1 |
2 |
import os |
3 |
import sys |
4 |
import string |
5 |
6 |
import unittest |
7 |
8 |
def _find_raydir(): |
9 |
if __name__ == '__main__': |
10 |
thisfile = sys.argv[0] |
11 |
else: thisfile = sys.modules[__name__].__file__ |
12 |
unit_tools = os.path.abspath(os.path.dirname(thisfile)) |
13 |
py_tests = os.path.dirname(unit_tools) |
14 |
test = os.path.dirname(py_tests) |
15 |
raydir = os.path.dirname(test) |
16 |
return raydir |
17 |
18 |
RAYDIR = _find_raydir() |
19 |
DATADIR = os.path.join(RAYDIR, 'test', 'test data') |
20 |
BINDIR = os.path.join(RAYDIR, 'bin') |
21 |
22 |
def binfile(fn): |
23 |
'''return the full path to file in bin dir''' |
24 |
if os.name == 'nt': |
25 |
return os.path.normpath(os.path.join(BINDIR, fn + '.exe')) |
26 |
else: return os.path.normpath(os.path.join(BINDIR, fn)) |
27 |
28 |
def datafile(fn): |
29 |
'''return the full path to file in data dir''' |
30 |
return os.path.normpath(os.path.join(DATADIR, fn)) |
31 |
32 |
def run_case(c): |
33 |
res = unittest.TestResult() |
34 |
s = unittest.makeSuite(c, 'test') |
35 |
s.run(res) |
36 |
if res.errors or res.failures: |
37 |
print ' failed' |
38 |
print '-----------------------------' |
39 |
for e in res.errors: |
40 |
print e[1] |
41 |
for e in res.failures: |
42 |
es = string.strip(e[1]) |
43 |
sl = string.split(es, '\n') |
44 |
print sl[-1] |
45 |
46 |
else: |
47 |
print ' ok' |
48 |
