--- ray/test/SConscript 2008/12/26 17:00:32 1.1 +++ ray/test/SConscript 2016/03/10 01:49:56 1.2 @@ -9,18 +9,18 @@ def run_tests(target=None,source=None,env=None): try: oldenv = env['ENV'] ray = os.getcwd() - up, cur = os.path.split(ray) - bin = os.path.join(up, 'bin') - lib = os.path.join(up, 'lib') + bin = Dir(env['RAD_BUILDBIN']).get_abspath() + lib = Dir(env['RAD_BUILDLIB']).get_abspath() + test = os.path.join(ray, 'test') if not test in sys.path: sys.path.append(test) oldpath = oldenv.get('PATH') - print oldpath + #print oldpath newpath = os.pathsep.join((bin, oldpath)) newenv = {'PATH' : newpath, 'RAYPATH':lib } env['ENV'] = newenv - run_all.main() + run_all.main(bindir=bin) finally: env['ENV'] = oldenv
