1 |
2 |
import os |
3 |
import math |
4 |
import string |
5 |
import unittest |
6 |
7 |
from unit_tools import support |
8 |
from unit_tools import lcompare |
9 |
10 |
class LamTestCase(unittest.TestCase): |
11 |
def setUp(self): |
12 |
self.oldpath = os.environ['PATH'] |
13 |
os.environ['PATH'] = os.path.abspath(support.BINDIR) |
14 |
15 |
def tearDown(self): |
16 |
os.environ['PATH'] = self.oldpath |
17 |
18 |
def test_lam(self): |
19 |
dat_de = support.datafile('lam_de.dat') |
20 |
dat_en = support.datafile('lam_en.dat') |
21 |
cmd = 'rlam -t: "%s" "%s"' % (dat_de, dat_en) |
22 |
raw = os.popen(cmd).read() |
23 |
result = map(string.split,string.split(raw,'\n')) |
24 |
expect = [ |
25 |
['eins:one'], |
26 |
['zwei:two'], |
27 |
['drei:three'], |
28 |
['vier:four'], |
29 |
['fuenf:five'], |
30 |
31 |
try: lcompare.llcompare(result, expect, ignore_empty=1) |
32 |
except lcompare.error, e: |
33 |
self.fail('%s [%s]' % (str(e),cmd)) |
34 |
35 |
def main(): |
36 |
support.run_case(LamTestCase) |
37 |
38 |
if __name__ == '__main__': |
39 |
main() |
40 |
41 |
# vi: set ts=4 sw=4 : |
