root/radiance/ray/test/py_tests/test_histo.py
Revision: 1.4
Committed: Mon Mar 28 17:48:43 2016 UTC (8 years, 2 months ago) by schorsch
Content type: text/x-python
State: FILE REMOVED
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
1
2 import os
3 import string
4 import unittest
5
6 from unit_tools import support
7 from unit_tools import lcompare
8
9 _bindir = None
10
11 class HistoTestCase(unittest.TestCase):
12 def setUp(self):
13 if _bindir:
14 self.oldpath = os.environ['PATH']
15 os.environ['PATH'] = _bindir
16
17 def tearDown(self):
18 if _bindir:
19 os.environ['PATH'] = self.oldpath
20
21 def test_histo(self):
22 cmd = 'histo -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
23 raw = os.popen(cmd).read()
24 result = map(string.split,string.split(raw,'\n'))
25 expect = [
26 [0, 720, 240, 432, 1080, 270],
27 [1, 720, 240, 432, 1080, 270],
28 [2, 720, 240, 432, 0, 270],
29 [3, 0, 240, 432, 0, 270],
30 [4, 0, 240, 432, 0, 270],
31 [5, 0, 240, 0, 0, 270],
32 [6, 0, 240, 0, 0, 270],
33 [7, 0, 240, 0, 0, 270],
34 [8, 0, 240, 0, 0, 0],
35 ]
36 try: lcompare.llcompare(result, expect, ignore_empty=1)
37 except lcompare.error, e:
38 self.fail('%s [%s]' % (str(e),cmd))
39
40 def test_histo_c(self):
41 cmd = 'histo -c -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
42 raw = os.popen(cmd).read()
43 result = map(string.split,string.split(raw,'\n'))
44 expect = [
45 [-0.5, 0, 0, 0, 0, 0],
46 [0.5, 720, 240, 432, 1080, 270],
47 [1.5, 1440, 480, 864, 2160, 540],
48 [2.5, 2160, 720, 1296, 2160, 810],
49 [3.5, 2160, 960, 1728, 2160, 1080],
50 [4.5, 2160, 1200, 2160, 2160, 1350],
51 [5.5, 2160, 1440, 2160, 2160, 1620],
52 [6.5, 2160, 1680, 2160, 2160, 1890],
53 [7.5, 2160, 1920, 2160, 2160, 2160],
54 [8.5, 2160, 2160, 2160, 2160, 2160],
55 ]
56 try: lcompare.llcompare(result, expect, ignore_empty=1)
57 except lcompare.error, e:
58 self.fail('%s [%s]' % (str(e),cmd))
59
60 def test_histo_p(self):
61 cmd = 'histo -p -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
62 raw = os.popen(cmd).read()
63 result = map(string.split,string.split(raw,'\n'))
64 expect = [
65 [0, 33.333333, 11.111111, 20.0, 50.0, 12.5],
66 [1, 33.333333, 11.111111, 20.0, 50.0, 12.5],
67 [2, 33.333333, 11.111111, 20.0, 0.0, 12.5],
68 [3, 0.0, 11.111111, 20.0, 0.0, 12.5],
69 [4, 0.0, 11.111111, 20.0, 0.0, 12.5],
70 [5, 0.0, 11.111111, 0.0, 0.0, 12.5],
71 [6, 0.0, 11.111111, 0.0, 0.0, 12.5],
72 [7, 0.0, 11.111111, 0.0, 0.0, 12.5],
73 [8, 0.0, 11.111111, 0.0, 0.0, 0.0],
74 ]
75 try: lcompare.llcompare(result, expect, ignore_empty=1)
76 except lcompare.error, e:
77 self.fail('%s [%s]' % (str(e),cmd))
78
79 def test_histo_pc(self):
80 cmd = 'histo -p -c -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
81 raw = os.popen(cmd).read()
82 result = map(string.split,string.split(raw,'\n'))
83 expect = [
84 [-0.5, 0.0, 0.0, 0.0, 0.0, 0.0],
85 [0.5, 33.333333, 11.111111, 20.0, 50.0, 12.5],
86 [1.5, 66.666667, 22.222222, 40.0, 100.0, 25.0],
87 [2.5, 100.0, 33.333333, 60.0, 100.0, 37.5],
88 [3.5, 100.0, 44.444444, 80.0, 100.0, 50.0],
89 [4.5, 100.0, 55.555556, 100.0, 100.0, 62.5],
90 [5.5, 100.0, 66.666667, 100.0, 100.0, 75.0],
91 [6.5, 100.0, 77.777778, 100.0, 100.0, 87.5],
92 [7.5, 100.0, 88.888889, 100.0, 100.0, 100.0],
93 [8.5, 100.0, 100.0, 100.0, 100.0, 100.0],
94 ]
95 try: lcompare.llcompare(result, expect, ignore_empty=1)
96 except lcompare.error, e:
97 self.fail('%s [%s]' % (str(e),cmd))
98
99 def main(bindir=None):
100 global _bindir
101 _bindir=bindir
102 support.run_case(HistoTestCase)
103
104 if __name__ == '__main__':
105 main()
106
107 # vi: set ts=4 sw=4 :
