root/radiance/ray/test/SConscript
Revision: 1.5
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 7 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad6R0, HEAD
Changes since 1.4: +9 -3 lines
1 from __future__ import division, print_function, unicode_literals
2
3 import os
4 import sys
5
6 import run_tests
7
8 Import('env')
9
10 def do_run_tests(target=None,source=None,env=None):
11 bindir = Dir(env['RAD_BUILDBIN']).get_abspath()
12 radlib = [Dir(env['RAD_BUILDRLIB']).get_abspath(),
13 Dir('#/src/gen').get_abspath(),
14 Dir('#/src/rt').get_abspath(),
15 ]
16 run_tests.RadianceTests(bindir=[bindir], radlib=radlib, V=True)
17
18 env.Command(None,'run_tests.py',action=Action(do_run_tests))
19
20 # vim: set syntax=python:
21 # vi: set ts=4 sw=4 :
22
