1 |
schorsch |
1.1 |
''' Text comparison functions for Radiance unit testing. |
2 |
3 |
This allows differences in whitespace, which is why the text |
4 |
corpora are split into tokens first. |
5 |
Tokens are then converted into an appropriate data type, so |
6 |
that floating point items will still be considered correct |
7 |
even if they are slightly different, eg. as a consequence of |
8 |
binary rounding errors. |
9 |
10 |
11 |
import string |
12 |
import types |
13 |
14 |
class error(Exception): pass |
15 |
16 |
# internal functions |
17 |
def _icompare(itest, iref): |
18 |
'''compare ints (not public)''' |
19 |
if type(itest) == str: |
20 |
iftest = int(itest) |
21 |
else: iftest = itest |
22 |
if iftest == iref: return 1 |
23 |
return 0 |
24 |
25 |
def _fcompare(ftest, fref): |
26 |
'''compare floats (not public)''' |
27 |
FUZZ = 0.0000001 # XXX heuristically determined |
28 |
if type(ftest) == str: |
29 |
fftest = float(ftest) |
30 |
else: fftest = ftest |
31 |
if (fftest < (fref + FUZZ)) and (fftest > (fref - FUZZ)): |
32 |
return 1 |
33 |
return 0 |
34 |
35 |
def _typify_token(t): |
36 |
'''return the token as int resp. float if possible (not public)''' |
37 |
try: return int(t) |
38 |
except ValueError: pass |
39 |
try: return float(t) |
40 |
41 |
return t |
42 |
43 |
44 |
# public comparison functions |
45 |
46 |
def lcompare(ltest, lref): |
47 |
'''compare a list of tokens |
48 |
raise an error if there are intolerable differences |
49 |
the reference tokens in lref should already be of the correct type. |
50 |
51 |
if len(ltest) != len(lref): |
52 |
raise error, ('List comparision failed: Different number of tokens' |
53 |
' (%d, %d)' % (len(ltest), len(lref))) |
54 |
for i in range(len(lref)): |
55 |
tref = lref[i] |
56 |
ttest = ltest[i] |
57 |
if type(tref) == str and tref != ttest: |
58 |
raise error, 'Token comparison failed: "%s" != "%s"' % (ttest, tref) |
59 |
elif type(tref) == int and not _icompare(ttest, tref): |
60 |
raise error, 'Token comparison failed: %s != %s' % (ttest, tref) |
61 |
elif type(tref) == float and not _fcompare(ttest, tref): |
62 |
63 |
64 |
def llcompare(lltest, llref, ignore_empty=0, recurse=[]): |
65 |
'''compare a list of lists of tokens recursively |
66 |
67 |
68 |
if ignore_empty is true, empty lines are not included in the comparison |
69 |
the recurse argument is only used internally |
70 |
71 |
if ignore_empty: |
72 |
lltest = filter(None, lltest) |
73 |
llref = filter(None, llref) |
74 |
if len(lltest) != len(llref): |
75 |
raise error, 'Comparision failed: Different number of lines (%d,%d)' %( |
76 |
len(lltest), len(llref)) |
77 |
for i in range(len(llref)): |
78 |
if llref[i]: |
79 |
rtype = type(llref[i][0]) |
80 |
if rtype == list or rtype == tuple: |
81 |
return llcompare(lltest[i], llref[i], |
82 |
recurse=recurse.append(i), ignore_empty=ignore_empty) |
83 |
try: lcompare(lltest[i], llref[i]) |
84 |
except error, e: |
85 |
if recurse: |
86 |
raise error, '%s (line %s)' % (str(e), recurse.append(i + 1)) |
87 |
else: raise error, '%s (line %d)' % (str(e), i + 1) |
88 |
89 |
def split_headers(s): |
90 |
'''split Radiance file headers |
91 |
return a list of lists of tokens suitable for llcompare() |
92 |
this is useful to check the output of getinfo''' |
93 |
ll = map(string.strip,string.split(s, '\n')) |
94 |
nll = [] |
95 |
for l in ll: |
96 |
parts = string.split(l, '=', 1) |
97 |
if len(parts) == 2: |
98 |
left = map(_typify_token, string.split(parts[0])) |
99 |
right = map(_typify_token, string.split(parts[1])) |
100 |
nll.append(left + ['='] + right) |
101 |
else: nll.append(map(_typify_token, string.split(l))) |
102 |
return nll |
103 |
104 |
def split_rad(s): |
105 |
'''Split the contents of a scene description string |
106 |
return a list of list of tokens suitable for llcompare()''' |
107 |
108 |
nll = [] |
109 |
for l in ll: |
110 |
111 |
return nll |
112 |
113 |
def split_radfile(fn): |
114 |
'''Split the contents of a file object containing a scene description |
115 |
116 |
f = open(fn, 'r') |
117 |
ll = split_rad(f.read()) |
118 |
f.close() |
119 |
return ll |
120 |
