root/radiance/ray/test/py_tests/test_lam.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (21 years, 7 months ago) by schorsch
Content type: text/x-python
First attempt at testing framework.
1
2 import os
3 import math
4 import string
5 import unittest
6
7 from unit_tools import support
8 from unit_tools import lcompare
9
10 class LamTestCase(unittest.TestCase):
11 def setUp(self):
12 self.oldpath = os.environ['PATH']
13 os.environ['PATH'] = os.path.abspath(support.BINDIR)
14
15 def tearDown(self):
16 os.environ['PATH'] = self.oldpath
17
18 def test_lam(self):
19 dat_de = support.datafile('lam_de.dat')
20 dat_en = support.datafile('lam_en.dat')
21 cmd = 'lam -t: "%s" "%s"' % (dat_de, dat_en)
22 raw = os.popen(cmd).read()
23 result = map(string.split,string.split(raw,'\n'))
24 expect = [
25 ['eins:one'],
26 ['zwei:two'],
27 ['drei:three'],
28 ['vier:four'],
29 ['fuenf:five'],
30 ]
31 try: lcompare.llcompare(result, expect, ignore_empty=1)
32 except lcompare.error, e:
33 self.fail('%s [%s]' % (str(e),cmd))
34
35 def main():
36 support.run_case(LamTestCase)
37
38 if __name__ == '__main__':
39 main()
40
41 # vi: set ts=4 sw=4 :
