| 1 |
# RCSid $Id: README.txt,v 1.2 2018/12/04 00:32:20 greg Exp $
| 2 |
| 3 |
ref/ Subdirectory containing reference outputs for comparison
| 4 |
| 5 |
Makefile Scene testing dependencies
| 6 |
| 7 |
README.txt This file
| 8 |
test.txt Some text for use in *text primitives
| 9 |
| 10 |
render.opt A few global rendering options used by most rad input files
| 11 |
| 12 |
fish.vf View parameters for standard fisheye view away from window
| 13 |
inside.vf View parameters for default interior view towards window
| 14 |
| 15 |
combined.rif A combined scene file including every primitive
| 16 |
dielectric.rif Test of dielectric material in window and mesh instance
| 17 |
glass.rif Test of glass pane in window and material mixture
| 18 |
inst.rif Test of octree instances and ashik2 material
| 19 |
mesh.rif Test of Radiance triangle mesh instances and view types
| 20 |
mirror.rif Test of mirror (virtual sources) and antimatter
| 21 |
mist.rif Test of mist (participating medium) in combination with spotlight
| 22 |
mixtex.rif Test of BSDF types and photon-mapping
| 23 |
patterns.rif Test of various pattern types and alias behavior
| 24 |
prism1.rif Test of prism1 type (single virtual source)
| 25 |
prism2.rif Test of prism2 type (dual virtual sources)
| 26 |
spectra.rif Test of spectral pattern types
| 27 |
tfunc.rif Test of BRTDfunc, transfunc and mkillum
| 28 |
trans.rif Test of anisotropic types, plasfunc and metfunc, mixtures
| 29 |
trans2.rif Test of trans2 and mkillum (again)
| 30 |
| 31 |
basic.mat Basic materials used by all models
| 32 |
chrome.mat Chrome material used in mesh model
| 33 |
gold.mat Gold material used in prism1 and prism2 models
| 34 |
mixtex.mat Nine test materials used in mixtex model
| 35 |
patterns.mat Nine test materials and aliases used in patterns model
| 36 |
spectral.mat Spectral test materials
| 37 |
| 38 |
antimatter_portal.rad Cut-away hole seen in mirror model
| 39 |
ball_in_cube.rad Example of dielectric and interface materials
| 40 |
ballcompare.rad Combo test of *func materials, mixtures, and text for trans model
| 41 |
blinds.rad BSDF from XML file with geometry placed by pkgBSDF
| 42 |
bubble_in_cube.rad Example of colored dielectric and interface
| 43 |
closed_end.rad Cap for far end of space when there is no window
| 44 |
combined_scene.rad Combination of all our test scenes without front caps
| 45 |
constellation.rad A set of ten simple light bulbs ina circle
| 46 |
dielectric_pane.rad Dual-surface dielectric window for testing
| 47 |
diorama_walls.rad The walls of our deep test room, minus both ends
| 48 |
disks.rad A generic set of nine disks for material testing
| 49 |
front_cap.rad Wall away from window (used except in combined scene)
| 50 |
glass_ill.rad Recorded output from mkillum run of glass window
| 51 |
glass_pane.rad Bluish glass pane for window
| 52 |
glowbulb.rad Test of glow material with non-zero influence radius
| 53 |
gymbal.rad Example of BRTDfunc type, cylinders and tubes
| 54 |
illum_glass.rad Input used to create glass_ill.rad
| 55 |
illum_tfunc.rad Mkillum input used in tfunc model
| 56 |
illum_trans2.rad Mkillum input used in trans2 model
| 57 |
mirror.rad Example of mirror on wall
| 58 |
mist.rad Example of mist (participating medium) inside test space
| 59 |
porsches.rad Two instances of porsche.octf with original material and ashik2
| 60 |
prism1.rad Example of rectangular prism1 pane in window
| 61 |
prism2.rad Example of rectangular prism2 pane in window
| 62 |
rect_fixture.rad A single rectangular light fixture with distribution
| 63 |
rect_opening.rad Rectangular opening in window wall
| 64 |
saucer.rad A shaped disk for material testing
| 65 |
sawtooth.rad Object with sawtooth profile for genBSDF input (not referenced)
| 66 |
spectral_objs.rad Some test objects for spectral rendering
| 67 |
spotcones.rad Cones enclosing spotlight regions for testing mist type
| 68 |
spotlights.rad Color spotlights
| 69 |
sunset_sky.rad Captured sky with disk covering sun position
| 70 |
torus.rad Psychedelic donut testing material mixtures and glow
| 71 |
trans_pane.rad A yellowish diffusing test of trans type
| 72 |
vase.rad Instance of vase triangle mesh
| 73 |
woman.rad Instance of "woman" triangle mesh
| 74 |
| 75 |
vase.rtm Vase triangle mesh with local texture map
| 76 |
woman.rtm Woman triangle mesh with local texture map
| 77 |
porsche.octf Frozen octree of Porsche with materials
| 78 |
| 79 |
aniso.cal Ward-Geisler-Moroder-Duer anisotropic reflection model
| 80 |
bumpypat.cal Used by texdata type in patterns model
| 81 |
climit.cal Standard color handling for local texture map used by vase.rad
| 82 |
diskcoords.cal Coordinates used for Shirley-Chiu BSDF data
| 83 |
fisheye.cal Mapping for captured sunset image
| 84 |
maxang.cal Used for transdata material in mixtex.mat
| 85 |
prism.cal Standard angle calculation for prismatic glazing (prism1 & prism2)
| 86 |
| 87 |
flower.hdr Image of flower used in various *pict types
| 88 |
sunset.hdr Captured sunset for environment map out window
| 89 |
vase.hdr Vase local texture map
| 90 |
| 91 |
copper_gold.dat Blend from copper to gold spectra
| 92 |
copper_spec.dat Copper spectral reflectivity
| 93 |
flower.dat Flower.hdr converted to a 10x10 gray data file
| 94 |
glass_illB.dat Distribution computed by mkillum for glass_ill.rad
| 95 |
glass_illG.dat Distribution computed by mkillum for glass_ill.rad
| 96 |
glass_illR.dat Distribution computed by mkillum for glass_ill.rad
| 97 |
rect_fixture.dat Rectangular light fixture output distribution
| 98 |
sawtooth.dat BRDF of sawtooth profile material converted to a data file
| 99 |
tcutoff.dat Used for transdata material in mixtex.mat
