root/radiance/ray/test/py_tests/unit_tools/support.py
Revision: 1.2
Committed: Sun Jul 4 12:05:33 2004 UTC (19 years, 10 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad4R2P2, rad5R0, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Changes since 1.1: +10 -18 lines
minor fixes.
1
2 import os
3 import sys
4 import string
5
6 import unittest
7
8 def _find_raydir():
9 if __name__ == '__main__':
10 thisfile = sys.argv[0]
11 else: thisfile = sys.modules[__name__].__file__
12 unit_tools = os.path.abspath(os.path.dirname(thisfile))
13 py_tests = os.path.dirname(unit_tools)
14 test = os.path.dirname(py_tests)
15 raydir = os.path.dirname(test)
16 return raydir
17
18 RAYDIR = _find_raydir()
19 DATADIR = os.path.join(RAYDIR, 'test', 'test data')
20 BINDIR = os.path.join(RAYDIR, 'bin')
21
22 def binfile(fn):
23 '''return the full path to file in bin dir'''
24 if os.name == 'nt':
25 return os.path.normpath(os.path.join(BINDIR, fn + '.exe'))
26 else: return os.path.normpath(os.path.join(BINDIR, fn))
27
28 def datafile(fn):
29 '''return the full path to file in data dir'''
30 return os.path.normpath(os.path.join(DATADIR, fn))
31
32 def run_case(c):
33 res = unittest.TestResult()
34 s = unittest.makeSuite(c, 'test')
35 s.run(res)
36 if res.errors or res.failures:
37 print ' failed'
38 print '-----------------------------'
39 for e in res.errors:
40 print e[1]
41 for e in res.failures:
42 es = string.strip(e[1])
43 sl = string.split(es, '\n')
44 print sl[-1]
45 print '-----------------------------'
46 else:
47 print ' ok'
48
