| 1 |
schorsch |
1.1 |
| 2 |
import os
| 3 |
import string
| 4 |
import unittest
| 5 |
| 6 |
from unit_tools import support
| 7 |
from unit_tools import lcompare
| 8 |
| 9 |
schorsch |
1.3 |
_bindir = None
| 10 |
| 11 |
schorsch |
1.1 |
class HistoTestCase(unittest.TestCase):
| 12 |
def setUp(self):
| 13 |
schorsch |
1.3 |
if _bindir:
| 14 |
self.oldpath = os.environ['PATH']
| 15 |
os.environ['PATH'] = _bindir
| 16 |
schorsch |
1.1 |
| 17 |
def tearDown(self):
| 18 |
schorsch |
1.3 |
if _bindir:
| 19 |
os.environ['PATH'] = self.oldpath
| 20 |
schorsch |
1.1 |
| 21 |
def test_histo(self):
| 22 |
schorsch |
1.2 |
cmd = 'histo -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
| 23 |
schorsch |
1.1 |
raw = os.popen(cmd).read()
| 24 |
result = map(string.split,string.split(raw,'\n'))
| 25 |
expect = [
| 26 |
schorsch |
1.2 |
[0, 720, 240, 432, 1080, 270],
| 27 |
[1, 720, 240, 432, 1080, 270],
| 28 |
[2, 720, 240, 432, 0, 270],
| 29 |
[3, 0, 240, 432, 0, 270],
| 30 |
[4, 0, 240, 432, 0, 270],
| 31 |
[5, 0, 240, 0, 0, 270],
| 32 |
[6, 0, 240, 0, 0, 270],
| 33 |
[7, 0, 240, 0, 0, 270],
| 34 |
[8, 0, 240, 0, 0, 0],
| 35 |
| 36 |
try: lcompare.llcompare(result, expect, ignore_empty=1)
| 37 |
except lcompare.error, e:
| 38 |
self.fail('%s [%s]' % (str(e),cmd))
| 39 |
| 40 |
def test_histo_c(self):
| 41 |
cmd = 'histo -c -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
| 42 |
| 43 |
| 44 |
expect = [
| 45 |
[-0.5, 0, 0, 0, 0, 0],
| 46 |
[0.5, 720, 240, 432, 1080, 270],
| 47 |
[1.5, 1440, 480, 864, 2160, 540],
| 48 |
[2.5, 2160, 720, 1296, 2160, 810],
| 49 |
[3.5, 2160, 960, 1728, 2160, 1080],
| 50 |
[4.5, 2160, 1200, 2160, 2160, 1350],
| 51 |
[5.5, 2160, 1440, 2160, 2160, 1620],
| 52 |
[6.5, 2160, 1680, 2160, 2160, 1890],
| 53 |
[7.5, 2160, 1920, 2160, 2160, 2160],
| 54 |
[8.5, 2160, 2160, 2160, 2160, 2160],
| 55 |
| 56 |
| 57 |
| 58 |
| 59 |
| 60 |
def test_histo_p(self):
| 61 |
cmd = 'histo -p -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
| 62 |
| 63 |
| 64 |
expect = [
| 65 |
[0, 33.333333, 11.111111, 20.0, 50.0, 12.5],
| 66 |
[1, 33.333333, 11.111111, 20.0, 50.0, 12.5],
| 67 |
[2, 33.333333, 11.111111, 20.0, 0.0, 12.5],
| 68 |
[3, 0.0, 11.111111, 20.0, 0.0, 12.5],
| 69 |
[4, 0.0, 11.111111, 20.0, 0.0, 12.5],
| 70 |
[5, 0.0, 11.111111, 0.0, 0.0, 12.5],
| 71 |
[6, 0.0, 11.111111, 0.0, 0.0, 12.5],
| 72 |
[7, 0.0, 11.111111, 0.0, 0.0, 12.5],
| 73 |
[8, 0.0, 11.111111, 0.0, 0.0, 0.0],
| 74 |
| 75 |
| 76 |
| 77 |
| 78 |
| 79 |
def test_histo_pc(self):
| 80 |
cmd = 'histo -p -c -0.5 8.5 9 < "%s"' % support.datafile('histo.dat')
| 81 |
| 82 |
| 83 |
expect = [
| 84 |
[-0.5, 0.0, 0.0, 0.0, 0.0, 0.0],
| 85 |
[0.5, 33.333333, 11.111111, 20.0, 50.0, 12.5],
| 86 |
[1.5, 66.666667, 22.222222, 40.0, 100.0, 25.0],
| 87 |
[2.5, 100.0, 33.333333, 60.0, 100.0, 37.5],
| 88 |
[3.5, 100.0, 44.444444, 80.0, 100.0, 50.0],
| 89 |
[4.5, 100.0, 55.555556, 100.0, 100.0, 62.5],
| 90 |
[5.5, 100.0, 66.666667, 100.0, 100.0, 75.0],
| 91 |
[6.5, 100.0, 77.777778, 100.0, 100.0, 87.5],
| 92 |
[7.5, 100.0, 88.888889, 100.0, 100.0, 100.0],
| 93 |
[8.5, 100.0, 100.0, 100.0, 100.0, 100.0],
| 94 |
schorsch |
1.1 |
| 95 |
| 96 |
| 97 |
| 98 |
| 99 |
schorsch |
1.3 |
def main(bindir=None):
| 100 |
global _bindir
| 101 |
_bindir=bindir
| 102 |
schorsch |
1.1 |
support.run_case(HistoTestCase)
| 103 |
| 104 |
if __name__ == '__main__':
| 105 |
main()
| 106 |
| 107 |
# vi: set ts=4 sw=4 :
