| 1 |
| 2 |
import os
| 3 |
import math
| 4 |
import string
| 5 |
import unittest
| 6 |
| 7 |
from unit_tools import support
| 8 |
from unit_tools import lcompare
| 9 |
| 10 |
_bindir = None
| 11 |
| 12 |
class EvTestCase(unittest.TestCase):
| 13 |
def setUp(self):
| 14 |
if _bindir:
| 15 |
self.oldpath = os.environ['PATH']
| 16 |
os.environ['PATH'] = _bindir
| 17 |
| 18 |
def tearDown(self):
| 19 |
if _bindir:
| 20 |
os.environ['PATH'] = self.oldpath
| 21 |
| 22 |
ltest = [
| 23 |
['2.3 + 5 * 21.7 / 1.43', [2.3 + 5 * 21.7 / 1.43]],
| 24 |
['if(1, 1, 0)', [1]],
| 25 |
['if(0, 1, 0)', [0]],
| 26 |
['select(3, 1, 2, 3, 4, 5)', [3]],
| 27 |
['floor(5.743)', [5]],
| 28 |
['ceil(5.743)', [6]],
| 29 |
['sqrt(7.4)', [math.sqrt(7.4)]],
| 30 |
['exp(3.4)', [math.exp(3.4)]],
| 31 |
['log(2.4)', [math.log(2.4)]],
| 32 |
['log10(5.4)', [math.log10(5.4)]],
| 33 |
['sin(.51)', [math.sin(.51)]],
| 34 |
['cos(.41)', [math.cos(.41)]],
| 35 |
['tan(0.77)', [math.tan(0.77)]],
| 36 |
['asin(0.83)', [math.asin(0.83)]],
| 37 |
['acos(.94)', [math.acos(.94)]],
| 38 |
['atan(0.22)', [math.atan(0.22)]],
| 39 |
['atan2(0.72, 0.54)', [math.atan2(0.72, 0.54)]],
| 40 |
| 41 |
| 42 |
def test_singleres(self):
| 43 |
for expr, expect in self.ltest:
| 44 |
cmd = 'ev "%s"' % expr
| 45 |
result = [string.strip(os.popen(cmd).read())]
| 46 |
try: lcompare.lcompare(result, expect)
| 47 |
except lcompare.error, e:
| 48 |
self.fail('%s [%s]' % (str(e),cmd))
| 49 |
| 50 |
def test_multipleres(self):
| 51 |
pass # XXX implement
| 52 |
| 53 |
def main(bindir=None):
| 54 |
global _bindir
| 55 |
_bindir=bindir
| 56 |
support.run_case(EvTestCase)
| 57 |
| 58 |
if __name__ == '__main__':
| 59 |
main()
| 60 |
| 61 |
# vi: set ts=4 sw=4 :
