root/radiance/ray/test/py_tests/test_ttyimage.py
Revision: 1.4
Committed: Mon Mar 28 17:48:43 2016 UTC (9 years, 3 months ago) by schorsch
Content type: text/x-python
State: FILE REMOVED
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
1
2
3 import os
4 import math
5 import string
6 import unittest
7
8 from unit_tools import support
9 from unit_tools import lcompare
10
11 _bindir = None
12
13 class TtyimageTestCase(unittest.TestCase):
14 def setUp(self):
15 if _bindir:
16 self.oldpath = os.environ['PATH']
17 os.environ['PATH'] = _bindir
18
19 def tearDown(self):
20 if _bindir:
21 os.environ['PATH'] = self.oldpath
22
23 def test_ttyimage(self):
24 '''We just do a few spot checks here'''
25 picfile = support.datafile('Earth128.pic')
26 cmd = 'ttyimage "%s"' % picfile
27 res0 = os.popen(cmd).read()
28 result = map(string.split,string.split(res0, '\n'))
29 expect = [[0,
30 ['################################################################'
31 '################################################################']],
32 [7,
33 ['#########################@%,,.?++&%%###$&###############@&:.....'
34 '.......,,.......,,.,,;..+?,...,.:*+.:&#########@################']],
35 [23,
36 ['.......;,:.....,++*+?++++;+;:,::,..,,;+;;+...................,;,'
37 '..,:;+::+;;:;;:;;;;;:;+;;;;;;;;;:;+;;;;;%%$@%$&%#?.....,#%......']],
38 [54,
39 ['................................,,,.......................*%?$@#'
40 '###########@$%%%;.........:?:.....,?+;:....;,...................']],
41 [99,
42 ['.....................................+++........................'
43 '................................................................']],
44 ]
45
46 for l in expect:
47 self.assertEqual(result[l[0]], l[1],
48 '%s : %s != %s [line %s]' % (cmd,result[l[0]],l[1], l[0]))
49
50 def main(bindir=None):
51 global _bindir
52 _bindir=bindir
53 support.run_case(TtyimageTestCase)
54
55 if __name__ == '__main__':
56 main()
57
58 # vi: set ts=4 sw=4 :
