root/radiance/ray/test/py_tests/unit_tools/lcompare.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (20 years, 6 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad4R2P2, rad5R0, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
First attempt at testing framework.
1 ''' Text comparison functions for Radiance unit testing.
2
3 This allows differences in whitespace, which is why the text
4 corpora are split into tokens first.
5 Tokens are then converted into an appropriate data type, so
6 that floating point items will still be considered correct
7 even if they are slightly different, eg. as a consequence of
8 binary rounding errors.
9 '''
10
11 import string
12 import types
13
14 class error(Exception): pass
15
16 # internal functions
17 def _icompare(itest, iref):
18 '''compare ints (not public)'''
19 if type(itest) == str:
20 iftest = int(itest)
21 else: iftest = itest
22 if iftest == iref: return 1
23 return 0
24
25 def _fcompare(ftest, fref):
26 '''compare floats (not public)'''
27 FUZZ = 0.0000001 # XXX heuristically determined
28 if type(ftest) == str:
29 fftest = float(ftest)
30 else: fftest = ftest
31 if (fftest < (fref + FUZZ)) and (fftest > (fref - FUZZ)):
32 return 1
33 return 0
34
35 def _typify_token(t):
36 '''return the token as int resp. float if possible (not public)'''
37 try: return int(t)
38 except ValueError: pass
39 try: return float(t)
40 except ValueError: pass
41 return t
42
43
44 # public comparison functions
45
46 def lcompare(ltest, lref):
47 '''compare a list of tokens
48 raise an error if there are intolerable differences
49 the reference tokens in lref should already be of the correct type.
50 '''
51 if len(ltest) != len(lref):
52 raise error, ('List comparision failed: Different number of tokens'
53 ' (%d, %d)' % (len(ltest), len(lref)))
54 for i in range(len(lref)):
55 tref = lref[i]
56 ttest = ltest[i]
57 if type(tref) == str and tref != ttest:
58 raise error, 'Token comparison failed: "%s" != "%s"' % (ttest, tref)
59 elif type(tref) == int and not _icompare(ttest, tref):
60 raise error, 'Token comparison failed: %s != %s' % (ttest, tref)
61 elif type(tref) == float and not _fcompare(ttest, tref):
62 raise error, 'Token comparison failed: %s != %s' % (ttest, tref)
63
64 def llcompare(lltest, llref, ignore_empty=0, recurse=[]):
65 '''compare a list of lists of tokens recursively
66 raise an error if there are intolerable differences
67 the reference tokens in lref should already be of the correct type.
68 if ignore_empty is true, empty lines are not included in the comparison
69 the recurse argument is only used internally
70 '''
71 if ignore_empty:
72 lltest = filter(None, lltest)
73 llref = filter(None, llref)
74 if len(lltest) != len(llref):
75 raise error, 'Comparision failed: Different number of lines (%d,%d)' %(
76 len(lltest), len(llref))
77 for i in range(len(llref)):
78 if llref[i]:
79 rtype = type(llref[i][0])
80 if rtype == list or rtype == tuple:
81 return llcompare(lltest[i], llref[i],
82 recurse=recurse.append(i), ignore_empty=ignore_empty)
83 try: lcompare(lltest[i], llref[i])
84 except error, e:
85 if recurse:
86 raise error, '%s (line %s)' % (str(e), recurse.append(i + 1))
87 else: raise error, '%s (line %d)' % (str(e), i + 1)
88
89 def split_headers(s):
90 '''split Radiance file headers
91 return a list of lists of tokens suitable for llcompare()
92 this is useful to check the output of getinfo'''
93 ll = map(string.strip,string.split(s, '\n'))
94 nll = []
95 for l in ll:
96 parts = string.split(l, '=', 1)
97 if len(parts) == 2:
98 left = map(_typify_token, string.split(parts[0]))
99 right = map(_typify_token, string.split(parts[1]))
100 nll.append(left + ['='] + right)
101 else: nll.append(map(_typify_token, string.split(l)))
102 return nll
103
104 def split_rad(s):
105 '''Split the contents of a scene description string
106 return a list of list of tokens suitable for llcompare()'''
107 ll = map(string.strip,string.split(s, '\n'))
108 nll = []
109 for l in ll:
110 nll.append(map(_typify_token, string.split(l)))
111 return nll
112
113 def split_radfile(fn):
114 '''Split the contents of a file object containing a scene description
115 return a list of list of tokens suitable for llcompare()'''
116 f = open(fn, 'r')
117 ll = split_rad(f.read())
118 f.close()
119 return ll
120
