root/radiance/ray/test/py_tests/test_histo.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (20 years, 6 months ago) by schorsch
Content type: text/x-python
First attempt at testing framework.
1
2 import os
3 import math
4 import string
5 import unittest
6
7 from unit_tools import support
8 from unit_tools import lcompare
9
10 class HistoTestCase(unittest.TestCase):
11 def setUp(self):
12 self.oldpath = os.environ['PATH']
13 os.environ['PATH'] = os.path.abspath(support.BINDIR)
14
15 def tearDown(self):
16 os.environ['PATH'] = self.oldpath
17
18 def test_histo(self):
19 cmd = 'histo 1 6 5 < "%s"' % support.datafile('histo.dat')
20 raw = os.popen(cmd).read()
21 result = map(string.split,string.split(raw,'\n'))
22 expect = [
23 [1.5, 720, 240, 432, 1080, 270],
24 [2.5, 720, 240, 432, 0, 270],
25 [3.5, 0, 240, 432, 0, 270],
26 [4.5, 0, 240, 432, 0, 270],
27 [5.5, 0, 240, 0, 0, 270],
28 ]
29 try: lcompare.llcompare(result, expect, ignore_empty=1)
30 except lcompare.error, e:
31 self.fail('%s [%s]' % (str(e),cmd))
32
33 def main():
34 support.run_case(HistoTestCase)
35
36 if __name__ == '__main__':
37 main()
38
39 # vi: set ts=4 sw=4 :
