1 |
schorsch |
1.1 |
2 |
3 |
import os |
4 |
import math |
5 |
import string |
6 |
import unittest |
7 |
8 |
from unit_tools import support |
9 |
from unit_tools import lcompare |
10 |
11 |
class GetinfoTestCase(unittest.TestCase): |
12 |
def setUp(self): |
13 |
self.oldpath = os.environ['PATH'] |
14 |
os.environ['PATH'] = os.path.abspath(support.BINDIR) |
15 |
16 |
def tearDown(self): |
17 |
os.environ['PATH'] = self.oldpath |
18 |
19 |
20 |
def test_getinfo(self): |
21 |
picfile = support.datafile('Earth128.pic') |
22 |
cmd = 'getinfo "%s"' % picfile |
23 |
res0 = os.popen(cmd).read() |
24 |
result = lcompare.split_headers(res0) |
25 |
exps = '''%s: |
26 |
Xim format conversion by: |
27 |
FORMAT=32-bit_rle_rgbe |
28 |
pfilt -e 2 -x 512 -y 512 -p 1 -r .67 |
29 |
EXPOSURE=4.926198e+00 |
30 |
normpat |
31 |
pfilt -1 -e .2 |
32 |
EXPOSURE=2.000000e-01 |
33 |
pfilt -x 128 -y 128 |
34 |
PIXASPECT=0.500000 |
35 |
EXPOSURE=2.571646e+00''' % picfile |
36 |
expect = lcompare.split_headers(exps) |
37 |
try: lcompare.llcompare(result, expect, ignore_empty=1) |
38 |
except lcompare.error, e: |
39 |
self.fail('%s [%s]' % (str(e),cmd)) |
40 |
41 |
def test_getinfo_d(self): |
42 |
43 |
cmd = 'getinfo -d "%s"' % picfile |
44 |
45 |
result = map(string.split,string.split(res0, '\n')) |
46 |
exps = '''%s: -Y 128 +X 128''' % picfile |
47 |
expect = map(string.split, string.split(exps, '\n')) |
48 |
49 |
50 |
51 |
52 |
def main(): |
53 |
support.run_case(GetinfoTestCase) |
54 |
55 |
if __name__ == '__main__': |
56 |
main() |
57 |
58 |
# vi: set ts=4 sw=4 : |
