root/Development/ray/test/py_tests/test_cnt.py
Revision: 1.1
Committed: Sun Dec 7 20:40:51 2003 UTC (22 years ago) by schorsch
Content type: text/x-python
CVS Tags: rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
First attempt at testing framework.
# User Rev Content
1 schorsch 1.1
2
3     import os
4     import math
5     import string
6     import unittest
7
8     from unit_tools import support
9     from unit_tools import lcompare
10
11     class CntTestCase(unittest.TestCase):
12     def setUp(self):
13     self.oldpath = os.environ['PATH']
14     os.environ['PATH'] = os.path.abspath(support.BINDIR)
15
16     def tearDown(self):
17     os.environ['PATH'] = self.oldpath
18
19     def test_1(self):
20     cmd = 'cnt 5'
21     res0 = os.popen(cmd).read()
22     res = map(string.strip,string.split(res0, '\n'))
23     exp = [0, 1, 2, 3, 4, '']
24     try: lcompare.lcompare(res, exp)
25     except lcompare.error, e: self.fail(str(e))
26
27     def test_2(self):
28     cmd = 'cnt 3 2'
29     res0 = os.popen(cmd).read()
30     res = map(string.split,string.split(res0, '\n'))
31     exp = [[0,0], [0,1], [1,0], [1,1], [2,0], [2,1], []]
32     try: lcompare.llcompare(res, exp)
33     except lcompare.error, e: self.fail(str(e))
34
35     def test_3(self):
36     cmd = 'cnt 3 2 3'
37     res0 = os.popen(cmd).read()
38     res = map(string.split,string.split(res0, '\n'))
39     exp = [[0,0,0],[0,0,1],[0,0,2],
40     [0,1,0],[0,1,1],[0,1,2],
41     [1,0,0],[1,0,1],[1,0,2],
42     [1,1,0],[1,1,1],[1,1,2],
43     [2,0,0],[2,0,1],[2,0,2],
44     [2,1,0],[2,1,1],[2,1,2],
45     []]
46     try: lcompare.llcompare(res, exp)
47     except lcompare.error, e: self.fail(str(e))
48
49
50     def main():
51     support.run_case(CntTestCase)
52
53     if __name__ == '__main__':
54     main()
55
56     # vi: set ts=4 sw=4 :
