root/radiance/ray/test/py_tests/test_getinfo.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (21 years, 5 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad3R7P2, rad4R2P2, rad4R2P1, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad5R0
First attempt at testing framework.
1
2
3 import os
4 import math
5 import string
6 import unittest
7
8 from unit_tools import support
9 from unit_tools import lcompare
10
11 class GetinfoTestCase(unittest.TestCase):
12 def setUp(self):
13 self.oldpath = os.environ['PATH']
14 os.environ['PATH'] = os.path.abspath(support.BINDIR)
15
16 def tearDown(self):
17 os.environ['PATH'] = self.oldpath
18
19
20 def test_getinfo(self):
21 picfile = support.datafile('Earth128.pic')
22 cmd = 'getinfo "%s"' % picfile
23 res0 = os.popen(cmd).read()
24 result = lcompare.split_headers(res0)
25 exps = '''%s:
26 Xim format conversion by:
27 FORMAT=32-bit_rle_rgbe
28 pfilt -e 2 -x 512 -y 512 -p 1 -r .67
29 EXPOSURE=4.926198e+00
30 normpat
31 pfilt -1 -e .2
32 EXPOSURE=2.000000e-01
33 pfilt -x 128 -y 128
34 PIXASPECT=0.500000
35 EXPOSURE=2.571646e+00''' % picfile
36 expect = lcompare.split_headers(exps)
37 try: lcompare.llcompare(result, expect, ignore_empty=1)
38 except lcompare.error, e:
39 self.fail('%s [%s]' % (str(e),cmd))
40
41 def test_getinfo_d(self):
42 picfile = support.datafile('Earth128.pic')
43 cmd = 'getinfo -d "%s"' % picfile
44 res0 = os.popen(cmd).read()
45 result = map(string.split,string.split(res0, '\n'))
46 exps = '''%s: -Y 128 +X 128''' % picfile
47 expect = map(string.split, string.split(exps, '\n'))
48 try: lcompare.llcompare(result, expect, ignore_empty=1)
49 except lcompare.error, e:
50 self.fail('%s [%s]' % (str(e),cmd))
51
52 def main():
53 support.run_case(GetinfoTestCase)
54
55 if __name__ == '__main__':
56 main()
57
58 # vi: set ts=4 sw=4 :
