root/Development/ray/test/README.txt
Revision: 1.4
Committed: Mon Mar 28 17:48:43 2016 UTC (9 years, 7 months ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, HEAD
Changes since 1.3: +68 -53 lines
Refactoring of test suite, use independently of SCons and with Py2.7 or 3.x.
# User Rev Content
1 schorsch 1.1
2     Radiance Testing Framework
3     --------------------------
4
5     A toolkit to test all (eventually) components of the Radiance
6     synthetic image generation system for conformance to their
7     specification.
8
9
10     Limitations
11
12 schorsch 1.4 We use the Python unittest module to run our tests. This means
13     that we're currently restricted to test only complete programs,
14     and not actual units (since unittest was designed to test Python
15     units, not C). A C-level testing framework may be added later.
16 schorsch 1.1
17 schorsch 1.2 There's no good way to automatically test GUI programs like
18     rview. We have to rely on good human testers to check whether
19     those work correctly or not.
20
21 schorsch 1.1
22     Requirements
23
24 schorsch 1.4 You need a working installation of Python 2.7 or 3.x on your
25     system. Radiance must be either built with the executables still
26     in the source tree (preferrable to test before installing), or as
27     a live installation.
28 schorsch 1.1
29
30     How to run tests
31
32 schorsch 1.3 The simplest way to run tests is to use the SCons build system.
33     The file ray/INSTALL.scons explains the requirements and details.
34     Once you have SCons working, go to the ray directory and type
35
36 schorsch 1.4 $> scons build
37 schorsch 1.3 $> scons test
38
39 schorsch 1.4 The first command will build Radiance, and place the executables
40     in a platform-specific directory below ray/scbuild/.
41     The second command will automatically execute all available tests
42     in the environment created by the build.
43
44     Other build systems may chose to integrate the tests in a similar
45     way. The file "run_tests.py" can either be invoked as a script or
46     imported as a module. Note that in either case, you probably need
47     to supply the correct paths to the Radiance binaries and library.
48
49     As a script:
50
51     usage: run_tests.py [-V] [-H] [-p bindir] [-l radlib] [-c cat]
52
53     optional arguments:
54     -V Verbose: Print all executed test cases to stderr
55     -H Help: print this text to stderr and exit
56     -p bindir Path to Radiance binaries
57     -l radlib Path to Radiance library
58     -c cat Category of tests to run (else all)
59
60     As a module:
61
62     Call the class run_tests.RadianceTests(...) with suitable arguments:
63     bindir=[directory ...] - will be prepended to PATH during tests
64     radlib=[directory ...] - will be prepended to RAYPATH during tests
65     cat=[category ...] - only test those categories (else TESTCATS)
66     V=False - if True, verbose listing of executed tests
67
68     Both methods will run all the tests, or just the category given
69     as the value of the "cat" argument.
70 schorsch 1.1
71
72     What gets tested
73
74 schorsch 1.4 There are several test categories, each containing a number of test
75     suites, each containing one or more tests. When running tests, each
76     test category will be printed to the console. Depending on the
77     settings, the individual test cases may also be listed, or just
78     indicated with a dot. And last the total results for each category are
79     shown.
80 schorsch 1.1
81     If any test fails, there will be diagnostic output about the
82     nature of the failure, but the remaining tests will continue to
83     be executed. Note that several utility programs may be used to
84     access the results of other calculations, so if eg. getinfo is
85     broken, that may cause a number of seemingly unrelated tests to
86     fail as well.
87
88
89     How to report failures
90
91     If any of the tests fail on your platform, please report your
92     results (and as much ancilliary information about your system and
93 schorsch 1.2 Radiance version as possible) to the radiance code development
94     mailing list on http://www.radiance-online.org/
95 schorsch 1.1 The developers will then either try to fix the bug, or instruct
96     you on how to refine your testing to get more information about
97     what went wrong.
98
99
100     How to contribute test cases
101
102 schorsch 1.4 The selection of tests to run is still very much incomplete, but
103     will hopefully grow over time. You can contribute by creating
104     tests too! Please ask on the code development mailing list first,
105     so that we can avoid overlaps between the work of different
106     contributors.
107 schorsch 1.1
108     There are two classes of tests to be considered:
109
110     - Testing individual executables
111     This means that an individual program like ev, xfom, or getinfo
112     is tested with typical input data, and the output is compared
113     against the expected result.
114
115     - Testing specific calculations
116     This will mainly affect the actual simulation programs rpict
117     and rtrace. For example, there should be a test suite for every
118     material (and modifier) type, which uses rtrace to shoot a
119     series of rays against a surface under varying angles, in order
120     to verify material behaviour under different parameters. Tests
121     of this kind may require a custom script.
122
123     Contributed tests can be of two kinds. In the simplest case, you
124     can contribute a small(!) set of test data, the command line(s)
125     used to run your tests on them, and a list of expected results.
126     Result comparisons are typically done in text form (by line).
127     If the result is a picture, we'll use ttyimage to pick out a few
128     scan lines for comparison (the image dimensions must be less than
129     128 pixels). Other binary data needs to be converted into a
130     suitable text representation as well. If you're not sure what to
131 schorsch 1.4 use, the developers will be happy to assist you. They will then
132 schorsch 1.1 also wrap your test case into a Python module for integration
133     with the framework.
134
135     Contributors sufficiently familiar with the Python programming
136 schorsch 1.4 language and the unittest framework can also submit complete
137     test suites in Python. Please use the existing tests below the
138     "testcases" directory as a template, and check out the helper
139     modules in ".../lib/pyradlib" (where ".../lib" is the location of
140     the Radiance support library).
141
142     Also note the pseudo-builtin module "testsupport" temporarily
143     created by the RadianceTests() class (see the docstrings there),
144     which provides information about the various required directory
145     locations.
146
147     And lastly you'll find that we have deliberately included a space
148     character in the name of the "test data" directory, because it is
149     a design requirement that all our executables can handle path
150     names with spaces.
151 schorsch 1.1
152 schorsch 1.4 In any case, remember that we can't use any shell scripts or
153 schorsch 1.1 similar tools in our tests. All tests should be able to run on
154     all supported platforms, where your favourite shell may not be
155     available. The Python programming language is available for
156     pretty much any platform, so we decided to use only that.
157
158
159
