root/Development/ray/test/UnitTests.txt
Wed May 21 17:23:07 2025 UTC (6 months, 1 week ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 1.19: +2 -1 lines
Diff to previous 1.19
feat(bsdfpeaks): Added new utility to find and measure peaks in BSDFs
Tue May 20 22:55:53 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 1.18: +10 -2 lines
Diff to previous 1.18
test: Updated missing tests
Tue Mar 15 00:25:50 2022 UTC (3 years, 8 months ago) by greg
Changes since 1.17: +2 -1 lines
Diff to previous 1.17
feat(rcrop): Created simple cropping utility for matrices and pictures
Thu Feb 17 00:12:13 2022 UTC (3 years, 9 months ago) by greg
Changes since 1.16: +41 -38 lines
Diff to previous 1.16
docs: Added missing items and alphabetized lists
Wed Feb 16 18:54:13 2022 UTC (3 years, 9 months ago) by greg
Changes since 1.15: +7 -6 lines
Diff to previous 1.15
test: Created unit tests for some tools built in src/cv
Wed Feb 16 17:57:05 2022 UTC (3 years, 9 months ago) by greg
Changes since 1.14: +2 -5 lines
Diff to previous 1.14
test(ra_t8,ra_gif): Added unit tests for ra_t8 and ra_gif
Sat Dec 18 00:43:56 2021 UTC (3 years, 11 months ago) by greg
Changes since 1.13: +2 -1 lines
Diff to previous 1.13
docs: Added missing checkBSDF to list
Mon Aug 9 22:54:03 2021 UTC (4 years, 3 months ago) by greg
Changes since 1.12: +5 -4 lines
Diff to previous 1.12
docs: Updated missing unit tests
Wed Jul 1 20:11:07 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 1.11
docs: added comment about binary files and CVS
Wed Jul 1 19:54:53 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 1.10
docs: corrected repeated and missing items
Wed Jul 1 18:18:03 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 1.9
test(ra_ps): added missing unit test
Wed Jul 1 18:04:19 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 1.8
test(pinterp,falsecolor,psign): added missing unit tests for px builds
Wed Jul 1 02:27:43 2020 UTC (5 years, 5 months ago) by greg
Diff to previous 1.7
docs: moved tool that was under wrong directory list
Wed Jul 1 02:00:06 2020 UTC (5 years, 5 months ago) by greg
Changes since 1.6: +8 -8 lines
Diff to previous 1.6
test: added most of the missing unit tests for px builds
Tue Jun 30 23:52:50 2020 UTC (5 years, 5 months ago) by greg
Changes since 1.5: +7 -7 lines
Diff to previous 1.5
test(pfilt, pflip,ra_tiff,normtiff,pvalue,pcompos,protate): added some unit tests for px build directory
Tue Jun 30 18:51:30 2020 UTC (5 years, 5 months ago) by greg
Changes since 1.4: +0 -3 lines
Diff to previous 1.4
test(obj2mesh): added missing unit test
Tue Jun 30 18:37:15 2020 UTC (5 years, 5 months ago) by greg
Changes since 1.3: +6 -6 lines
Diff to previous 1.3
test: updated unit test coverage
Fri Mar 22 22:46:08 2019 UTC (6 years, 8 months ago) by greg
Changes since 1.2: +4 -0 lines
Diff to previous 1.2
Noted absence of obj2mesh test, which could use gensurf as input
Fri Mar 22 21:27:32 2019 UTC (6 years, 8 months ago) by greg
Changes since 1.1: +3 -0 lines
Added missing Perl script tests
Fri Mar 22 21:11:07 2019 UTC (6 years, 8 months ago) by greg
Added list of in-progress unit tests
