root/Development/ray/test/UnitTests.txt
Wed Jul 1 20:11:07 2020 UTC (5 years, 4 months ago) by greg
Diff to previous 1.11
docs: added comment about binary files and CVS
Wed Jul 1 19:54:53 2020 UTC (5 years, 4 months ago) by greg
Diff to previous 1.10
docs: corrected repeated and missing items
Wed Jul 1 18:18:03 2020 UTC (5 years, 4 months ago) by greg
Diff to previous 1.9
test(ra_ps): added missing unit test
Wed Jul 1 18:04:19 2020 UTC (5 years, 4 months ago) by greg
Diff to previous 1.8
test(pinterp,falsecolor,psign): added missing unit tests for px builds
Wed Jul 1 02:27:43 2020 UTC (5 years, 4 months ago) by greg
Diff to previous 1.7
docs: moved tool that was under wrong directory list
Wed Jul 1 02:00:06 2020 UTC (5 years, 4 months ago) by greg
Changes since 1.6: +8 -8 lines
Diff to previous 1.6
test: added most of the missing unit tests for px builds
Tue Jun 30 23:52:50 2020 UTC (5 years, 4 months ago) by greg
Changes since 1.5: +7 -7 lines
Diff to previous 1.5
test(pfilt, pflip,ra_tiff,normtiff,pvalue,pcompos,protate): added some unit tests for px build directory
Tue Jun 30 18:51:30 2020 UTC (5 years, 4 months ago) by greg
Changes since 1.4: +0 -3 lines
Diff to previous 1.4
test(obj2mesh): added missing unit test
Tue Jun 30 18:37:15 2020 UTC (5 years, 4 months ago) by greg
Changes since 1.3: +6 -6 lines
Diff to previous 1.3
test: updated unit test coverage
Fri Mar 22 22:46:08 2019 UTC (6 years, 7 months ago) by greg
Changes since 1.2: +4 -0 lines
Diff to previous 1.2
Noted absence of obj2mesh test, which could use gensurf as input
Fri Mar 22 21:27:32 2019 UTC (6 years, 7 months ago) by greg
Changes since 1.1: +3 -0 lines
Added missing Perl script tests
Fri Mar 22 21:11:07 2019 UTC (6 years, 7 months ago) by greg
Added list of in-progress unit tests
