root/radiance/ray/test/cv/ref/checkBSDFout.txt
Revision: 1.1
Committed: Wed Feb 16 18:54:13 2022 UTC (3 years, 2 months ago) by greg
CVS Tags: rad5R4, HEAD
test: Created unit tests for some tools built in src/cv
# User Rev Content
1 greg 1.1 =====================================================
2     File: '../renders/blinds20c.xml'
3     Manufacturer: 'Greg Ward'
4     BSDF Name: 'Green specular venetian blinds at 20 degree angle'
5     Dimensions (W x H x Thickness): 300 x 97.369 x 3.75911 cm
6     Type: Anisotropic_Tensor_Tree
7     Color: 1
8     Has Geometry: 1
9     Component Lambertian XYZ (%) Max. Dir Min. Angle
10     Interior Refl 0.0 0.0 0.0 46.4% 3.58 deg
11     Exterior Refl 0.0 0.0 0.0 66.5% 3.58 deg
12     Int->Ext Trans 0.0 0.0 0.0 100.4% 3.58 deg
13     Ext->Int Trans 0.0 0.0 0.0 0% 180 deg
14     Component Reciprocity Error (min avg max %)
15     Interior Refl 0.0 0.0 0.0
16     Exterior Refl 0.0 0.0 0.0
17     Transmission 0 0 0
18     =====================================================
19     File: '../renders/sawtooth.xml'
20     Manufacturer: 'Manufacturer'
21     BSDF Name: 'Name'
22     Dimensions (W x H x Thickness): 24 x 24 x 0.2 cm
23     Type: Klems_Full
24     Color: 0
25     Has Geometry: 0
26     Component Lambertian XYZ (%) Max. Dir Min. Angle
27     Interior Refl 0.0 0.0 0.0 69.9% 8.56 deg
28     Exterior Refl 0.0 0.0 0.0 0% 180 deg
29     Int->Ext Trans 0.0 0.0 0.0 0% 180 deg
30     Ext->Int Trans 0 0 0 0% 180 deg
31     Component Reciprocity Error (min avg max %)
32     Interior Refl 0.0 5.6 99.4
33     Exterior Refl 0 0 0
34     Transmission 0 0 0
