17.disk1.seg.31 +0 +0 +8 + -5.5 1 10.7246304115 + -5.5 1 10.7266107252 + 0.212183041958 0.203847090683 + +mat1 cone mixtex.17.disk1.seg.32 +0 +0 +8 + -5.5 1 10.7266107252 + -5.5 1 10.7285115924 + 0.203847090683 0.19549266489 + +mat1 cone mixtex.17.disk1.seg.33 +0 +0 +8 + -5.5 1 10.7285115924 + -5.5 1 10.7303328407 + 0.19549266489 0.187120521736 + +mat1 cone mixtex.17.disk1.seg.34 +0 +0 +8 + -5.5 1 10.7303328407 + -5.5 1 10.732074305 + 0.187120521736 0.178731419981 + +mat1 cone mixtex.17.disk1.seg.35 +0 +0 +8 + -5.5 1 10.732074305 + -5.5 1 10.7337358275 + 0.178731419981 0.170326119924 + +mat1 cone mixtex.17.disk1.seg.36 +0 +0 +8 + -5.5 1 10.7337358275 + -5.5 1 10.7353172577 + 0.170326119924 0.161905383332 + +mat1 cone mixtex.17.disk1.seg.37 +0 +0 +8 + -5.5 1 10.7353172577 + -5.5 1 10.7368184523 + 0.161905383332 0.153469973369 + +mat1 cone mixtex.17.disk1.seg.38 +0 +0 +8 + -5.5 1 10.7368184523 + -5.5 1 10.7382392751 + 0.153469973369 0.145020654532 + +mat1 cone mixtex.17.disk1.seg.39 +0 +0 +8 + -5.5 1 10.7382392751 + -5.5 1 10.7395795974 + 0.145020654532 0.136558192575 + +mat1 cone mixtex.17.disk1.seg.40 +0 +0 +8 + -5.5 1 10.7395795974 + -5.5 1 10.7408392977 + 0.136558192575 0.128083354446 + +mat1 cone mixtex.17.disk1.seg.41 +0 +0 +8 + -5.5 1 10.7408392977 + -5.5 1 10.7420182619 + 0.128083354446 0.119596908213 + +mat1 cone mixtex.17.disk1.seg.42 +0 +0 +8 + -5.5 1 10.7420182619 + -5.5 1 10.7431163831 + 0.119596908213 0.111099622997 + +mat1 cone mixtex.17.disk1.seg.43 +0 +0 +8 + -5.5 1 10.7431163831 + -5.5 1 10.7441335618 + 0.111099622997 0.102592268901 + +mat1 cone mixtex.17.disk1.seg.44 +0 +0 +8 + -5.5 1 10.7441335618 + -5.5 1 10.7450697058 + 0.102592268901 0.0940756169409 + +mat1 cone mixtex.17.disk1.seg.45 +0 +0 +8 + -5.5 1 10.7450697058 + -5.5 1 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat1 cone mixtex.17.disk1.seg.46 +0 +0 +8 + -5.5 1 10.7459247303 + -5.5 1 10.7466985578 + 0.0855504389738 0.077017507631 + +mat1 cone mixtex.17.disk1.seg.47 +0 +0 +8 + -5.5 1 10.7466985578 + -5.5 1 10.7473911181 + 0.077017507631 0.068477596246 + +mat1 cone mixtex.17.disk1.seg.48 +0 +0 +8 + -5.5 1 10.7473911181 + -5.5 1 10.7480023485 + 0.068477596246 0.059931478785 + +mat1 cone mixtex.17.disk1.seg.49 +0 +0 +8 + -5.5 1 10.7480023485 + -5.5 1 10.7485321935 + 0.059931478785 0.0513799297765 + +mat1 cone mixtex.17.disk1.seg.50 +0 +0 +8 + -5.5 1 10.7485321935 + -5.5 1 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat1 cone mixtex.17.disk1.seg.51 +0 +0 +8 + -5.5 1 10.7489806053 + -5.5 1 10.749347543 + 0.0428237242414 0.0342636376225 + +mat1 cone mixtex.17.disk1.seg.52 +0 +0 +8 + -5.5 1 10.749347543 + -5.5 1 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat1 cone mixtex.17.disk1.seg.53 +0 +0 +8 + -5.5 1 10.7496329735 + -5.5 1 10.749836871 + 0.0257004457143 0.017134924593 + +mat1 cone mixtex.17.disk1.seg.54 +0 +0 +8 + -5.5 1 10.749836871 + -5.5 1 10.7499592168 + 0.017134924593 0.00856785054562 + +mat1 cone mixtex.17.disk1.seg.55 +0 +0 +8 + -5.5 1 10.7499592168 + -5.5 1 10.75 + 0.00856785054562 0 +# xform -m mat2 -n disk2 -t -5.5 2.5 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat2 cone mixtex.17.disk2.seg.1 +0 +0 +8 + -5.5 2.5 10.6294228634 + -5.5 2.5 10.6336714694 + 0.45 0.442559632181 + +mat2 cone mixtex.17.disk2.seg.2 +0 +0 +8 + -5.5 2.5 10.6336714694 + -5.5 2.5 10.6378490518 + 0.442559632181 0.435079155496 + +mat2 cone mixtex.17.disk2.seg.3 +0 +0 +8 + -5.5 2.5 10.6378490518 + -5.5 2.5 10.641955232 + 0.435079155496 0.427559247895 + +mat2 cone mixtex.17.disk2.seg.4 +0 +0 +8 + -5.5 2.5 10.641955232 + -5.5 2.5 10.6459896379 + 0.427559247895 0.420000590903 + +mat2 cone mixtex.17.disk2.seg.5 +0 +0 +8 + -5.5 2.5 10.6459896379 + -5.5 2.5 10.6499519038 + 0.420000590903 0.412403869555 + +mat2 cone mixtex.17.disk2.seg.6 +0 +0 +8 + -5.5 2.5 10.6499519038 + -5.5 2.5 10.6538416706 + 0.412403869555 0.404769772336 + +mat2 cone mixtex.17.disk2.seg.7 +0 +0 +8 + -5.5 2.5 10.6538416706 + -5.5 2.5 10.6576585858 + 0.404769772336 0.397098991119 + +mat2 cone mixtex.17.disk2.seg.8 +0 +0 +8 + -5.5 2.5 10.6576585858 + -5.5 2.5 10.6614023035 + 0.397098991119 0.389392221102 + +mat2 cone mixtex.17.disk2.seg.9 +0 +0 +8 + -5.5 2.5 10.6614023035 + -5.5 2.5 10.6650724844 + 0.389392221102 0.381650160744 + +mat2 cone mixtex.17.disk2.seg.10 +0 +0 +8 + -5.5 2.5 10.6650724844 + -5.5 2.5 10.6686687958 + 0.381650160744 0.373873511702 + +mat2 cone mixtex.17.disk2.seg.11 +0 +0 +8 + -5.5 2.5 10.6686687958 + -5.5 2.5 10.6721909119 + 0.373873511702 0.366062978768 + +mat2 cone mixtex.17.disk2.seg.12 +0 +0 +8 + -5.5 2.5 10.6721909119 + -5.5 2.5 10.6756385134 + 0.366062978768 0.358219269806 + +mat2 cone mixtex.17.disk2.seg.13 +0 +0 +8 + -5.5 2.5 10.6756385134 + -5.5 2.5 10.6790112878 + 0.358219269806 0.350343095686 + +mat2 cone mixtex.17.disk2.seg.14 +0 +0 +8 + -5.5 2.5 10.6790112878 + -5.5 2.5 10.6823089295 + 0.350343095686 0.342435170218 + +mat2 cone mixtex.17.disk2.seg.15 +0 +0 +8 + -5.5 2.5 10.6823089295 + -5.5 2.5 10.6855311397 + 0.342435170218 0.334496210094 + +mat2 cone mixtex.17.disk2.seg.16 +0 +0 +8 + -5.5 2.5 10.6855311397 + -5.5 2.5 10.6886776263 + 0.334496210094 0.326526934816 + +mat2 cone mixtex.17.disk2.seg.17 +0 +0 +8 + -5.5 2.5 10.6886776263 + -5.5 2.5 10.6917481041 + 0.326526934816 0.318528066632 + +mat2 cone mixtex.17.disk2.seg.18 +0 +0 +8 + -5.5 2.5 10.6917481041 + -5.5 2.5 10.6947422949 + 0.318528066632 0.310500330475 + +mat2 cone mixtex.17.disk2.seg.19 +0 +0 +8 + -5.5 2.5 10.6947422949 + -5.5 2.5 10.6976599273 + 0.310500330475 0.302444453894 + +mat2 cone mixtex.17.disk2.seg.20 +0 +0 +8 + -5.5 2.5 10.6976599273 + -5.5 2.5 10.7005007368 + 0.302444453894 0.294361166986 + +mat2 cone mixtex.17.disk2.seg.21 +0 +0 +8 + -5.5 2.5 10.7005007368 + -5.5 2.5 10.7032644661 + 0.294361166986 0.286251202333 + +mat2 cone mixtex.17.disk2.seg.22 +0 +0 +8 + -5.5 2.5 10.7032644661 + -5.5 2.5 10.7059508647 + 0.286251202333 0.278115294937 + +mat2 cone mixtex.17.disk2.seg.23 +0 +0 +8 + -5.5 2.5 10.7059508647 + -5.5 2.5 10.708559689 + 0.278115294937 0.269954182149 + +mat2 cone mixtex.17.disk2.seg.24 +0 +0 +8 + -5.5 2.5 10.708559689 + -5.5 2.5 10.7110907026 + 0.269954182149 0.261768603605 + +mat2 cone mixtex.17.disk2.seg.25 +0 +0 +8 + -5.5 2.5 10.7110907026 + -5.5 2.5 10.7135436762 + 0.261768603605 0.253559301157 + +mat2 cone mixtex.17.disk2.seg.26 +0 +0 +8 + -5.5 2.5 10.7135436762 + -5.5 2.5 10.7159183875 + 0.253559301157 0.24532701881 + +mat2 cone mixtex.17.disk2.seg.27 +0 +0 +8 + -5.5 2.5 10.7159183875 + -5.5 2.5 10.7182146212 + 0.24532701881 0.237072502648 + +mat2 cone mixtex.17.disk2.seg.28 +0 +0 +8 + -5.5 2.5 10.7182146212 + -5.5 2.5 10.7204321692 + 0.237072502648 0.228796500774 + +mat2 cone mixtex.17.disk2.seg.29 +0 +0 +8 + -5.5 2.5 10.7204321692 + -5.5 2.5 10.7225708306 + 0.228796500774 0.220499763235 + +mat2 cone mixtex.17.disk2.seg.30 +0 +0 +8 + -5.5 2.5 10.7225708306 + -5.5 2.5 10.7246304115 + 0.220499763235 0.212183041958 + +mat2 cone mixtex.17.disk2.seg.31 +0 +0 +8 + -5.5 2.5 10.7246304115 + -5.5 2.5 10.7266107252 + 0.212183041958 0.203847090683 + +mat2 cone mixtex.17.disk2.seg.32 +0 +0 +8 + -5.5 2.5 10.7266107252 + -5.5 2.5 10.7285115924 + 0.203847090683 0.19549266489 + +mat2 cone mixtex.17.disk2.seg.33 +0 +0 +8 + -5.5 2.5 10.7285115924 + -5.5 2.5 10.7303328407 + 0.19549266489 0.187120521736 + +mat2 cone mixtex.17.disk2.seg.34 +0 +0 +8 + -5.5 2.5 10.7303328407 + -5.5 2.5 10.732074305 + 0.187120521736 0.178731419981 + +mat2 cone mixtex.17.disk2.seg.35 +0 +0 +8 + -5.5 2.5 10.732074305 + -5.5 2.5 10.7337358275 + 0.178731419981 0.170326119924 + +mat2 cone mixtex.17.disk2.seg.36 +0 +0 +8 + -5.5 2.5 10.7337358275 + -5.5 2.5 10.7353172577 + 0.170326119924 0.161905383332 + +mat2 cone mixtex.17.disk2.seg.37 +0 +0 +8 + -5.5 2.5 10.7353172577 + -5.5 2.5 10.7368184523 + 0.161905383332 0.153469973369 + +mat2 cone mixtex.17.disk2.seg.38 +0 +0 +8 + -5.5 2.5 10.7368184523 + -5.5 2.5 10.7382392751 + 0.153469973369 0.145020654532 + +mat2 cone mixtex.17.disk2.seg.39 +0 +0 +8 + -5.5 2.5 10.7382392751 + -5.5 2.5 10.7395795974 + 0.145020654532 0.136558192575 + +mat2 cone mixtex.17.disk2.seg.40 +0 +0 +8 + -5.5 2.5 10.7395795974 + -5.5 2.5 10.7408392977 + 0.136558192575 0.128083354446 + +mat2 cone mixtex.17.disk2.seg.41 +0 +0 +8 + -5.5 2.5 10.7408392977 + -5.5 2.5 10.7420182619 + 0.128083354446 0.119596908213 + +mat2 cone mixtex.17.disk2.seg.42 +0 +0 +8 + -5.5 2.5 10.7420182619 + -5.5 2.5 10.7431163831 + 0.119596908213 0.111099622997 + +mat2 cone mixtex.17.disk2.seg.43 +0 +0 +8 + -5.5 2.5 10.7431163831 + -5.5 2.5 10.7441335618 + 0.111099622997 0.102592268901 + +mat2 cone mixtex.17.disk2.seg.44 +0 +0 +8 + -5.5 2.5 10.7441335618 + -5.5 2.5 10.7450697058 + 0.102592268901 0.0940756169409 + +mat2 cone mixtex.17.disk2.seg.45 +0 +0 +8 + -5.5 2.5 10.7450697058 + -5.5 2.5 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat2 cone mixtex.17.disk2.seg.46 +0 +0 +8 + -5.5 2.5 10.7459247303 + -5.5 2.5 10.7466985578 + 0.0855504389738 0.077017507631 + +mat2 cone mixtex.17.disk2.seg.47 +0 +0 +8 + -5.5 2.5 10.7466985578 + -5.5 2.5 10.7473911181 + 0.077017507631 0.068477596246 + +mat2 cone mixtex.17.disk2.seg.48 +0 +0 +8 + -5.5 2.5 10.7473911181 + -5.5 2.5 10.7480023485 + 0.068477596246 0.059931478785 + +mat2 cone mixtex.17.disk2.seg.49 +0 +0 +8 + -5.5 2.5 10.7480023485 + -5.5 2.5 10.7485321935 + 0.059931478785 0.0513799297765 + +mat2 cone mixtex.17.disk2.seg.50 +0 +0 +8 + -5.5 2.5 10.7485321935 + -5.5 2.5 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat2 cone mixtex.17.disk2.seg.51 +0 +0 +8 + -5.5 2.5 10.7489806053 + -5.5 2.5 10.749347543 + 0.0428237242414 0.0342636376225 + +mat2 cone mixtex.17.disk2.seg.52 +0 +0 +8 + -5.5 2.5 10.749347543 + -5.5 2.5 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat2 cone mixtex.17.disk2.seg.53 +0 +0 +8 + -5.5 2.5 10.7496329735 + -5.5 2.5 10.749836871 + 0.0257004457143 0.017134924593 + +mat2 cone mixtex.17.disk2.seg.54 +0 +0 +8 + -5.5 2.5 10.749836871 + -5.5 2.5 10.7499592168 + 0.017134924593 0.00856785054562 + +mat2 cone mixtex.17.disk2.seg.55 +0 +0 +8 + -5.5 2.5 10.7499592168 + -5.5 2.5 10.75 + 0.00856785054562 0 +# xform -m mat3 -n disk3 -t -5.5 4 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat3 cone mixtex.17.disk3.seg.1 +0 +0 +8 + -5.5 4 10.6294228634 + -5.5 4 10.6336714694 + 0.45 0.442559632181 + +mat3 cone mixtex.17.disk3.seg.2 +0 +0 +8 + -5.5 4 10.6336714694 + -5.5 4 10.6378490518 + 0.442559632181 0.435079155496 + +mat3 cone mixtex.17.disk3.seg.3 +0 +0 +8 + -5.5 4 10.6378490518 + -5.5 4 10.641955232 + 0.435079155496 0.427559247895 + +mat3 cone mixtex.17.disk3.seg.4 +0 +0 +8 + -5.5 4 10.641955232 + -5.5 4 10.6459896379 + 0.427559247895 0.420000590903 + +mat3 cone mixtex.17.disk3.seg.5 +0 +0 +8 + -5.5 4 10.6459896379 + -5.5 4 10.6499519038 + 0.420000590903 0.412403869555 + +mat3 cone mixtex.17.disk3.seg.6 +0 +0 +8 + -5.5 4 10.6499519038 + -5.5 4 10.6538416706 + 0.412403869555 0.404769772336 + +mat3 cone mixtex.17.disk3.seg.7 +0 +0 +8 + -5.5 4 10.6538416706 + -5.5 4 10.6576585858 + 0.404769772336 0.397098991119 + +mat3 cone mixtex.17.disk3.seg.8 +0 +0 +8 + -5.5 4 10.6576585858 + -5.5 4 10.6614023035 + 0.397098991119 0.389392221102 + +mat3 cone mixtex.17.disk3.seg.9 +0 +0 +8 + -5.5 4 10.6614023035 + -5.5 4 10.6650724844 + 0.389392221102 0.381650160744 + +mat3 cone mixtex.17.disk3.seg.10 +0 +0 +8 + -5.5 4 10.6650724844 + -5.5 4 10.6686687958 + 0.381650160744 0.373873511702 + +mat3 cone mixtex.17.disk3.seg.11 +0 +0 +8 + -5.5 4 10.6686687958 + -5.5 4 10.6721909119 + 0.373873511702 0.366062978768 + +mat3 cone mixtex.17.disk3.seg.12 +0 +0 +8 + -5.5 4 10.6721909119 + -5.5 4 10.6756385134 + 0.366062978768 0.358219269806 + +mat3 cone mixtex.17.disk3.seg.13 +0 +0 +8 + -5.5 4 10.6756385134 + -5.5 4 10.6790112878 + 0.358219269806 0.350343095686 + +mat3 cone mixtex.17.disk3.seg.14 +0 +0 +8 + -5.5 4 10.6790112878 + -5.5 4 10.6823089295 + 0.350343095686 0.342435170218 + +mat3 cone mixtex.17.disk3.seg.15 +0 +0 +8 + -5.5 4 10.6823089295 + -5.5 4 10.6855311397 + 0.342435170218 0.334496210094 + +mat3 cone mixtex.17.disk3.seg.16 +0 +0 +8 + -5.5 4 10.6855311397 + -5.5 4 10.6886776263 + 0.334496210094 0.326526934816 + +mat3 cone mixtex.17.disk3.seg.17 +0 +0 +8 + -5.5 4 10.6886776263 + -5.5 4 10.6917481041 + 0.326526934816 0.318528066632 + +mat3 cone mixtex.17.disk3.seg.18 +0 +0 +8 + -5.5 4 10.6917481041 + -5.5 4 10.6947422949 + 0.318528066632 0.310500330475 + +mat3 cone mixtex.17.disk3.seg.19 +0 +0 +8 + -5.5 4 10.6947422949 + -5.5 4 10.6976599273 + 0.310500330475 0.302444453894 + +mat3 cone mixtex.17.disk3.seg.20 +0 +0 +8 + -5.5 4 10.6976599273 + -5.5 4 10.7005007368 + 0.302444453894 0.294361166986 + +mat3 cone mixtex.17.disk3.seg.21 +0 +0 +8 + -5.5 4 10.7005007368 + -5.5 4 10.7032644661 + 0.294361166986 0.286251202333 + +mat3 cone mixtex.17.disk3.seg.22 +0 +0 +8 + -5.5 4 10.7032644661 + -5.5 4 10.7059508647 + 0.286251202333 0.278115294937 + +mat3 cone mixtex.17.disk3.seg.23 +0 +0 +8 + -5.5 4 10.7059508647 + -5.5 4 10.708559689 + 0.278115294937 0.269954182149 + +mat3 cone mixtex.17.disk3.seg.24 +0 +0 +8 + -5.5 4 10.708559689 + -5.5 4 10.7110907026 + 0.269954182149 0.261768603605 + +mat3 cone mixtex.17.disk3.seg.25 +0 +0 +8 + -5.5 4 10.7110907026 + -5.5 4 10.7135436762 + 0.261768603605 0.253559301157 + +mat3 cone mixtex.17.disk3.seg.26 +0 +0 +8 + -5.5 4 10.7135436762 + -5.5 4 10.7159183875 + 0.253559301157 0.24532701881 + +mat3 cone mixtex.17.disk3.seg.27 +0 +0 +8 + -5.5 4 10.7159183875 + -5.5 4 10.7182146212 + 0.24532701881 0.237072502648 + +mat3 cone mixtex.17.disk3.seg.28 +0 +0 +8 + -5.5 4 10.7182146212 + -5.5 4 10.7204321692 + 0.237072502648 0.228796500774 + +mat3 cone mixtex.17.disk3.seg.29 +0 +0 +8 + -5.5 4 10.7204321692 + -5.5 4 10.7225708306 + 0.228796500774 0.220499763235 + +mat3 cone mixtex.17.disk3.seg.30 +0 +0 +8 + -5.5 4 10.7225708306 + -5.5 4 10.7246304115 + 0.220499763235 0.212183041958 + +mat3 cone mixtex.17.disk3.seg.31 +0 +0 +8 + -5.5 4 10.7246304115 + -5.5 4 10.7266107252 + 0.212183041958 0.203847090683 + +mat3 cone mixtex.17.disk3.seg.32 +0 +0 +8 + -5.5 4 10.7266107252 + -5.5 4 10.7285115924 + 0.203847090683 0.19549266489 + +mat3 cone mixtex.17.disk3.seg.33 +0 +0 +8 + -5.5 4 10.7285115924 + -5.5 4 10.7303328407 + 0.19549266489 0.187120521736 + +mat3 cone mixtex.17.disk3.seg.34 +0 +0 +8 + -5.5 4 10.7303328407 + -5.5 4 10.732074305 + 0.187120521736 0.178731419981 + +mat3 cone mixtex.17.disk3.seg.35 +0 +0 +8 + -5.5 4 10.732074305 + -5.5 4 10.7337358275 + 0.178731419981 0.170326119924 + +mat3 cone mixtex.17.disk3.seg.36 +0 +0 +8 + -5.5 4 10.7337358275 + -5.5 4 10.7353172577 + 0.170326119924 0.161905383332 + +mat3 cone mixtex.17.disk3.seg.37 +0 +0 +8 + -5.5 4 10.7353172577 + -5.5 4 10.7368184523 + 0.161905383332 0.153469973369 + +mat3 cone mixtex.17.disk3.seg.38 +0 +0 +8 + -5.5 4 10.7368184523 + -5.5 4 10.7382392751 + 0.153469973369 0.145020654532 + +mat3 cone mixtex.17.disk3.seg.39 +0 +0 +8 + -5.5 4 10.7382392751 + -5.5 4 10.7395795974 + 0.145020654532 0.136558192575 + +mat3 cone mixtex.17.disk3.seg.40 +0 +0 +8 + -5.5 4 10.7395795974 + -5.5 4 10.7408392977 + 0.136558192575 0.128083354446 + +mat3 cone mixtex.17.disk3.seg.41 +0 +0 +8 + -5.5 4 10.7408392977 + -5.5 4 10.7420182619 + 0.128083354446 0.119596908213 + +mat3 cone mixtex.17.disk3.seg.42 +0 +0 +8 + -5.5 4 10.7420182619 + -5.5 4 10.7431163831 + 0.119596908213 0.111099622997 + +mat3 cone mixtex.17.disk3.seg.43 +0 +0 +8 + -5.5 4 10.7431163831 + -5.5 4 10.7441335618 + 0.111099622997 0.102592268901 + +mat3 cone mixtex.17.disk3.seg.44 +0 +0 +8 + -5.5 4 10.7441335618 + -5.5 4 10.7450697058 + 0.102592268901 0.0940756169409 + +mat3 cone mixtex.17.disk3.seg.45 +0 +0 +8 + -5.5 4 10.7450697058 + -5.5 4 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat3 cone mixtex.17.disk3.seg.46 +0 +0 +8 + -5.5 4 10.7459247303 + -5.5 4 10.7466985578 + 0.0855504389738 0.077017507631 + +mat3 cone mixtex.17.disk3.seg.47 +0 +0 +8 + -5.5 4 10.7466985578 + -5.5 4 10.7473911181 + 0.077017507631 0.068477596246 + +mat3 cone mixtex.17.disk3.seg.48 +0 +0 +8 + -5.5 4 10.7473911181 + -5.5 4 10.7480023485 + 0.068477596246 0.059931478785 + +mat3 cone mixtex.17.disk3.seg.49 +0 +0 +8 + -5.5 4 10.7480023485 + -5.5 4 10.7485321935 + 0.059931478785 0.0513799297765 + +mat3 cone mixtex.17.disk3.seg.50 +0 +0 +8 + -5.5 4 10.7485321935 + -5.5 4 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat3 cone mixtex.17.disk3.seg.51 +0 +0 +8 + -5.5 4 10.7489806053 + -5.5 4 10.749347543 + 0.0428237242414 0.0342636376225 + +mat3 cone mixtex.17.disk3.seg.52 +0 +0 +8 + -5.5 4 10.749347543 + -5.5 4 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat3 cone mixtex.17.disk3.seg.53 +0 +0 +8 + -5.5 4 10.7496329735 + -5.5 4 10.749836871 + 0.0257004457143 0.017134924593 + +mat3 cone mixtex.17.disk3.seg.54 +0 +0 +8 + -5.5 4 10.749836871 + -5.5 4 10.7499592168 + 0.017134924593 0.00856785054562 + +mat3 cone mixtex.17.disk3.seg.55 +0 +0 +8 + -5.5 4 10.7499592168 + -5.5 4 10.75 + 0.00856785054562 0 +# xform -m mat4 -n disk4 -t -4 1 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat4 cone mixtex.17.disk4.seg.1 +0 +0 +8 + -4 1 10.6294228634 + -4 1 10.6336714694 + 0.45 0.442559632181 + +mat4 cone mixtex.17.disk4.seg.2 +0 +0 +8 + -4 1 10.6336714694 + -4 1 10.6378490518 + 0.442559632181 0.435079155496 + +mat4 cone mixtex.17.disk4.seg.3 +0 +0 +8 + -4 1 10.6378490518 + -4 1 10.641955232 + 0.435079155496 0.427559247895 + +mat4 cone mixtex.17.disk4.seg.4 +0 +0 +8 + -4 1 10.641955232 + -4 1 10.6459896379 + 0.427559247895 0.420000590903 + +mat4 cone mixtex.17.disk4.seg.5 +0 +0 +8 + -4 1 10.6459896379 + -4 1 10.6499519038 + 0.420000590903 0.412403869555 + +mat4 cone mixtex.17.disk4.seg.6 +0 +0 +8 + -4 1 10.6499519038 + -4 1 10.6538416706 + 0.412403869555 0.404769772336 + +mat4 cone mixtex.17.disk4.seg.7 +0 +0 +8 + -4 1 10.6538416706 + -4 1 10.6576585858 + 0.404769772336 0.397098991119 + +mat4 cone mixtex.17.disk4.seg.8 +0 +0 +8 + -4 1 10.6576585858 + -4 1 10.6614023035 + 0.397098991119 0.389392221102 + +mat4 cone mixtex.17.disk4.seg.9 +0 +0 +8 + -4 1 10.6614023035 + -4 1 10.6650724844 + 0.389392221102 0.381650160744 + +mat4 cone mixtex.17.disk4.seg.10 +0 +0 +8 + -4 1 10.6650724844 + -4 1 10.6686687958 + 0.381650160744 0.373873511702 + +mat4 cone mixtex.17.disk4.seg.11 +0 +0 +8 + -4 1 10.6686687958 + -4 1 10.6721909119 + 0.373873511702 0.366062978768 + +mat4 cone mixtex.17.disk4.seg.12 +0 +0 +8 + -4 1 10.6721909119 + -4 1 10.6756385134 + 0.366062978768 0.358219269806 + +mat4 cone mixtex.17.disk4.seg.13 +0 +0 +8 + -4 1 10.6756385134 + -4 1 10.6790112878 + 0.358219269806 0.350343095686 + +mat4 cone mixtex.17.disk4.seg.14 +0 +0 +8 + -4 1 10.6790112878 + -4 1 10.6823089295 + 0.350343095686 0.342435170218 + +mat4 cone mixtex.17.disk4.seg.15 +0 +0 +8 + -4 1 10.6823089295 + -4 1 10.6855311397 + 0.342435170218 0.334496210094 + +mat4 cone mixtex.17.disk4.seg.16 +0 +0 +8 + -4 1 10.6855311397 + -4 1 10.6886776263 + 0.334496210094 0.326526934816 + +mat4 cone mixtex.17.disk4.seg.17 +0 +0 +8 + -4 1 10.6886776263 + -4 1 10.6917481041 + 0.326526934816 0.318528066632 + +mat4 cone mixtex.17.disk4.seg.18 +0 +0 +8 + -4 1 10.6917481041 + -4 1 10.6947422949 + 0.318528066632 0.310500330475 + +mat4 cone mixtex.17.disk4.seg.19 +0 +0 +8 + -4 1 10.6947422949 + -4 1 10.6976599273 + 0.310500330475 0.302444453894 + +mat4 cone mixtex.17.disk4.seg.20 +0 +0 +8 + -4 1 10.6976599273 + -4 1 10.7005007368 + 0.302444453894 0.294361166986 + +mat4 cone mixtex.17.disk4.seg.21 +0 +0 +8 + -4 1 10.7005007368 + -4 1 10.7032644661 + 0.294361166986 0.286251202333 + +mat4 cone mixtex.17.disk4.seg.22 +0 +0 +8 + -4 1 10.7032644661 + -4 1 10.7059508647 + 0.286251202333 0.278115294937 + +mat4 cone mixtex.17.disk4.seg.23 +0 +0 +8 + -4 1 10.7059508647 + -4 1 10.708559689 + 0.278115294937 0.269954182149 + +mat4 cone mixtex.17.disk4.seg.24 +0 +0 +8 + -4 1 10.708559689 + -4 1 10.7110907026 + 0.269954182149 0.261768603605 + +mat4 cone mixtex.17.disk4.seg.25 +0 +0 +8 + -4 1 10.7110907026 + -4 1 10.7135436762 + 0.261768603605 0.253559301157 + +mat4 cone mixtex.17.disk4.seg.26 +0 +0 +8 + -4 1 10.7135436762 + -4 1 10.7159183875 + 0.253559301157 0.24532701881 + +mat4 cone mixtex.17.disk4.seg.27 +0 +0 +8 + -4 1 10.7159183875 + -4 1 10.7182146212 + 0.24532701881 0.237072502648 + +mat4 cone mixtex.17.disk4.seg.28 +0 +0 +8 + -4 1 10.7182146212 + -4 1 10.7204321692 + 0.237072502648 0.228796500774 + +mat4 cone mixtex.17.disk4.seg.29 +0 +0 +8 + -4 1 10.7204321692 + -4 1 10.7225708306 + 0.228796500774 0.220499763235 + +mat4 cone mixtex.17.disk4.seg.30 +0 +0 +8 + -4 1 10.7225708306 + -4 1 10.7246304115 + 0.220499763235 0.212183041958 + +mat4 cone mixtex.17.disk4.seg.31 +0 +0 +8 + -4 1 10.7246304115 + -4 1 10.7266107252 + 0.212183041958 0.203847090683 + +mat4 cone mixtex.17.disk4.seg.32 +0 +0 +8 + -4 1 10.7266107252 + -4 1 10.7285115924 + 0.203847090683 0.19549266489 + +mat4 cone mixtex.17.disk4.seg.33 +0 +0 +8 + -4 1 10.7285115924 + -4 1 10.7303328407 + 0.19549266489 0.187120521736 + +mat4 cone mixtex.17.disk4.seg.34 +0 +0 +8 + -4 1 10.7303328407 + -4 1 10.732074305 + 0.187120521736 0.178731419981 + +mat4 cone mixtex.17.disk4.seg.35 +0 +0 +8 + -4 1 10.732074305 + -4 1 10.7337358275 + 0.178731419981 0.170326119924 + +mat4 cone mixtex.17.disk4.seg.36 +0 +0 +8 + -4 1 10.7337358275 + -4 1 10.7353172577 + 0.170326119924 0.161905383332 + +mat4 cone mixtex.17.disk4.seg.37 +0 +0 +8 + -4 1 10.7353172577 + -4 1 10.7368184523 + 0.161905383332 0.153469973369 + +mat4 cone mixtex.17.disk4.seg.38 +0 +0 +8 + -4 1 10.7368184523 + -4 1 10.7382392751 + 0.153469973369 0.145020654532 + +mat4 cone mixtex.17.disk4.seg.39 +0 +0 +8 + -4 1 10.7382392751 + -4 1 10.7395795974 + 0.145020654532 0.136558192575 + +mat4 cone mixtex.17.disk4.seg.40 +0 +0 +8 + -4 1 10.7395795974 + -4 1 10.7408392977 + 0.136558192575 0.128083354446 + +mat4 cone mixtex.17.disk4.seg.41 +0 +0 +8 + -4 1 10.7408392977 + -4 1 10.7420182619 + 0.128083354446 0.119596908213 + +mat4 cone mixtex.17.disk4.seg.42 +0 +0 +8 + -4 1 10.7420182619 + -4 1 10.7431163831 + 0.119596908213 0.111099622997 + +mat4 cone mixtex.17.disk4.seg.43 +0 +0 +8 + -4 1 10.7431163831 + -4 1 10.7441335618 + 0.111099622997 0.102592268901 + +mat4 cone mixtex.17.disk4.seg.44 +0 +0 +8 + -4 1 10.7441335618 + -4 1 10.7450697058 + 0.102592268901 0.0940756169409 + +mat4 cone mixtex.17.disk4.seg.45 +0 +0 +8 + -4 1 10.7450697058 + -4 1 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat4 cone mixtex.17.disk4.seg.46 +0 +0 +8 + -4 1 10.7459247303 + -4 1 10.7466985578 + 0.0855504389738 0.077017507631 + +mat4 cone mixtex.17.disk4.seg.47 +0 +0 +8 + -4 1 10.7466985578 + -4 1 10.7473911181 + 0.077017507631 0.068477596246 + +mat4 cone mixtex.17.disk4.seg.48 +0 +0 +8 + -4 1 10.7473911181 + -4 1 10.7480023485 + 0.068477596246 0.059931478785 + +mat4 cone mixtex.17.disk4.seg.49 +0 +0 +8 + -4 1 10.7480023485 + -4 1 10.7485321935 + 0.059931478785 0.0513799297765 + +mat4 cone mixtex.17.disk4.seg.50 +0 +0 +8 + -4 1 10.7485321935 + -4 1 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat4 cone mixtex.17.disk4.seg.51 +0 +0 +8 + -4 1 10.7489806053 + -4 1 10.749347543 + 0.0428237242414 0.0342636376225 + +mat4 cone mixtex.17.disk4.seg.52 +0 +0 +8 + -4 1 10.749347543 + -4 1 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat4 cone mixtex.17.disk4.seg.53 +0 +0 +8 + -4 1 10.7496329735 + -4 1 10.749836871 + 0.0257004457143 0.017134924593 + +mat4 cone mixtex.17.disk4.seg.54 +0 +0 +8 + -4 1 10.749836871 + -4 1 10.7499592168 + 0.017134924593 0.00856785054562 + +mat4 cone mixtex.17.disk4.seg.55 +0 +0 +8 + -4 1 10.7499592168 + -4 1 10.75 + 0.00856785054562 0 +# xform -m mat5 -n disk5 -t -4 2.5 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat5 cone mixtex.17.disk5.seg.1 +0 +0 +8 + -4 2.5 10.6294228634 + -4 2.5 10.6336714694 + 0.45 0.442559632181 + +mat5 cone mixtex.17.disk5.seg.2 +0 +0 +8 + -4 2.5 10.6336714694 + -4 2.5 10.6378490518 + 0.442559632181 0.435079155496 + +mat5 cone mixtex.17.disk5.seg.3 +0 +0 +8 + -4 2.5 10.6378490518 + -4 2.5 10.641955232 + 0.435079155496 0.427559247895 + +mat5 cone mixtex.17.disk5.seg.4 +0 +0 +8 + -4 2.5 10.641955232 + -4 2.5 10.6459896379 + 0.427559247895 0.420000590903 + +mat5 cone mixtex.17.disk5.seg.5 +0 +0 +8 + -4 2.5 10.6459896379 + -4 2.5 10.6499519038 + 0.420000590903 0.412403869555 + +mat5 cone mixtex.17.disk5.seg.6 +0 +0 +8 + -4 2.5 10.6499519038 + -4 2.5 10.6538416706 + 0.412403869555 0.404769772336 + +mat5 cone mixtex.17.disk5.seg.7 +0 +0 +8 + -4 2.5 10.6538416706 + -4 2.5 10.6576585858 + 0.404769772336 0.397098991119 + +mat5 cone mixtex.17.disk5.seg.8 +0 +0 +8 + -4 2.5 10.6576585858 + -4 2.5 10.6614023035 + 0.397098991119 0.389392221102 + +mat5 cone mixtex.17.disk5.seg.9 +0 +0 +8 + -4 2.5 10.6614023035 + -4 2.5 10.6650724844 + 0.389392221102 0.381650160744 + +mat5 cone mixtex.17.disk5.seg.10 +0 +0 +8 + -4 2.5 10.6650724844 + -4 2.5 10.6686687958 + 0.381650160744 0.373873511702 + +mat5 cone mixtex.17.disk5.seg.11 +0 +0 +8 + -4 2.5 10.6686687958 + -4 2.5 10.6721909119 + 0.373873511702 0.366062978768 + +mat5 cone mixtex.17.disk5.seg.12 +0 +0 +8 + -4 2.5 10.6721909119 + -4 2.5 10.6756385134 + 0.366062978768 0.358219269806 + +mat5 cone mixtex.17.disk5.seg.13 +0 +0 +8 + -4 2.5 10.6756385134 + -4 2.5 10.6790112878 + 0.358219269806 0.350343095686 + +mat5 cone mixtex.17.disk5.seg.14 +0 +0 +8 + -4 2.5 10.6790112878 + -4 2.5 10.6823089295 + 0.350343095686 0.342435170218 + +mat5 cone mixtex.17.disk5.seg.15 +0 +0 +8 + -4 2.5 10.6823089295 + -4 2.5 10.6855311397 + 0.342435170218 0.334496210094 + +mat5 cone mixtex.17.disk5.seg.16 +0 +0 +8 + -4 2.5 10.6855311397 + -4 2.5 10.6886776263 + 0.334496210094 0.326526934816 + +mat5 cone mixtex.17.disk5.seg.17 +0 +0 +8 + -4 2.5 10.6886776263 + -4 2.5 10.6917481041 + 0.326526934816 0.318528066632 + +mat5 cone mixtex.17.disk5.seg.18 +0 +0 +8 + -4 2.5 10.6917481041 + -4 2.5 10.6947422949 + 0.318528066632 0.310500330475 + +mat5 cone mixtex.17.disk5.seg.19 +0 +0 +8 + -4 2.5 10.6947422949 + -4 2.5 10.6976599273 + 0.310500330475 0.302444453894 + +mat5 cone mixtex.17.disk5.seg.20 +0 +0 +8 + -4 2.5 10.6976599273 + -4 2.5 10.7005007368 + 0.302444453894 0.294361166986 + +mat5 cone mixtex.17.disk5.seg.21 +0 +0 +8 + -4 2.5 10.7005007368 + -4 2.5 10.7032644661 + 0.294361166986 0.286251202333 + +mat5 cone mixtex.17.disk5.seg.22 +0 +0 +8 + -4 2.5 10.7032644661 + -4 2.5 10.7059508647 + 0.286251202333 0.278115294937 + +mat5 cone mixtex.17.disk5.seg.23 +0 +0 +8 + -4 2.5 10.7059508647 + -4 2.5 10.708559689 + 0.278115294937 0.269954182149 + +mat5 cone mixtex.17.disk5.seg.24 +0 +0 +8 + -4 2.5 10.708559689 + -4 2.5 10.7110907026 + 0.269954182149 0.261768603605 + +mat5 cone mixtex.17.disk5.seg.25 +0 +0 +8 + -4 2.5 10.7110907026 + -4 2.5 10.7135436762 + 0.261768603605 0.253559301157 + +mat5 cone mixtex.17.disk5.seg.26 +0 +0 +8 + -4 2.5 10.7135436762 + -4 2.5 10.7159183875 + 0.253559301157 0.24532701881 + +mat5 cone mixtex.17.disk5.seg.27 +0 +0 +8 + -4 2.5 10.7159183875 + -4 2.5 10.7182146212 + 0.24532701881 0.237072502648 + +mat5 cone mixtex.17.disk5.seg.28 +0 +0 +8 + -4 2.5 10.7182146212 + -4 2.5 10.7204321692 + 0.237072502648 0.228796500774 + +mat5 cone mixtex.17.disk5.seg.29 +0 +0 +8 + -4 2.5 10.7204321692 + -4 2.5 10.7225708306 + 0.228796500774 0.220499763235 + +mat5 cone mixtex.17.disk5.seg.30 +0 +0 +8 + -4 2.5 10.7225708306 + -4 2.5 10.7246304115 + 0.220499763235 0.212183041958 + +mat5 cone mixtex.17.disk5.seg.31 +0 +0 +8 + -4 2.5 10.7246304115 + -4 2.5 10.7266107252 + 0.212183041958 0.203847090683 + +mat5 cone mixtex.17.disk5.seg.32 +0 +0 +8 + -4 2.5 10.7266107252 + -4 2.5 10.7285115924 + 0.203847090683 0.19549266489 + +mat5 cone mixtex.17.disk5.seg.33 +0 +0 +8 + -4 2.5 10.7285115924 + -4 2.5 10.7303328407 + 0.19549266489 0.187120521736 + +mat5 cone mixtex.17.disk5.seg.34 +0 +0 +8 + -4 2.5 10.7303328407 + -4 2.5 10.732074305 + 0.187120521736 0.178731419981 + +mat5 cone mixtex.17.disk5.seg.35 +0 +0 +8 + -4 2.5 10.732074305 + -4 2.5 10.7337358275 + 0.178731419981 0.170326119924 + +mat5 cone mixtex.17.disk5.seg.36 +0 +0 +8 + -4 2.5 10.7337358275 + -4 2.5 10.7353172577 + 0.170326119924 0.161905383332 + +mat5 cone mixtex.17.disk5.seg.37 +0 +0 +8 + -4 2.5 10.7353172577 + -4 2.5 10.7368184523 + 0.161905383332 0.153469973369 + +mat5 cone mixtex.17.disk5.seg.38 +0 +0 +8 + -4 2.5 10.7368184523 + -4 2.5 10.7382392751 + 0.153469973369 0.145020654532 + +mat5 cone mixtex.17.disk5.seg.39 +0 +0 +8 + -4 2.5 10.7382392751 + -4 2.5 10.7395795974 + 0.145020654532 0.136558192575 + +mat5 cone mixtex.17.disk5.seg.40 +0 +0 +8 + -4 2.5 10.7395795974 + -4 2.5 10.7408392977 + 0.136558192575 0.128083354446 + +mat5 cone mixtex.17.disk5.seg.41 +0 +0 +8 + -4 2.5 10.7408392977 + -4 2.5 10.7420182619 + 0.128083354446 0.119596908213 + +mat5 cone mixtex.17.disk5.seg.42 +0 +0 +8 + -4 2.5 10.7420182619 + -4 2.5 10.7431163831 + 0.119596908213 0.111099622997 + +mat5 cone mixtex.17.disk5.seg.43 +0 +0 +8 + -4 2.5 10.7431163831 + -4 2.5 10.7441335618 + 0.111099622997 0.102592268901 + +mat5 cone mixtex.17.disk5.seg.44 +0 +0 +8 + -4 2.5 10.7441335618 + -4 2.5 10.7450697058 + 0.102592268901 0.0940756169409 + +mat5 cone mixtex.17.disk5.seg.45 +0 +0 +8 + -4 2.5 10.7450697058 + -4 2.5 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat5 cone mixtex.17.disk5.seg.46 +0 +0 +8 + -4 2.5 10.7459247303 + -4 2.5 10.7466985578 + 0.0855504389738 0.077017507631 + +mat5 cone mixtex.17.disk5.seg.47 +0 +0 +8 + -4 2.5 10.7466985578 + -4 2.5 10.7473911181 + 0.077017507631 0.068477596246 + +mat5 cone mixtex.17.disk5.seg.48 +0 +0 +8 + -4 2.5 10.7473911181 + -4 2.5 10.7480023485 + 0.068477596246 0.059931478785 + +mat5 cone mixtex.17.disk5.seg.49 +0 +0 +8 + -4 2.5 10.7480023485 + -4 2.5 10.7485321935 + 0.059931478785 0.0513799297765 + +mat5 cone mixtex.17.disk5.seg.50 +0 +0 +8 + -4 2.5 10.7485321935 + -4 2.5 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat5 cone mixtex.17.disk5.seg.51 +0 +0 +8 + -4 2.5 10.7489806053 + -4 2.5 10.749347543 + 0.0428237242414 0.0342636376225 + +mat5 cone mixtex.17.disk5.seg.52 +0 +0 +8 + -4 2.5 10.749347543 + -4 2.5 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat5 cone mixtex.17.disk5.seg.53 +0 +0 +8 + -4 2.5 10.7496329735 + -4 2.5 10.749836871 + 0.0257004457143 0.017134924593 + +mat5 cone mixtex.17.disk5.seg.54 +0 +0 +8 + -4 2.5 10.749836871 + -4 2.5 10.7499592168 + 0.017134924593 0.00856785054562 + +mat5 cone mixtex.17.disk5.seg.55 +0 +0 +8 + -4 2.5 10.7499592168 + -4 2.5 10.75 + 0.00856785054562 0 +# xform -m mat6 -n disk6 -t -4 4 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat6 cone mixtex.17.disk6.seg.1 +0 +0 +8 + -4 4 10.6294228634 + -4 4 10.6336714694 + 0.45 0.442559632181 + +mat6 cone mixtex.17.disk6.seg.2 +0 +0 +8 + -4 4 10.6336714694 + -4 4 10.6378490518 + 0.442559632181 0.435079155496 + +mat6 cone mixtex.17.disk6.seg.3 +0 +0 +8 + -4 4 10.6378490518 + -4 4 10.641955232 + 0.435079155496 0.427559247895 + +mat6 cone mixtex.17.disk6.seg.4 +0 +0 +8 + -4 4 10.641955232 + -4 4 10.6459896379 + 0.427559247895 0.420000590903 + +mat6 cone mixtex.17.disk6.seg.5 +0 +0 +8 + -4 4 10.6459896379 + -4 4 10.6499519038 + 0.420000590903 0.412403869555 + +mat6 cone mixtex.17.disk6.seg.6 +0 +0 +8 + -4 4 10.6499519038 + -4 4 10.6538416706 + 0.412403869555 0.404769772336 + +mat6 cone mixtex.17.disk6.seg.7 +0 +0 +8 + -4 4 10.6538416706 + -4 4 10.6576585858 + 0.404769772336 0.397098991119 + +mat6 cone mixtex.17.disk6.seg.8 +0 +0 +8 + -4 4 10.6576585858 + -4 4 10.6614023035 + 0.397098991119 0.389392221102 + +mat6 cone mixtex.17.disk6.seg.9 +0 +0 +8 + -4 4 10.6614023035 + -4 4 10.6650724844 + 0.389392221102 0.381650160744 + +mat6 cone mixtex.17.disk6.seg.10 +0 +0 +8 + -4 4 10.6650724844 + -4 4 10.6686687958 + 0.381650160744 0.373873511702 + +mat6 cone mixtex.17.disk6.seg.11 +0 +0 +8 + -4 4 10.6686687958 + -4 4 10.6721909119 + 0.373873511702 0.366062978768 + +mat6 cone mixtex.17.disk6.seg.12 +0 +0 +8 + -4 4 10.6721909119 + -4 4 10.6756385134 + 0.366062978768 0.358219269806 + +mat6 cone mixtex.17.disk6.seg.13 +0 +0 +8 + -4 4 10.6756385134 + -4 4 10.6790112878 + 0.358219269806 0.350343095686 + +mat6 cone mixtex.17.disk6.seg.14 +0 +0 +8 + -4 4 10.6790112878 + -4 4 10.6823089295 + 0.350343095686 0.342435170218 + +mat6 cone mixtex.17.disk6.seg.15 +0 +0 +8 + -4 4 10.6823089295 + -4 4 10.6855311397 + 0.342435170218 0.334496210094 + +mat6 cone mixtex.17.disk6.seg.16 +0 +0 +8 + -4 4 10.6855311397 + -4 4 10.6886776263 + 0.334496210094 0.326526934816 + +mat6 cone mixtex.17.disk6.seg.17 +0 +0 +8 + -4 4 10.6886776263 + -4 4 10.6917481041 + 0.326526934816 0.318528066632 + +mat6 cone mixtex.17.disk6.seg.18 +0 +0 +8 + -4 4 10.6917481041 + -4 4 10.6947422949 + 0.318528066632 0.310500330475 + +mat6 cone mixtex.17.disk6.seg.19 +0 +0 +8 + -4 4 10.6947422949 + -4 4 10.6976599273 + 0.310500330475 0.302444453894 + +mat6 cone mixtex.17.disk6.seg.20 +0 +0 +8 + -4 4 10.6976599273 + -4 4 10.7005007368 + 0.302444453894 0.294361166986 + +mat6 cone mixtex.17.disk6.seg.21 +0 +0 +8 + -4 4 10.7005007368 + -4 4 10.7032644661 + 0.294361166986 0.286251202333 + +mat6 cone mixtex.17.disk6.seg.22 +0 +0 +8 + -4 4 10.7032644661 + -4 4 10.7059508647 + 0.286251202333 0.278115294937 + +mat6 cone mixtex.17.disk6.seg.23 +0 +0 +8 + -4 4 10.7059508647 + -4 4 10.708559689 + 0.278115294937 0.269954182149 + +mat6 cone mixtex.17.disk6.seg.24 +0 +0 +8 + -4 4 10.708559689 + -4 4 10.7110907026 + 0.269954182149 0.261768603605 + +mat6 cone mixtex.17.disk6.seg.25 +0 +0 +8 + -4 4 10.7110907026 + -4 4 10.7135436762 + 0.261768603605 0.253559301157 + +mat6 cone mixtex.17.disk6.seg.26 +0 +0 +8 + -4 4 10.7135436762 + -4 4 10.7159183875 + 0.253559301157 0.24532701881 + +mat6 cone mixtex.17.disk6.seg.27 +0 +0 +8 + -4 4 10.7159183875 + -4 4 10.7182146212 + 0.24532701881 0.237072502648 + +mat6 cone mixtex.17.disk6.seg.28 +0 +0 +8 + -4 4 10.7182146212 + -4 4 10.7204321692 + 0.237072502648 0.228796500774 + +mat6 cone mixtex.17.disk6.seg.29 +0 +0 +8 + -4 4 10.7204321692 + -4 4 10.7225708306 + 0.228796500774 0.220499763235 + +mat6 cone mixtex.17.disk6.seg.30 +0 +0 +8 + -4 4 10.7225708306 + -4 4 10.7246304115 + 0.220499763235 0.212183041958 + +mat6 cone mixtex.17.disk6.seg.31 +0 +0 +8 + -4 4 10.7246304115 + -4 4 10.7266107252 + 0.212183041958 0.203847090683 + +mat6 cone mixtex.17.disk6.seg.32 +0 +0 +8 + -4 4 10.7266107252 + -4 4 10.7285115924 + 0.203847090683 0.19549266489 + +mat6 cone mixtex.17.disk6.seg.33 +0 +0 +8 + -4 4 10.7285115924 + -4 4 10.7303328407 + 0.19549266489 0.187120521736 + +mat6 cone mixtex.17.disk6.seg.34 +0 +0 +8 + -4 4 10.7303328407 + -4 4 10.732074305 + 0.187120521736 0.178731419981 + +mat6 cone mixtex.17.disk6.seg.35 +0 +0 +8 + -4 4 10.732074305 + -4 4 10.7337358275 + 0.178731419981 0.170326119924 + +mat6 cone mixtex.17.disk6.seg.36 +0 +0 +8 + -4 4 10.7337358275 + -4 4 10.7353172577 + 0.170326119924 0.161905383332 + +mat6 cone mixtex.17.disk6.seg.37 +0 +0 +8 + -4 4 10.7353172577 + -4 4 10.7368184523 + 0.161905383332 0.153469973369 + +mat6 cone mixtex.17.disk6.seg.38 +0 +0 +8 + -4 4 10.7368184523 + -4 4 10.7382392751 + 0.153469973369 0.145020654532 + +mat6 cone mixtex.17.disk6.seg.39 +0 +0 +8 + -4 4 10.7382392751 + -4 4 10.7395795974 + 0.145020654532 0.136558192575 + +mat6 cone mixtex.17.disk6.seg.40 +0 +0 +8 + -4 4 10.7395795974 + -4 4 10.7408392977 + 0.136558192575 0.128083354446 + +mat6 cone mixtex.17.disk6.seg.41 +0 +0 +8 + -4 4 10.7408392977 + -4 4 10.7420182619 + 0.128083354446 0.119596908213 + +mat6 cone mixtex.17.disk6.seg.42 +0 +0 +8 + -4 4 10.7420182619 + -4 4 10.7431163831 + 0.119596908213 0.111099622997 + +mat6 cone mixtex.17.disk6.seg.43 +0 +0 +8 + -4 4 10.7431163831 + -4 4 10.7441335618 + 0.111099622997 0.102592268901 + +mat6 cone mixtex.17.disk6.seg.44 +0 +0 +8 + -4 4 10.7441335618 + -4 4 10.7450697058 + 0.102592268901 0.0940756169409 + +mat6 cone mixtex.17.disk6.seg.45 +0 +0 +8 + -4 4 10.7450697058 + -4 4 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat6 cone mixtex.17.disk6.seg.46 +0 +0 +8 + -4 4 10.7459247303 + -4 4 10.7466985578 + 0.0855504389738 0.077017507631 + +mat6 cone mixtex.17.disk6.seg.47 +0 +0 +8 + -4 4 10.7466985578 + -4 4 10.7473911181 + 0.077017507631 0.068477596246 + +mat6 cone mixtex.17.disk6.seg.48 +0 +0 +8 + -4 4 10.7473911181 + -4 4 10.7480023485 + 0.068477596246 0.059931478785 + +mat6 cone mixtex.17.disk6.seg.49 +0 +0 +8 + -4 4 10.7480023485 + -4 4 10.7485321935 + 0.059931478785 0.0513799297765 + +mat6 cone mixtex.17.disk6.seg.50 +0 +0 +8 + -4 4 10.7485321935 + -4 4 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat6 cone mixtex.17.disk6.seg.51 +0 +0 +8 + -4 4 10.7489806053 + -4 4 10.749347543 + 0.0428237242414 0.0342636376225 + +mat6 cone mixtex.17.disk6.seg.52 +0 +0 +8 + -4 4 10.749347543 + -4 4 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat6 cone mixtex.17.disk6.seg.53 +0 +0 +8 + -4 4 10.7496329735 + -4 4 10.749836871 + 0.0257004457143 0.017134924593 + +mat6 cone mixtex.17.disk6.seg.54 +0 +0 +8 + -4 4 10.749836871 + -4 4 10.7499592168 + 0.017134924593 0.00856785054562 + +mat6 cone mixtex.17.disk6.seg.55 +0 +0 +8 + -4 4 10.7499592168 + -4 4 10.75 + 0.00856785054562 0 +# xform -m mat7 -n disk7 -t -2.5 1 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat7 cone mixtex.17.disk7.seg.1 +0 +0 +8 + -2.5 1 10.6294228634 + -2.5 1 10.6336714694 + 0.45 0.442559632181 + +mat7 cone mixtex.17.disk7.seg.2 +0 +0 +8 + -2.5 1 10.6336714694 + -2.5 1 10.6378490518 + 0.442559632181 0.435079155496 + +mat7 cone mixtex.17.disk7.seg.3 +0 +0 +8 + -2.5 1 10.6378490518 + -2.5 1 10.641955232 + 0.435079155496 0.427559247895 + +mat7 cone mixtex.17.disk7.seg.4 +0 +0 +8 + -2.5 1 10.641955232 + -2.5 1 10.6459896379 + 0.427559247895 0.420000590903 + +mat7 cone mixtex.17.disk7.seg.5 +0 +0 +8 + -2.5 1 10.6459896379 + -2.5 1 10.6499519038 + 0.420000590903 0.412403869555 + +mat7 cone mixtex.17.disk7.seg.6 +0 +0 +8 + -2.5 1 10.6499519038 + -2.5 1 10.6538416706 + 0.412403869555 0.404769772336 + +mat7 cone mixtex.17.disk7.seg.7 +0 +0 +8 + -2.5 1 10.6538416706 + -2.5 1 10.6576585858 + 0.404769772336 0.397098991119 + +mat7 cone mixtex.17.disk7.seg.8 +0 +0 +8 + -2.5 1 10.6576585858 + -2.5 1 10.6614023035 + 0.397098991119 0.389392221102 + +mat7 cone mixtex.17.disk7.seg.9 +0 +0 +8 + -2.5 1 10.6614023035 + -2.5 1 10.6650724844 + 0.389392221102 0.381650160744 + +mat7 cone mixtex.17.disk7.seg.10 +0 +0 +8 + -2.5 1 10.6650724844 + -2.5 1 10.6686687958 + 0.381650160744 0.373873511702 + +mat7 cone mixtex.17.disk7.seg.11 +0 +0 +8 + -2.5 1 10.6686687958 + -2.5 1 10.6721909119 + 0.373873511702 0.366062978768 + +mat7 cone mixtex.17.disk7.seg.12 +0 +0 +8 + -2.5 1 10.6721909119 + -2.5 1 10.6756385134 + 0.366062978768 0.358219269806 + +mat7 cone mixtex.17.disk7.seg.13 +0 +0 +8 + -2.5 1 10.6756385134 + -2.5 1 10.6790112878 + 0.358219269806 0.350343095686 + +mat7 cone mixtex.17.disk7.seg.14 +0 +0 +8 + -2.5 1 10.6790112878 + -2.5 1 10.6823089295 + 0.350343095686 0.342435170218 + +mat7 cone mixtex.17.disk7.seg.15 +0 +0 +8 + -2.5 1 10.6823089295 + -2.5 1 10.6855311397 + 0.342435170218 0.334496210094 + +mat7 cone mixtex.17.disk7.seg.16 +0 +0 +8 + -2.5 1 10.6855311397 + -2.5 1 10.6886776263 + 0.334496210094 0.326526934816 + +mat7 cone mixtex.17.disk7.seg.17 +0 +0 +8 + -2.5 1 10.6886776263 + -2.5 1 10.6917481041 + 0.326526934816 0.318528066632 + +mat7 cone mixtex.17.disk7.seg.18 +0 +0 +8 + -2.5 1 10.6917481041 + -2.5 1 10.6947422949 + 0.318528066632 0.310500330475 + +mat7 cone mixtex.17.disk7.seg.19 +0 +0 +8 + -2.5 1 10.6947422949 + -2.5 1 10.6976599273 + 0.310500330475 0.302444453894 + +mat7 cone mixtex.17.disk7.seg.20 +0 +0 +8 + -2.5 1 10.6976599273 + -2.5 1 10.7005007368 + 0.302444453894 0.294361166986 + +mat7 cone mixtex.17.disk7.seg.21 +0 +0 +8 + -2.5 1 10.7005007368 + -2.5 1 10.7032644661 + 0.294361166986 0.286251202333 + +mat7 cone mixtex.17.disk7.seg.22 +0 +0 +8 + -2.5 1 10.7032644661 + -2.5 1 10.7059508647 + 0.286251202333 0.278115294937 + +mat7 cone mixtex.17.disk7.seg.23 +0 +0 +8 + -2.5 1 10.7059508647 + -2.5 1 10.708559689 + 0.278115294937 0.269954182149 + +mat7 cone mixtex.17.disk7.seg.24 +0 +0 +8 + -2.5 1 10.708559689 + -2.5 1 10.7110907026 + 0.269954182149 0.261768603605 + +mat7 cone mixtex.17.disk7.seg.25 +0 +0 +8 + -2.5 1 10.7110907026 + -2.5 1 10.7135436762 + 0.261768603605 0.253559301157 + +mat7 cone mixtex.17.disk7.seg.26 +0 +0 +8 + -2.5 1 10.7135436762 + -2.5 1 10.7159183875 + 0.253559301157 0.24532701881 + +mat7 cone mixtex.17.disk7.seg.27 +0 +0 +8 + -2.5 1 10.7159183875 + -2.5 1 10.7182146212 + 0.24532701881 0.237072502648 + +mat7 cone mixtex.17.disk7.seg.28 +0 +0 +8 + -2.5 1 10.7182146212 + -2.5 1 10.7204321692 + 0.237072502648 0.228796500774 + +mat7 cone mixtex.17.disk7.seg.29 +0 +0 +8 + -2.5 1 10.7204321692 + -2.5 1 10.7225708306 + 0.228796500774 0.220499763235 + +mat7 cone mixtex.17.disk7.seg.30 +0 +0 +8 + -2.5 1 10.7225708306 + -2.5 1 10.7246304115 + 0.220499763235 0.212183041958 + +mat7 cone mixtex.17.disk7.seg.31 +0 +0 +8 + -2.5 1 10.7246304115 + -2.5 1 10.7266107252 + 0.212183041958 0.203847090683 + +mat7 cone mixtex.17.disk7.seg.32 +0 +0 +8 + -2.5 1 10.7266107252 + -2.5 1 10.7285115924 + 0.203847090683 0.19549266489 + +mat7 cone mixtex.17.disk7.seg.33 +0 +0 +8 + -2.5 1 10.7285115924 + -2.5 1 10.7303328407 + 0.19549266489 0.187120521736 + +mat7 cone mixtex.17.disk7.seg.34 +0 +0 +8 + -2.5 1 10.7303328407 + -2.5 1 10.732074305 + 0.187120521736 0.178731419981 + +mat7 cone mixtex.17.disk7.seg.35 +0 +0 +8 + -2.5 1 10.732074305 + -2.5 1 10.7337358275 + 0.178731419981 0.170326119924 + +mat7 cone mixtex.17.disk7.seg.36 +0 +0 +8 + -2.5 1 10.7337358275 + -2.5 1 10.7353172577 + 0.170326119924 0.161905383332 + +mat7 cone mixtex.17.disk7.seg.37 +0 +0 +8 + -2.5 1 10.7353172577 + -2.5 1 10.7368184523 + 0.161905383332 0.153469973369 + +mat7 cone mixtex.17.disk7.seg.38 +0 +0 +8 + -2.5 1 10.7368184523 + -2.5 1 10.7382392751 + 0.153469973369 0.145020654532 + +mat7 cone mixtex.17.disk7.seg.39 +0 +0 +8 + -2.5 1 10.7382392751 + -2.5 1 10.7395795974 + 0.145020654532 0.136558192575 + +mat7 cone mixtex.17.disk7.seg.40 +0 +0 +8 + -2.5 1 10.7395795974 + -2.5 1 10.7408392977 + 0.136558192575 0.128083354446 + +mat7 cone mixtex.17.disk7.seg.41 +0 +0 +8 + -2.5 1 10.7408392977 + -2.5 1 10.7420182619 + 0.128083354446 0.119596908213 + +mat7 cone mixtex.17.disk7.seg.42 +0 +0 +8 + -2.5 1 10.7420182619 + -2.5 1 10.7431163831 + 0.119596908213 0.111099622997 + +mat7 cone mixtex.17.disk7.seg.43 +0 +0 +8 + -2.5 1 10.7431163831 + -2.5 1 10.7441335618 + 0.111099622997 0.102592268901 + +mat7 cone mixtex.17.disk7.seg.44 +0 +0 +8 + -2.5 1 10.7441335618 + -2.5 1 10.7450697058 + 0.102592268901 0.0940756169409 + +mat7 cone mixtex.17.disk7.seg.45 +0 +0 +8 + -2.5 1 10.7450697058 + -2.5 1 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat7 cone mixtex.17.disk7.seg.46 +0 +0 +8 + -2.5 1 10.7459247303 + -2.5 1 10.7466985578 + 0.0855504389738 0.077017507631 + +mat7 cone mixtex.17.disk7.seg.47 +0 +0 +8 + -2.5 1 10.7466985578 + -2.5 1 10.7473911181 + 0.077017507631 0.068477596246 + +mat7 cone mixtex.17.disk7.seg.48 +0 +0 +8 + -2.5 1 10.7473911181 + -2.5 1 10.7480023485 + 0.068477596246 0.059931478785 + +mat7 cone mixtex.17.disk7.seg.49 +0 +0 +8 + -2.5 1 10.7480023485 + -2.5 1 10.7485321935 + 0.059931478785 0.0513799297765 + +mat7 cone mixtex.17.disk7.seg.50 +0 +0 +8 + -2.5 1 10.7485321935 + -2.5 1 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat7 cone mixtex.17.disk7.seg.51 +0 +0 +8 + -2.5 1 10.7489806053 + -2.5 1 10.749347543 + 0.0428237242414 0.0342636376225 + +mat7 cone mixtex.17.disk7.seg.52 +0 +0 +8 + -2.5 1 10.749347543 + -2.5 1 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat7 cone mixtex.17.disk7.seg.53 +0 +0 +8 + -2.5 1 10.7496329735 + -2.5 1 10.749836871 + 0.0257004457143 0.017134924593 + +mat7 cone mixtex.17.disk7.seg.54 +0 +0 +8 + -2.5 1 10.749836871 + -2.5 1 10.7499592168 + 0.017134924593 0.00856785054562 + +mat7 cone mixtex.17.disk7.seg.55 +0 +0 +8 + -2.5 1 10.7499592168 + -2.5 1 10.75 + 0.00856785054562 0 +# xform -m mat8 -n disk8 -t -2.5 2.5 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat8 cone mixtex.17.disk8.seg.1 +0 +0 +8 + -2.5 2.5 10.6294228634 + -2.5 2.5 10.6336714694 + 0.45 0.442559632181 + +mat8 cone mixtex.17.disk8.seg.2 +0 +0 +8 + -2.5 2.5 10.6336714694 + -2.5 2.5 10.6378490518 + 0.442559632181 0.435079155496 + +mat8 cone mixtex.17.disk8.seg.3 +0 +0 +8 + -2.5 2.5 10.6378490518 + -2.5 2.5 10.641955232 + 0.435079155496 0.427559247895 + +mat8 cone mixtex.17.disk8.seg.4 +0 +0 +8 + -2.5 2.5 10.641955232 + -2.5 2.5 10.6459896379 + 0.427559247895 0.420000590903 + +mat8 cone mixtex.17.disk8.seg.5 +0 +0 +8 + -2.5 2.5 10.6459896379 + -2.5 2.5 10.6499519038 + 0.420000590903 0.412403869555 + +mat8 cone mixtex.17.disk8.seg.6 +0 +0 +8 + -2.5 2.5 10.6499519038 + -2.5 2.5 10.6538416706 + 0.412403869555 0.404769772336 + +mat8 cone mixtex.17.disk8.seg.7 +0 +0 +8 + -2.5 2.5 10.6538416706 + -2.5 2.5 10.6576585858 + 0.404769772336 0.397098991119 + +mat8 cone mixtex.17.disk8.seg.8 +0 +0 +8 + -2.5 2.5 10.6576585858 + -2.5 2.5 10.6614023035 + 0.397098991119 0.389392221102 + +mat8 cone mixtex.17.disk8.seg.9 +0 +0 +8 + -2.5 2.5 10.6614023035 + -2.5 2.5 10.6650724844 + 0.389392221102 0.381650160744 + +mat8 cone mixtex.17.disk8.seg.10 +0 +0 +8 + -2.5 2.5 10.6650724844 + -2.5 2.5 10.6686687958 + 0.381650160744 0.373873511702 + +mat8 cone mixtex.17.disk8.seg.11 +0 +0 +8 + -2.5 2.5 10.6686687958 + -2.5 2.5 10.6721909119 + 0.373873511702 0.366062978768 + +mat8 cone mixtex.17.disk8.seg.12 +0 +0 +8 + -2.5 2.5 10.6721909119 + -2.5 2.5 10.6756385134 + 0.366062978768 0.358219269806 + +mat8 cone mixtex.17.disk8.seg.13 +0 +0 +8 + -2.5 2.5 10.6756385134 + -2.5 2.5 10.6790112878 + 0.358219269806 0.350343095686 + +mat8 cone mixtex.17.disk8.seg.14 +0 +0 +8 + -2.5 2.5 10.6790112878 + -2.5 2.5 10.6823089295 + 0.350343095686 0.342435170218 + +mat8 cone mixtex.17.disk8.seg.15 +0 +0 +8 + -2.5 2.5 10.6823089295 + -2.5 2.5 10.6855311397 + 0.342435170218 0.334496210094 + +mat8 cone mixtex.17.disk8.seg.16 +0 +0 +8 + -2.5 2.5 10.6855311397 + -2.5 2.5 10.6886776263 + 0.334496210094 0.326526934816 + +mat8 cone mixtex.17.disk8.seg.17 +0 +0 +8 + -2.5 2.5 10.6886776263 + -2.5 2.5 10.6917481041 + 0.326526934816 0.318528066632 + +mat8 cone mixtex.17.disk8.seg.18 +0 +0 +8 + -2.5 2.5 10.6917481041 + -2.5 2.5 10.6947422949 + 0.318528066632 0.310500330475 + +mat8 cone mixtex.17.disk8.seg.19 +0 +0 +8 + -2.5 2.5 10.6947422949 + -2.5 2.5 10.6976599273 + 0.310500330475 0.302444453894 + +mat8 cone mixtex.17.disk8.seg.20 +0 +0 +8 + -2.5 2.5 10.6976599273 + -2.5 2.5 10.7005007368 + 0.302444453894 0.294361166986 + +mat8 cone mixtex.17.disk8.seg.21 +0 +0 +8 + -2.5 2.5 10.7005007368 + -2.5 2.5 10.7032644661 + 0.294361166986 0.286251202333 + +mat8 cone mixtex.17.disk8.seg.22 +0 +0 +8 + -2.5 2.5 10.7032644661 + -2.5 2.5 10.7059508647 + 0.286251202333 0.278115294937 + +mat8 cone mixtex.17.disk8.seg.23 +0 +0 +8 + -2.5 2.5 10.7059508647 + -2.5 2.5 10.708559689 + 0.278115294937 0.269954182149 + +mat8 cone mixtex.17.disk8.seg.24 +0 +0 +8 + -2.5 2.5 10.708559689 + -2.5 2.5 10.7110907026 + 0.269954182149 0.261768603605 + +mat8 cone mixtex.17.disk8.seg.25 +0 +0 +8 + -2.5 2.5 10.7110907026 + -2.5 2.5 10.7135436762 + 0.261768603605 0.253559301157 + +mat8 cone mixtex.17.disk8.seg.26 +0 +0 +8 + -2.5 2.5 10.7135436762 + -2.5 2.5 10.7159183875 + 0.253559301157 0.24532701881 + +mat8 cone mixtex.17.disk8.seg.27 +0 +0 +8 + -2.5 2.5 10.7159183875 + -2.5 2.5 10.7182146212 + 0.24532701881 0.237072502648 + +mat8 cone mixtex.17.disk8.seg.28 +0 +0 +8 + -2.5 2.5 10.7182146212 + -2.5 2.5 10.7204321692 + 0.237072502648 0.228796500774 + +mat8 cone mixtex.17.disk8.seg.29 +0 +0 +8 + -2.5 2.5 10.7204321692 + -2.5 2.5 10.7225708306 + 0.228796500774 0.220499763235 + +mat8 cone mixtex.17.disk8.seg.30 +0 +0 +8 + -2.5 2.5 10.7225708306 + -2.5 2.5 10.7246304115 + 0.220499763235 0.212183041958 + +mat8 cone mixtex.17.disk8.seg.31 +0 +0 +8 + -2.5 2.5 10.7246304115 + -2.5 2.5 10.7266107252 + 0.212183041958 0.203847090683 + +mat8 cone mixtex.17.disk8.seg.32 +0 +0 +8 + -2.5 2.5 10.7266107252 + -2.5 2.5 10.7285115924 + 0.203847090683 0.19549266489 + +mat8 cone mixtex.17.disk8.seg.33 +0 +0 +8 + -2.5 2.5 10.7285115924 + -2.5 2.5 10.7303328407 + 0.19549266489 0.187120521736 + +mat8 cone mixtex.17.disk8.seg.34 +0 +0 +8 + -2.5 2.5 10.7303328407 + -2.5 2.5 10.732074305 + 0.187120521736 0.178731419981 + +mat8 cone mixtex.17.disk8.seg.35 +0 +0 +8 + -2.5 2.5 10.732074305 + -2.5 2.5 10.7337358275 + 0.178731419981 0.170326119924 + +mat8 cone mixtex.17.disk8.seg.36 +0 +0 +8 + -2.5 2.5 10.7337358275 + -2.5 2.5 10.7353172577 + 0.170326119924 0.161905383332 + +mat8 cone mixtex.17.disk8.seg.37 +0 +0 +8 + -2.5 2.5 10.7353172577 + -2.5 2.5 10.7368184523 + 0.161905383332 0.153469973369 + +mat8 cone mixtex.17.disk8.seg.38 +0 +0 +8 + -2.5 2.5 10.7368184523 + -2.5 2.5 10.7382392751 + 0.153469973369 0.145020654532 + +mat8 cone mixtex.17.disk8.seg.39 +0 +0 +8 + -2.5 2.5 10.7382392751 + -2.5 2.5 10.7395795974 + 0.145020654532 0.136558192575 + +mat8 cone mixtex.17.disk8.seg.40 +0 +0 +8 + -2.5 2.5 10.7395795974 + -2.5 2.5 10.7408392977 + 0.136558192575 0.128083354446 + +mat8 cone mixtex.17.disk8.seg.41 +0 +0 +8 + -2.5 2.5 10.7408392977 + -2.5 2.5 10.7420182619 + 0.128083354446 0.119596908213 + +mat8 cone mixtex.17.disk8.seg.42 +0 +0 +8 + -2.5 2.5 10.7420182619 + -2.5 2.5 10.7431163831 + 0.119596908213 0.111099622997 + +mat8 cone mixtex.17.disk8.seg.43 +0 +0 +8 + -2.5 2.5 10.7431163831 + -2.5 2.5 10.7441335618 + 0.111099622997 0.102592268901 + +mat8 cone mixtex.17.disk8.seg.44 +0 +0 +8 + -2.5 2.5 10.7441335618 + -2.5 2.5 10.7450697058 + 0.102592268901 0.0940756169409 + +mat8 cone mixtex.17.disk8.seg.45 +0 +0 +8 + -2.5 2.5 10.7450697058 + -2.5 2.5 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat8 cone mixtex.17.disk8.seg.46 +0 +0 +8 + -2.5 2.5 10.7459247303 + -2.5 2.5 10.7466985578 + 0.0855504389738 0.077017507631 + +mat8 cone mixtex.17.disk8.seg.47 +0 +0 +8 + -2.5 2.5 10.7466985578 + -2.5 2.5 10.7473911181 + 0.077017507631 0.068477596246 + +mat8 cone mixtex.17.disk8.seg.48 +0 +0 +8 + -2.5 2.5 10.7473911181 + -2.5 2.5 10.7480023485 + 0.068477596246 0.059931478785 + +mat8 cone mixtex.17.disk8.seg.49 +0 +0 +8 + -2.5 2.5 10.7480023485 + -2.5 2.5 10.7485321935 + 0.059931478785 0.0513799297765 + +mat8 cone mixtex.17.disk8.seg.50 +0 +0 +8 + -2.5 2.5 10.7485321935 + -2.5 2.5 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat8 cone mixtex.17.disk8.seg.51 +0 +0 +8 + -2.5 2.5 10.7489806053 + -2.5 2.5 10.749347543 + 0.0428237242414 0.0342636376225 + +mat8 cone mixtex.17.disk8.seg.52 +0 +0 +8 + -2.5 2.5 10.749347543 + -2.5 2.5 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat8 cone mixtex.17.disk8.seg.53 +0 +0 +8 + -2.5 2.5 10.7496329735 + -2.5 2.5 10.749836871 + 0.0257004457143 0.017134924593 + +mat8 cone mixtex.17.disk8.seg.54 +0 +0 +8 + -2.5 2.5 10.749836871 + -2.5 2.5 10.7499592168 + 0.017134924593 0.00856785054562 + +mat8 cone mixtex.17.disk8.seg.55 +0 +0 +8 + -2.5 2.5 10.7499592168 + -2.5 2.5 10.75 + 0.00856785054562 0 +# xform -m mat9 -n disk9 -t -2.5 4 .5 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A rounded saucer for material testing +# +# genrev mat seg -.25+.9*cos(PI/6*(1-t)) .9*sin(PI/6*(1-t)) 55 + +mat9 cone mixtex.17.disk9.seg.1 +0 +0 +8 + -2.5 4 10.6294228634 + -2.5 4 10.6336714694 + 0.45 0.442559632181 + +mat9 cone mixtex.17.disk9.seg.2 +0 +0 +8 + -2.5 4 10.6336714694 + -2.5 4 10.6378490518 + 0.442559632181 0.435079155496 + +mat9 cone mixtex.17.disk9.seg.3 +0 +0 +8 + -2.5 4 10.6378490518 + -2.5 4 10.641955232 + 0.435079155496 0.427559247895 + +mat9 cone mixtex.17.disk9.seg.4 +0 +0 +8 + -2.5 4 10.641955232 + -2.5 4 10.6459896379 + 0.427559247895 0.420000590903 + +mat9 cone mixtex.17.disk9.seg.5 +0 +0 +8 + -2.5 4 10.6459896379 + -2.5 4 10.6499519038 + 0.420000590903 0.412403869555 + +mat9 cone mixtex.17.disk9.seg.6 +0 +0 +8 + -2.5 4 10.6499519038 + -2.5 4 10.6538416706 + 0.412403869555 0.404769772336 + +mat9 cone mixtex.17.disk9.seg.7 +0 +0 +8 + -2.5 4 10.6538416706 + -2.5 4 10.6576585858 + 0.404769772336 0.397098991119 + +mat9 cone mixtex.17.disk9.seg.8 +0 +0 +8 + -2.5 4 10.6576585858 + -2.5 4 10.6614023035 + 0.397098991119 0.389392221102 + +mat9 cone mixtex.17.disk9.seg.9 +0 +0 +8 + -2.5 4 10.6614023035 + -2.5 4 10.6650724844 + 0.389392221102 0.381650160744 + +mat9 cone mixtex.17.disk9.seg.10 +0 +0 +8 + -2.5 4 10.6650724844 + -2.5 4 10.6686687958 + 0.381650160744 0.373873511702 + +mat9 cone mixtex.17.disk9.seg.11 +0 +0 +8 + -2.5 4 10.6686687958 + -2.5 4 10.6721909119 + 0.373873511702 0.366062978768 + +mat9 cone mixtex.17.disk9.seg.12 +0 +0 +8 + -2.5 4 10.6721909119 + -2.5 4 10.6756385134 + 0.366062978768 0.358219269806 + +mat9 cone mixtex.17.disk9.seg.13 +0 +0 +8 + -2.5 4 10.6756385134 + -2.5 4 10.6790112878 + 0.358219269806 0.350343095686 + +mat9 cone mixtex.17.disk9.seg.14 +0 +0 +8 + -2.5 4 10.6790112878 + -2.5 4 10.6823089295 + 0.350343095686 0.342435170218 + +mat9 cone mixtex.17.disk9.seg.15 +0 +0 +8 + -2.5 4 10.6823089295 + -2.5 4 10.6855311397 + 0.342435170218 0.334496210094 + +mat9 cone mixtex.17.disk9.seg.16 +0 +0 +8 + -2.5 4 10.6855311397 + -2.5 4 10.6886776263 + 0.334496210094 0.326526934816 + +mat9 cone mixtex.17.disk9.seg.17 +0 +0 +8 + -2.5 4 10.6886776263 + -2.5 4 10.6917481041 + 0.326526934816 0.318528066632 + +mat9 cone mixtex.17.disk9.seg.18 +0 +0 +8 + -2.5 4 10.6917481041 + -2.5 4 10.6947422949 + 0.318528066632 0.310500330475 + +mat9 cone mixtex.17.disk9.seg.19 +0 +0 +8 + -2.5 4 10.6947422949 + -2.5 4 10.6976599273 + 0.310500330475 0.302444453894 + +mat9 cone mixtex.17.disk9.seg.20 +0 +0 +8 + -2.5 4 10.6976599273 + -2.5 4 10.7005007368 + 0.302444453894 0.294361166986 + +mat9 cone mixtex.17.disk9.seg.21 +0 +0 +8 + -2.5 4 10.7005007368 + -2.5 4 10.7032644661 + 0.294361166986 0.286251202333 + +mat9 cone mixtex.17.disk9.seg.22 +0 +0 +8 + -2.5 4 10.7032644661 + -2.5 4 10.7059508647 + 0.286251202333 0.278115294937 + +mat9 cone mixtex.17.disk9.seg.23 +0 +0 +8 + -2.5 4 10.7059508647 + -2.5 4 10.708559689 + 0.278115294937 0.269954182149 + +mat9 cone mixtex.17.disk9.seg.24 +0 +0 +8 + -2.5 4 10.708559689 + -2.5 4 10.7110907026 + 0.269954182149 0.261768603605 + +mat9 cone mixtex.17.disk9.seg.25 +0 +0 +8 + -2.5 4 10.7110907026 + -2.5 4 10.7135436762 + 0.261768603605 0.253559301157 + +mat9 cone mixtex.17.disk9.seg.26 +0 +0 +8 + -2.5 4 10.7135436762 + -2.5 4 10.7159183875 + 0.253559301157 0.24532701881 + +mat9 cone mixtex.17.disk9.seg.27 +0 +0 +8 + -2.5 4 10.7159183875 + -2.5 4 10.7182146212 + 0.24532701881 0.237072502648 + +mat9 cone mixtex.17.disk9.seg.28 +0 +0 +8 + -2.5 4 10.7182146212 + -2.5 4 10.7204321692 + 0.237072502648 0.228796500774 + +mat9 cone mixtex.17.disk9.seg.29 +0 +0 +8 + -2.5 4 10.7204321692 + -2.5 4 10.7225708306 + 0.228796500774 0.220499763235 + +mat9 cone mixtex.17.disk9.seg.30 +0 +0 +8 + -2.5 4 10.7225708306 + -2.5 4 10.7246304115 + 0.220499763235 0.212183041958 + +mat9 cone mixtex.17.disk9.seg.31 +0 +0 +8 + -2.5 4 10.7246304115 + -2.5 4 10.7266107252 + 0.212183041958 0.203847090683 + +mat9 cone mixtex.17.disk9.seg.32 +0 +0 +8 + -2.5 4 10.7266107252 + -2.5 4 10.7285115924 + 0.203847090683 0.19549266489 + +mat9 cone mixtex.17.disk9.seg.33 +0 +0 +8 + -2.5 4 10.7285115924 + -2.5 4 10.7303328407 + 0.19549266489 0.187120521736 + +mat9 cone mixtex.17.disk9.seg.34 +0 +0 +8 + -2.5 4 10.7303328407 + -2.5 4 10.732074305 + 0.187120521736 0.178731419981 + +mat9 cone mixtex.17.disk9.seg.35 +0 +0 +8 + -2.5 4 10.732074305 + -2.5 4 10.7337358275 + 0.178731419981 0.170326119924 + +mat9 cone mixtex.17.disk9.seg.36 +0 +0 +8 + -2.5 4 10.7337358275 + -2.5 4 10.7353172577 + 0.170326119924 0.161905383332 + +mat9 cone mixtex.17.disk9.seg.37 +0 +0 +8 + -2.5 4 10.7353172577 + -2.5 4 10.7368184523 + 0.161905383332 0.153469973369 + +mat9 cone mixtex.17.disk9.seg.38 +0 +0 +8 + -2.5 4 10.7368184523 + -2.5 4 10.7382392751 + 0.153469973369 0.145020654532 + +mat9 cone mixtex.17.disk9.seg.39 +0 +0 +8 + -2.5 4 10.7382392751 + -2.5 4 10.7395795974 + 0.145020654532 0.136558192575 + +mat9 cone mixtex.17.disk9.seg.40 +0 +0 +8 + -2.5 4 10.7395795974 + -2.5 4 10.7408392977 + 0.136558192575 0.128083354446 + +mat9 cone mixtex.17.disk9.seg.41 +0 +0 +8 + -2.5 4 10.7408392977 + -2.5 4 10.7420182619 + 0.128083354446 0.119596908213 + +mat9 cone mixtex.17.disk9.seg.42 +0 +0 +8 + -2.5 4 10.7420182619 + -2.5 4 10.7431163831 + 0.119596908213 0.111099622997 + +mat9 cone mixtex.17.disk9.seg.43 +0 +0 +8 + -2.5 4 10.7431163831 + -2.5 4 10.7441335618 + 0.111099622997 0.102592268901 + +mat9 cone mixtex.17.disk9.seg.44 +0 +0 +8 + -2.5 4 10.7441335618 + -2.5 4 10.7450697058 + 0.102592268901 0.0940756169409 + +mat9 cone mixtex.17.disk9.seg.45 +0 +0 +8 + -2.5 4 10.7450697058 + -2.5 4 10.7459247303 + 0.0940756169409 0.0855504389738 + +mat9 cone mixtex.17.disk9.seg.46 +0 +0 +8 + -2.5 4 10.7459247303 + -2.5 4 10.7466985578 + 0.0855504389738 0.077017507631 + +mat9 cone mixtex.17.disk9.seg.47 +0 +0 +8 + -2.5 4 10.7466985578 + -2.5 4 10.7473911181 + 0.077017507631 0.068477596246 + +mat9 cone mixtex.17.disk9.seg.48 +0 +0 +8 + -2.5 4 10.7473911181 + -2.5 4 10.7480023485 + 0.068477596246 0.059931478785 + +mat9 cone mixtex.17.disk9.seg.49 +0 +0 +8 + -2.5 4 10.7480023485 + -2.5 4 10.7485321935 + 0.059931478785 0.0513799297765 + +mat9 cone mixtex.17.disk9.seg.50 +0 +0 +8 + -2.5 4 10.7485321935 + -2.5 4 10.7489806053 + 0.0513799297765 0.0428237242414 + +mat9 cone mixtex.17.disk9.seg.51 +0 +0 +8 + -2.5 4 10.7489806053 + -2.5 4 10.749347543 + 0.0428237242414 0.0342636376225 + +mat9 cone mixtex.17.disk9.seg.52 +0 +0 +8 + -2.5 4 10.749347543 + -2.5 4 10.7496329735 + 0.0342636376225 0.0257004457143 + +mat9 cone mixtex.17.disk9.seg.53 +0 +0 +8 + -2.5 4 10.7496329735 + -2.5 4 10.749836871 + 0.0257004457143 0.017134924593 + +mat9 cone mixtex.17.disk9.seg.54 +0 +0 +8 + -2.5 4 10.749836871 + -2.5 4 10.7499592168 + 0.017134924593 0.00856785054562 + +mat9 cone mixtex.17.disk9.seg.55 +0 +0 +8 + -2.5 4 10.7499592168 + -2.5 4 10.75 + 0.00856785054562 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Multiple light sources for material models +# + +void light bright +0 +0 +3 100 100 100 + +bright sphere mixtex.17.bulb0 +0 +0 +4 -1.9 2.5 12.4 0.03 + +bright sphere mixtex.17.bulb1 +0 +0 +4 -2.30106431181 3.73434902981 12.4 0.03 + +bright sphere mixtex.17.bulb2 +0 +0 +4 -3.35106431181 4.49721868422 12.4 0.03 + +bright sphere mixtex.17.bulb3 +0 +0 +4 -4.64893568819 4.49721868422 12.4 0.03 + +bright sphere mixtex.17.bulb4 +0 +0 +4 -5.69893568819 3.73434902981 12.4 0.03 + +bright sphere mixtex.17.bulb5 +0 +0 +4 -6.1 2.5 12.4 0.03 + +bright sphere mixtex.17.bulb6 +0 +0 +4 -5.69893568819 1.26565097019 12.4 0.03 + +bright sphere mixtex.17.bulb7 +0 +0 +4 -4.64893568819 0.50278131578 12.4 0.03 + +bright sphere mixtex.17.bulb8 +0 +0 +4 -3.35106431181 0.50278131578 12.4 0.03 + +bright sphere mixtex.17.bulb9 +0 +0 +4 -2.30106431181 1.26565097019 12.4 0.03 +# xform -n spectra.18 -t 0 5.2 9.6 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Basic materials used for walls, etc. + +void plastic wall_mat +0 +0 +5 0.5 0.5 0.5 0 0 + +void plastic ceil_mat +0 +0 +5 0.7 0.7 0.7 0 0 + +void plastic floor_mat +0 +0 +5 0.3 0.2 0.1 0.02 0.04 + +void plastic black_outside +0 +0 +5 0.05 0.05 0.05 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Spectral material definitions +# + +void spectrum gold_spec +0 +0 +82 380 775 0.389133964 0.389133964 0.389255302 0.389980986 0.391051245 0.392138273 0.392908482 0.393032534 0.392429968 0.391351324 0.390030615 0.388650157 0.387407915 0.386320218 0.385530031 0.385510124 0.386040307 0.386026057 0.388298949 0.394215681 0.404140535 0.419966115 0.443246002 0.473861019 0.511014174 0.552643396 0.596304788 0.639685049 0.682955923 0.723645597 0.759200442 0.789126545 0.813469177 0.832955943 0.848265499 0.860485356 0.870549939 0.878925721 0.885276016 0.891159039 0.896546999 0.901393946 0.905636686 0.909327028 0.912475235 0.91521538 0.917680109 0.919998384 0.922297675 0.924966158 0.927728576 0.930571538 0.933477024 0.936421086 0.939377245 0.942439249 0.945588396 0.948563802 0.951319598 0.953828111 0.956075841 0.958059262 0.959789105 0.961306963 0.96261608 0.963753124 0.964748535 0.965627808 0.966413149 0.96712339 0.967778124 0.968398351 0.968976934 0.969517604 0.970024269 0.970500409 0.970949021 0.971372989 0.971775043 0.972157635 + +void specfile copper_spec +1 copper_spec.dat +0 +0 +# Third real argument is bandwidth and determines brightness/saturation + +void specfunc rainbow_spec +14 xrainbow rainbow.cal -s 4 -t -6 0 0 -i 1 -t 0 5.2 9.6 +0 +3 380 780 30 + +gold_spec metal gold_smat +0 +0 +5 1 1 1 1 0 + +copper_spec metal copper_smat +0 +0 +5 1 1 1 1 0 + +rainbow_spec plastic rainbow_smat +0 +0 +5 1 1 1 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ + +void metal gold +0 +0 +5 0.99717 0.781957 0.334172 1 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# Walls of our diorama +# xform -ry -90 +# genprism black_outside wall 10 -.1 -.1 -.1 5.1 3.1 5.1 3.1 -.1 -.1 -.1 0 0 3 0 3 5 0 5 0 0 -l 0 0 8 -c + +black_outside polygon spectra.18.wall.b +0 +0 +30 + -6.12323399574e-18 5.1 9.5 + -6.12323399574e-18 10.3 9.5 + 1.89820253868e-16 10.3 12.7 + 1.89820253868e-16 5.1 12.7 + -6.12323399574e-18 5.1 9.5 + 0 5.2 9.6 + 1.83697019872e-16 5.2 12.6 + 1.83697019872e-16 10.2 12.6 + 0 10.2 9.6 + 0 5.2 9.6 + +black_outside polygon spectra.18.wall.t +0 +0 +30 + -8 5.2 9.6 + -8 10.2 9.6 + -8 10.2 12.6 + -8 5.2 12.6 + -8 5.2 9.6 + -8 5.1 9.5 + -8 5.1 12.7 + -8 10.3 12.7 + -8 10.3 9.5 + -8 5.1 9.5 + +black_outside polygon spectra.18.wall.1 +0 +0 +12 + -6.12323399574e-18 5.1 9.5 + -8 5.1 9.5 + -8 10.3 9.5 + -6.12323399574e-18 10.3 9.5 + +black_outside polygon spectra.18.wall.2 +0 +0 +12 + -6.12323399574e-18 10.3 9.5 + -8 10.3 9.5 + -8 10.3 12.7 + 1.89820253868e-16 10.3 12.7 + +black_outside polygon spectra.18.wall.3 +0 +0 +12 + 1.89820253868e-16 10.3 12.7 + -8 10.3 12.7 + -8 5.1 12.7 + 1.89820253868e-16 5.1 12.7 + +black_outside polygon spectra.18.wall.4 +0 +0 +12 + 1.89820253868e-16 5.1 12.7 + -8 5.1 12.7 + -8 5.1 9.5 + -6.12323399574e-18 5.1 9.5 +# black_outside polygon wall.5 +# 0 +# 0 +# 12 +# -6.12323399574e-18 -0.1 -0.1 +# -8 -0.1 -0.1 +# -8 0 4.89858719659e-16 +# 0 0 0 + +wall_mat polygon spectra.18.wall.6 +0 +0 +12 + 0 5.2 9.6 + -8 5.2 9.6 + -8 5.2 12.6 + 1.83697019872e-16 5.2 12.6 + +ceil_mat polygon spectra.18.wall.7 +0 +0 +12 + 1.83697019872e-16 5.2 12.6 + -8 5.2 12.6 + -8 10.2 12.6 + 1.83697019872e-16 10.2 12.6 + +wall_mat polygon spectra.18.wall.8 +0 +0 +12 + 1.83697019872e-16 10.2 12.6 + -8 10.2 12.6 + -8 10.2 9.6 + 0 10.2 9.6 + +floor_mat polygon spectra.18.wall.9 +0 +0 +12 + 0 10.2 9.6 + -8 10.2 9.6 + -8 5.2 9.6 + 0 5.2 9.6 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# A closed wall for the end cap of our diorama +# xform -t -8.2 -.1 -.1 +# genbox wall_mat end_wall .2 5.2 3.2 + +wall_mat polygon spectra.18.end_wall.1540 +0 +0 +12 + -8 5.1 9.5 + -8 5.1 12.7 + -8.2 5.1 12.7 + -8.2 5.1 9.5 + +wall_mat polygon spectra.18.end_wall.4620 +0 +0 +12 + -8.2 5.1 12.7 + -8.2 10.3 12.7 + -8.2 10.3 9.5 + -8.2 5.1 9.5 + +wall_mat polygon spectra.18.end_wall.2310 +0 +0 +12 + -8.2 10.3 9.5 + -8 10.3 9.5 + -8 5.1 9.5 + -8.2 5.1 9.5 + +wall_mat polygon spectra.18.end_wall.3267 +0 +0 +12 + -8 10.3 9.5 + -8.2 10.3 9.5 + -8.2 10.3 12.7 + -8 10.3 12.7 + +wall_mat polygon spectra.18.end_wall.5137 +0 +0 +12 + -8 5.1 12.7 + -8 5.1 9.5 + -8 10.3 9.5 + -8 10.3 12.7 + +wall_mat polygon spectra.18.end_wall.6457 +0 +0 +12 + -8.2 10.3 12.7 + -8.2 5.1 12.7 + -8 5.1 12.7 + -8 10.3 12.7 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# xform -s 0.0253999863 -rz 90 -t -4 2.5 2.999 +# +# Wellmade 2 lamp fixture, model 395-12A-248RS +# +# Dimensions in inches, fixture parallel to y axis, center at origin +# + +void brightdata lum_dist +19 flatcorr rect_fixture.dat source.cal src_phi4 src_theta -s 0.0253999863 -rz 90 -t -4 2.5 2.999 -i 1 -t 0 5.2 9.6 +0 +0 +# this is scaled by 1/area (SI) + +lum_dist light lum_bright +0 +0 +3 20 20 20 +# 3 1.55 1.55 1.55 + +lum_bright polygon spectra.18.luminaire +0 +0 +12 + -3.42215031167 7.42695014727 12.599 + -4.57784968833 7.42695014728 12.599 + -4.57784968833 7.97304985273 12.599 + -3.42215031167 7.97304985272 12.599 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# A few spectral test objects +# +# xform -m gold -t 0 -1 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Vase model courtesy Tom Mertens from web page: +# http://people.csail.mit.edu/tmertens/textransfer/data +# Include acknowledgment in any published work: +# "textured 3D model from the MIT CSAIL database" +# +# Origin is at center of base; Z-axis is up. +# Vase is approx. 23cm tall +# Moved into middle of room for testing +# + +void colorpict vase_pat +19 lim_r lim_g lim_b vase.hdr climit.cal Lu Lv -i 1 -t 0 -1 0 -i 1 -t 0 5.2 9.6 +0 +3 0.318558228 0.196044229 0.0860372415 + +vase_pat plastic vase_clay +0 +0 +5 1 1 1 0 0 + +gold mesh spectra.18.vase +23 vase.rtm -t 25 5 130 -s .005 -t -4 2.5 1 -i 1 -t 0 -1 0 -i 1 -t 0 5.2 9.6 +0 +0 +# xform -m gold_smat -t 0 1 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Vase model courtesy Tom Mertens from web page: +# http://people.csail.mit.edu/tmertens/textransfer/data +# Include acknowledgment in any published work: +# "textured 3D model from the MIT CSAIL database" +# +# Origin is at center of base; Z-axis is up. +# Vase is approx. 23cm tall +# Moved into middle of room for testing +# + +void colorpict vase_pat +19 lim_r lim_g lim_b vase.hdr climit.cal Lu Lv -i 1 -t 0 1 0 -i 1 -t 0 5.2 9.6 +0 +3 0.318558228 0.196044229 0.0860372415 + +vase_pat plastic vase_clay +0 +0 +5 1 1 1 0 0 + +gold_smat mesh spectra.18.vase +23 vase.rtm -t 25 5 130 -s .005 -t -4 2.5 1 -i 1 -t 0 1 0 -i 1 -t 0 5.2 9.6 +0 +0 +# xform -m copper_smat -t 1 0 0 +# RCSid $Id: combined.rad,v 1.14 2023/11/17 21:22:27 greg Exp $ +# +# Vase model courtesy Tom Mertens from web page: +# http://people.csail.mit.edu/tmertens/textransfer/data +# Include acknowledgment in any published work: +# "textured 3D model from the MIT CSAIL database" +# +# Origin is at center of base; Z-axis is up. +# Vase is approx. 23cm tall +# Moved into middle of room for testing +# + +void colorpict vase_pat +19 lim_r lim_g lim_b vase.hdr climit.cal Lu Lv -i 1 -t 1 0 0 -i 1 -t 0 5.2 9.6 +0 +3 0.318558228 0.196044229 0.0860372415 + +vase_pat plastic vase_clay +0 +0 +5 1 1 1 0 0 + +copper_smat mesh spectra.18.vase +23 vase.rtm -t 25 5 130 -s .005 -t -4 2.5 1 -i 1 -t 1 0 0 -i 1 -t 0 5.2 9.6 +0 +0 + +rainbow_smat polygon spectra.18.rainbow1 +0 +0 +12 + -6 5.21 10.6 + -2 5.21 10.6 + -2 5.21 11.6 + -6 5.21 11.6 + +rainbow_smat polygon spectra.18.rainbow2 +0 +0 +12 + -6 10.19 11.6 + -2 10.19 11.6 + -2 10.19 10.6 + -6 10.19 10.6
