root/radiance/ray/test/renders/Makefile
Fri May 23 19:42:48 2025 UTC (2 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 1.41: +2 -12 lines
Diff to previous 1.41 , to selected 1.36
test(mgf2rad): Added test of spectral output with WGMDfunc
Mon Dec 9 00:44:29 2024 UTC (7 months, 3 weeks ago) by greg
Changes since 1.40: +21 -3 lines
Diff to previous 1.40 , to selected 1.36
Tue Mar 12 15:49:18 2024 UTC (16 months, 2 weeks ago) by greg
Changes since 1.39: +31 -31 lines
Diff to previous 1.39 , to selected 1.36
chore: Removed inappropriate dependencies
Wed Jan 17 18:57:54 2024 UTC (18 months, 1 week ago) by greg
Changes since 1.38: +29 -57 lines
Diff to previous 1.38 , to selected 1.36
test: Update to spectral rendering code
Fri Dec 15 16:31:32 2023 UTC (19 months, 2 weeks ago) by greg
Diff to previous 1.37 , to selected 1.36
test: Added spectral testing to batch run for Windows
Fri Nov 17 22:03:14 2023 UTC (20 months, 1 week ago) by greg
Changes since 1.36: +6 -1 lines
Diff to previous 1.36
test: added missing target for spectra.oct
Revision 1.36 - (view) (download) (annotate) - [selected]
Fri Nov 17 21:22:27 2023 UTC (20 months, 1 week ago) by greg
Changes since 1.35: +16 -2 lines
Diff to previous 1.35
test: Added hyperspectral test scene "spectra.rif" and test-spectra-fish
Tue Mar 2 17:51:56 2021 UTC (4 years, 4 months ago) by greg
Changes since 1.34: +9 -7 lines
Diff to previous 1.34 , to selected 1.36
test: rearranged target order in hopes of making build more efficient
Fri Feb 19 06:01:46 2021 UTC (4 years, 5 months ago) by greg
Changes since 1.33: +19 -4 lines
Diff to previous 1.33 , to selected 1.36
test: fixes and improvements with addition of batches for splitting job
Thu Feb 18 23:24:12 2021 UTC (4 years, 5 months ago) by greg
Changes since 1.32: +2 -2 lines
Diff to previous 1.32 , to selected 1.36
test: bumped up threshold a little further
Thu Feb 18 23:17:49 2021 UTC (4 years, 5 months ago) by greg
Changes since 1.31: +2 -2 lines
Diff to previous 1.31 , to selected 1.36
test: Added relative difference minimum to picture comparisons
Sun Jan 24 01:53:41 2021 UTC (4 years, 6 months ago) by greg
Changes since 1.30: +2 -2 lines
Diff to previous 1.30 , to selected 1.36
test: increased tolerance for picture comparisons to deal better with speculars
Sat Jan 2 02:46:57 2021 UTC (4 years, 6 months ago) by greg
Diff to previous 1.29 , to selected 1.36
test: Added missing tests for prism1 and prism2
Sat Jan 2 01:56:17 2021 UTC (4 years, 6 months ago) by greg
Diff to previous 1.28 , to selected 1.36
test: added missing test for trans2-win
Fri Jan 1 20:15:35 2021 UTC (4 years, 6 months ago) by greg
Diff to previous 1.27 , to selected 1.36
Added bias compensation to photon-mapping tests
Thu Jul 30 02:19:27 2020 UTC (5 years ago) by greg
Changes since 1.26: +6 -2 lines
Diff to previous 1.26 , to selected 1.36
test: conditional to turn multi-processing off under Windows (thanks to Mingbo)
Wed Jul 29 23:38:22 2020 UTC (5 years ago) by greg
Changes since 1.25: +5 -5 lines
Diff to previous 1.25 , to selected 1.36
test: fix for Windows, which doesn't like single-quotes in commands
Wed Jul 29 18:45:00 2020 UTC (5 years ago) by greg
Changes since 1.24: +4 -4 lines
Diff to previous 1.24 , to selected 1.36
test: corrected target octree with mkillum involved
Mon Jul 27 16:49:56 2020 UTC (5 years ago) by greg
Diff to previous 1.23 , to selected 1.36
feat(radcompare): added -c option to ignore comments
Fri Jul 17 15:43:31 2020 UTC (5 years ago) by greg
Diff to previous 1.22 , to selected 1.36
test(rad): fixed multi-job race condition
Tue Jun 30 18:51:30 2020 UTC (5 years, 1 month ago) by greg
Changes since 1.21: +6 -3 lines
Diff to previous 1.21 , to selected 1.36
test(obj2mesh): added missing unit test
Mon Jun 29 23:41:32 2020 UTC (5 years, 1 month ago) by greg
Changes since 1.20: +2 -2 lines
Diff to previous 1.20 , to selected 1.36
fix(rfluxmtx): Increased minimum for relative comparisons between matrices
Wed Feb 13 17:24:06 2019 UTC (6 years, 5 months ago) by greg
Diff to previous 1.19 , to selected 1.36
Minor fix
Fri Jan 25 23:49:41 2019 UTC (6 years, 6 months ago) by greg
Diff to previous 1.18 , to selected 1.36
Fixed bad target name
Tue Jan 8 00:21:52 2019 UTC (6 years, 6 months ago) by greg
Changes since 1.17: +14 -12 lines
Diff to previous 1.17 , to selected 1.36
Added targets and aliases for test-rpiece and test-mkpmap
Mon Jan 7 21:11:24 2019 UTC (6 years, 6 months ago) by greg
Changes since 1.16: +14 -3 lines
Diff to previous 1.16 , to selected 1.36
Added unit tests for oconv and rad
Sat Jan 5 00:34:21 2019 UTC (6 years, 6 months ago) by greg
Changes since 1.15: +8 -5 lines
Diff to previous 1.15 , to selected 1.36
Added NPROC setting for testing multi-processing on some targets
Fri Jan 4 22:45:37 2019 UTC (6 years, 6 months ago) by greg
Changes since 1.14: +29 -5 lines
Diff to previous 1.14 , to selected 1.36
Added special tests for rtrace and rfluxmtx/rcontrib
Fri Jan 4 18:52:06 2019 UTC (6 years, 6 months ago) by greg
Changes since 1.13: +2 -2 lines
Diff to previous 1.13 , to selected 1.36
Fixed typo in target
Tue Dec 25 18:21:30 2018 UTC (6 years, 7 months ago) by greg
Diff to previous 1.12 , to selected 1.36
Added removal of *.leaf files for OoC photon-mapping
Fri Dec 7 17:44:58 2018 UTC (6 years, 7 months ago) by greg
Diff to previous 1.11 , to selected 1.36
Switched to photon-mapping in mixtex scene to reduce artifacts
Sun Dec 2 18:57:05 2018 UTC (6 years, 7 months ago) by greg
Diff to previous 1.10 , to selected 1.36
Updated after correction and made xform max difference testing more sensitive
Sat Dec 1 05:40:35 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 1.9 , to selected 1.36
Fixes to reproducibility issues
Sat Dec 1 02:06:04 2018 UTC (6 years, 8 months ago) by greg
Changes since 1.8: +62 -4 lines
Diff to previous 1.8 , to selected 1.36
Finished additions for BSDF's, etc. to complete primitive testing
Wed Nov 21 22:59:04 2018 UTC (6 years, 8 months ago) by greg
Changes since 1.7: +21 -2 lines
Diff to previous 1.7 , to selected 1.36
Work in progress on test of mixtures, textures and BSDF data types
Wed Nov 21 20:42:58 2018 UTC (6 years, 8 months ago) by greg
Changes since 1.6: +21 -2 lines
Diff to previous 1.6 , to selected 1.36
Added test for patterns and aliases
Tue Nov 20 02:58:24 2018 UTC (6 years, 8 months ago) by greg
Changes since 1.5: +5 -5 lines
Diff to previous 1.5 , to selected 1.36
Changed build order a bit to help finish faster on multi-core (-j > 1)
Tue Nov 20 01:49:16 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 1.4 , to selected 1.36
Made non-standard auxiliary files local
Sun Nov 18 17:11:54 2018 UTC (6 years, 8 months ago) by greg
Diff to previous 1.3 , to selected 1.36
Made xform scene output comparison ignore comments
Sun Nov 18 16:37:32 2018 UTC (6 years, 8 months ago) by greg
Changes since 1.2: +223 -162 lines
Diff to previous 1.2 , to selected 1.36
Added xform test and avoided race condition for building octrees with -j > 1
Sat Nov 17 23:22:43 2018 UTC (6 years, 8 months ago) by greg
Changes since 1.1: +21 -21 lines
Diff to previous 1.1 , to selected 1.36
Minor changes and tweaks to make comparisons more reliable
Sat Nov 17 22:09:12 2018 UTC (6 years, 8 months ago) by greg
Diff to selected 1.36
Created rendering tests
