1 |
2 |
3 |
import os |
4 |
import math |
5 |
import string |
6 |
import unittest |
7 |
8 |
from unit_tools import support |
9 |
from unit_tools import lcompare |
10 |
11 |
_bindir = None |
12 |
13 |
class CntTestCase(unittest.TestCase): |
14 |
def setUp(self): |
15 |
if _bindir: |
16 |
self.oldpath = os.environ['PATH'] |
17 |
os.environ['PATH'] = _bindir |
18 |
19 |
def tearDown(self): |
20 |
if _bindir: |
21 |
os.environ['PATH'] = self.oldpath |
22 |
23 |
def test_1(self): |
24 |
cmd = 'cnt 5' |
25 |
res0 = os.popen(cmd).read() |
26 |
res = map(string.strip,string.split(res0, '\n')) |
27 |
exp = [0, 1, 2, 3, 4, ''] |
28 |
try: lcompare.lcompare(res, exp) |
29 |
except lcompare.error, e: self.fail(str(e)) |
30 |
31 |
def test_2(self): |
32 |
cmd = 'cnt 3 2' |
33 |
34 |
res = map(string.split,string.split(res0, '\n')) |
35 |
exp = [[0,0], [0,1], [1,0], [1,1], [2,0], [2,1], []] |
36 |
try: lcompare.llcompare(res, exp) |
37 |
38 |
39 |
def test_3(self): |
40 |
cmd = 'cnt 3 2 3' |
41 |
42 |
43 |
exp = [[0,0,0],[0,0,1],[0,0,2], |
44 |
[0,1,0],[0,1,1],[0,1,2], |
45 |
[1,0,0],[1,0,1],[1,0,2], |
46 |
[1,1,0],[1,1,1],[1,1,2], |
47 |
[2,0,0],[2,0,1],[2,0,2], |
48 |
[2,1,0],[2,1,1],[2,1,2], |
49 |
50 |
51 |
52 |
53 |
54 |
def main(bindir=None): |
55 |
global _bindir |
56 |
_bindir=bindir |
57 |
support.run_case(CntTestCase) |
58 |
59 |
if __name__ == '__main__': |
60 |
main() |
61 |
62 |
# vi: set ts=4 sw=4 : |
