root/radiance/ray/test/SConscript
Revision: 1.2
Committed: Thu Mar 10 01:49:56 2016 UTC (9 years, 5 months ago) by schorsch
Changes since 1.1: +5 -5 lines
SCons build system learns about platform architecture
1 # -*- coding: latin-1 -*-
2 import os
3 import sys
4 import run_all
5
6 Import('env')
7
8 def run_tests(target=None,source=None,env=None):
9 try:
10 oldenv = env['ENV']
11 ray = os.getcwd()
12 bin = Dir(env['RAD_BUILDBIN']).get_abspath()
13 lib = Dir(env['RAD_BUILDLIB']).get_abspath()
14
15 test = os.path.join(ray, 'test')
16 if not test in sys.path:
17 sys.path.append(test)
18 oldpath = oldenv.get('PATH')
19 #print oldpath
20 newpath = os.pathsep.join((bin, oldpath))
21 newenv = {'PATH' : newpath, 'RAYPATH':lib }
22 env['ENV'] = newenv
23 run_all.main(bindir=bin)
24 finally:
25 env['ENV'] = oldenv
26
27
28 env.Command(None,'run_all.py',action=Action(run_tests))
