root/radiance/ray/test/py_tests/test_ev.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (20 years, 5 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad3R7P2, rad4R2P2, rad4R2P1, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad5R0
First attempt at testing framework.
# User Rev Content
1 schorsch 1.1
2     import os
3     import math
4     import string
5     import unittest
6
7     from unit_tools import support
8     from unit_tools import lcompare
9
10     class EvTestCase(unittest.TestCase):
11     def setUp(self):
12     self.oldpath = os.environ['PATH']
13     os.environ['PATH'] = os.path.abspath(support.BINDIR)
14
15     def tearDown(self):
16     os.environ['PATH'] = self.oldpath
17
18     ltest = [
19     ['2.3 + 5 * 21.7 / 1.43', [2.3 + 5 * 21.7 / 1.43]],
20     ['if(1, 1, 0)', [1]],
21     ['if(0, 1, 0)', [0]],
22     ['select(3, 1, 2, 3, 4, 5)', [3]],
23     ['floor(5.743)', [5]],
24     ['ceil(5.743)', [6]],
25     ['sqrt(7.4)', [math.sqrt(7.4)]],
26     ['exp(3.4)', [math.exp(3.4)]],
27     ['log(2.4)', [math.log(2.4)]],
28     ['log10(5.4)', [math.log10(5.4)]],
29     ['sin(.51)', [math.sin(.51)]],
30     ['cos(.41)', [math.cos(.41)]],
31     ['tan(0.77)', [math.tan(0.77)]],
32     ['asin(0.83)', [math.asin(0.83)]],
33     ['acos(.94)', [math.acos(.94)]],
34     ['atan(0.22)', [math.atan(0.22)]],
35     ['atan2(0.72, 0.54)', [math.atan2(0.72, 0.54)]],
36     ]
37
38     def test_singleres(self):
39     for expr, expect in self.ltest:
40     cmd = 'ev "%s"' % expr
41     result = [string.strip(os.popen(cmd).read())]
42     try: lcompare.lcompare(result, expect)
43     except lcompare.error, e:
44     self.fail('%s [%s]' % (str(e),cmd))
45
46     def test_multipleres(self):
47     pass # XXX implement
48
49     def main():
50     support.run_case(EvTestCase)
51
52     if __name__ == '__main__':
53     main()
54
55     # vi: set ts=4 sw=4 :
