root/radiance/ray/test/py_tests/test_cnt.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (20 years, 5 months ago) by schorsch
Content type: text/x-python
CVS Tags: rad3R7P2, rad4R2P2, rad4R2P1, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad5R0
First attempt at testing framework.
1
2
3 import os
4 import math
5 import string
6 import unittest
7
8 from unit_tools import support
9 from unit_tools import lcompare
10
11 class CntTestCase(unittest.TestCase):
12 def setUp(self):
13 self.oldpath = os.environ['PATH']
14 os.environ['PATH'] = os.path.abspath(support.BINDIR)
15
16 def tearDown(self):
17 os.environ['PATH'] = self.oldpath
18
19 def test_1(self):
20 cmd = 'cnt 5'
21 res0 = os.popen(cmd).read()
22 res = map(string.strip,string.split(res0, '\n'))
23 exp = [0, 1, 2, 3, 4, '']
24 try: lcompare.lcompare(res, exp)
25 except lcompare.error, e: self.fail(str(e))
26
27 def test_2(self):
28 cmd = 'cnt 3 2'
29 res0 = os.popen(cmd).read()
30 res = map(string.split,string.split(res0, '\n'))
31 exp = [[0,0], [0,1], [1,0], [1,1], [2,0], [2,1], []]
32 try: lcompare.llcompare(res, exp)
33 except lcompare.error, e: self.fail(str(e))
34
35 def test_3(self):
36 cmd = 'cnt 3 2 3'
37 res0 = os.popen(cmd).read()
38 res = map(string.split,string.split(res0, '\n'))
39 exp = [[0,0,0],[0,0,1],[0,0,2],
40 [0,1,0],[0,1,1],[0,1,2],
41 [1,0,0],[1,0,1],[1,0,2],
42 [1,1,0],[1,1,1],[1,1,2],
43 [2,0,0],[2,0,1],[2,0,2],
44 [2,1,0],[2,1,1],[2,1,2],
45 []]
46 try: lcompare.llcompare(res, exp)
47 except lcompare.error, e: self.fail(str(e))
48
49
50 def main():
51 support.run_case(CntTestCase)
52
53 if __name__ == '__main__':
54 main()
55
56 # vi: set ts=4 sw=4 :
