root/radiance/ray/test/SConscript
Revision: 1.3
Committed: Mon Mar 28 17:48:43 2016 UTC (9 years, 1 month ago) by schorsch
Changes since 1.2: +8 -20 lines
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
1 # -*- coding: latin-1 -*-
2 from __future__ import division, print_function, unicode_literals
3
4 import os
5 import sys
6
7 import run_tests
8
9 Import('env')
10
11 def run_tests(target=None,source=None,env=None):
12 bindir = Dir(env['RAD_BUILDBIN']).get_abspath()
13 radlib = Dir(env['RAD_BUILDRLIB']).get_abspath()
14 run_tests.RadianceTests(bindir=[bindir], radlib=[radlib], V=True)
15
16 env.Command(None,'run_tests.py',action=Action(run_tests))
