root/radiance/ray/test/README.txt
Revision: 1.2
Committed: Sun Jul 4 12:05:33 2004 UTC (20 years, 11 months ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8, rad3R9
minor fixes.
1
2 Radiance Testing Framework
3 --------------------------
4
5 A toolkit to test all (eventually) components of the Radiance
6 synthetic image generation system for conformance to their
7 specification.
8
9
10 Limitations
11
12 For the moment, we use PyUnit to run our tests. This means that
13 we're restricted to test only complete programs, and not actual
14 units (since PyUnit was designed to test Python units, not C).
15 A C-level testing framework may be added later.
16
17 There's no good way to automatically test GUI programs like
18 rview. We have to rely on good human testers to check whether
19 those work correctly or not.
20
21
22 Requirements
23
24 You need a working installation of Python 2.1 (or newer) on your
25 system. The reason for this is that the PyUnit framework isn't
26 included with earlier versions. If you prefer to use an older
27 Python (back to 1.5.2), you can get PyUnit here, and install it
28 somewhere on your PYTHONPATH:
29 http://pyunit.sourceforge.net/
30
31 Our testing framework currently assumes that the Radiance files
32 reside in the following local file tree (seen from the "test/"
33 subdirectory where this file resides):
34
35 executables: ../bin/*[.exe]
36 support files: ../lib/*
37 data files: ./test data/*
38
39 This is the location where the experimental SCons build system
40 will place everything, so it might be easiest to compile Radiance
41 using SCons for testing.
42 The space character in the name of the test data directory is
43 deliberate, because it is a design requirement that all our
44 executables can handle path names with spaces.
45
46
47 How to run tests
48
49 On unix systems, just type "run_all.py" in this directory to
50 test everything. If that file doesn't have execute rights, you
51 can supply it to the python interpreter as its single argument:
52 "python run_all.py". You can also run individual test suites from
53 the "py_tests" directory directly: "python test_getinfo.py".
54
55 On Windows, this should usually work as well. As an alternative,
56 use the "winrun.bat" script. WARNING: You need to change the
57 paths in this script to match your Python installation first.
58
59
60 What gets tested
61
62 There are several test groups, each containing a number of test
63 suites, each containing one or more tests. When running tests,
64 the name of the test groups and test suites will get printed to
65 the console, the latter with an "ok" if they succeeded.
66
67 If any test fails, there will be diagnostic output about the
68 nature of the failure, but the remaining tests will continue to
69 be executed. Note that several utility programs may be used to
70 access the results of other calculations, so if eg. getinfo is
71 broken, that may cause a number of seemingly unrelated tests to
72 fail as well.
73
74
75 How to report failures
76
77 If any of the tests fail on your platform, please report your
78 results (and as much ancilliary information about your system and
79 Radiance version as possible) to the radiance code development
80 mailing list on http://www.radiance-online.org/
81 The developers will then either try to fix the bug, or instruct
82 you on how to refine your testing to get more information about
83 what went wrong.
84
85
86 How to contribute test cases
87
88 The list of tests run is still very much incomplete, but will
89 hopefully grow quickly. You can contribute by creating tests too!
90 Please ask on the code development mailing list first, so that we
91 can avoid overlaps between the work of different contributors.
92
93 There are two classes of tests to be considered:
94
95 - Testing individual executables
96 This means that an individual program like ev, xfom, or getinfo
97 is tested with typical input data, and the output is compared
98 against the expected result.
99
100 - Testing specific calculations
101 This will mainly affect the actual simulation programs rpict
102 and rtrace. For example, there should be a test suite for every
103 material (and modifier) type, which uses rtrace to shoot a
104 series of rays against a surface under varying angles, in order
105 to verify material behaviour under different parameters. Tests
106 of this kind may require a custom script.
107
108 Contributed tests can be of two kinds. In the simplest case, you
109 can contribute a small(!) set of test data, the command line(s)
110 used to run your tests on them, and a list of expected results.
111 Result comparisons are typically done in text form (by line).
112 If the result is a picture, we'll use ttyimage to pick out a few
113 scan lines for comparison (the image dimensions must be less than
114 128 pixels). Other binary data needs to be converted into a
115 suitable text representation as well. If you're not sure what to
116 use, the developers can help you about that point. They will then
117 also wrap your test case into a Python module for integration
118 with the framework.
119
120 Contributors sufficiently familiar with the Python programming
121 language and the PyUnit test framework can also submit complete
122 test suites in Python. Please use the existing tests in the
123 "py_tests" directory as a template, and check out the helper
124 modules in "py_tests/unit_tools".
125
126 In any case, please note that we can't use any shell scripts or
127 similar tools in our tests. All tests should be able to run on
128 all supported platforms, where your favourite shell may not be
129 available. The Python programming language is available for
130 pretty much any platform, so we decided to use only that.
131
132
133
