root/Development/ray/test/py_tests/test_ev.py
Revision: 1.3
Committed: Mon Mar 28 17:48:43 2016 UTC (9 years, 9 months ago) by schorsch
Content type: text/x-python
State: FILE REMOVED
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
1
2 import os
3 import math
4 import string
5 import unittest
6
7 from unit_tools import support
8 from unit_tools import lcompare
9
10 _bindir = None
11
12 class EvTestCase(unittest.TestCase):
13 def setUp(self):
14 if _bindir:
15 self.oldpath = os.environ['PATH']
16 os.environ['PATH'] = _bindir
17
18 def tearDown(self):
19 if _bindir:
20 os.environ['PATH'] = self.oldpath
21
22 ltest = [
23 ['2.3 + 5 * 21.7 / 1.43', [2.3 + 5 * 21.7 / 1.43]],
24 ['if(1, 1, 0)', [1]],
25 ['if(0, 1, 0)', [0]],
26 ['select(3, 1, 2, 3, 4, 5)', [3]],
27 ['floor(5.743)', [5]],
28 ['ceil(5.743)', [6]],
29 ['sqrt(7.4)', [math.sqrt(7.4)]],
30 ['exp(3.4)', [math.exp(3.4)]],
31 ['log(2.4)', [math.log(2.4)]],
32 ['log10(5.4)', [math.log10(5.4)]],
33 ['sin(.51)', [math.sin(.51)]],
34 ['cos(.41)', [math.cos(.41)]],
35 ['tan(0.77)', [math.tan(0.77)]],
36 ['asin(0.83)', [math.asin(0.83)]],
37 ['acos(.94)', [math.acos(.94)]],
38 ['atan(0.22)', [math.atan(0.22)]],
39 ['atan2(0.72, 0.54)', [math.atan2(0.72, 0.54)]],
40 ]
41
42 def test_singleres(self):
43 for expr, expect in self.ltest:
44 cmd = 'ev "%s"' % expr
45 result = [string.strip(os.popen(cmd).read())]
46 try: lcompare.lcompare(result, expect)
47 except lcompare.error, e:
48 self.fail('%s [%s]' % (str(e),cmd))
49
50 def test_multipleres(self):
51 pass # XXX implement
52
53 def main(bindir=None):
54 global _bindir
55 _bindir=bindir
56 support.run_case(EvTestCase)
57
58 if __name__ == '__main__':
59 main()
60
61 # vi: set ts=4 sw=4 :
