root/radiance/ray/test/renders/mixtex.rif
Fri Feb 19 06:01:46 2021 UTC (4 years, 4 months ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 1.8
test: fixes and improvements with addition of batches for splitting job
Sun Jan 3 00:07:03 2021 UTC (4 years, 5 months ago) by greg
Diff to previous 1.7
Corrected use of bias compensation
Fri Jan 1 20:15:35 2021 UTC (4 years, 5 months ago) by greg
Diff to previous 1.6
Added bias compensation to photon-mapping tests
Mon Aug 10 20:48:12 2020 UTC (4 years, 10 months ago) by greg
Diff to previous 1.5
test(mkpmap): Better choice of photon portal thanks to Roland Schregle
Fri Dec 7 23:07:37 2018 UTC (6 years, 6 months ago) by greg
Diff to previous 1.4
Reduced QUALITY setting
Fri Dec 7 17:44:58 2018 UTC (6 years, 6 months ago) by greg
Changes since 1.3: +7 -5 lines
Diff to previous 1.3
Switched to photon-mapping in mixtex scene to reduce artifacts
Sat Dec 1 05:40:35 2018 UTC (6 years, 6 months ago) by greg
Changes since 1.2: +2 -4 lines
Diff to previous 1.2
Fixes to reproducibility issues
Sat Dec 1 02:06:05 2018 UTC (6 years, 6 months ago) by greg
Changes since 1.1: +19 -6 lines
Diff to previous 1.1
Finished additions for BSDF's, etc. to complete primitive testing
Wed Nov 21 22:59:04 2018 UTC (6 years, 7 months ago) by greg
Work in progress on test of mixtures, textures and BSDF data types
