| 1 |
# -*- coding: latin-1 -*-
| 2 |
import os
| 3 |
import sys
| 4 |
import run_all
| 5 |
| 6 |
Import('env')
| 7 |
| 8 |
def run_tests(target=None,source=None,env=None):
| 9 |
try:
| 10 |
oldenv = env['ENV']
| 11 |
ray = os.getcwd()
| 12 |
up, cur = os.path.split(ray)
| 13 |
bin = os.path.join(up, 'bin')
| 14 |
lib = os.path.join(up, 'lib')
| 15 |
test = os.path.join(ray, 'test')
| 16 |
if not test in sys.path:
| 17 |
sys.path.append(test)
| 18 |
oldpath = oldenv.get('PATH')
| 19 |
print oldpath
| 20 |
newpath = os.pathsep.join((bin, oldpath))
| 21 |
newenv = {'PATH' : newpath, 'RAYPATH':lib }
| 22 |
env['ENV'] = newenv
| 23 |
run_all.main()
| 24 |
finally:
| 25 |
env['ENV'] = oldenv
| 26 |
| 27 |
| 28 |
env.Command(None,'run_all.py',action=Action(run_tests))
