root/radiance/ray/test/py_tests/test_genbeads.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (20 years, 4 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad3R7P2, rad4R2P2, rad4R2P1, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad5R0
First attempt at testing framework.
1
2 import os
3 import math
4 import string
5 import unittest
6
7 from unit_tools import support
8 from unit_tools import lcompare
9
10 class GenbeadsTestCase(unittest.TestCase):
11 def setUp(self):
12 self.oldpath = os.environ['PATH']
13 os.environ['PATH'] = os.path.abspath(support.BINDIR)
14
15 def tearDown(self):
16 os.environ['PATH'] = self.oldpath
17
18 def test_genbeads(self):
19 cmd = 'genbeads mymat myname 0 0 0 1 1 1 2 0 0 0 2 0 .1 .4'
20 raw = os.popen(cmd).read()
21 result = map(string.split,string.split(raw,'\n'))
22 expect = [['mymat', 'sphere', 'myname.0'], [0], [0],
23 [4, 0, 0, 0, 0.1],
24 ['mymat', 'sphere', 'myname.1'], [0], [0],
25 [4, 0.36, 0.04, 0.104, 0.1],
26 ['mymat', 'sphere', 'myname.2'], [0], [0],
27 [4, 0.651440715413, 0.167781092737, 0.365893348046, 0.1],
28 ['mymat', 'sphere', 'myname.3'], [0], [0],
29 [4, 0.844350245496, 0.366600314978, 0.655866088042, 0.1],
30 ['mymat', 'sphere', 'myname.4'], [0], [0],
31 [4, 0.960791445178, 0.643185551339, 0.897901825177, 0.1],
32 ]
33 try: lcompare.llcompare(result, expect, ignore_empty=1)
34 except lcompare.error, e:
35 self.fail('%s [%s]' % (str(e),cmd))
36
37
38 def main():
39 support.run_case(GenbeadsTestCase)
40
41 if __name__ == '__main__':
42 main()
43
44 # vi: set ts=4 sw=4 :
