--- ray/test/SConscript 2016/03/10 01:49:56 1.2 +++ ray/test/SConscript 2016/03/28 17:48:43 1.3 @@ -1,28 +1,16 @@ # -*- coding: latin-1 -*- +from __future__ import division, print_function, unicode_literals + import os import sys -import run_all +import run_tests + Import('env') def run_tests(target=None,source=None,env=None): - try: - oldenv = env['ENV'] - ray = os.getcwd() - bin = Dir(env['RAD_BUILDBIN']).get_abspath() - lib = Dir(env['RAD_BUILDLIB']).get_abspath() + bindir = Dir(env['RAD_BUILDBIN']).get_abspath() + radlib = Dir(env['RAD_BUILDRLIB']).get_abspath() + run_tests.RadianceTests(bindir=[bindir], radlib=[radlib], V=True) - test = os.path.join(ray, 'test') - if not test in sys.path: - sys.path.append(test) - oldpath = oldenv.get('PATH') - #print oldpath - newpath = os.pathsep.join((bin, oldpath)) - newenv = {'PATH' : newpath, 'RAYPATH':lib } - env['ENV'] = newenv - run_all.main(bindir=bin) - finally: - env['ENV'] = oldenv - - -env.Command(None,'run_all.py',action=Action(run_tests)) +env.Command(None,'run_tests.py',action=Action(run_tests))
