| 1 |
''' Text comparison functions for Radiance unit testing.
| 2 |
| 3 |
This allows differences in whitespace, which is why the text
| 4 |
corpora are split into tokens first.
| 5 |
Tokens are then converted into an appropriate data type, so
| 6 |
that floating point items will still be considered correct
| 7 |
even if they are slightly different, eg. as a consequence of
| 8 |
binary rounding errors.
| 9 |
| 10 |
| 11 |
| 12 |
class error(Exception): pass
| 13 |
| 14 |
# internal functions
| 15 |
def _icompare(itest, iref):
| 16 |
'''compare ints (not public)'''
| 17 |
if type(itest) == str:
| 18 |
iftest = int(itest)
| 19 |
else: iftest = itest
| 20 |
if iftest == iref: return 1
| 21 |
return 0
| 22 |
| 23 |
def _fcompare(ftest, fref):
| 24 |
'''compare floats (not public)'''
| 25 |
FUZZ = 0.0000001 # XXX heuristically determined
| 26 |
if type(ftest) == str:
| 27 |
fftest = float(ftest)
| 28 |
else: fftest = ftest
| 29 |
if (fftest < (fref + FUZZ)) and (fftest > (fref - FUZZ)):
| 30 |
return 1
| 31 |
return 0
| 32 |
| 33 |
def _typify_token(t):
| 34 |
'''return the token as int resp. float if possible (not public)'''
| 35 |
try: return int(t)
| 36 |
except ValueError: pass
| 37 |
try: return float(t)
| 38 |
| 39 |
return t
| 40 |
| 41 |
| 42 |
# public comparison functions
| 43 |
| 44 |
def lcompare(ltest, lref):
| 45 |
'''compare a list of tokens
| 46 |
raise an error if there are intolerable differences
| 47 |
the reference tokens in lref should already be of the correct type.
| 48 |
| 49 |
if len(ltest) != len(lref):
| 50 |
raise error, ('List comparision failed: Different number of tokens'
| 51 |
' (%d, %d)' % (len(ltest), len(lref)))
| 52 |
for i in range(len(lref)):
| 53 |
tref = lref[i]
| 54 |
ttest = ltest[i]
| 55 |
if type(tref) == str and tref != ttest:
| 56 |
raise error, 'Token comparison failed: "%s" != "%s"' % (ttest, tref)
| 57 |
elif type(tref) == int and not _icompare(ttest, tref):
| 58 |
raise error, 'Token comparison failed: %s != %s' % (ttest, tref)
| 59 |
elif type(tref) == float and not _fcompare(ttest, tref):
| 60 |
| 61 |
| 62 |
def llcompare(lltest, llref, ignore_empty=0, recurse=[]):
| 63 |
'''compare a list of lists of tokens recursively
| 64 |
| 65 |
| 66 |
if ignore_empty is true, empty lines are not included in the comparison
| 67 |
the recurse argument is only used internally
| 68 |
| 69 |
if ignore_empty:
| 70 |
lltest = filter(None, lltest)
| 71 |
llref = filter(None, llref)
| 72 |
if len(lltest) != len(llref):
| 73 |
raise error, 'Comparision failed: Different number of lines (%d, %d)' %(
| 74 |
len(lltest), len(llref))
| 75 |
for i in range(len(llref)):
| 76 |
if llref[i]:
| 77 |
rtype = type(llref[i][0])
| 78 |
if rtype == list or rtype == tuple:
| 79 |
return llcompare(lltest[i], llref[i],
| 80 |
recurse=recurse.append(i), ignore_empty=ignore_empty)
| 81 |
try: lcompare(lltest[i], llref[i])
| 82 |
except error, e:
| 83 |
if recurse:
| 84 |
raise error, '%s (line %s)' % (str(e), recurse.append(i + 1))
| 85 |
else: raise error, '%s (line %d)' % (str(e), i + 1)
| 86 |
| 87 |
def split_headers(s):
| 88 |
'''split Radiance file headers
| 89 |
return a list of lists of tokens suitable for llcompare()
| 90 |
this is useful to check the output of getinfo'''
| 91 |
ll = [ss.strip() for ss in s.split('\n')]
| 92 |
nll = []
| 93 |
for l in ll:
| 94 |
parts = l.split('=', 1)
| 95 |
if len(parts) == 2:
| 96 |
left = map(_typify_token, parts[0].split())
| 97 |
right = map(_typify_token, parts[1].split())
| 98 |
nll.append(left + ['='] + right)
| 99 |
else: nll.append(map(_typify_token, l.split()))
| 100 |
return nll
| 101 |
| 102 |
def split_rad(s):
| 103 |
'''Split the contents of a scene description string
| 104 |
return a list of list of tokens suitable for llcompare()'''
| 105 |
| 106 |
nll = []
| 107 |
for l in ll:
| 108 |
| 109 |
return nll
| 110 |
| 111 |
def split_radfile(fn):
| 112 |
'''Split the contents of a file object containing a scene description
| 113 |
| 114 |
f = open(fn, 'r')
| 115 |
ll = split_rad(f.read())
| 116 |
f.close()
| 117 |
return ll
| 118 |
