1 |
# RCSid $Id$ |
2 |
3 |
ref/ Subdirectory containing reference outputs for comparison |
4 |
5 |
Makefile Scene testing dependencies |
6 |
7 |
README.txt This file |
8 |
test.txt Some text for use in *text primitives |
9 |
10 |
render.opt A few global rendering options used by most rad input files |
11 |
12 |
fish.vf view parameters for standard fisheye view away from window |
13 |
inside.vf view parameters for default interior view towards window |
14 |
15 |
combined.rif A combined scene file including every primitive |
16 |
dielectric.rif Test of dielectric material in window and mesh instance |
17 |
glass.rif Test of glass pane in window and material mixture |
18 |
inst.rif Test of octree instances and ashik2 material |
19 |
mesh.rif Test of Radiance triangle mesh instances and view types |
20 |
mirror.rif Test of mirror (virtual sources) and antimatter |
21 |
mist.rif Test of mist (participating medium) in combination with spotlight |
22 |
mixtex.rif Test of BSDF types and photon-mapping |
23 |
patterns.rif Test of various pattern types and alias behavior |
24 |
prism1.rif Test of prism1 type (single virtual source) |
25 |
prism2.rif Test of prism2 type (dual virtual sources) |
26 |
tfunc.rif Test of BRTDfunc, transfunc and mkillum |
27 |
trans.rif Test of anisotropic types, plasfunc and metfunc, mixtures |
28 |
trans2.rif Test of trans2 and mkillum (again) |
29 |
30 |
basic.mat Basic materials used by all models |
31 |
chrome.mat Chrome material used in mesh model |
32 |
gold.mat Gold material used in prism1 and prism2 models |
33 |
mixtex.mat Nine test materials used in mixtex model |
34 |
patterns.mat Nine test materials and aliases used in patterns model |
35 |
36 |
antimatter_portal.rad Cut-away hole seen in mirror model |
37 |
ball_in_cube.rad Example of dielectric and interface materials |
38 |
ballcompare.rad Combo test of *func materials, mixtures, and text for trans model |
39 |
blinds.rad BSDF from XML file with geometry placed by pkgBSDF |
40 |
bubble_in_cube.rad Example of colored dielectric and interface |
41 |
closed_end.rad Cap for far end of space when there is no window |
42 |
combined_scene.rad Combination of all our test scenes without front caps |
43 |
constellation.rad A set of ten simple light bulbs ina circle |
44 |
dielectric_pane.rad Dual-surface dielectric window for testing |
45 |
diorama_walls.rad The walls of our deep test room, minus both ends |
46 |
disks.rad A generic set of nine disks for material testing |
47 |
front_cap.rad Wall away from window (used except in combined scene) |
48 |
glass_ill.rad Recorded output from mkillum run of glass window |
49 |
glass_pane.rad Bluish glass pane for window |
50 |
gymbal.rad Example of BRTDfunc type, cylinders and tubes |
51 |
illum_glass.rad Input used to create glass_ill.rad |
52 |
illum_tfunc.rad Mkillum input used in tfunc model |
53 |
illum_trans2.rad Mkillum input used in trans2 model |
54 |
mirror.rad Example of mirror on wall |
55 |
mist.rad Example of mist (participating medium) inside test space |
56 |
porsches.rad Two instances of porsche.octf with original material and ashik2 |
57 |
prism1.rad Example of rectangular prism1 pane in window |
58 |
prism2.rad Example of rectangular prism2 pane in window |
59 |
rect_fixture.rad A single rectangular light fixture with distribution |
60 |
rect_opening.rad Rectangular opening in window wall |
61 |
saucer.rad A shaped disk for material testing |
62 |
sawtooth.rad Object with sawtooth profile for genBSDF input (not referenced) |
63 |
spotcones.rad Cones enclosing spotlight regions for testing mist type |
64 |
spotlights.rad Color spotlights |
65 |
sunset_sky.rad Captured sky with disk covering sun position |
66 |
torus.rad Psychedelic donut testing material mixtures and glow |
67 |
trans_pane.rad A yellowish diffusing test of trans type |
68 |
vase.rad Instance of vase triangle mesh |
69 |
woman.rad Instance of "woman" triangle mesh |
70 |
71 |
vase.rtm Vase triangle mesh with local texture map |
72 |
woman.rtm Woman triangle mesh with local texture map |
73 |
porsche.octf Frozen octree of Porsche with materials |
74 |
75 |
aniso.cal Ward-Geisler-Moroder-Duer anisotropic reflection model |
76 |
bumpypat.cal Used by texdata type in patterns model |
77 |
climit.cal Standard color handling for local texture map used by vase.rad |
78 |
diskcoords.cal Coordinates used for Shirley-Chiu BSDF data |
79 |
fisheye.cal Mapping for captured sunset image |
80 |
maxang.cal Used for transdata material in mixtex.mat |
81 |
prism.cal Standard angle calculation for prismatic glazing (prism1 & prism2) |
82 |
83 |
flower.hdr Image of flower used in various *pict types |
84 |
sunset.hdr Captured sunset for environment map out window |
85 |
vase.hdr Vase local texture map |
86 |
87 |
flower.dat Flower.hdr converted to a 10x10 gray data file |
88 |
glass_illB.dat Distribution computed by mkillum for glass_ill.rad |
89 |
glass_illG.dat Distribution computed by mkillum for glass_ill.rad |
90 |
glass_illR.dat Distribution computed by mkillum for glass_ill.rad |
91 |
rect_fixture.dat Rectangular light fixture output distribution |
92 |
sawtooth.dat BRDF of sawtooth profile material converted to a data file |
93 |
tcutoff.dat Used for transdata material in mixtex.mat |
